DAPs
ONIX Tocata XM2 DAP Arrives With 800 mW Output and Full Hi-Res PCM/DSD Support
ONIX’s $439 Tocata XM2 DAP debuts with a balanced CS4308P DAC, 800 mW output, TIDAL streaming, LDAC support, and clean design—though it lacks Bluetooth LE and aptX Lossless.
ONIX Tocata XM2 DAP in hand
The ONIX Tocata XM2 drops this week at $439, and ONIX isn’t dipping a toe into the DAP market so much as cannonballing straight into the crowded deep end dominated by Astell&Kern, FiiO, Cayin, and iBasso. Building on the design language of the Overture XM5 and the pocket-friendly footprint of the Waltz XM10, the Tocata XM2 fuses ONIX’s minimalist aesthetic with real-world portability. It delivers up to 800 mW into 32 ohms with full hi-res PCM and DSD support—an affordable, compact player meant to carry the ONIX identity into a far more competitive arena.
2025 has been a strange little plot twist. FiiO and Astell&Kern have doubled down on a category many assumed was drifting into irrelevance as consumers leaned on smartphones, wireless headphones, or a simple Dongle DAC hanging off the charging port. And when Samsung, Google, and Apple are already extracting a kidney for their latest flagships, the idea of carrying a second, dedicated digital audio player should feel like a non-starter. Yet here we are because overseas demand hasn’t just held steady, it’s thriving. Turns out a lot more people want a purpose-built music player than the doomsayers ever predicted.
onix-tocata-xm2-dap-angle
Latest DAC Technology: New Cirrus Logic CS4308P Debuts in ONIX Tocata XM2
The Tocata XM2 is the first ONIX player to feature Cirrus Logic’s new flagship CS4308P, an 8-channel DAC designed for fully balanced implementation and a clear step forward from the brand’s previous-generation chipsets. ONIX supports the DAC with its in-house “Brighton” I/V conversion stage and a pair of SGM amplifiers capable of delivering up to 800 mW into 32 ohms. The design maintains a low output impedance, making the XM2 equally suitable for demanding full-size headphones and sensitive IEMs without noise or instability.
Streamlined Performance and a Purpose-Built Audio Platform
Powered by the Ingenic X2000, the Tocata XM2 runs a lean, fast system tailored for listeners who want music without the smartphone circus. It plays local hi-res files from a microSD card, supports Tidal streaming, and works seamlessly over DLNA or AirPlay to keep the signal clean and uninterrupted. The aluminum chassis carries the usual ONIX refinement, with bi-directional Bluetooth for sending or receiving wireless audio, a USB digital output for feeding an external DAC, and USB DAC mode for use with a computer or smartphone. ONIX even adds support for its new magnetic phone case to make tethered listening more practical—though the case itself is sold separately.
onix-tocata-xm2-dap-top-front
Specifications and What They Actually Mean
The Tocata XM2 stays compact at 82 × 65 × 18 mm (roughly 3.2 × 2.6 × 0.7 inches) and 140 grams, making it a legitimately pocketable DAP. It runs ONIX’s in-house system on the Ingenic X2000 platform with a 3-inch square 720p OLED touchscreen—simple, sharp, and functional. Music can be loaded from a microSD card up to 2 TB or streamed directly through TIDAL, DLNA, or AirPlay. Control comes through the touchscreen, four physical buttons, and a volume wheel, with remote operation handled via ONIX’s SyncLink system in the Eddict Player app for Android and iOS.
Wireless support includes two-way Bluetooth 5.2 with LDAC, aptX HD, aptX, SBC, and AAC. Wi-Fi runs on 2.4 and 5 GHz bands, letting the player stream or act as a DLNA/AirPlay target. The USB-C port handles standard charging, USB DAC mode for bypassing a phone or laptop’s internal audio, and USB digital output for feeding an external DAC. Hi-res file support tops out at PCM 768kHz/32-bit and DSD512, which covers anything most listeners will realistically throw at it.
onix-tocata-xm2-dap-screen-front
Headphone outputs include both 3.5mm single-ended and 4.4mm balanced, each with low and high gain. The single-ended output delivers 51 mW at 32 ohms in low gain and 204 mW at 32 ohms in high gain, with a low 0.4-ohm output impedance—good news for sensitive IEMs. The balanced output is where the muscle lives: 200 mW at 32 ohms in low gain and 800 mW at 32 ohms in high gain, with a 0.7-ohm output impedance.
