Best Bookshelf Speakers Under $1,000: Editors’ Choice 2024
Looking for the best bookshelf or stand-mounted speakers below $1,000? We’ve awarded 10 loudspeakers that have impressed us enormously.
Best Bookshelf Speakers 2024
Update: You might be looking for our most recent Editors’ Choice awards for the Best Bookshelf Speakers for audiophiles.
Introduction
Bookshelf or stand-mounted loudspeakers are evolving and whilst the movement is in the direction of wireless loudspeakers, there is still no shortage of excellent and affordable passive bookshelf options right now.
Not everyone has the space or budget for floorstanding loudspeakers and there are also a growing number of consumers who have not heeded the RTO charge from their employers and continue to work from home and desire something for the desktop or their office.
At the bottom of our list this year are a number of new introductions that we have plans to review in 2025 and we suspect that a number of them will make our mid-year list based on some very early listening — but it didn’t make sense to include them yet without conducting more comprehensive reviews.
Some models like the Q Acoustics 3030i are being replaced with the 3030c so you are likely to find them on sale.
The brand new LC1 from Chesky Audio which were a hit at CAF 2024 (we have the first review) make the list this year because they are such a surprisingly well designed pair of loudspeakers — from a 17 year-old student with some help from a rather brilliant professor at Princeton that we have met a few times over the years and who blew our minds with his lab demonstrations.
Methodology
Eligible products must be currently shipping whether or not they were released in the current year. At least one eCoustics staff member must nominate a product within the category that they feel offers best-in-class performance at its listed retail price before it can be voted on by our Editors.
Best Bookshelf Loudspeakers
RSL Speakers CG3M ($210)
RSL Speakers CG3M Bookshelf Loudspeakers
RSL Speakers CG3M
The new C3GM bookshelf loudspeakers replace the best-selling CG3 that were discontinued in 2022 and it’s almost impossible to find a better pair of loudspeakers at the price; RSL sells all of their products direct to consumers and there is enormous value here for $210 USD/pair.
The C3GM work well on both stands or a desktop; the loudspeakers do not take up a lot of space (9.5”H x 5.3″D x 6.7”W) and there is a keyhole mount for those who might wish to mount them on a wall and use them as rear channel speakers.
The 4-inch mineral-filled woven aramid fiber cone woofer and 1-inch silk dome tweeter offer a fairly robust sound, but there is noticeable roll-off around 90Hz making these ideal candidate for a subwoofer.
The 86.5 dB (6 ohms) sensitivity is on the lower side but they will work just fine with 30-50 watts; and they certainly won’t implode if you drive them with 100 to 125 watts of power either.
A clean sounding pair of bookshelf loudspeakers with above average detail and speed considering the entry-level price tag.
Pros:
  • Hard to find anything better for $210
  • Can also be mounted to the wall for rear surround channels
  • Fairly robust sounding from 90Hz to 20kHz
  • Above average detail levels
  • Can handle more power than you might think
Cons:
  • Average sensitivity rating
  • Definitely require a subwoofer below 90Hz
Where to buy: $210/pair at rslspeakers.com
Triangle Borea BR03 ($349)
Triangle BR03 Bookshelf Speakers
Triangle BR03
The Triangle Borea BR03 BT made our “Best Wireless Speakers of 2022” list and I was very fortunate to try them for almost 6 months. They are worth every cent.
The passive version are even more impressive and less than 50% of the price which makes them one of the easiest recommendations of 2024. The Borea BR03 are rather agile sounding loudspeakers, although I do wish that the 1-inch silk dome tweeter was slightly better behaved depending on the amplifier.
The 6.2-inch woofer has more than enough extension and scale to make orchestral and classic rock selections come alive in my 16′ x 13′ x 9′ den.
Clarity, detail, and a rather high level of resolution makes these one of our favorite loudspeakers on the list because they really respond well to integrated amplifiers in the $650 to $1,500 range and you would never guess how affordable they are.
The 90 dB sensitivity (4 ohms) is slightly deceptive and we would suggest 50 watts as a minimum to really give these vibrant loudspeakers the foundation they need. Triangle has a done a great job with the Borea range and these are still flying under the radar for most people which we find a tad strange.
