Sony Launches LinkBuds Fit Green Hatsune Miku Limited Edition Earbuds
Sony’s LinkBuds Fit Hatsune Miku Edition blends ANC earbuds with a virtual idol—real human voice, not AI hype. Culture, color, and clarity collide.
Sony LinkBuds Fit Hatsune Miku Edition Wireless Earbuds Lifestyle
Sony Electronics has decided that plain green isn’t enough—so it added a globally famous digital pop star who doesn’t technically exist. The result is the LinkBuds Fit Green – Hatsune Miku Limited Edition, a collaboration that leans hard into Japanese pop culture and knows exactly who it’s talking to. For the uninitiated, Hatsune Miku isn’t an anime mascot or a passing meme—she’s a full-blown animated holographic performer with sold-out concerts, charting music, and a fanbase that spans far beyond Japan.
Sony isn’t just slapping a name on a pair of earbuds here; it’s tapping into a digital idol phenomenon that’s been shaping music, fandom, and tech culture for more than a decade.
Hatsune Miku Isn’t “AI” — She’s a Digital Instrument With a Real Human Voice
Let’s clear the fog before the comment section lights its torches.
Hatsune Miku is not “AI” in the modern, self-learning, Skynet-adjacent sense. She doesn’t think, adapt, or wake up one day deciding to drop a diss track. At her core, Miku is a voice synthesizer built from pre-recorded samples of a real human voice, provided by Japanese voice actress Saki Fujita. That makes her far closer to a digital instrument than an autonomous intelligence—more Stradivarius, less Terminator.
That said, things have evolved. VOCALOID6 incorporates VOCALOID:AI, which uses AI-based processing to make performances sound more natural and expressive. You input the melody and lyrics, and the software handles phrasing, dynamics, and realism far better than earlier versions. New editing tools let creators shape accents, vibrato, timing, and rhythmic feel like a producer in the control room guiding the performance rather than letting an algorithm run wild.
The key distinction? The AI assists expression; it doesn’t replace authorship. Miku still relies on human-created voice samples, human-written music, and human intent. She’s a virtual idol persona—carefully curated, creatively directed, and backed by over a decade of cultural history—not a generative AI hallucination spitting out content on its own.
Video: Hatsune Miko Hologram “live” in Concert
Sony LinkBuds Fit Hatsune Miku Edition: What You’re Actually Getting in the Box
The limited-edition package includes a custom acrylic earbud stand featuring artwork by Ogipote, plus two exclusive HoloModels of Hatsune Miku. That means owners aren’t just getting green earbuds and vibes—they’re getting collectible physical gear and digital content that actually required human effort.
Buyers also gain access to a special campaign track, “BELIEVE DAY,” complete with an animated performance viewable through Sony’s HoloModels app on iOS and Android. Download the app, drop Miku into your living room, a subway platform, or wherever your dignity allows, and capture photos of her performing in real-world environments.
Sony LinkBuds Fit Features
  • Fit: LinkBuds Fit are designed for extended wear, using Sony’s Air Fitting Supporters to improve stability and reduce pressure during long listening sessions.
  • Calls: Beamforming microphones and noise reduction processing are used to improve voice clarity during calls, helping reduce background noise in everyday environments.
  • Customization: LinkBuds Fit support cosmetic and ergonomic customization, including interchangeable Air Fitting Supporters and optional case covers available in multiple colors.
  • Dynamic Driver X: Sony’s Dynamic Driver X is tuned for a broad frequency range, with an emphasis on vocal clarity and balanced low-frequency response rather than exaggerated bass.
  • Sound Connect App: The Sony Sound Connect app (iOS and Android) provides access to EQ adjustment, sound modes, control customization, and firmware updates.
  • Auto Noise Canceling Optimizer: This system automatically adjusts noise cancelation based on environmental sound and wearing conditions. Ambient Sound Mode is included for awareness when needed.
  • Listening Time: Battery life is rated at up to 5.5 hours with noise cancelation enabled, with an additional 15.5 hours available from the charging case.
