Wanbo Unveils Vali 1 and T2 Ultra Compact Lifestyle Projectors Under $350 — Affordable Big-Screen Viewing on the Go
The Wanbo Vali 1 and T2 Ultra are affordable LCD projectors offering sharp 1080p resolution, practical features, and flexible setup.
Wanbo Vali 1 and T2 Ultra Lifestyle Projectors
While most projector makers stick with DLP to throw images on a wall, a smaller crowd still swears by LCD tech. Epson is the big name in that camp, relying on a 3-chip LCD system for richer color and smoother motion. Wanbo, on the other hand, isn’t exactly a household name in the U.S., and they lean on a single-chip LCD setup for most of their models.
Now they’re stepping into the 2025 portable projector arms race — a category that’s hotter than ever thanks to new models from LG, Hisense, Anker, and others — with the launch of the Vali 1 and T2 Ultra. Both are compact, both are portable, and both aim to squeeze as much big-screen fun as possible out of a budget-friendly price tag.
Wanbo Vali 1 LCD Projector: Affordable Big-Screen Viewing Without the DLP Price Tag
wanbo-vali-1
With the Vali 1, LCD projection technology is just the beginning. The Wanbo Vali 1 includes a built-in adjustable stand with a 200° rotation range, enabling precise image placement on walls, ceilings, or projector screens. Its ±30° auto-keystone correction straightens the image in seconds, ensuring accurate alignment without manual adjustments.
wanbo-vali-1-installation
You can project onto a screen, wall, or ceiling. Use it to turn your ceiling into a nighttime star field, enjoy movies or games on an indoor or outdoor screen, or mix and match for different viewing setups. The Vali 1 offers versatile projection options.
Brightness: Despite its compact size and budget-friendly price, the Vali 1 delivers 900 ANSI lumens of brightness—nearly twice that of many competitors. Combined with its native 1080p resolution, it produces sharp, detailed images.
Sound: The Vali 1 features built-in 6-watt x 2 full-range stereo speakers. For private listening or more powerful audio, a headphone jack is available for connecting headphones or an external speaker/amplifier.
wanbo-tv-menu
Streaming: Running Android 11, the Vali 1 connects via Wi-Fi to over 7,000 Google Play apps, including Netflix, YouTube, Disney+, HBO Max, and more. Netflix certification ensures smooth, reliable, high-quality playback.
Google Assistant: Built-in Google Assistant enables hands-free voice control for quick navigation and content search. Chromecast integration allows easy wireless screen mirroring from compatible devices. The included remote offers one-touch access to popular streaming services for added convenience.
wanbo-t2-ultra-projector-hey-google
Easy Auto Setup: The Wanbo Vali 1 features ASA 3.0, combining auto-focus, auto-keystone correction, ScreenFit, and obstacle avoidance. This intelligent projection system automatically detects screen boundaries, sharpens focus, aligns the image, and adjusts for any obstructions, ensuring a fast, accurate, and hassle-free setup.
Quiet Cooling: The Wanbo Vali 1 stands out with its largest cooling fan yet—10 cm in diameter and 3.3 cm tall—delivering efficient, whisper-quiet operation even during extended use.
Compact Design: The power socket is cleverly mounted on the gimbal bracket instead of the projector body, reducing cable clutter and allowing unrestricted movement. It supports multiple mounting options, including ceiling, wall, stand, and bracket setups.
Game Mode and Ambient Art Walls: Game Mode reduces latency and boosts refresh responsiveness for smoother gameplay. Ambient Art Wall mode projects calming visuals like ocean waves or starfields, turning any room into a dynamic art display.
Wanbo T2 Ultra Projector: Lower Brightness but Sharp Colors and Easy Auto-Alignment
As the step-down from the Vali 1, the Wanbo T2 Ultra offers lower brightness at up to 500 ANSI lumens. Still, it delivers enhanced color accuracy and contrast for a satisfying viewing experience, especially in darker environments. Like the Vali 1, the T2 Ultra includes ASA 3.0 auto-alignment technology, making focus and image alignment simple even from unconventional angles.
Its integrated 120° gimbal stand easily adapts to various projection surfaces—including ceilings—freeing users from the limits of fixed setups.
Powered by Android TV 11, the T2 Ultra allows seamless streaming in 1080p from popular services like Netflix and Disney+, guaranteeing vibrant, high-definition content anytime, anywhere.