Pros:
  • Amazing build quality for the price
  • Clear, detailed, and surprising mid bass punch
  • Dynamic sounding
  • Front port makes them ideal for a bookshelf or placement close to the wall
  • Woofer and tweeter are high quality
Cons:
  • Tweeter can be slightly hard sounding with the wrong kind of amplifier
  • Sensitivity rating is misleading – 50 watts at minimum
Where to buy: $349/pair at Amazon
ELAC Debut 3.0 DB63 ($449)
ELAC Debut 3.0 DB63-BK Bookshelf Speaker
Can lightning strike again for ELAC? The manufacturer has announced upgrades to its most affordable loudspeaker range priced from $350 to $1,000/pair. Now in its third generation, the new Debut 3.0 speaker series follows the very popular Debut 2.0 line-up from 2018, adding seven new models.
The Debut 3.0 models feature an all-new design with custom designed aluminum dome tweeters (instead of soft dome) and rear ports (instead of front). There’s also a newly designed 6.5″ aramid fiber woofer, soft touch front baffle, custom aluminum phase plug and magnetic grilles.
The Debut 3.0 requires less power from an amplifier to achieve the same volume level as lower impedance speakers, making them more efficient and compatible with a wider range of amplifiers, including those with lower power ratings.
There are two bookshelf models but the DB63-BK Debut 3.0 is a terrific value at $449/pair USD.
Pros:
  • Big improvement over the Debut 2.0’s build quality
  • Clear, detailed, and rather good with dynamic shifts
  • Easier to drive than the previous iteration
  • Tremendous bass for a bookshelf model
Cons:
  • Aluminum dome tweeter has greater detail than the previous soft dome but is also more sensitive to amplification
  • Rear port makes them harder place inside a bookshelf
Where to buy: $449 at Amazon | Crutchfield
DALI Spektor 2 ($499)
DALI Spektor 2 Bookshelf Speaker in Walnut
DALI Spektor 2
The Danish manufacturer is now distributed by Lenbrook in N. America and that situation makes them much easier to find. DALI makes excellent loudspeakers across the board but their affordable Spektor 2 is a fantastic value and wonderful platform for a wide range of amplifiers.
DALI manufactures every component in these loudspeakers including the screws and the attention to detail in the overall build quality is rather evident.
The Spektor 2 offer an insightful, detailed, and very expressive presentation. They are not overly fussy about placement, but they can be rather underwhelming with low powered amplifiers. Anything above 50 watts per channel should be quite sufficient.
Pros:
  • Superb build quality
  • Excellent value for the money
  • Expressive, detailed, and insightful
  • Require about 50 watts to really open up
  • Not hard to setup
Cons:
  • Definitely require more power or they can sound rather anemic and dynamically flat
  • More forward sounding amplifiers will create a fatiguing presentation
Where to buy$499/pair at Amazon | Amazon.co.uk
Q Acoustics 3030i ($549)
Q Acoustics 3030i Bookshelf Speaker in walnut
Q Acoustics 3030i
Very much like Jason Statham’s character in Lock, Stock and Two Smoking Barrels, the Q Acoustics 3030i are a tad unleashed. They communicate music like an effortless weapon, and with some serious punch in the lower registers with the right amplifier.
They borrow some of their driver technology from their much larger sibling; the Q Acoustics 3050i floor-standing loudspeaker that retails for almost twice the price.
Q Acoustics have tweaked something in the cabinet design and crossover of the 3030i making it hit much harder than one would expect considering the size of the cabinet and drivers.
The 3030i are not a very difficult loudspeaker to drive (88dB, 6 ohms) on paper, but we discovered during our review that they benefit enormously from a lot more power and an amplifier that has a lot of control in the low end.
Stay away from amps that veer dark because the 1-inch soft-dome tweeter needs some illumination.
Available in Graphite Grey, English Walnut, Carbon Black or Arctic White. All are finished with an attractive chrome bezel around each driver and feature magnetic speaker grilles.
Ditch the grille covers and do not use the foam bungs even if you need to place them closer to the wall; the mid bass and lower midrange loses some of clarity in the process.
Pros:
  • Massive presence for their size
  • Powerful and deep bass response
  • Clear midrange
  • Excellent build quality and finish at its price
  • Can the basis for an excellent 2.1 music/home theater system if you are short on space
Cons:
  • Definitely require more power than the specifications suggest
  • Rear port makes them harder to place close to the wall and we hate the foam bungs
  • Tweeter is slightly restrained sounding – needs an amplifier with greater illumination
Where to buy: $549/pair at Amazon
Q Acoustics 5020 ($899)
Q Acoustics 5020 Bookshelf Speaker Grille Off in Santos Rosewood
Q Acoustics 5020
The Budget Audiophiler’s review of the 5020 can found here and those interested in learning more can watch his videos on Instagram. What’s fascinating about the 5020 is just how different it sounds than the 3030i; the tonal balance and presentation are completely different, yet it manages to be one of the most open, expressive, and spacious sounding bookshelf loudspeakers on the market.
