WiiM Sound Smart Speaker Launches with Room Correction, No AirPlay Support
At $299, the WiiM Sound features room correction, Wi-Fi 6E, stereo pairing and 5.1 setups, but lacks AirPlay, HDMI-ARC, and a phono input.
WiiM Sound Smart Speaker Lifestyle White
Since bursting onto the scene in 2021, WiiM has been shaking up the music streaming market with affordable gear that punches well above its price—starting at just $100. Their followers have only grown as each new product lands. At the 2025 High-End Munich show, they unveiled their first smart speaker, the WiiM Sound, a full-stack unit that combines streaming, amplification, and speakers in one tidy package.
Building on their streaming expertise—and the award-winning Ultra, Amp Ultra, Vibelink, and WiiM Amp Pro—WiiM is staking its claim as a one-stop source for smart, room-corrected audio, even if AirPlay fans will have to look elsewhere.
WiiM Sound: Smart Speaker with Room Correction and All-in-One Streaming
wiim-sound-smart-speaker-black-lifestyle
The core features of the WiiM Sound read like a smart speaker that should cost way more than its $299 price tag.
  • High-Resolution Wireless Streaming: Enjoy music, podcasts, Smart Preset, and radio in full 24-bit/192 kHz quality—no need to tether your smartphone to get the best sound.
  • Connectivity: The WiiM Sound covers all the bases with built-in Wi-Fi 6E, Ethernet, and Bluetooth. For wired sources, there’s a 3.5 mm analog stereo input.
  • Room Correction (AIRoomFit): Optimize your listening environment with WiiM’s Room Correction system, which measures your room and makes custom adjustments for the best possible audio.
  • Sound Customization: Beyond room correction, you get 24 preset EQ profiles, a 10-band graphic EQ, and a parametric EQ to fine-tune the sound exactly how you like it.
  • Stereo Pairing: Pair two WiiM Sound speakers to create a left/right stereo setup and expand your soundstage.
  • Subwoofer Pairing: Connect the WiiM Sound to the upcoming WiiM Sub Pro for deeper, tighter bass.
  • Home Theater Integration: Use the WiiM Sound as a surround or center channel speaker in a Dolby 5.1 setup for a fully immersive home cinema experience.
  • Universal Casting Support: Stream directly from your favorite apps via Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast.
  • Touch Display: A 1.8-inch round touch display shows album art, track info, EQ settings, room fit status, and even the time with alarm functionality.
  • WiiM Ecosystem: Full integration with the WiiM Home App gives you control over streaming, voice commands, EQ, stereo or surround setup, and multiroom audio.
wiim-sound-sub-pro
wiim-sound-remote
Specifications
WiiM Model WiiM Sound
Product TypeSmart Speaker
Price (each)$299
Frequency Response50 Hz – 20K Hz.
Peak Power100 W total
Speaker Drivers1 x 4” long-throw woofer, 50W
2 x full-range tweeters, 2x25W
Crossover Frequency2.4 kHz
Hi-Res AudioUp to 24-bit/192 kHz, gapless playback.
Room CorrectionAI RoomFit automatic/assisted tuning
EQOn-device Quick EQ; advanced EQ in app (presets + custom); separate EQ settings for Wi-Fi/Ethernet, Bluetooth, and Aux.
Wireless InputWi-Fi 6E (802.11 b/g/n/ax, tri-band: 2.4/5/6 GHz)
Bluetooth 5.3 (Receiver & Transmitter, supports SBC, AAC, LC3)
Wired Input100Mbps Ethernet
3.5mm Aux input
Control Options1.8″ Round Touch Display (Hi‑Res)
TouchButtons: Play/Pause, Volume Up/Down, Next/Previous Track
WiiM Voice Remote 2 Lite (included) — one‑tap playback/volume/skip, push‑to‑talk voice, preset buttons
Voice: Works with Alexa or Google Assistant via compatible devices
App: WiiM Home App for iOS/Android/Windows/MAC/Apple TV/Google TV
Supported PlatformsWiiMHome App, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Certification pending)
Multi-Room AudioWiiM, Google Cast, and Alexa multi-room systems
Stereo PairingEnables left/right speaker setup for expanded soundstage
Home Theater IntegrationFunctions as the surround or center channel speaker in a Dolby 5.1 setup
Smart PresetStreamlines the listening experience by offering quick access to frequently used content and settings
Alarm ClockSet the alarm time, occurrence, and choose from various music sources.
Touch DisplayScreen: 1.8” glass-covered, high-resolution touch display
Functions:  Playback control, album art, EQ adjustments, audio input selection, device settings
Display queue, presets, VU meters, time/date in standby mode
Supports customizable wallpapers
Guides setup (OOBE) and OTA firmware updates
PowerAC-powered, 100-240V AC universal power supply; energy-efficient standby; firmware over-the-air (OTA) updates.
FinishesMinimalist modern, Black/White, Fabric/Glass/PC.
Dimensions146 x 146 x 193 mm
5.7” x 5.7” x 7.5 inches
Weight5.5 lbs (2.5 kg)
In the BoxWiiM Sound Smart Speaker
PowerCable
WiiM Voice Remote 2 Lite (with batteries)
USB-C Charge Cable for Remote
RCA to 3.5mm cable
QuickStart Guide
Setting up WiiM SoundPlug in and connect to Wi-Fi with the WiiM Home App.
