Tivoli Audio Refreshes PAL BT Portable Speaker FM Radio for 2025
Upgraded for 2025 in new colors with better sound and longer battery life, the Tivoli Audio PAL BT portable Bluetooth speaker and FM radio is ready to rock for $219.
Tivoli Audio PAL BT portable Bluetooth Speaker Radio Collage (2025 models)
If you’re searching for a design-driven portable speaker that doesn’t overcomplicate the fun, the Tivoli Audio PAL BT nails it with vintage style, analog controls, and surprisingly big sound. It’s also water-resistant, which makes it perfect for the bathroom or the backyard. Because let’s be honest—not everyone’s dropping serious cash on custom in-wall or in-ceiling speakers just to listen to the ballgame or some tunes while showering or, you know, taking care of business. The PAL BT keeps it simple, stylish, and colorful against your questionable backsplash choices.
Tivoli Audio PAL BT: Analog Soul, Digital Brains, and Bathroom-Proof Durability
tivoli-pal-bt-2025-white-angle
Under that retro shell, the Tivoli Audio PAL BT isn’t just a pretty face. It packs an FM tuner for old-school radio junkies, simple Bluetooth 5.0 pairing for the Spotify crowd, and an auxiliary input for whatever vintage source you’re still clinging to. There’s also a stereo headphone output when you want to keep the noise (and your thoughts) to yourself.
A full-range neodymium driver and a 45W Class D amplifier push serious sound for something that weighs just 2 pounds. Add in 56-bit DSP processing, 24-bit stereo ADC/DAC conversion, and weather resistance, and you’ve got a compact, waterproof speaker that sounds way bigger than it looks. Available in five bold matte finishes—because good design shouldn’t stop at your bathroom door.
Power and Pairing: How to Charge, Connect, and Keep It Out of the Tub
The Tivoli Audio PAL BT keeps things refreshingly simple. It ships with a USB-C to USB-C charging cable, so all you need is a USB-C PD charger that delivers at least 2.5 watts and no more than 20 watts. For the fastest top-up, use a 20-watt charger capable of pushing 9V / 2.2A.
tivoli-pal-bt-2025-white-back
Turn the PAL BT on, switch to Bluetooth mode, and hit the pairing button on the back. Then open your device’s Bluetooth settings and select “Tivoli PALBT3|xxxxx” to connect. That’s it—no app, no nonsense.
The PAL BT runs up to 14 hours on a charge, depending on volume and source, which is plenty for weekend playlists or a long soak. It’s water-resistant, not waterproof—so it can handle bathroom humidity or a poolside splash, but if it ends up floating next to your rubber duck, you’ve gone too far.
Plenty of Fierce Competition
Let’s be real — the portable speaker space is more crowded than a Jersey Shore boardwalk in July. The Tivoli Audio PAL BT might have style and simplicity on its side, but it’s got no shortage of rivals waiting to steal your bathroom soundtrack. The KEF Muo brings modern flair with Bluetooth 5.4, aptX Adaptive, and a 24-hour battery — perfect if you’re more “minimalist design exhibit” than “morning talk radio.” The Soundcore Boom 3i flexes a muscular 50 W output, Bluetooth 5.3, and IP68 protection, basically daring you to drop it in the tub and operate its emergency beacon which can be heard down the block.
Meanwhile, Bose has the SoundLink Plus and Micro Gen 2, which nail that familiar polished Bose sound and solid waterproofing, while Bang & Olufsen’s A1 (3rd Gen) adds Scandinavian chic to your countertop. Even Sonos is in the mix with the Roam, tossing in Wi-Fi and AirPlay for those who can’t go ten minutes without a multi-room audio fix. And let’s not forget the Brane X, which is probably overkill unless your idea of self-care involves throwing a rave in the shower.
Most of these contenders offer at least Bluetooth 5.2 (some even 5.4) and AirPlay support, meaning the PAL BT’s old-school analog charm is going up against some serious tech muscle. But that’s also the point — the Tivoli doesn’t try to be everything. It’s the one you grab when you want simple, great sound without asking Alexa for permission to play “Born to Run.”
tivoli-pal-bt-2025-blue-top-front
The Bottom Line
The Tivoli Audio PAL BT isn’t the most advanced portable speaker on the market, but that’s not really the point. It delivers clean, balanced sound, a real FM tuner, and that signature Tivoli design that actually looks good sitting on a bathroom counter or kitchen shelf.
Sure, the competition offers newer Bluetooth versions, AirPlay, and waterproof ratings that could survive a pool party gone wrong—but most of those cost more and lack the PAL BT’s old-school charm. For $219, it’s a solid mix of design, simplicity, and sound quality that proves you don’t need to spend Sonos money to enjoy music while brushing your teeth.
Where to buy: $219.99 at Tivoli Audio (red, white, blue, gray, black)
Tip: Get the previous generation Tivoli Audio PAL BT for $115 at Amazon while supplies last. It includes an AM radio, but the new one doesn’t.
2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Clarus Concerto MKII Power Conditioner Angle Clarus Concerto MKII Power Conditioner Angle
Clarus Concerto MKII targets noise and power stability for high-end systems, but at $12,000 it raises the question: who really needs it?
SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle
Can the SVS 3000 Micro R|Evolution deliver deep bass from dual 9-inch drivers, 1,200 watts power, and advanced DSP without taking over your room?
2026 Paradigm Premier v2 Loudspeakers 2026 Paradigm Premier v2 Loudspeakers
Paradigm Premier Series v2 arrives at AXPONA 2026 with six new models, upgraded driver technology, and pricing aimed at affordable high performance.
Advance Paris A-i190 Integrated Amplifier Black Advance Paris A-i190 Integrated Amplifier Black
Advance Paris debuts NOVA at AXPONA 2026 with modular integrated amplifiers, streaming and Bluetooth add-ons, but should streaming be optional at this price?
2026 Cambridge Audio MSX Speakers Lifestyle 2026 Cambridge Audio MSX Speakers Lifestyle
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
At $799, the Marshall Bromley 450 packs 360-degree sound, 40+ hour battery, and mic inputs in a 27 pound portable party speaker box.
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Loudspeakers
No specs or pricing yet, but Klipsch concept products at CES 2026 signal a strategic shift fittingly timed with the legendary speaker maker’s 80th...
Extremely Loud Infinitely Expressive?Fender Audio makes a bold statement with ELIE E6 and E12 portable Bluetooth speakers and modular MIX wireless headphones.
LG expands its xboom by will.i.am lineup with the Rock, Mini, Blast, and Stage 501—bringing AI sound, rugged designs, and party-ready power to CES...
Portable Bluetooth speakers are now a billion-dollar category. We break down what actually matters — sound, battery life, ruggedness, and the models worth buying.
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Ruark R1 vs Tivoli Model One BT: a showdown of design, tone, and tech. Tivoli brings punch, but the Ruark’s refinement makes it worth...
