Stratton Acoustics Element 6 & 8 Loudspeakers Dazzle at AXPONA 2025
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Britain-based high-end speaker maker Stratton Acoustics Ltd unveiled two new models at AXPONA 2025—the Element 6 and Element 8—expanding their Element range with more compact options that maintain the meticulous design and sonic precision of the larger Element 12 and flagship Elypsis 1512.
With tariffs and trade costs looming large in conversations across the show floor, Stratton’s commitment to UK-based craftsmanship drew even more attention, highlighting the premium these speakers carry in both quality and price.
Despite their more compact bookshelf/standmount form factor, the Element 6 and 8 pack a bold visual punch, combining premium materials with class-leading electro-acoustic design and engineering to deliver a truly luxurious experience—for both your eyes and your ears.
Element 6
stratton-element-6
The Element 6 is the smaller of Stratton’s two new models, with clean lines and refined finishes designed to fit seamlessly into a variety of room styles. Despite its compact size, it aims to deliver a balanced and engaging listening experience.
Inside, it features a 6-inch (150mm) carbon-fibre bass/midrange driver and a waveguide-loaded 29mm soft dome tweeter, designed for accurate imaging, wide dispersion, and smooth integration between drivers.
The enclosure uses an acrylic-silica reinforced polymer matrix for added rigidity and reduced resonance, paired with CNC-machined aluminium front and rear baffles for structural stability and a modern aesthetic.
Ideal for smaller rooms or nearfield setups, the Element 6 shows that well-executed design doesn’t always need to be oversized.
Element 8
stratton-element-8
If the Element 6 feels a bit too compact, the larger Element 8 builds on the same core design principles while offering a step up in scale and low-end performance. It features an 8-inch (200mm) carbon-fibre bass/midrange driver for deeper bass response, without sacrificing the clarity and balance that define the line.
Like its smaller sibling, the Element 8 includes a patented decoupled, waveguide-loaded 29mm soft dome tweeter and uses the same rigid, low-resonance acrylic-silica reinforced polymer matrix enclosure.
A bass reflex cabinet with a precision-engineered flared port further extends the speaker’s low-frequency reach. The result is a speaker designed to handle larger rooms and more demanding playback without compromising detail or musicality.
Element Stands
To complement the Element 6 and 8, Stratton offers dedicated stands that provide stable support and greater placement flexibility.
Machined from aerospace-grade aluminium, the stands are built for durability, rigidity, and vibration control. Their design echoes the detailing of the speakers’ front and rear baffles, creating a cohesive visual presentation.
Beyond aesthetics, the stands are engineered to help reduce floor-borne vibrations that can affect sound clarity. Like the speakers themselves, the stands balance practical engineering with thoughtful design, rounding out the system both visually and functionally.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers Front on Stands
From Founder David Fowler: “These new models encapsulate our passion for designing speakers that don’t just sound beautiful, but are beautiful…“The Element 6 and Element 8 are compact, yes, but uncompromising. They’re built for music lovers who want to experience the passion in music, but who also value precision engineering, as well as timeless beauty.”
Comparison
stratton-element-6-8-12-1512
Element 6Element  8Element 12Elypsis 1512
Speaker TypeBass Reflex loaded two-way passive loudspeakerBass Reflex loaded two-way passive loudspeakerTwin bass reflex-loaded, two-way, high-sensitivity passive loudspeaker Quad bass reflex loaded 3-way passive speaker.
Price per pair$20,000$25,000$42,000Starts at £69,000
Enclosure Acrylic-silica reinforced polymer matrix carcass with aluminium front and rear panelsAcrylic-silica reinforced polymer matrix carcass with aluminium front and rear panelsFully braced bamboo ply with CNC-machined aluminum trimsBraced Birch Wood
Integrated Stand No – Optional  – aerospace-grade aluminiumNo – Optional – aerospace-grade aluminiumFolded Voronoi geometry structural panels with a bamboo ply base No
Bass DriversN/AN/AN/A2 x 380mm (15 inches) with paper diaphragm and ferrite motor system.
Ports1124
Bass/Mid Driver 1 x 6-in (150mm) carbon-fiber diaphragm1 x 8-in (200mm) carbon-fiber diaphragm1 x 300mm (12 inches) with NeFeB motor, paper diaphragm, and twin voice coils
Midrange DriversN/AN/AN/A1 x 300mm (12-inch) with hand-doped paper diapraghm and NeFeB Motor system.
Tweeter 29mm (1.2 inch) waveguide soft dome29mm (1.2 inch) waveguide loaded29mm (1.2 inch) waveguide loaded NeFeB motor soft dome29mm (1.2 inches) with waveguide-loaded soft dome and NeFeB Motor system.