Bookshelf loudspeakers are generally less sensitive than floor standing loudspeakers and that proved to be the case with the 5020; they responded better to the amplifiers in the 60 to 100 watts/channel range but that doesn’t mean that I was remotely unsatisfied with the lower power tube amplifiers in my collection.
A lot of the performance and choice of amplification depended on the size of the room and genre of music; if you don’t listen at very loud levels and don’t plan on feeding them a steady diet of rock or new wave music — you can certainly get away with less.
If you listen on the desktop or in a nearfield scenario where you are 10 feet or less from the speakers, 30 watts per channel is going to work just fine.
Pros:
  • Industrial design and build quality
  • Strong mid bass output that is leaner sounding compared to the 3020i
  • Clear and expressive sounding
  • Imaging
  • Easy to drive but respond well to 60 to 100 watts/channel
Cons:
  • Bass is tight and lean requiring an amplifier with some color and force
  • Work fine on the desktop but are better suited for stands
Where to buy: $899/pair at Amazon
Focal Theva No.1 ($998)
Focal Theva No. 1 Bookshelf Speaker in Light Wood
Focal Theva No.1
The Focal Theva No.1 offer a very different level of performance but at a price that actually makes us want to own them. $998 USD for a pair of loudspeakers made in France. William Jennings was completely smitten by their performance and you can read this detailed review here.
The French manufacturer has been designing and manufacturing drivers and loudspeakers internally at their facility in Saint-Étienne, France, since 1979 and jumped into the car audio category in 1989.
The Theva No.1 is the entry-level model in the lineup which also includes 3 floor standing models, a center channel loudspeaker, surround loudspeakers, and two different stands for home cinema users who may wish to mix and match models to create the multi-channel configuration that is ideal for them.
They possess the clarity and detail in the treble that make Focal’s speakers special, the fluidity of the larger Kanta models, and the tonal balance of the Chora 806 that charmed the pants off our esteemed EIC Ian White.
Combine all of those positive attributes and you have an extremely good pair of loudspeakers that are engaging, colorful, and lively in the best possible way.
Pros:
  • Focal makes excellent drivers and tweeters
  • Value for the money
  • Clarity and detail from the lower midrange through the treble
  • Dynamic sounding presentation with all genres of music
  • Build quality
  • Easy to drive but respond well to 50 watts or more
Cons:
  • Need more power than the specifications might suggest
  • Take off those boring looking grille covers
  • Work better on stands which add to the cost
Where to buy: $998/pair at Crutchfield
Chesky Audio LC1 ($996)
Chesky Audio LC1 Bookshelf Speaker Angle
CAF 2024 attendees left the show in Rockville, Maryland, shaking their heads after listening to these – and Chris Boylan was rather proactive in requesting a review pair.
You can read our rather comprehensive review of the Chesky Audio LC1 here and learn a great deal more about the technology, design process, and why these might be one of the most surprising new loudspeakers of 2024.
It’s not often that a new speaker maker bursts onto the scene with a product that shakes up the establishment. And even less often that designer is a 17-year-old high school student. But that’s just what is happening right now with the Chesky Audio LC1 ($996/pair), a small but mighty bookshelf speaker, named after the designer himself, Lucca Chesky (“LC”).
The speaker is a 2-way design, with a single crossover between the tweeter and midrange-low frequency driver. To supplement the bass in such a small cabinet, the LC1 employs dual inertially-balanced “subwoofers” – passive drivers which extend the low frequency output beyond what one would normally expect from such a compact design, at the expense of efficiency (there is no such thing as a free lunch).
With the rather low sensitivity (83dB), you’re going to need to pair the LC1s with a fairly beefy power amp or integrated amplifier.
For under $1,000, the LC1 deliver wonderful articulation and definition, natural sounding timbre, solid imaging, and affordability in a compact and attractive design.
Pros:
  • A 17 year-old designed something this good
  • Solid imaging
  • Compact
  • Tonally accurate
  • Excellent definition and articulation
  • Innovative cabinet design
Cons:
  • Low sensitivity – you definitely need a more powerful amplifier
  • Sound better on stands
Where to buy: $996/pair at Chesky Audio
KEF LS50 META ($999)
KEF LS50 Meta Colors
KEF LS50 Meta
Originally introduced as part of the company’s 50th Anniversary celebration, the KEF LS50 remains a favorite of music lovers, audiophiles and audio reviewers worldwide.
