Monitor Audio Bronze Series 7G Aims to Redefine “Entry-Level” Without Draining Your Wallet
Five Monitor Audio Bronze Series 7G loudspeakers bring upgraded drivers, sleek design, and Dolby Atmos support at wallet-friendly prices.
Monitor Audio Bronze 7G Loudspeakers White
Monitor Audio just dropped their Bronze Series 7G, aiming to shake up the entry-level speaker game for both two-channel setups and home theater systems. At the heart of this lineup is their updated Ceramic-Coated Aluminium Magnesium (C-CAM) gold dome tweeter — a tech they’ve been refining since 1982 — promising sharper highs and detailed clarity.
But let’s be real: the Bronze 7G faces stiff competition from heavy hitters like Q Acoustics, KEF, DALI, ELAC, and Klipsch, all of whom have raised the bar in affordable speaker performance. It’s a crowded battlefield, but Monitor Audio believes their new range can carve out a solid spot.
A Starting Point For Acoustic Excellence
The all-new Bronze Series 7G marks a full reset. Monitor Audio’s R&D team went back through every previous Bronze iteration to pinpoint exactly what made the Bronze DNA stand out — its strengths, its class-leading qualities, and what fans have always loved.
With five meticulously designed models, each pushing the limits of entry-level performance, this series introduces new acoustic tech, updated cabinet designs, and flexible options for both stereo and AV setups. The Bronze 7G clearly aims to remain the go-to starting point for anyone serious about experiencing true high-fidelity sound.
monitor-audio-bronze-7g-black
The Monitor Audio Bronze Series 7G is available in black, walnut or white.
The Bronze Series 7G lineup includes five models, led by the Bronze 300 7G floorstanding speakers as the flagship. Rounding out the range are the Bronze 50 stand-mounts, Bronze Centre 7G, Bronze On-Wall 7G, and the Bronze AMS 7G Dolby Atmos-enabled speakers—covering all the bases for stereo and surround setups.
Complementing the new tweeter are the Ceramic-Coated Aluminium Magnesium (C-CAM) bass and mid-bass drivers, engineered for a lightweight but rigid build with strong motor systems that deliver deep, punchy, and accurate bass. This latest C-CAM design also features a larger voice coil and optimized magnet setup, aiming to cut distortion and boost sensitivity for cleaner, more detailed midrange performance.
The crossovers in the Bronze Series 7G use high-quality components like refined capacitors and transistors, ensuring a clean signal path for more accurate musical reproduction. On the outside, each Bronze 7G cabinet is crafted for performance, featuring real wood and plywood front baffles that balance strength, rigidity, and acoustic integrity. Monitor Audio’s ‘through-bolt’ technology secures the cabinets internally, reducing unwanted resonance and enhancing structural stability. The Bronze Series 7G speakers come in walnut, black, or white finishes, with pricing as follows:
  • Bronze 300 7G: £1000 / €1250 / $1699 per pair
  • Bronze 50 7G: £500 / €600 / $849 per pair
  • Bronze Centre 7G: £400 / €500 / $649
  • Bronze On-Wall 7G: £300 / €350 / $499
  • Bronze AMS 7G: £450 / €575 / $779 per pair
Bronze Series 7G Benefits
New On-Wall Model Joins The Bronze Range
The Bronze On-Wall 7G is a fresh, versatile addition to the lineup. Its ultra-slim profile makes it ideal not just for rear and side channel AV roles but also as a wall-mountable front LCR (left-center-right) speaker—perfect for home theaters. It delivers detailed, high-fidelity surround sound while blending effortlessly into your décor.
New C-CAM Gold Dome Tweeter
The latest Bronze 7G tweeter is thinner, lighter, and more rigid than the previous generation. Its profiled dome now incorporates the UD (Uniform Dispersion) Waveguide II, which improves time alignment and lowers the crossover frequency for wider sound dispersion. Alongside a new compression ring, this means less distortion and a cleaner, more enjoyable listen. Newly optimized venting also boosts output in the critical 2-3kHz range for sharper playback at louder volumes.
