Are We Hitting Peak Turntable? Pro-Ject E1.2 Aims for Audiophile Sound Quality For Under $350
Pro-Ject E1.2 delivers audiophile-grade performance at a budget price. A real entry-level winner with serious upgrades and no gimmicks—just sound.
Pro-Ject E1.2 Turntable Top Black
How many entry-level turntables does the world really need?
It’s a fair question — one the audio industry doesn’t seem particularly interested in answering. In 2025, consumers are drowning in budget-friendly vinyl spinners from every conceivable corner of the market: Pro-Ject, U-Turn, Fluance, Audio-Technica, Sony, Orange, Andover, Rega, Denon… and probably Aunt Mildred from Toledo, who just launched a Kickstarter for a belt-drive deck built from recycled hummus tubs.
We’ve reached saturation point — or at least Saturation Hour — in the affordable turntable category. The options are plentiful, but are they all necessary? That’s the needle Pro-Ject is trying to thread with the new E1.2: a sleek, stripped-down model promising real audiophile performance at a price that won’t trigger your credit card fraud alerts.
So does the E1.2 earn its place on your rack, or is it just another pretender in a category flooded with some questionable options? Let’s dig in…but only after you think about this first.
If you’re shopping for your first turntable or just trying to escape the plastic plague of Crosley-grade clunkers, you need to ask yourself a basic question: What kind of vinyl listener are you?
Are you looking for a plug-and-play solution with all the modern conveniences baked in — built-in phono stage, Bluetooth, decent moving magnet cartridge, and a tonearm that won’t make you regret every LP purchase after three spins? Or do you want something simpler and more honest — no gimmicks, no internal DACs or wireless modules — just solid engineering, good parts, and the freedom to upgrade as you go?
pro-ject-e1-2-front-black
Pro-Ject’s new E1.2 isn’t trying to be your Swiss Army turntable. It’s not here to connect to your AirPods or impress your barista with a spec sheet full of fluff. What it does offer is a refreshingly stripped-down, audiophile-first experience at a price that’s still within reach for someone who just dropped $40 on a new Blue Note reissue and needs to hear it without warps, wow, or wobble.
It gives you the essentials — a properly built tonearm, solid bearing, good MM cartridge, an upgraded platter, and actual room to grow. And for a lot of listeners? That’s the smarter way in.
Pro-Ject E1.2: A No-Frills Turntable for Modern Vinyl Purists That Goes Back to the Future
You’re right to feel a bit of déjà vu with the new Pro-Ject E1.2. It may look like a throwback, but this isn’t just a lazy retread of the 1991 original. In the 30+ years since launching the Pro-Ject 1, the Austrian manufacturer has sold more than a million turntables, built one of the most advanced turntable factories on the planet, and figured out how to design nearly every part in-house.
That kind of scale and institutional memory gives Pro-Ject a serious edge in the entry-level category — and it shows. The E1.2 might be minimalist in spirit and appearance, but under the hood it’s a distillation of decades of know-how. Other brands in this price range are still figuring out how to build decent bearings; Pro-Ject’s already moved on to refining motor decoupling and making isolation matter at $300.
pro-ject-e1-2-wood-side
What’s New with the Pro-Ject E1.2? Upgraded Features for Serious Starters
Pro-Ject is making some noise about the upgrades baked into the E1.2—and for good reason. Compared to the 2022 E1, this isn’t just a cosmetic refresh or a parts-bin shuffle. The main platter now sports an aluminum die-cast design with a built-in TPE damping ring, which should do a better job taming unwanted vibrations and keeping playback tighter and cleaner. That’s not lip service—it’s a solid engineering move borrowed from the company’s more expensive tables.
Even better, the E1.2 steals the sub-platter from Pro-Ject’s popular Debut line—specifically a glass-fiber-reinforced ABS design that offers improved speed stability and durability. That’s trickle-down tech that actually matters.
Also gone is the generic Audio-Technica AT3600L cartridge from the previous model. In its place? Pro-Ject’s own Pick it MM E cartridge, which promises better tracking, smoother tonal balance, and lower distortion. No, it’s not some $400 moving coil stunner, but for the price, it’s more than respectable—and it looks the part too.
Available in high-gloss black, satin white, or walnut, the E1.2 looks sleek without shouting, “I bought this at Urban Outfitters.” This is still an audiophile company with both feet planted in the high-end world, and they haven’t forgotten how to dress an affordable turntable properly.