For audio, it features 10W dual full-range speakers with dual bass diaphragms that extend low-frequency response for richer sound.
wanbo-t2-ultra-projector-rear
Comparison
Vali 1T2 Ultra
Product Type Compact Lifestyle ProjectorCompact Lifestyle Projector
Price$319.99$249.99
Display TechnologyLCD (single chip)LCD (single chip)
Light SourceLED (20,000 hr use life)LED (20,000 hr use life)
Brightness (Screen size dependent)Up to 900 ANSI LumensUp to 500 ANSI Lumens
Resolution1920 x 1080 FHD1920  x 1080 FHD
Lens3 Pcs aspherical pure glass lens3 Pcs aspherical pure glass lens
Zoom Function50%-100%50%-100%
Throw Ratio1.35:11.2: 1
Screen Size40-130 Inch45-140 Inch
Projection Distance1.2-3.9m1.2-3.8m
Keystone CorrectionAutoAuto
Focus AdjustmentAutoAuto
Obstacle AvoidanceAutoAuto
Screen AlignmentAutoAuto
Speaker System6W x 25W  x  2
Fan Noise≤28dB/m≤30dB/m
Internal Volume500CC370CC
BluetoothVer  5.0Ver  5.0
WiFiDual Band 2.4/5GHzDual Band 2.4/5GHz
Smart OSAndroid 11Android 11
Inputs HDMI x 1
USB x 1
AUX 3.5mm x 1
HDMI x 1
USB x 1
AUX 3.5mm x 1
Product ColorWhiteWhite
Dimensions 254 x 188.8 x 227.6 mm
10 x 7.43 x 8.97 inches
145 x 142 x 219 mm
5.71 x 5.6 x 8.62 inches
Weight2.8Kg / 6 lbs 3 oz1.5Kg / 3 lbs 5 oz
wanbo-t2-ultra-projector-rear-screen
The Bottom Line
The projector market is drowning in cheap models flaunting specs that rarely deliver—but Wanbo bucks that trend with the Vali 1 and T2 Ultra, two practical contenders for small-room use. The Vali 1 stands out with a claimed 900 ANSI lumens, nearly doubling the brightness of pricier lifestyle projectors like the Xgimi MoGo 4 (450 lumens) and Samsung Freestyle (550 lumens). Both Wanbo models use LCD tech instead of the more common DLP, avoiding the color-wheel rainbow effect and offering balanced white and color brightness—something DLP can’t match. This design choice, paired with a single LCD chip and LED light source, also trims manufacturing costs, translating to value for users.
With native 1080p resolution, Android 11, Google Assistant, easy auto-alignment, and a flexible gimbal stand, the Vali 1 delivers solid features for its price. The T2 Ultra, however, falls short with just 500 ANSI lumens, making it best suited for darker rooms and less versatile overall.
In comparison, the Xgimi MoGo 4 and Samsung Freestyle offer strong brand recognition and features but can’t match Wanbo’s brightness or flexible mounting options. If you prioritize brightness, sharp image alignment, and a no-nonsense smart OS at a budget price, the Wanbo Vali 1 deserves serious consideration. The T2 Ultra is a decent secondary option but doesn’t quite deliver the same bang for your buck.
Price & Availability
2 Comments
2 Comments
  1. David M.
    August 13, 2025 at 3:45 pm
    There’s a $90 coupon until 9/1 for the Vali 1 and the T2 is currently priced at $149.99. Both sounded like huge bargains at retail, so with the discounts, my mind is simply blown.
    • Ian White
      August 13, 2025 at 3:55 pm
      David,
      That does sound like a “bargain” but just keep in mind that they are affordable compared to the competition for a reason. Curious to know how either one works out.
      IW
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
At $269, XGIMI’s Vibe One makes projectors fun and portable for convenient big screen entertainment just about anywhere.
The $200 Aurzen D1R Cube brings Roku OS to a 1080p lifestyle projector, but its limited light output holds it back.
The 2025 Hisense 100UX and 116UX RGB Mini-LED 4K TVs feature cutting edge backlighting in 100-inch or 116-inch screen sizes.
At $199, the Denon Home 150 is a versatile wireless speaker with Alexa built-in and HEOS for multi-room setups and hi-res music streaming.
At $2,499 the versatile Hisense C2 Ultra lifestyle 4K projector offers optical zoom, built-in JBL speakers, gaming features and more.
At under $2,000, the Dangbei MP1 Max is a compact 4K lifestyle projector with Google TV, AI setup, and hybrid laser-LED tech for screens...