Sony LinkBuds Fit Specifications
sony-linkbuds-fit-hatsune-miku-earbuds-case
Sony Model LinkBuds Fit
Product Type True Wireless Stereo (TWS) Earbuds
MSRPStandard: $229.99
Limited Edition: $249.99
Driver Unit8.4 mm
Wearing StyleClosed – In-ear
Environmental RatingIPX4
Frequency Response (Bluetooth® Communication)20 Hz – 20,000 Hz (44.1 kHz sampling), 20 Hz – 40,000 Hz (LDAC 96 kHz sampling 990 kbps)
Ambient Sound ModeYes
Noise CancelingPersonal NC Optimizer
BluetoothVersion 5.3
Effective Range: 10m
Frequency Range: 2.4 GHz band (2.400 0 GHz – 2.483 5 GHz)
Bluetooth ProfilesA2DP, AVRCP, HFP, HSP, TMAP, CSIP, MCP, VCP, CCP
Bluetooth Code SupportSBC, AAC, LDAC, LC3
Supported Content ProtectionSCMS-T
Battery TypeRechargeable – Lithium-ion (Li-ion)
Charging MethodUSB charge (with case)
Battery Life (Waiting Time)Max. 6.5 hrs (NC ON) / Max. 14 hrs (NC OFF)
Battery Life (Continuous Communication Time) Max. 4 hrs (NC ON) / Max. 4 hrs (NC OFF)
Battery Life (Earbuds) Max. 5.5 hrs (NC ON) / Max. 8 hrs (NC OFF)
Battery Life (Case)Max 15.5 hours
Dimensions (Charging Case)Approx. 47.2 x 47.2 x 32.6 mm
WeightApprox. 41 g
What’s in the Box
Earbuds
Charging Case
USB Cable
Air Fitting Supporters (Pair)
4 Different-Sized Earbud Tips
Limited-Edition Acrylic Earbud Stand
The Bottom Line
The Sony LinkBuds Fit are built for people who actually move—runners, gym regulars, commuters who refuse to sit still. They offer secure all-day comfort, effective noise canceling for workouts, and a usable Ambient Sound mode when situational awareness matters. Sound quality is solid across music and calls, with ANC and transparency doing their jobs without drama. The trade-offs are real but manageable: touch and voice controls are limited, and EQ flexibility—especially in the low end—isn’t as generous as some competitors.
The Green – Hatsune Miku Limited Edition doesn’t change the sound, the tuning, or the performance—and it doesn’t pretend to. What it adds is personality: a distinctive colorway and collectible appeal tied to Hatsune Miku, which will resonate strongly with fans, particularly in Japan. At $249, you’re paying a premium for the collaboration, not upgraded hardware.
Who is this for?
Active users who want a secure, comfortable ANC earbud—and Hatsune Miku fans who want something more expressive than another pair of black or white earbuds. If you’re here for maximum customization or bass-heavy tuning, look elsewhere. If you want reliable performance with a cultural wink, this one knows exactly who it’s selling to.
For a deeper dive, see our initial report and full review of the LinkBuds Fit.
Price & Availability
Technics SL-1500CS Turntable Silver
Technics SL-1500CS upgrades the popular SL-1500C with Delta Sigma Drive motor control. Does this precision boost make it the new direct drive leader in...
Rega Aos MC Phono Preamplifier Angle Left Rega Aos MC Phono Preamplifier Angle Left
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
Nagra Compact Player Angle Nagra Compact Player Angle
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
LG xboom Plus and Lite wireless earbuds LG xboom Plus and Lite wireless earbuds
LG expands its xboom lineup with Buds Plus and Buds Lite, adding ANC, Auracast, UVnano+ tech, and up to 35 hours of battery life.
ViewSonic LX60HD smart LED 1080p projector angle ViewSonic LX60HD smart LED 1080p projector angle
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
HiBy W4 Portable HiFi Bluetooth Headphone Amplifier HiBy W4 Portable HiFi Bluetooth Headphone Amplifier
HiBy W4 packs aptX Lossless, LDAC, 475mW balanced output, and a touchscreen into a $99 portable Bluetooth DAC Amplifier.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our hands-on review of Sony’s new top-of-the-line WF-1000XM6 wireless earbuds reveals they've been improved in a few key areas.
The Case for Audio/Video Receivers (AVRs) While soundbars have evolved over the years and can provide a convenient solution to better TV sound, nothing beats a...
Can Sony gain ground in a crowded entry-level vinyl market with the new PS-LX3BT and PS-LX5BT Bluetooth turntables, or will strong competition from established...
At $229 do Sony LinkBuds Clip justify their price with comfort, smart features and open-ear convenience or do the sound tradeoffs matter more?
Premium audio sounds better than ever but warranties are stuck in the past. Why are $400 to $2000 headphones and speakers still treated as...
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Sony and TCL are forming a global TV joint venture with TCL holding majority control. It’s a seismic power shift that rewrites the future...