Crossover TypeSymmetrical 3rd orderSymmetrical 3rd orderTwo-way with third-order slopesPart-impedance compensated three-way with asymmetric second and third order slopes
Crossover Frequency 1.4kHz1.4kHz1.7kHz350Hz and 2.5kHz
Frequency Response 48Hz to 20kHz46Hz to 20kHz50Hz to 18kHz ±2dB45hz to 18kHz (+/- 2dB)
Low Frequency Cut-off6dB @ 42Hz6dB @ 39Hz-6dB @ 37Hz -6dB @ 28Hz
Midband Sensitivity (2.83V @ 1m)87dB 89.5dB94dB96dB
Nominal Impedance 8 ohms8 ohms
Electrical Phase<±55° above 50Hz<±55° above 50Hz< ±45° between 100Hz and 10kHz
Group Delay <14mS<11mS<10mS above 50Hz <12ms above 40Hz
Amplifier Compatibility 20 watts (8Ω) minimum20 watts (8Ω) minimumAny amplifier will work according to Stratton AcousticsAny amplifier will work according to Stratton Acoustics
EQ OptionsN/AN/AN/AMF and HF +/- 2dB
Connections Bi-wire custom binding posts Bi-wire custom binding posts Bi-wire custom binding posts Tri-wire/Tri Amp Neutrik Speakeron sockets
Speaker Dimensions (HWD)400 x  230 x 239mm
(15.7 x 9.1 x 9.4 inches)
450 x  255 x 254mm
(17.7 x 20.0 x 10.0 inches)
1214 x 500 x 596mm
(48 in x 19.7 x 23.5 in)
876 x 1001 x 515mm
(34.5 x 39.4 x 20.3 inches)
Speaker Weight25 kg
(55.1 lbs)
32 kg
(70.6lbs)
47.6 kg
(105 lbs)
140 kg
(308.6 lbs)
Stratton Acoustics Element 8 and 6 Loudspeakers Rear Angle
Stratton Acoustics Element 8 (Left) and Element 6 (Right) Loudspeakers Rear Angle
The Bottom Line
Stratton Audio made a bold entrance in 2023 with their first loudspeaker, the Elypsis 1512—a striking, large-format design that draws clear inspiration from iconic models like the JBL 4350, Tannoy Buckingham and Urei 815a. While paying homage to those vintage studio and high-efficiency giants, the Elypsis 1512 adds a thoroughly modern twist in both engineering and aesthetics, targeting today’s discerning audiophile—especially the ones with deep pockets and a taste for statement gear.
In 2024, Stratton introduced its second speaker, the Element 12—a more traditional-looking design that carried forward much of the innovation developed for the Elypsis 1512.
For 2025, the lineup expands with two bookshelf/stand-mount models, the Element 6 and Element 8, aimed at delivering the sonic character of the Element 12 in more compact, space-friendly form factors.
All this sounds great, but comes at a hefty price, putting the two new Elements in a similar price category as the TAD ME1TX ($18,000/pair) or Focal Sopra No1 ($13,000/pair). With a lot of great bookshelf speakers selling for less than $1,000 a pair, the Strattons really need to be something special to get audiophiles to dig deeper into their wallets.
Price & Availability
Every Stratton Acoustics loudspeaker is hand-built and tested in the UK.
Stratton speakers (including the Element 6 and 8) are sold in pairs and are available directly from Stratton at the following prices:
  • Element 6 (speakers only): $20K, £15K, €17.5K
  • Element 8 (speakers only): $25K, £20K, €22K
  • Stands: $5K, £3.5K, €4.5K
Note: As of the published date of this article, Elements 6 and 8 information and purchase pages are not yet available on the Stratton Acoustics Website
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Stand-mount loudspeakers
3 Comments
3 Comments
  1. ORT
    April 21, 2025 at 1:30 pm
    I submit for a vote that the Element 8 be renamed the “Liberace” and the Element 6 the “Bootsy Collin’s Parliament-Funkadelic”.
    Both speakers are, as was coined/popularized by the great Cab Calloway in the song, “Are You Hep To The Jive” (released in 1940) very “Fly”.
    “Do you lace your boots high?
    (Yes, yes)
    Are you fly, are you fly?
    (Yes, yes)
    Do you dig, do you dig
    Do you swing on a gig?
    Are you hep to the jive?“
    In the vernacular of today paying homage to a far more palatable past? “Sheeeeeit! Are you all reet?
    Pass out the flashlights.
    Gaius petORTicus Arbiter
    • Ian White
      April 21, 2025 at 1:58 pm
      ORT,
      Being too kind. Not a fan of the styling. If one can call it that.
      IW
  2. ORT
    April 22, 2025 at 1:47 pm
    Ian, you are correct!
    These remind me of mid ‘70s platform shoes with goldfish swimming in the 8 inch heels. Liberace wept.
    ORT
Toneoptic CAN Record Storage System stacked with mixed colors
A/V Furniture & Accessories
Toneoptic’s CAN record storage system offers modular stackable vinyl storage made in Los Angeles starting at $195 and designed to replace milk crates for...
Arendal Sound 1610 Loudspeaker Series Arendal Sound 1610 Loudspeaker Series
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
Okki Nokki One DV Record Cleaning Machine Front Okki Nokki One DV Record Cleaning Machine Front
Can the $749 Okki Nokki ONE built in the Netherlands set a new standard for quieter and more reliable record cleaning machines?
Optoma UHZ36 4K Laser Projector Lifestyle Optoma UHZ36 4K Laser Projector Lifestyle
Does Optoma's $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
BenQ W5850 4K Laser Projector BenQ W5850 4K Laser Projector
BenQ’s W5850 targets serious home theater enthusiasts with laser brightness, factory calibration, and film-first features—but at a higher price and with notable omissions.
Unison Research Unico Pre V2 and DM V2 in Gold Finishes Unison Research Unico Pre V2 and DM V2 in Gold Finishes
Unison Research’s Unico PRE v2 and DM v2 introduce a modern design, substantially more power, and an $18,498 system price—no streamer, no Bluetooth, just...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
KLH Audio President David Kelley joins the podcast to discuss the company's history, loudspeaker design, today's product line and more.
Only 25 numbered pairs will ever be made, finished in piano-gloss rosewood with satin-black detailing, engraved plaques and certificates of authenticity.
Polk Audio have been quite aggressive with their Reserve and Legend Series speakers, and news has dropped on a brand new lineup called the...
Celebrating 40 years, Acoustic Energy’s AE1 Anniversary Edition updates the iconic compact loudspeaker with modern drivers and refined engineering.
Perlisten A-Series loudspeakers are designed for stereo or home theater. Choose between two towers, a stand-mount and on-wall surround.