New 6-Inch C-CAM Bass Driver
Behind the lightweight yet rigid C-CAM cone sits a powerful motor system. Enhanced with an optimized surround, new spider design, and a larger voice coil diameter, it delivers tight, controlled deep bass with reduced distortion and punchier, more precise low-end performance.
New 6-Inch C-CAM Bass-Mid Driver
The mid-bass drivers now sport larger voice coils and magnets than ever before, cutting distortion and improving midrange clarity. The result is better control, greater power handling, higher sensitivity, and more lifelike sound.
New Crossover Design
Hundreds of hours of listening tests and meticulous component selection have shaped the Bronze 7G crossover. Extensive measurements ensure a pure, seamless signal transfer for faithful music reproduction.
Enhanced Cabinet Design
Monitor Audio’s reputation for cabinetry craftsmanship continues with Bronze 7G. The speakers feature real wood and plywood front baffles paired with satin-finished vinyl-wrapped cabinets for a blend of strength, acoustic integrity, and style.
New Robust & Stronger Outriggers
The redesigned outriggers include adjustable height for perfect leveling with minimal hassle. They feature rubber feet for hard floors and spikes for carpeted surfaces, reducing vibration and isolating the speakers from external interference to optimize audio clarity.
Bronze 300 7G
monitor-audio-bronze-7g-300-white
The Bronze 300 7G is the flagship floorstander in Monitor Audio’s Bronze Series, designed to deliver a large, detailed soundstage paired with punchy, full-bodied bass. It features a two-and-a-half-way design with a 1-inch C-CAM gold dome tweeter using the UD waveguide for cleaner highs and improved dispersion, along with dual 6-inch C-CAM drivers handling bass and midrange duties.
The cabinet uses Monitor Audio’s HiVe II port technology to optimize airflow, reducing turbulence and improving bass response. Built with robust outriggers and a plinth/spike assembly, it’s stable and suited for serious listening rooms. Available in walnut, black, or white finishes, it combines solid build quality with a versatile sound profile.
Key Specs:
  • Design: 2.5-way, ported cabinet with HiVe II port
  • Drivers: 1 x 1-inch C-CAM Gold Dome tweeter (UD waveguide), 1 x 6-inch C-CAM bass-mid driver, 1 x 6-inch C-CAM bass driver
  • Frequency response: 34 Hz – 30 kHz (-6dB in-room)
  • Sensitivity: 88 dB (2.83 Vrms @ 1m, free-field)
  • Nominal impedance: 8 Ohms (minimum 4.4 Ohms @ 38 Hz)
  • Maximum peak SPL: 118 dB
  • Power handling: 150 W continuous (CTA 426-B)
  • Recommended amp power: 40-150 W into 8 Ohms, 75-300 W into 4 Ohms
  • Crossover frequencies: 470 Hz (LF/MF), 2.6 kHz (MF/HF)
  • Dimensions (HxWxD): 1005 x 269 x 392 mm (39.5 x 10.6 x 15.7 in)
  • Weight: 15.6 kg (34 lb 6 oz) each
  • Warranty: 5 years
  • Sold as a pair
Bronze 50 7G
monitor-audio-bronze-7g-50-walnut
The Bronze 50 7G is Monitor Audio’s compact bookshelf speaker designed to deliver detailed, powerful sound without taking up much space. Its discreet size makes it perfect for smaller rooms or tighter setups, while optional ST-2 floor stands offer flexible placement options. The speaker features Monitor Audio’s latest C-CAM driver tech, including a 1-inch gold dome tweeter with UD waveguide for clear, precise highs, paired with a 6-inch bass-mid driver. The ported cabinet with HiVe II technology ensures tight and controlled bass performance.
