ONIX Zenith XMT20 Streamer Transport Debuts With TIDAL Connect, Qobuz Connect, and Roon Ready Certification
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
Shanling ONIX Zenith XMT20 Streaming Music Bridge
Shanling is pushing deeper into serious digital front-end territory with the ONIX Zenith XMT20 streamer transport, the company’s first product built around its newly developed Linux-based streaming platform. Priced at $2,199 USD internationally and €2,399 in the European Union (North American pricing is still TBD), the ONIX Zenith XMT20 is clearly aimed at listeners who want a dedicated, high-end digital source without the clutter or compromises of an all-in-one solution.
The new platform is designed around faster, simpler operation, with a heavy emphasis on remote control and native support for TIDAL Connect, Qobuz Connect, and full Roon Ready certification.
The XMT20 also underscores how tight the relationship between ONIX and Shanling has become. Following a string of recent collaborations, including the XST20 SACD/CD transport, the two brands are clearly aligning their engineering and design efforts across both disc-based and network audio.
shanling-onix-zenith-xmt20-music-streamer-rear
Beyond streaming, the XMT20 supports gapless local playback via USB storage or an internal SSD slot, handles all common Hi-Res formats, and uses the Eddict Controller app for Android and iOS. DLNA and AirPlay 2 round out the feature set, making the XMT20 a flexible but purpose-built transport rather than a lifestyle streamer trying to be everything at once.
High-End Grade Digital Output
The ONIX XMT20 is built to function as a true reference-grade digital transport, offering six digital outputs to accommodate virtually any external DAC. Standard coaxial, optical, BNC, and AES/EBU connections are joined by an advanced USB output and a dedicated I²S interface, making the XMT20 far more flexible than a typical network streamer. The FPGA-assisted I²S output is a key differentiator, providing 10 preconfigured pinout options to ensure broad compatibility with most I²S-capable DACs on the market—no guesswork, no adapters, no excuses.
Digital signal integrity is handled with the same seriousness ONIX applies to its disc transports. A pair of KDS high-precision crystal oscillators anchors the clocking architecture, delivering low-jitter performance intended for high-resolution playback across all supported outputs. In practical terms, the design philosophy mirrors what made the ONIX XST20 such a compelling SACD/CD transport: clean signal paths, stable timing, and an emphasis on musical coherence rather than feature bloat. The XMT20 takes that same approach and applies it squarely to modern network and file-based digital playback.
shanling-onix-zenith-xst20-xmt20-xda20
Shanling ONIX Zenith XST20 SACD/CD Transport, XMT20 Streamer, XDA20 DAC-AMP
Adapted for CD Playback & Ripping
The ONIX Zenith XMT20 doesn’t stop at streaming and file playback. It also introduces a new CD playback and ripping system, extending the unit’s role as a central digital hub. The platform supports both basic USB CD drives and the more advanced Shanling CR60, giving users the choice between simple disc access or a higher-grade external transport. CDs can be played directly through the XMT20 or securely ripped to an internal SSD or connected USB storage.
Ripping is handled with minimal friction. The system supports automatic metadata tagging and album art downloads, all managed through the Eddict Controller app, keeping the process streamlined and hands-off once initiated. In practice, this brings the same disciplined, transport-first mindset ONIX applies to disc playback into the file-based world—letting users preserve their CD collections digitally without resorting to a computer-based workflow or third-party software.
shanling-onix-zenith-xmt20-music-streamer-remote
Key Specifications
  • Dimensions / Weight: 32 x 24 x 7.2 cm / 5.2 kg
  • Display: 3.4-inch touch screen
  • Platform: In-house Linux-based streaming system
  • Streaming Support: TIDAL Connect, Qobuz Connect, Roon Ready
  • Networking: Wi-Fi, Ethernet, DLNA, AirPlay 2, NAS
  • Local Playback:
    • USB storage (rear port, up to 2TB)
    • M.2 NVMe SSD slot (bottom-mounted)
  • File Support:
    DSD (.iso, .dsf, .dff), DXD, FLAC, WAV, AIFF, APE, ALAC, AAC, MP3, OGG, M3U/M3U8 (DST not supported)
  • CD Playback / Ripping:
    USB CD drives and Shanling CR60
  • Digital Outputs:
    • Optical, Coaxial, BNC, AES/EBU: PCM 24/192, DSD64 (DoP)
    • USB & I²S: PCM 24/768, DSD512 (native)
  • Power Supply: 25VA Talema transformer
shanling-onix-zenith-xmt20-music-streamer-angle
The Bottom Line
The ONIX XMT20 is not trying to be a mass-market streamer, and that’s exactly the point. What makes it unique is its transport-first design: a new in-house Linux platform built around native TIDAL Connect, Qobuz Connect, and full Roon Ready certification, combined with an unusually deep set of high-end digital outputs, including FPGA-assisted I²S with broad DAC compatibility. Add local playback from USB or internal NVMe SSD, plus CD playback and ripping via external drives, and the XMT20 becomes a modern digital hub that treats signal integrity and flexibility as priorities rather than afterthoughts.
Based on €2,399 EU pricing and $2,199 international pricing, it is highly unlikely the North American price will land under $2,000 USD; a figure closer to $2,400 is far more realistic. There is also no Spotify Connect support, which immediately narrows the audience—and intentionally so. The XMT20 is for Roon-centric listeners, Qobuz and TIDAL subscribers, and DAC owners who want a serious, future-proof digital transport without paying for an internal DAC they don’t need. If you’re building a high-end system around external conversion and care more about clocking, output options, and control than app ecosystems or lifestyle features, the XMT20 is very much aimed at you.
For more information: XMT20 Streamer
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
Hi-Fi Components
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
Can the iFi NEO Stream 3 and ZEN Stream 3 stand out in the crowded sub-$1,000 streamer market where WiiM, Bluesound, Eversolo, and Cambridge...
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
