Kii Audio SEVEN Wireless Bookshelf Speakers Get New Titanium Finish and DSP Update
Kii Audio SEVEN wireless speakers add a third color, Qobuz Connect, Spotify Lossless support, and more with free software update.
Kii Audio Seven Fine Touch Titanium Wireless Active Speaker
High-end audio is moving away from passive boxes, racks of separates, endless cable debates, and systems like the Kii SEVEN explain why. As Kii Audio brings its ultra compact wireless music system to the 2026 Bristol Hi-Fi Show, the updates being previewed underscore a broader shift: premium loudspeakers are increasingly defined by integrated amplification, software control, and flexible system architecture rather than nostalgia for traditional hi-fi hierarchies.
Introduced in 2023, the Kii SEVEN was designed to function as a complete, scalable audio solution. Each speaker can be used individually, as a stereo pair, part of a multi-speaker home theater setup including Dolby Atmos, or within a multi-room environment. This level of flexibility is not about replacing “real” hi-fi, it’s about acknowledging that the future of high-end audio is smarter, more adaptable, and far less dependent on stacks of external hardware.
“You now just need Kii SEVEN speakers, a power connection and a streaming service subscription to create a complete high-end audio system. With our unique technologies and room-optimisation tools, this means you can get rid of a traditional hi-fi stack and a spaghetti of cables, streamline your life, and improve your listening experience at the same time” says Kii Audio co-founder, Wim Weijers.
Kii Audio SEVEN Wireless Bookshelf Speakers Updated With New Titanium Finish
Kii Audio SEVEN Wireless Speakers in new Fine Touch Titanium
Core Features
Wireless Music System: The Kii SEVEN is a compact, high-end three-way active wireless (or wired) bookshelf sized loudspeaker designed for both professional monitoring and serious home listening. It supports a wide range of wired inputs, including AES/EBU, XLR, and TRS, alongside wireless connectivity via Bluetooth, Wi-Fi, and Apple AirPlay 2. Each speaker incorporates 600 watts of Class D amplification, delivering 1,200 watts per stereo pair, with amplification and DSP fully integrated into the cabinet.
Cardioid Speaker Design: Engineered by Kii Audio, the Kii SEVEN employs a true cardioid dispersion pattern that extends down into the low-mid and bass frequencies. By controlling rearward energy, the design reduces unwanted room interaction, improving bass definition and placement consistency across a wider range of listening environments.
Kii Home App
Kii Home App: The Kii Home App for iOS and Android provides straightforward control of the Kii SEVEN from a mobile device. It allows users to manage playback, assemble streaming playlists, and control multiroom audio when multiple Kii SEVEN speakers are deployed throughout a home. The app is designed to handle system setup and day-to-day operation without requiring additional hardware or a separate control interface.
Active Wave Focusing: Rather than relying on conventional crossover filters alone, Kii’s Active Wave Focusing technology uses DSP and strategically positioned drive units to shape a coherent wavefront directed toward the listener. This approach enables precise time alignment across the full frequency range, improving clarity, imaging, and phase consistency without requiring external calibration hardware.
Weijers further stated, “Because our own DSP and firmware drive every Kii speaker, we’re always looking to add refinements, features, and ecosystem upgrades through software instead of forcing owners to buy a ‘Mark II’. These updates enhance the system you already own – without making it obsolete.”
What’s New for the Kii SEVEN in 2026
Since 2015, Kii Audio has focused on combining engineering-driven design with a streamlined user experience. That approach continues at the 2026 Bristol Hi-Fi Show, where the company is previewing a new color option and a series of functional updates for the Kii SEVEN.
Alongside the existing Fine Touch White and Fine Touch Dark Grey finishes, the Kii SEVEN will now be offered in a new Fine Touch Titanium finish.
Software updates are equally practical. New features include native Qobuz Connect support, improved TIDAL Connect and Spotify Connect performance including compatibility with Spotify Lossless, and even simpler setup with 24-bit/192kHz wireless communication between speakers.
The software update will be available at no cost to existing owners and can be downloaded directly through the Kii Audio Support Center.
kii-audio-seven-fine-touch-white-speaker-on-stand-side
Kii SEVEN (side view) in white on stand
The Bottom Line
Rather than chasing a replacement model, Kii Audio is doing the smarter thing by keeping the Kii SEVEN current through software and a subtle hardware refresh. The addition of Qobuz Connect, improved TIDAL and Spotify Connect support (including Spotify Lossless), and higher-quality wireless speaker setup improve system performance without forcing owners into an upgrade cycle.
This approach will resonate most with listeners who want high-end performance in a compact, self-contained system and expect it to evolve with streaming standards rather than become obsolete.
Tip: The Kii SEVEN were awarded Best in Show at NAMM 2025, while the larger Kii THREE BXT Loudspeaker System earned Best in Show at NAMM 2026.
kii-control-white
Kii CONTROL
Price & Availability
The Kii SEVEN wireless active speakers can be purchased individually for $4,495 each or $9,885/pair with Kii CONTROL (remote) from Authorized Dealers. Optional companion stands are $445 each ($890/pair). The updated Kii SEVEN will be demonstrated at the Bristol Hi-Fi Show, taking place from February 20-22, 2026.
For more information: kiiaudio.com
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Marantz's Model M1 packs 100W, HEOS, HDMI eARC, and Dirac Live into a compact streaming amp for only $1,000.
Denon brings Dolby Atmos music support to its HEOS whole home music platform with this trio of wireless speakers.
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Loudspeakers
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Qobuz Connect arrives on Cambridge Audio StreamMagic Gen 2 and 3 via firmware update, extending new streaming features to legacy models.
Can the iFi NEO Stream 3 and ZEN Stream 3 stand out in the crowded sub-$1,000 streamer market where WiiM, Bluesound, Eversolo, and Cambridge...
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