Key Specs:
  • Design: 2-way, ported cabinet with HiVe II port
  • Frequency response: 41 Hz – 30 kHz (-6dB in-room)
  • Sensitivity: 86 dB (2.83 Vrms @ 1m, free-field)
  • Nominal impedance: 8 Ohms (minimum 4.0 Ohms @ 200 Hz)
  • Maximum peak SPL: 112 dB
  • Power handling: 100 W continuous (CTA 426-B)
  • Recommended amp power: 30-100 W into 8 Ohms, 50-200 W into 4 Ohms
  • Crossover frequency: 3.0 kHz (LF/HF)
  • Dimensions (HxWxD): 335 x 185 x 328 mm (13.3 x 7.3 x 12.9 in)
  • Weight: 6.4 kg (14 lb 2 oz) each
  • Warranty: 5 years
  • Sold as a pair
Bronze On-Wall 7G
monitor-audio-bronze-7g-on-wall-white
The Bronze On-Wall 7G is Monitor Audio’s sleek solution for home theater and stereo setups where floor or shelf space is at a premium. Designed for wall mounting, it delivers detailed, dynamic sound with minimal visual impact. Whether you’re using it as a front LCR (Left-Center-Right) setup or as surround speakers, the On-Wall 7G blends discreet design with the proven performance of the latest C-CAM driver technology. Its ported enclosure, advanced crossover, and high sensitivity make it a flexible and decor-friendly option for modern AV systems.
Key Specs:
  • Design: 2-way wall-mounted, ported
  • Frequency Response (in-room, -6dB): 42 Hz – 30 kHz
  • Nominal Impedance: 8 Ohms (min 4.7 Ohms @ 17 kHz)
  • Maximum Peak SPL: 112 dB
  • Power Handling: 100 W continuous (CTA 426-B)
  • Recommended Amp Power: 30–100 W into 8 Ohms / 50–200 W into 4 Ohms
  • Crossover Frequency: 3.0 kHz
  • Port Tuning Frequency: 47 Hz
  • Dimensions (HxWxD): 465 x 300 x 135 mm (18.3 x 11.8 x 5.3 in)
  • Weight: 7 kg (15 lb 7 oz) each
  • Finishes: Walnut, Black, White
  • Warranty: 5 years
  • Sold As: Single speaker
Bronze Centre 7G
monitor-audio-bronze-7g-centre-black
The Bronze Centre 7G pulls center channel duty with poise and precision. Compact and acoustically refined, it’s purpose-built to anchor your movie and TV dialogue with authority while blending seamlessly with the rest of the Bronze 7G lineup. Thanks to its dual 6-inch C-CAM bass-mid drivers and the signature 1-inch Gold Dome tweeter with Uniform Dispersion waveguide, this sealed speaker delivers crisp vocal clarity, impressive dynamic range, and a cohesive front soundstage without taking over your living room.
Key Specs:
  • Design: 2-way sealed enclosure
  • Drivers:
     - 1 x 25mm C-CAM Gold Dome tweeter (UD Waveguide)
     - 2 x 6″ C-CAM bass-mid drivers
  • Frequency Response (-6dB): 50 Hz – 30 kHz
  • Sensitivity: 88 dB (2.83 Vrms @ 1m, Free-Field)
  • Minimum Impedance: 4.3 Ohms @ 200 Hz
  • Max Peak SPL: 119 dB (AES75, Z-weighted)
  • Continuous Power Handling: 120 W (CTA 426-B)
     - 60–140 W into 4 Ohms
     - 30–120 W into 8 Ohms
  • Bass Alignment: Sealed
  • Crossover Frequency: 2.7 kHz
  • External Dimensions (H x W x D):
     205 x 500 x 229 mm (8¹⁄₁₆ x 19¹¹⁄₁₆ x 9″)
  • Weight: 8.1 kg (17 lb 14 oz)
  • Finishes: Walnut, black, white
  • Warranty: 5 years
  • Sold As: Single unit
Bronze AMS 7G
monitor-audio-bronze-7g-ams-white
The Bronze AMS 7G is Monitor Audio’s answer to immersive audio without drilling into your ceiling. Designed to perch perfectly atop the Bronze 50 7G or 300 7G, this compact two-way Dolby Atmos enabled speaker uses angled drivers and a sealed cabinet to deliver height effects with clarity, precision, and impact. Inside, it pairs a 4-inch C-CAM bass-mid driver with the brand’s latest 1-inch Gold Dome tweeter and UD waveguide to reproduce overhead cues with speed and spatial accuracy—without wrecking your room’s aesthetic.