Pro-Ject E1.2 Technical Specifications
  • Speeds: 33 ⅓ RPM, 45 RPM (electronic speed control)
  • Drive Principle: Belt drive with electronic speed regulation
  • Platter Bearing: Stainless steel axle in bronze bushing
  • Wow & Flutter: 33 RPM: ±0.23% / 45 RPM: ±0.21%
  • Speed Drift: 33 RPM: ±0.7% / 45 RPM: ±0.6%
  • Signal-to-Noise Ratio: 65 dB
  • Tonearm:
    • Effective Length: 218.5 mm
    • Effective Mass: 7.0 g
    • Overhang: 22 mm
  • Included Accessories:
    • 15V DC / 0.8A power supply
    • Dust cover
    • 7″ single adapter
  • Power Consumption: 4.5 W
  • Dimensions (W x H x D): 420 x 112 x 330 mm
  • Weight: 3.6 kg (net)
Pro-Ject Pick it MM E Cartridge
pick-it-mm-e-cartridge=lifestyle
  • Type: Moving Magnet (MM)
  • Output Voltage: 3.8 mV @ 1 kHz
  • Frequency Response: 10–20,000 Hz (±2 dB)
  • Stylus: Conical
  • Tracking Force: 1.8–2.2 g (recommended: 2.0 g)
  • Tracking Ability (315Hz): 70 μm
  • Dynamic Compliance: 14 μm/mN
  • Tracking Angle: 23°
  • Load Resistance: 47 kΩ
  • Height (Stylus Tip to Mount): 18.2 mm
  • Cartridge Weight: 5.5 g
pro-ject-e1-2-white
The Bottom Line
The Pro-Ject E1.2 isn’t trying to reinvent the turntable—thankfully. What it does do is offer a genuinely well-built, entry-level deck that doesn’t feel like a cheap toy or a branding exercise slapped together for the streaming generation. You’re getting real engineering here: a heavier, damped platter, upgraded sub-platter tech lifted from the Debut line, and a capable cartridge that’s been properly matched to the arm. It’s fully manual, solidly built, and styled with just enough class to fit in anywhere without screaming “budget hi-fi.”
After 30+ years and over a million turntables sold, Pro-Ject still give a damn about the budget buyer. That matters.
Back to the original question: Do we need another entry-level turntable? No. But do we need better ones that aren’t just plastic cash grabs? Absolutely. If you’re looking to start your vinyl journey with a deck that prioritizes sound quality, upgradeability, and build over gimmicks, the E1.2 might be the smartest move you can make without getting fleeced.
For more information: project-audio.com
2 Comments
2 Comments
  1. Timothy L Zdybek
    August 6, 2025 at 9:50 am
    I want to purchase a turntable
  2. Ian Ev
    August 7, 2025 at 1:49 pm
    Received mine in the mail today. Easy to set up, just thread the belt and put on the turntable.
    First minute I was worried! A humming sound very noticeable made me think I’d be sending it back but…after moving the turntable about 12 inches from the amp everything was fine.
    It’s a beautiful piece of engineering and sounds great!
2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
Dan D'Agostino Momentum C2Z Preamplifier with Power Supply Dan D'Agostino Momentum C2Z Preamplifier with Power Supply
Dan D’Agostino Momentum C2Z preamplifier refines the C2 with Z circuitry and FET output stage. If you have to ask the price this is...
Musical Fidelity M6xi Integrated Amplifier Silver Musical Fidelity M6xi Integrated Amplifier Silver
At $3,799, Musical Fidelity’s M6xi delivers 230 WPC with an onboard DAC, HDMI ARC, and MM/MC phono stage, offering a powerful and flexible solution...
Denon AVR-S980H Home Theater A/V Receiver Lifestyle Denon AVR-S980H Home Theater A/V Receiver Lifestyle
Denon AVR-S980H adds wireless surround support, 1440p pass-through, and channel level monitoriing offering a flexible step-up from soundbars under $1,000.
2026 Samsung R85H Micro RGB TV Lifestyle 2026 Samsung R85H Micro RGB TV Lifestyle
Samsung reveals pricing and availability for its 2026 Micro RGB LED TV lineup, introducing a new approach to color accuracy and premium display performance.
Feeling lucky? Enter for a chance to win a Denon DP-500BT Turntable. Must be 18+ and U.S. or Canada resident and enter before 11:59pm...
At $899, the Technics SL-40CBT Bluetooth Direct Drive Turntable features aptX Adaptive, built-in MM phono stage and three finishes.
Technics ends the SL-1200/1210G run with two Grand Class Master Edition turntables in black or silver with even better performance and fancy gold accents.
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
Pro-Ject’s Pre Box S3 is a compact control hub with phono, HDMI eARC, USB-C, Bluetooth, and headphone support—but can one small box really run...
Andover Audio’s SpinPlay is a brutally well-executed all-in-one record player that sounds far better than it should at its price—and may be the company’s...