The current Meta version was introduced four years ago and builds upon the original’s strengths while making subtle but significant improvements to their sound quality.
The Meta designation comes from KEF’s “Metamaterial Absorption Technology” (MAT) – an advanced maze-like structure in the speaker cabinet which the company says absorbs “99% of the unwanted sound from the rear of the driver, eliminating the resulting distortion and providing purer, more natural sound.” The result is a loudspeaker that sounds even sweeter and cleaner than the original – and that’s saying something.
If you’re a budget-minded audiophile or music-lover searching for a taste of that elusive high-end sound for a minimum investment, the LS50 Meta may be just what you’re looking for. The speakers simply disappear when you press play on your source component of choice, transporting you to the studio where the music was recorded.
What makes the KEF LS50 Meta so special? Its coaxial UniQ driver design places the tweeter in the center of the woofer/midrange unit, which avoids the phasing distortion and time delay anomalies that can happen with traditional staggered driver speaker designs.
Though the LS50 is fairly compact in size (12 inches high by 9 inches wide by 11 inches deep), the speaker can go much lower into the bass registers than you’d expect – down to about 50 Hz of solid, musical bass.
Those who want “Mo Bass” can pair it with a KEF Kube 10B subwoofer, extending the low end response down to near the lowest audible registers and freeing the LS50s to concentrate on what they do best: the mid-bass, midrange and treble.
Note that these are wired loudspeakers (not wireless). They do require amplification. They work well with vintage gear (Chris Boylan driver his pair with a Conrad-Johnson tube power amp), but can also be paired with a high quality modern integrated amp like those from ARCAM, NAD, Rotel or Cambridge Audio. You can even use a high-end receiver, just make sure it’s got plenty of power and headroom.
Pros:
  • Compact
  • Imaging
  • Solid bass response
  • UniQ coaxial driver
  • Very low levels of distortion
  • Midrange and Treble resolution
Cons:
  • Demanding of the amplifier on the other end
  • You might require a subwoofer depending on the size of your room
Where to buy: $999/pair at Amazon | Crutchfield
Related reading: Best Wireless Speakers
46 Comments
46 Comments
  1. Steve Messenger
    January 23, 2023 at 3:59 pm
    Ian, I always look forward to and appreciate your posts. What integrated amps do you suggest with the Triangle BR03, and are they OK if only 10 inches off the front wall? Thank you. Steve
    • Ian White
      January 24, 2023 at 1:59 pm
      Steve,
      Thank you for reading and kind words.
      Cambridge Audio and Rega would be a great place to start with these. Not the io.
      Best,
      Ian White
      • Dean
        January 28, 2023 at 4:17 am
        Hi,I have a spare pair of q acoustics 3020i’s in the bedroom attatched to a very small nobsound amp, while I was impressed with this cheap amp from China at 50 Watts per channel because I can bluetooth to it from my samsung s21 ultra in bed I feel I need another amp to get more clarity,I do have a system in my lounge, rega planar 3 marantz cd & pm 6007 with bowers & wilkins 607 s2 silver anniversaries. so I know a bit but I only have about £250 budget for upstairs, any ideas what’s suitable.
        • Ian White
          January 28, 2023 at 12:22 pm
          Dean,
          Thank you for reading us and that is a great question.
          I’m not sure how much the NAD C316BEE V2 is in the UK, but that is a great combination. If you can find one used in great shape for that price…definitely do it.
          If you can find an older Audiolab 8000A (the original) used. that is another excellent amplifier for these speakers.
          Let me think on this some more, but these two are a start.
          Best,
          Ian White
          • Martz
            March 10, 2023 at 10:23 pm
            I would stick to ChiFi for a bedroom set up, especially if you want Bluetooth connectivity. Go for something with tone controls, like the Aiyma T9,or T9 Pro, or the BRZHiFi M6 (the later has tone controls for bass, treble and mids). Both have all the connectivity options you could ever need, and sub out (the sub out on the BRZ unit is not well implemented though – the output to the sub is not controlled by the unit’s volume).
            The slightly thin mid range typical of Class D amplification, and somewhat exposed by the 3020i, can be greatly improved by a slight bump in equalisation between around 120 to 800 Htz.