The measured performance is clean: 20 Hz – 40 kHz frequency response within half a decibel, THD+N at 0.0005% (A-weighted), 112 dB channel separation, and a 121 dB signal-to-noise ratio. Noise performance at 114 dB (A-weighted) keeps hiss out of the picture with efficient IEMs.
Battery capacity is 3000 mAh, yielding up to 8.5 hours of playback from either output. Not class-leading, not terrible—just the cost of running a fully balanced design and a bright OLED screen in a small enclosure.
onix-tocata-xm2-dap-cases
onix-tocata-xm2-dap-case-with-iphone
The Bottom Line
The ONIX Tocata XM2 steps directly into a heavyweight division dominated by the FiiO M21 and Shanling M3, but it doesn’t show up unprepared. At $439, it delivers a fully balanced design built around Cirrus Logic’s new CS4308P DAC, ONIX’s “Brighton” I/V stage, and a genuine 800 mW of output power from the 4.4 mm jack. It keeps the experience focused: hi-res local playback, TIDAL streaming, DLNA/AirPlay, USB DAC mode, and two-way Bluetooth with LDAC and aptX HD. It’s compact, metal-bodied, and purpose-built for people who want a music player—not a pocket-sized tablet pretending to be one.
But accuracy also means calling out the limits. There’s no Bluetooth LE or aptX Lossless, two features that are becoming more relevant as wireless audio moves forward. Battery life is only average, and the OS remains intentionally lean compared to what FiiO and Shanling offer on their higher-end models. Even so, the XM2 carves out a credible lane: a simpler, more affordable DAP that still has the power, measured performance, and everyday usability to compete where the listening actually happens.
For more information: onixhiend.co.uk/introducing-onix-tocata-xm2/
Arendal Sound 1610 Loudspeaker Series
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
Okki Nokki One DV Record Cleaning Machine Front Okki Nokki One DV Record Cleaning Machine Front
Can the $749 Okki Nokki ONE built in the Netherlands set a new standard for quieter and more reliable record cleaning machines?
Optoma UHZ36 4K Laser Projector Lifestyle Optoma UHZ36 4K Laser Projector Lifestyle
Does Optoma's $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
BenQ W5850 4K Laser Projector BenQ W5850 4K Laser Projector
BenQ’s W5850 targets serious home theater enthusiasts with laser brightness, factory calibration, and film-first features—but at a higher price and with notable omissions.
Unison Research Unico Pre V2 and DM V2 in Gold Finishes Unison Research Unico Pre V2 and DM V2 in Gold Finishes
Unison Research’s Unico PRE v2 and DM v2 introduce a modern design, substantially more power, and an $18,498 system price—no streamer, no Bluetooth, just...
MoFi UltraPhono Pro Front Angle MoFi UltraPhono Pro Front Angle
At $2,495, MoFi Electronics’ UltraPhono Pro brings MasterPhono design DNA to a more attainable phono preamp with fully discrete, low noise, MM/MC flexibility, and...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
EarFun unveils Air Pro 4+, Clip 2, and Wave Pro X at CES 2026 with hybrid ANC, Bluetooth 6.0, lossless audio, AI translation, and...
Shanling’s M3 Plus, iBasso’s DX340, and Astell&Kern’s SP4000 show why DAPs still matter: better power, better sound, and a distraction-free experience no smartphone with...
The Astell&Kern A&ultima SP3000T was the only portable DAP that impressed us in 2024, but it will cost you $2,999 USD.
DAPs
Shanling's M3 Plus portable DAP delivers a sleek design, warm sound, Android 13, and balanced output for under $500.
The Edifier MR5 delivers impressive near neutral accuracy, deeper bass, LDAC support and true three-way power for $350, making it a top budget studio...
Dongle DACs
Questyle’s QCC ($59) and QCC Pro ($99) finally bring aptX Adaptive and LDAC to iPhone and iPad, giving Apple users higher resolution Bluetooth audio.
At $69.99, SOUNDPEATS Clip1 delivers Dolby Audio, LDAC, and N-Flex Arch comfort in a lightweight open-ear wireless earbud built for all-day wear, workouts, and...
Dongle DACs
The Questyle M18i blurs the line between dongle and desktop DAC, offering current-mode amplification, wired and wireless versatility, and exceptional sound quality—but short battery...