Key Specs:
  • Design: 2-way Dolby Atmos enabled speaker (sealed enclosure)
  • Drivers:
     - 1 x 4″ C-CAM bass-mid driver
  • Frequency Response (-6dB): 83 Hz – 30 kHz
  • Sensitivity: 86 dB (2.83 Vrms @ 1m, Free-Field)
  • Minimum Impedance: 3.7 Ohms @ 10 kHz
  • Max Peak SPL: 110 dB (AES75, Z-weighted)
  • Continuous Power Handling: 60 W (CTA 426-B)
     - 30–120 W into 4 Ohms
     - 10–60 W into 8 Ohms
  • Crossover Frequency: 4.8 kHz
     173 x 185 x 302 mm (6¹³⁄₁₆ x 7⁵⁄₁₆ x 11⁷⁄₈”)
  • Weight (each): 3.1 kg (6 lb 13 oz)
  • Warranty: 5 years
  • Sold As: Pair
monitor-audio-bronze-7g-300-with-vestra-subwoofer
Monitor Audio Bronze 300 7G with Vestra Subwoofer
The Bottom Line
The Bronze Series 7G from Monitor Audio doesn’t just raise the bar for entry-level loudspeakers—it aims to drag it up the hill and plant a flag. With solid engineering behind its updated C-CAM drivers, refined crossover design, and thoughtfully braced cabinets, the entire lineup delivers technical performance that puts real pressure on more expensive offerings from Bowers & Wilkins, KEF, Q Acoustics, DALI, and Klipsch.
Every model—from the punchy Bronze 50 7G bookshelf to the immersive AMS 7G Atmos module—shows attention to detail that exceeds expectations at this price. Whether you’re building a stereo setup or going full home theater, the Bronze Series 7G offers exceptional value and sonic capability without the usual compromises that plague entry-tier options.
In a crowded field, Monitor Audio has quietly released one of the most complete and competitively priced speaker ranges you’ll find under $1,500.
For more information: monitoraudio.com
2 Comments
2 Comments
  1. ORT
    July 24, 2025 at 9:40 pm
    This do look nice and they remind me somewhat of Jamo Series 8 speakers which I also thing well of and I have owned some of their small footprint towers in the past.
    Affordability and high quality are exactly what’s needed to attract and keep people interested and active in home audio and video.
    ORT
  2. ORT
    July 24, 2025 at 9:42 pm
    Yes…It do look nice. LOL!! I am so bad at proofing my own thoughts. 🙂 🙂
    ORT
Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Victrola and Third Man Records Limited Edition Turntable and Speakers Victrola and Third Man Records Limited Edition Turntable and Speakers
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
2026 TCL QM8L 4K TV Lifestyle 2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
In-Wall Speakers
Large-format Monitor Audio Creator Series W1L, W2L, W3L in-wall speakers and Mount Boxes offer reference-quality sound that hides in plain sight.
We put MartinLogan's least expensive speaker to the test to see if it can capture the magic of the company's far more expensive models.
GoldenEar’s T44 hybrid floorstanding loudspeaker offers powerful sound and deep bass without the need for a subwoofer.
At $2,500/pair, the Monitor Audio Studio 89 bookshelf speaker combines inspiration from the past with flagship Hyphn technology.
Sony’s new CS Series loudspeakers deliver solid home theater and music performance without breaking the bank. Perfect for budget setups and secondary rooms.
Monitor Audio Vestra Subwoofers deliver unbeatable value and performance. With deep bass, customizable tuning, and sleek designs, the W10, W12, and W15 offer premium...
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
In-depth review compares the Q Acoustics 5050 floorstanding loudspeakers ($1,999/pair) with three different amplifiers to reveal what makes them sing.
