In-Wall Speakers
Does Theory Audio’s Million Dollar Home Theater System Really Come with a Free House?
Theory Audio Design shows that you can put together a fine-sounding home theater system – or whole home music system – for a whole lot less than the cost of an actual house.
Theory Audio Design Best in Show at CEDIA Expo 2025
As in previous years, CEDIA Expo 2025 had its share of impressive sounding multi-hundred thousand dollar or even million+ dollar whole home audio and home theater systems. If you’ve got a flexible budget, there are many ways you can invest your money in order to enjoy movies and music anywhere in your home. But Theory Audio Design’s L. Paul Hales (you can call him Paul) says that if you spend a million dollars on a home audio/video system, “you’re doing it wrong.” And in his presentation and demo at CEDIA Expo, he went on to explain why.
In Hales’ opinion, speakers and amplification don’t need to be ridiculously expensive in order to provide great sound. And to prove that point, he went on to demonstrate Theory’s new and existing CI speakers, starting with the brand new ic5 in-wall/in-ceiling speaker that sells for just $695/each.
Bucking the trend of using bombastic action movie clips for speaker demos (which can be fun, in moderation), Hales prefers to demonstrate his company’s speakers using quirky 2-channel stereo music tracks. He does this so the listener can appreciate how Theory speakers reproduce real instruments and voices – without distracting visuals or artificially mixed multi-channel surround sound. You can get a hint of this sound in our Theory Audio at CEDIA 2025 video, which includes Hales’ complete CEDIA Expo 2025 presentation (below):
As he did last year, Mr. Hales began the demo with a pair of the ic6 in-wall/ceiling speakers (now up to $885/each in the United States, thanks to tariffs) mounted in the front walls, then demonstrated the same tracks through the same speaker, supplemented by some subwoofers. Or did he? Actually for the second part of the demo, Hales snuck in the little brother, the new ic5 speaker ($698/each), which can also be used in-wall or in-ceiling. In both cases the music was punchy and dynamic and offered excellent spatiality. The ic5 offers similar sound to the ic6, but with a smaller 5-inch woofer. According to Hales, despite its compact size, the ic5 is able to hit 108 dB peaks, more than enough to fill your living room (or yacht) with sound. Both the ic5 and ic6 are available with waterproof enclosure options and waterproof grilles for outdoor and marine use.
When they added the Theory iws12-9 in-wall subwoofer ($2,100/each) into the mix, the performance went up a notch with deep, tight bass extension that gave the sound a powerful foundation. These little speakers have no business making such big sound.
One Speaker: Many Options
What makes the Theory IC series speakers special is that they offer super-flexible mounting options – in-wall, in-ceiling, on a wall, on a ceiling or in a pendant – just by adding the appropriate bracket or enclosure. The same speakers can also be used in the company’s ballard landscape speaker enclosure we covered in some detail last year and which were featured again in Theory’s CEDIA Expo 2025 demo. We should note that the ic5 will only be available as an in-ceiling/in-wall option at first. Pendant, cabinet and bollard options will follow at some point in the future.
This flexibility is particularly compelling if you’re putting together a stealth home theater or surround sound system – one that is to be heard but not seen. You could outfit your entire living room, media room or home theater with the ic5 or ic6 – three in the front wall for left, center, right, two in the rear wall and four hanging from the ceiling in pendant enclosures for height effects. Add a couple of in-wall subs for good measure so the bottom octaves are covered as well. With identical drivers (and identical timbre) in all channels you’ll get a seamless and immersive dome of sound when watching movies, TV shows or listening to music, without any visible speakers.
Theory Audio also introduced a new PLC line of speaker controller/amplifiers at CEDIA Expo 2025, built on Powersoft technology. These can intelligently share power as needed to different speakers.
The only complicating factor in building a system around Theory Audio Design speakers is that they are not sold as standard passive speakers for use with any old receiver or integrated amp. They only work with the company’s proprietary active loudspeaker controllers. These are basically power amps with advanced DSP (Digital Signal Processing). Instead of plugging the ic6 directly into a receiver or power amp, you use a preamp/processor or an A/V receiver with preamp outputs to deliver sound to the ALC which then drives the speakers directly.
theory-audio-ic5-in-ceiling-speaker-side-back
The Theory iC5 (pictured) and ic6 in-wall/in-ceiling speaker can be deployed in a number of different cabinets and housings, depending on your needs.
Pricing for a stereo pair of Theory Audio Design speakers starts at about $1,400 for the ic5 in-wall or in-ceiling speakers or about $1,770 for the ic6. You’ll need to add one of those controller/amplifiers I mentioned, which starts at about $2,495 for a model DLC-250.4 4-channel active loudspeaker controller. And while $3,900 (or so) plus the cost of a source device and/or receiver or preamp isn’t exactly cheap, it’s a fraction of the cost of many less capable in-wall and in-ceiling speakers in the CI market.
The More the Merrier
It’s worth noting that Theory’s active loudspeaker controllers are designed to drive a lot more speakers than one might expect. The 4-channel 250W DLC-250.4d can actually drive up to 64 of Theory’s ic6 speakers in “Hi Z” mode and the company’s DLC-1500.4d ($5,000) can power up to 300 Theory speakers in Hi Z mode. So the cost efficiency of the system increases exponentially in larger deployments. Got a 5 acre backyard that needs some sound reinforcement? Better call Theory.
Considering the relatively affordable cost of Theory’s speakers and amplifiers, Hales argued that his “million dollar home theater system” was better than his competitors, because his million dollar system comes with a “free house.” You save enough on the system that you’ll have enough money leftover to buy a 5,000 SF house on two acres of land… in Alabama (note: price or home details may vary depending on where you want to live).
While the ic6 isn’t brand new this year, it still wowed us in its punchy dynamic sound in its bollard outdoor enclosure. So congratulations to Theory Audio Design for winning our “Best in Show” awards for CEDIA Expo 2025 both the ic5 in-wall/in-ceiling speaker for best “bang for buck” and the ic6 in its bollard enclosure for “best outdoor sound.”
The Bottom Line
If nothing else, Paul Hales from Theory Audio Design is a great presenter. His CEDIA Expo demos are among the most entertaining at the show. But they’re also among the best-sounding. And they seem to make the most common sense. Indeed, why spend a million dollars on a home theater if the home is not included? Maybe there is something to this argument?
Burchardt S400 MKIII Bookshelf Loudspeaker Natural Oak Front 2026
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Audio Note Oto SE 35 Audio Note Oto SE 35
Audio Note ignores trends again. The Oto SE 35 brings new transformers and PSU to the cult EL84 amp. Low power, big attitude. Hear...
Magico S7 2026 Loudspeaker Views Magico S7 2026 Loudspeaker Views
Magico previews the $200,000 S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Emotiva BasX TA2+ Integrated Amplifier Emotiva BasX TA2+ Integrated Amplifier
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