Run AIRoomFit to tailor the sound to your room.
Personalize the display (clock/wallpaper/art) and create your first Smart Preset
wiim-sound-white-lifestyle
The Bottom Line
The WiiM Sound Smart Speaker packs an impressive suite of practical features at $299, delivering high-resolution streaming, analog input support, room correction, and Wi-Fi 6E/Ethernet connectivity that even some $999 wireless speakers, like the KEF Coda W, don’t offer.
It can serve as a stereo or 5.1 channel surround speaker, but three notable omissions; AirPlay, a dedicated phono input, and HDMI-ARC, limit its appeal for some setups.
Compared with the Denon Home 150, which includes AirPlay for $199, the WiiM Sound lacks Apple ecosystem compatibility, though both can be used as single or stereo pairs. The Denon is also part of the growing number of wireless speakers and AVRs that support the HEOS wireless ecosystem.
Despite these gaps, WiiM’s aggressive approach and growing ecosystem including award-winning products like the Amp Ultra, Vibelink, and WiiM Pro Plus—position it as a practical, affordable contender that could challenge Sonos, HEOS, DTS Play-Fi, MusicCast, and Bluesound’s BluOS in the wireless streaming space.
wiim-sound-top-side
Price & Availability
The WiiM Sound Smart Speaker is priced at $299 and will be available on Amazon starting October 28, 2025. U.S. shoppers, though, will have to wait a bit longer: the rollout has been delayed thanks to factors beyond WiiM’s control—namely, FCC clearance getting held up by the ongoing government shutdown. International markets are already seeing shipments, but here in the States, the feds apparently need a little more time to approve a smart speaker while the lights are flickering in Washington.
4 Comments
4 Comments
  1. Replica
    October 22, 2025 at 3:08 pm
    Where can I find the Denon home 150 with Airplay for 199? Most sites list it at 249.
    • Larry
      October 22, 2025 at 10:41 pm
      The Denon Home 150NV was $180 during September, which was likely pre-tariff inventory. I bought one at BB and returned it within 48 hours. I found that it wasn’t all that stable as a product. Before I returned it, I did feed the analog output from a WiiM Mini into it and found it sounded much better than native HEOS on the 150.
  2. Larry
    October 22, 2025 at 11:10 pm
    Hi Robert,
    I think the intended market for the product isn’t as a soundbar replacement, but as part of a WiiM HT setup or as a standalone device. I think the win for something like this is in a guest room, bedroom, or kitchen. I have a few Panasonic SC-NP10 systems I use for that purpose.
    For $600, a pair moves them into the range of some good all-in-one systems that will sound better, e.g., Q Acoustics M20 HD and a WiiM Mini, which is an excellent small audio system.
    Larry
    • Ian White
      October 23, 2025 at 1:03 am
      Larry,
      I have a pair of Q Acoustics M20 HD on my desktop on Iso-Acoustic stands connected to a WiiM Pro Plus. Sounds great. Excellent advice.
      IW
STAX SR-009S Headphones
STAX unveils the SR-009D, the latest evolution of its legendary SR-009 electrostatic headphone platform. Can the new flagship raise the bar again?
ABYSS Diana TC Signature Audiophile Headphones ABYSS Diana TC Signature Audiophile Headphones
Can the $4,995 ABYSS Diana TC Signature really compete with Audeze and Meze? We listened at CanJam NYC 2026 on a $30K Woo Audio...
Ferrum WANDLA GoldenSound Edition Gen 2 DAC/Preamp Ferrum WANDLA GoldenSound Edition Gen 2 DAC/Preamp
Ferrum debuts the WANDLA GoldenSound Edition Gen 2 at CanJam NYC 2026 with Tube Mode, Impact+ bass tuning, and new spatial audio controls.
Fosi Audio CanJam NYC 2026 Fosi Audio CanJam NYC 2026
Fosi Audio debuts the C3 AI Gaming Sound Card and MD3 Magnetic DAC/Amp at CanJam NYC 2026, expanding into gaming audio and portable hi-fi.
Woman wearing Meze Audio Astru IEM in-ear Woman wearing Meze Audio Astru IEM in-ear
Can one driver beat complex hybrids? Meze Audio unveils the $899 ASTRU flagship IEM at CanJam NYC 2026 with a single dynamic driver design.
HiFiMAN Arya WiFI and HE1000 WiFi Headphones HiFiMAN Arya WiFI and HE1000 WiFi Headphones
Can HiFiMAN’s HE1000 WiFi and Arya WiFi bring true high resolution audio to wireless planar open-back headphones? We’ll find out at CanJam NYC 2026.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
Amp Multi is Sonos’ first new product in over a year, built for complex home audio systems. Is this where the platform goes next?
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Our favorite integrated amplifiers for audiophiles in 2025 includes models from WiiM, Advance Paris, Moon by Simaudio, Quad and Marantz.
Our favorite streaming amplifiers of 2025 for audiophiles include models from WiiM, Marantz, Ruark, Naim and Aavik.
In 2025, the best-in-class streamers from Cambridge, Bluesound and WiiM set the pace as new challengers from FiiO, Topping, and Eversolo loom for 2026.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
