Turntables and Bluetooth? Yes, You Can Have Your Vinyl and Stream It Too
Want to spin vinyl without the wires? Learn how to connect your turntable to Bluetooth or wireless speakers and bring record playback to your modern setup.
Audioengine Wireless Speakers with Bluetooth Turntable
Let’s not kid ourselves—vinyl sounds fantastic. But setting it up can feel more like a chore than a joyride, especially when you’re juggling cartridges, tonearms, and alignment tools like you’re prepping for audio surgery. RCA cables coiled like barbed wire, grounding wires flapping about like lost semaphore flags, and connections that wouldn’t look out of place on a Cold War ham radio built in a Latvian basement. If you adore your records but prefer the modern luxury of wireless speakers or multi-room systems like Sonos or HEOS, congratulations—you can finally spin your vinyl without needing a trench coat and a soldering iron.
Even wireless headphones that support high-res Bluetooth codecs like aptX HD, LDAC, or aptX Lossless can now join the analog party. Harry Bosch might insist on hardwired everything, but the rest of us are fully on board with embracing the 21st century—sans tangle.
With Bluetooth turntables and some slick adapters, you can spin those records without feeling like you’re setting up a covert surveillance van in 1979. But we’re not adverse to some Winchell’s donuts and coffee if that’s the deal.
And I’m not kidding—a turntable manufacturer recently asked me how to explain this setup to their customers. When the turntable makers are asking the streaming nerds for help, you know the world’s changing. Not sure if I should be flattered or slightly scared. Most likely a little of both.
Why would anyone do this?
For some listeners, the wireless speakers and headphones they’ve sunk money into—Sonos, HEOS, maybe some slick Focal Bathys—don’t have a phono preamp onboard. And let’s be honest, there’s no way they’re going back to stacking gear in a rack like it’s 2012 and they just discovered FLAC files and IKEA Lack tables.
And honestly, who can blame them? Bluetooth technology has come a long way, with support for high-resolution codecs like aptX HD, aptX Adaptive, LDAC, and even aptX Lossless sneaking into the mix. That’s a good sign. It means people do care about sound quality and want to integrate vinyl into their sleek, wireless ecosystems without sacrificing fidelity—or aesthetic. Vinyl isn’t dying or going full retro; it’s just evolving with the times, and Bluetooth is the bridge making that happen.
Learning the differences between all these Bluetooth codecs—aptX, aptX HD, LDAC, AAC, SBC—is like trying to read Bosch’s cold case files after six bourbons: confusing, full of acronyms, and likely to end in frustration unless you know what you’re looking for. We’ve broken it all down for you here.
How to Connect Your Turntable to a Bluetooth or Wireless Audio System
Step 1: Start with the Right Turntable (or Add Bluetooth to Yours)
pro-ject-t1-evo-bt
Pro-Ject T1 Evo BT
If you already own a Bluetooth turntable—like the Audio-Technica AT-LP120XBT, Sony PS-LX310BT, Cambridge Audio Alva TT v2 or Pro-Ject T1 Evo BT—you’re halfway there. These models have built-in Bluetooth transmitters, allowing you to connect directly to Bluetooth speakers or wireless headphones.
If your beloved vintage deck like a Vinyl Nirvana restored Thorens or high-end turntable doesn’t have Bluetooth built-in, don’t panic. You can still go wireless by using a Bluetooth transmitter. Simply plug it into the turntable’s RCA output (or into the phono preamp if your turntable requires one), and voilà—your analog gear now speaks Bluetooth.
Pro Tip: Make sure the transmitter supports aptX or aptX HD if your speakers or headphones do, for better sound quality and lower latency.
Step 2: Understand the Signal Chain
Bluetooth turntables usually come with built-in phono preamps, meaning they’ll output a line-level signal ready to be transmitted wirelessly. But if your turntable only outputs a phono-level signal, you’ll need a phono preamp between the turntable and the Bluetooth transmitter to boost the signal to proper line level.
If you skip the preamp and connect a phono-level output directly to the transmitter, you’ll get a weak, muddy sound—and possibly blow your speaker trying to crank the volume.
Step 3: Pair with Your Wireless System
Audioengine HD6 Powered Speaker Pair White
Audioengine HD6 Powered Speakers with Bluetooth ($699)
Once your turntable or transmitter is broadcasting a Bluetooth signal, set your wireless speaker or receiver to pairing mode. Pairing methods vary (some require button pressing, others use apps), so follow the instructions for your specific speaker or system.
Once paired, you’re all set—just drop the needle and let that so-called “glorious analog warmth” waft wirelessly through the room like incense at an audiophile yoga retreat. Don’t look too hard because that’s not really something you can see — and maybe time to switch to a less potent drug or alcohol if that actually becomes a thing.
Step 4: Watch for Latency
Bluetooth isn’t always perfectly in sync—especially with cheaper transmitters or speakers. If you’re super sensitive to delay or want to sync the vinyl sound with a video source (like spinning a soundtrack to a movie), latency could drive you nuts. To minimize this, stick to gear that supports aptX Low Latency or Bluetooth 5.2+.
Umm…I Don’t Actually Own an External Phono Preamplifier
That’s perfectly fine and nothing to be ashamed about. Trust me—I’ve done enough questionable things for all of us to carry a lifetime of shame, and I recently took one for the team, so you’re off the hook. The truth is, there’s a wide range of affordable phono preamps out there that get the job done without raiding your 401K plan.
We’re sticking with a few smart, budget-conscious picks because, let’s be honest, it makes zero sense to drop thousands on a high-end phono preamp when you’re just going to convert that analog signal into digital before sending it off via Bluetooth. The logic for buying any of these is that you’ll end up with a quality entry-level phone preamp should you decide to upgrade your system in the future and want to experience better sound quality.