      • HARRYVH50@GMAIL.COM
        January 30, 2023 at 1:07 am
        Just surfing but play with hifi description of room size and amp type very informative, watch out for d class amps
      • Javier Gonzalez
        March 7, 2023 at 2:18 am
        Hey Ian, I have an old denon avr3300. Trying to keep my system budget friendly. I’d like to put my money into some speakers so I was wondering if this receiver would do for now paired with any of the speakers mentioned. The BRO3 really caught my eye.
        • Ian White
          March 7, 2023 at 3:10 am
          Javier,
          Power rating into 8 ohms and overall tonal balance?
          Best,
          Ian White
          • Javier Gonzalez
            March 11, 2023 at 4:05 am
            105w per channel
            As for the tonal balance, I’m not sure. I apologize. I’m fairly new to this. Would that be similar to frequency response? If so, it’s 10Hz-50kHz.
    • Gordon
      February 8, 2025 at 10:57 pm
      Mine are connected to a Naim Unity Atom in a 16×12 room and sound amazing.
  2. sorrel
    January 23, 2023 at 8:15 pm
    Oops! .4 meter (m). Hmm. Still, experiment w/ speaker placement.
  3. roman
    January 25, 2023 at 8:00 pm
    Hello! I have the Q Acoustics 3020i pair with a Rega IO amp, do you think this is a good combo?
    • sorrel
      January 26, 2023 at 7:32 pm
      Hi, roman. QA’s entry-level speakers play well with most good amps. Been there, done that. But to answer your question: N-O. (See ASR–Rega IO Review.) All the best to you.
      • Ian White
        January 26, 2023 at 11:33 pm
        I would say no from a power perspective. The io is a good integrated amplifier within its limitations.
        Best,
        Ian White
        • Paul Ingle
          February 22, 2023 at 11:13 am
          Ok loving this article. Back into music and want a good system no more than 1500 hopefully this article really helps.
  4. Doesnt Matter
    January 27, 2023 at 8:30 pm
    500$ is a budget speakers now? wow..
    • Ian White
      January 27, 2023 at 10:57 pm
      The list includes speakers that are under $100 up to $500. That is certainly budget.
      Best,
      Ian White
    • Paul Orr
      February 1, 2023 at 10:05 pm
      Very budget. Unfortunately.
      • Ian White
        February 3, 2023 at 9:26 pm
        It is but the truth is that all of these speakers sound great at their respective price points.
        And you can get a lot more today for your money than even 5 years ago. I get that $500 is a lot of money for most people but that buys a really good speaker in 2023.
        IW
    • Will Kimbrough
      April 16, 2023 at 3:06 am
  5. Lash
    January 30, 2023 at 2:34 am
    Good to see an piece like this. Too many mags are enamored with stuff very few can afford.
  6. Kyle Bass
    January 31, 2023 at 3:06 pm
    Cool article! Don’t know how they sound but those MKII are beautiful looking speakers.
    • Ian White
      January 31, 2023 at 3:16 pm
      Kyle,
      The Acoustic Energy are excellent loudspeakers. Really great value for the money.
      Best,
      Ian White
      • Tom
        March 5, 2023 at 6:00 am
        I have to agree Ian, I own the AE100MK2 and continue to be amazed. They require better electronics to appreciate what they can offer. I’m using Schiit, Rotel, and other tweaks in a 2 channel A/V system with stellar results! Cheers
        • Ian White
          March 5, 2023 at 12:37 pm
          Tom,
          Great to hear that I’m not alone. I love them. And I agree that they require better electronics.
          Best,
          Ian White
          • Mark A
            June 19, 2023 at 3:57 pm
            I have the AE Aesprit 300’s from 20 years ago. Still out great sounds.
  7. Mike Waz
    February 1, 2023 at 12:33 am
    Hi. Thanks for the good article. Aside from some MUCH higher end speakers in other rooms, in the bedroom I have some Mordaunt Short Music Series speakers. They are quite old but generally fine. Are any of these, in your judgment, seemingly superior? If not, anything else you might recommend?
    Thank you
    • Ian White
      February 1, 2023 at 1:24 pm
      Mike,
      The DALI are the true sleeper product in this mix. They need some power to really shine though. I’m a big Wharfedale and Q Acoustics person (I own multiple pairs of speakers from both brands), but there is something about the DALI that really shines higher than the rest.
      You need to spend a lot more money in my opinion in the bookshelf category to get better products. Perhaps $500 to $1,000 more.
