Shanling Audio may not be the most widely recognized name in high-end audio, but its growing lineup of well-regarded products continues to earn attention. At High End Munich 2025, taking place from May 15–18, Shanling will showcase five of its top-performing models.
ONIX Zenith XST20 SACD Transport
Shanling’s ONIX Zenith XST20 is a top-loading SACD/CD transport designed for seamless integration with external DACs. It supports CD, multi-layer and single-layer SACD, MQA-CD playback, and delivers pure DSD audio output for SACDs. Outputs include Coaxial, Optical, AES, BNC, and USB, along with two I2S connections—one for SACD and one for Red Book CDs. The XST20 also offers 10 selectable I2S pinout modes for broad system compatibility.
Pro Tip: The USB output does not support SACD playback.
Where to buy: $2,099 at HiFiGo
Shanling ECZeroT CD Player
The ECZeroT is Shanling’s new portable CD player, making its debut at High End Munich 2025. While full details have not yet been released, some core features and the U.S. price have been confirmed.
- Battery Operation Option: The ECZeroT has a built-in rechargeable 55mAh battery, and it is also assumed that it can be used with AC power by a provided battery charger/AC adapter (Desktop Mode).
- Vacuum Tubes: In an interesting twist, especially for a portable player, the ECZeroT incorporates Vacuum Tube sound with two JAN6418 tubes.
- DAC: The ECZeroT incorporates s Shanling-developed R2R DAC for optimal listening quality.
- USB: A USB port is also provided so the ECZeroT can be used as a standalone DAC with compatible external digital sources.
- CD to Bluetooth Output: This allows the player to be used with wireless bluetooth headphones/earphones, in addition to wired headphone connectivity options.
The announced US price for the ECZeroT is $589 through Authorized Dealers and Distributors, or the Shanling Store
ONIX XDA20 DAC/Headphone Amplifier
This is another Shanling component that will be previewed at High End Munich 2025, but details remain limited. Here’s what we know:
- DACs: The ONIX XDA20 features dual ESS ES9039PRO DACs.
- Outputs: The XDA20 includes a dedicated headphone output, along with RCA and XLR balanced outputs for connection to external amplifiers or powered speakers.
- Inputs: Physical connectivity options include Coaxial, Optical, BNC, AES, USB, and I2S inputs.
- Transformer: The XDA20 is equipped with dual transformers.
- Chassis: The enclosure is CNC-machined from aluminum.
- Pricing and availability: To be announced.
Shanling SM1.3 DAC/Streamer
The Shanling SM1.3 Music Streamer (network streamer) is powered by a 64-bit ARM Cortex CPU and runs a customized, closed version of Android 12. It features an aluminum alloy chassis.
- Feature and Content Navigation: The SM1.3 offers an intuitive UI through a 5.8-inch 1080p touchscreen, or users can control it via the Eddict Controller App (iOS/Android).
- DAC and Headphone Amp: It incorporates the AKM 4499EX DAC paired with the AK4191 Modulator. A dedicated TPA6120 headphone amplifier and comprehensive input/output stages provide flexible setup options.
- Streaming Services: The SM1.3 supports streaming from Spotify, TIDAL, Apple Music, Apple Classical, and Amazon Music.
- Bluetooth and Wireless Connectivity: Bluetooth 5.2 is supported, including LDAC, SBC, aptX Adaptive, aptX Low Latency, and aptX HD. Apple AirPlay 2 compatibility is also included. MQA decoding is supported.
- Added Content Access: Music files can be played from USB flash drives, and an M.2 SSD slot is provided for larger digital collections. The SM1.3 also functions as a DLNA-compatible music hub.
- Internet Connectivity: The SM1.3 supports both Wi-Fi 6 and wired Ethernet (Gigabit LAN) connections.
- Inputs and Outputs: Inputs include digital optical and coaxial connections. Outputs include RCA and XLR analog outputs, along with an I2S digital output (HDMI) featuring an FPGA with 10 selectable compatibility modes.
Where to buy: $1,199 at Linsoul
Shanling HW600 Headphones
The Shanling HW600 Planar Open-Back Wired Headphones feature high-performance planar dynamic drivers with an 86 x 110 mm diaphragm made from ultra-thin 8μm polymer materials. This design enhances rigidity and sensitivity, reducing distortion for clear, dynamic sound across an extended frequency range—even at higher listening levels.
- Wearing Comfort: The headphone cups are crafted from polished, aircraft-grade 7xxx aluminum, and the ear cushions are made from replaceable lambskin. The HW600 also optimizes airflow through dual acoustic chambers to enhance comfort and sound performance.
- Drivers: The HW600 uses 14 neodymium-iron-boron magnets in a dual-sided assembly, achieving a magnetic flux density of 1.8T. With a low impedance of 30Ω, the HW600 is relatively easy to drive and compatible with a wide range of amplifiers.
Where to buy: $1,099 at Linsoul
The Bottom Line
One of the great things about shows like High End Munich is the chance to see and hear a wide range of new gear in one place. However, with so much happening, it can be overwhelming to decide which products stand out. Shanling is stepping up with a strong lineup, showcasing three current models and previewing two new ones. Among the highlights, the ECZeroT portable CD player—combining vacuum tube technology with portability—could be particularly hard for audiophiles to ignore.
It’s also worth noting that 2025 marks the final year of High End Munich before the show moves to Vienna, Austria in 2026 and beyond. Despite ongoing uncertainty around tariffs and international trade, Shanling’s new lineup gives audio enthusiasts plenty to be excited about heading into this new chapter.
Related Reading
Anton
May 1, 2025 at 3:44 pm
The SACD player and DAC/Headphone amplifier are stunning. Hope the tariffs don’t make these outrageously expensive.
Ian White
May 1, 2025 at 6:09 pm
They probably will unless the distributor here has enough inventory to ride this out for a few months. The new products have not shipped yet so who knows…
IW