You can find our extensive affordable phono preamp buying guide here for reference but we like the following picks:
Best Affordable Phono Preamplifiers
Schiit Audio Mani 2
Schiit Mani 2
Price: $188 at Amazon
Why to Buy: The Mani 2 is a well-rounded, budget-friendly option with solid performance and flexibility. Its adjustable gain makes it suitable for a variety of cartridges, and its price is hard to beat for audiophile-grade sound.
Andover Audio Spinstage
Andover Audio SpinStage Phono Preamp Lifestyle
Price: $249 at andoveraudio.com
Why to Buy: The Spinstage delivers excellent value with premium circuitry in a well-priced package. It’s perfect for those who want to step up from entry-level preamps without blowing the budget. Plus, the discrete circuitry ensures crisp, clean sound.
iFi ZEN Phono 3
iFi ZEN Phono 3
Price: $249 at Crutchfield
Why to Buy: The ZEN Phono 3 offers exceptional value with its balanced design and noise-reduction tech. It’s perfect for those who want a cleaner, more detailed sound without breaking the bank. Plus, the adjustable gain gives you flexibility for different setups.
Bluetooth Transmitter?
When shopping for a Bluetooth transmitter to connect your turntable to a wireless system, look for one that supports high-resolution codecs like aptX HD, aptX Adaptive, or LDAC—because sending glorious analog sound over crummy SBC just feels criminal. You’ll also want something with low latency (especially if syncing audio with video), stable signal range, and flexible input options like RCA or 3.5mm. Bonus points if it’s compact and doesn’t look like a leftover prop from Blade Runner.
iFi Audio ZEN Air Blue
iFi ZEN Air Blue Front
Price: $99 at Amazon
Why to Buy: Built like a tank, sounds like a champ. The ZEN Air Blue is audiophile-approved and works seamlessly with nearly any system. Plus, it looks great on a desk or audio rack—not like a Wi-Fi router from 2008. The ZEN Air Blue is reliable to around 32 feet but the construction of your home will impact its performance. Be aware that it does not offer digital inputs.
  • Supports LDAC, LHDC, aptX HD, aptX Adaptive, aptX LL, AAC, SBC
  • Single set of RCA inputs
  • Bluetooth 5.1 with extended range
Pro Tip: For an extra $200, the new iFi ZEN Blue 3 supports aptX Lossless, LDAC, LHDC/HWA, aptX Adaptive, aptX, AAC and SBC. That means you can send and receive CD-quality audio via aptX Lossless – and it also comes complete with a Hi-Res USB mode for desktop use — supporting 24-bit/96kHz PCM digital playback.
The ZEN Blue 3 is also able to function as a fully wired DAC, offering 96kHz/24-Bit audio via USB-C, or 192kHz/24-Bit audio via SPDIF, which can be output via 4.4 balanced or RCA analog outputs.
For those thinking of using a desktop headphone amplifier while they work, one can connect the ZEN Blue 3 as your DAC and utilize the analog inputs with your phono stage. $300 isn’t cheap but this is a forward thinking BT transmitter that will be able to send hi-res digital to multiple Bluetooth speakers or headphones in the future that support LDAC or aptX Lossless.
Auris bluMe HD
BluME HD Bluetooth Transmitter
Price: $119 at Amazon
Why to Buy: An affordable, plug-and-play solution with great sound and solid codec support. It’s a slick way to go wireless without sounding like you’re streaming through a tin can on a string.
  • Supports aptX HD, aptX LL, AAC, SBC
  • RCA and optical outputs
  • Bluetooth 5.0
  • 100 feet of range
  • compatible with Android devices, iPhone, iPad, PC, Tablet, PCs, MacBook, MacBook Pro, Echo Dot
  • 32-bit/384kHz PCM
Pro Tip: The step-up Auris BluMe Pro for $170 adds support for LDAC, aptX Adaptive and uses a higher quality ESS Sabre ES9028Q2M DAC for up to 32-bit/384kHz PCM. It also includes a 1.3-inch OLED screen.
Bonus: Multi-Room and Smart Speaker Setups
Got a Sonos, HEOS, or Yamaha MusicCast system? You’re not left out. Some of these platforms allow you to plug a turntable into a connected speaker or hub (like the Sonos Five or Sonos Port) and then send the signal wirelessly to other speakers in your home.
Yes, it’s still technically “wired to the hub,” but once it’s in the system, it becomes wireless across your home. A hybrid win.
The Bottom Line
You don’t need to be tethered to a traditional hi-fi setup to enjoy your records—this isn’t 1978, and your Bluetooth transmitter doesn’t need to look like a Cold War-era radio. With the right combination of a decent phono preamp and a capable Bluetooth transmitter, you can spin vinyl wirelessly to everything from Sonos to HEOS to your favorite portable speaker and even your wireless headphones.
And while audiophile purists may gasp into their vacuum tubes, the rest of us are too busy enjoying our music to care. As Bosch might say—everybody counts, or nobody counts… even Bluetooth vinyl lovers.
Featuring Schiit’s new Continuity A output stage, Mesh DAC architecture, and Forkbeard app control, the Asgard X brings trickle-down Mjolnir tech to a powerful...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Qobuz Connect arrives on Cambridge Audio StreamMagic Gen 2 and 3 via firmware update, extending new streaming features to legacy models.
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
High-power headphone output, Bluetooth 5.4 with lossless codecs, PCM768/DSD512 support, multiple digital and RCA analog inputs in one compact DAC/amp.
Pro-Ject’s Pre Box S3 is a compact control hub with phono, HDMI eARC, USB-C, Bluetooth, and headphone support—but can one small box really run...