      Best,
      Ian White
      • Mike Waz
        February 1, 2023 at 3:17 pm
        Thank you Ian. Perhaps allow me to further clarify. The bedroom receiver is an arguably mediocre Yamaha Natural Sound RX-A1040. The MS speakers are the 30i version. Given the receiver, has the technology improved so much that the DALI speakers would clearly be superior to the MS 30i? Also, IF I wish to spend more, what bookshelf speakers would you suggest for $1,500 a pair or less given the existing receiver? The best speakers I own are the B&W Nautilus 803S but they are clearly not going into the bedroom. Thanks again.
        • Ian White
          February 2, 2023 at 3:11 pm
          Mike,
          Let me do some research on your Yamaha before I answer.
          Best,
          Ian White
          • Ian White
            February 3, 2023 at 9:52 pm
            Mike,
            I would use the Wharfedale or Q Acoustics with that amplifier. Not a huge investment and it would work rather well.
            IW
        • sorrel
          February 3, 2023 at 5:19 pm
          I’m curious, Mike Waz: What amplifier do power your 803S loudspeakers with?
      • Pier
        December 3, 2023 at 10:59 pm
        Hi Ian.
        Since I believe you have heard many times the new diamond 12.x series , how would you compare them against the 3000 series from Q ? In particular 12.2 vs 3030i
        • Ian White
          December 4, 2023 at 2:48 pm
          Pier,
          Similar in some ways (warmer tonal balance), but the 3030i offer much firmer bass response. The 3030i definitely need more power. I’ve noticed a significant difference in their performance when driven by more powerful solid state amplifiers. They can handle 100 watts or more and it opens up the sound a lot. Both have similar sounding treble ranges.
          Best,
          Ian White
  8. Mike Waz
    February 3, 2023 at 6:43 pm
    Hi. The Krell KAV-2250.
    • Ian White
      February 3, 2023 at 9:18 pm
      Mike,
      That’s a really nice amplifier.
      Indeed.
      IW
      • Mike Waz
        February 3, 2023 at 9:46 pm
        Agreed; thank you.
  9. Alex
    February 9, 2023 at 9:54 am
    Hi, will you make a similar articles for floorstanding speakers ?
    • Ian White
      February 9, 2023 at 1:29 pm
      Alex,
      Coming this month. Already started it.
      Best,
      Ian White
      • Alex
        April 28, 2023 at 6:45 am
        Has the same articles for Floorstanding been released ?
        Didn’t found it 🙂
  10. GordM
    October 23, 2023 at 9:58 pm
    I have a pair of Wharfedale Diamond 12.0 powered by a NAD C388 w/ a Bluos module for TV and music in my bedroom system which I purchased online from Vinyl Sound, sight unseen. To say that they far exceeded my expectations would be an understatement. Would love to hear some of Wharfedale’s big boys some time, if their smallest system is that impressive. The company seems to be a bit underrepresented in Canada, certainly as the higher end models are concerned.
  11. Mike Hartmann
    March 26, 2024 at 1:18 pm
    Just recently purchased the Acoustic energy AE100 2 bookshelf speakers being amplified with the Naim UnitiQute 2 streamer inegrated 30 watt amp in a small living room setting sitting 10 feet away from speakers and I must say the sound is sublime,very happy with speaker choice.
    • Ian White
      March 26, 2024 at 5:34 pm
      Mike,
      Have a pair myself driven by an older NAD amplifier. Sounds great. Enjoy.
      Best,
      Ian White
  12. Asa
    December 14, 2024 at 7:42 pm
    Best bookshelf wireless stereo pair w/o wires except power plugin? Thanks Ian, and love these summary year end updates.
    • Ian White
      December 17, 2024 at 4:23 pm
      Asa,
      Coming later this week. Have 5 more to publish. Integrated amplifiers, headphones, network audio players, network amplifiers, and wireless speakers.
      IW
  13. Asa
    December 17, 2024 at 4:46 pm
    Thanks, Ian…looking forward to the remainder.
The world's top-selling projector brand just unveiled a trio of new home projectors that have lumens out the wazoo.
Loudspeakers
Armour Home boss Charlie Henderson explains how Q Acoustics, Goldring and QED plan to rebuild U.S. visibility, expand products and reach younger listeners.
Does the Triangle AIO Twin look better in Macassar? The $899 wireless stereo system adds real wood veneer while keeping vinyl and hi-res streaming.
Are the $1,499 Wharfedale Super Denton truly the British Bulldog of standmount speakers, and do they justify their place in the Heritage lineup?
The $1,099 Q Acoustics 3040c brings twin C3 drivers to smaller rooms, but costs only $100 less than the larger 3050c in the U.S.
