Lyngdorf TDAI-2210 Crashes the Network Amp Party at High End Munich 2025 — Because Everyone Needs a Streaming Amp Now, Apparently
Who needs boring amps when you can have touchscreen magic, digital guts, and enough inputs to confuse your mother-in-law? Stream, upgrade, or just flex—your call.
Lyngdorf Audio TDAI-2210 Digital Music Streamer
Network streaming amplifiers these days come in all shapes and sizes — from the sleek Naim Uniti Atom to the versatile WiiM Amp Ultra, the solid Cambridge Audio EVO 150, and even entry-level options from Topping, Bluesound, NAD, Marantz, and Denon. Into that crowded field steps Lyngdorf Audio with its latest offering: the TDAI-2210.
Sitting in the middle of their TDAI lineup, this model brings a fresh color touchscreen, Lyngdorf’s signature digital amplification, and their acclaimed RoomPerfect room calibration to the table.
Because why settle for boring when you can have fancy digital wizardry?
The TDAI-2210 is a fully integrated streaming amplifier built to handle just about any setup. It offers a range of digital inputs like USB-C and HDMI 2.1, along with analog inputs and modular upgrade options. Plus, it includes an integrated music streamer and the RoomPerfect system that tunes your room for the best sound possible. Power-wise, it pushes out a healthy 2 x 210 watts into 4 ohms, enough to drive demanding speakers without breaking a sweat.
lyngdorf-tdai-2210-front
One of the key improvements is the new color touchscreen with a smooth glass surface. It’s functional, making setup and streaming controls more straightforward. The screen is also more resistant to fingerprints and offers a clear, sharp display that’s easy on the eyes.
Under the hood, the TDAI-2210 is a 100% digital amplifier — no analog conversion until the signal hits your speakers. The volume control adjusts gain digitally in the output stage, cutting out a bunch of analog components that usually add noise, hiss, and distortion. The result? Cleaner, more accurate sound at every volume level, with none of the usual coloring or interference.
The TDAI-2210 also supports modular upgrades, such as a high-end analog module with an MM phono stage and balanced XLR inputs, or an HDMI 2.1 module with additional HDMI inputs and eARC support .
lyngdorf-tdai-2210-rear
Lyngdorf TDAI-2210 rear view (without optional modules).
The amplifier includes an integrated music streaming player compatible with Roon Ready, Spotify Connect, TIDAL Connect, Apple AirPlay 2, Google Chromecast, and DLNA/UPnP, providing versatile streaming capabilities .
Upgrades
Lyngdorf offers two optional upgrade modules for the TDAI-2210 if you want to expand its capabilities—at an extra cost, of course.
lyngdorf-tdai-2210-hdmi-module
First up, the HDMI 2.1 input/output module is perfect if you want to hook this amp into a home theater setup. It supports high-res video pass-through up to 8K at 50/60Hz and 4K at 100/120Hz, plus it handles the latest TV features like Enhanced Audio Return Channel (eARC) and CEC control. This module adds two HDMI inputs for audio up to 192kHz/24-bit, plus an HDMI in/out with eARC/ARC support. You can order it right away with a new TDAI-2210 or add it later to your existing unit.
lyngdorf-tdai-2210-analog-module
The other option is the high-end analog input module for those who want to plug in more analog sources, including a turntable. It includes four inputs: a dedicated phono input with RIAA correction for moving magnet cartridges, two unbalanced RCA inputs, and a balanced XLR input. You can boost the sensitivity on each input up to 24 dB, with the first 6 dB handled by gold-plated relays to keep the signal clean and maximize headroom before digital conversion.
Lyngdorf TDAI-2210 – Specifications
  • Description: 2-channel integrated streaming amplifier
  • Power Output:
    • 2 x 210 W @ 4Ω
    • 2 x 105 W @ 8Ω
  • Idle Power Consumption: 18–26 W
  • Standby Power Consumption: < 0.5 W
  • Maximum Output Current per Channel: 35 A
  • Audio Performance:
    • Frequency Response: ±0.5 dB from 20 – 20,000 Hz
    • Total Harmonic Distortion: 0.05% max from 20 – 20,000 Hz
    • THD-N at 1 W / 8Ω: 0.04%
    • THD-N at 1 W / 4Ω: 0.04%
    • Digital Inputs:
    • 3 x Coaxial (≤192 kHz / 24 bit)
    • 2 x Optical (≤96 kHz / 24 bit)
    • 1 x USB-C (≤192 kHz / 24 bit)
    • 1 x HDMI 2.1 (≤192 kHz / 24 bit)
  • Digital Output:
    • 1 x Coaxial (96 kHz / 24 bit)
  • Analog Inputs:
    • 2 x Single Ended RCA
    • 1 x Microphone Input (XLR) for RoomPerfect™
  • Analog Outputs:
    • 1 x Single Ended RCA
    • 1 x XLR Balanced
    • 1 x 3.5mm Headphone
  • Optional Modular Upgrades:
    • High-End Analog Module:
      • 1 x RIAA Phono MM
      • 1 x XLR Balanced
    • HDMI 2.1 Module:
      • 1 x HDMI Output
      • 2 x HDMI Inputs (PCM ≤192 kHz / 24 bit)
      • eARC/ARC
      • CEC Integration
  • Equalization:
    • RoomPerfect™
    • Voicings
    • Bass/Treble Tone Controls
  • Media Player Features:
    • Internet Radio (Airable)
    • Spotify Connect
    • TIDAL Connect
    • Roon Ready
    • Google Chromecast
    • Apple AirPlay 2
    • DLNA Support (UPnP)
    • Local File Playback (USB)
    • Bluetooth (BLE)
    • Audirvana Playback
  • Interfaces:
    • Touchscreen
    • Web Interface for Setup and Media Player
    • Remote Application for iOS and Android
    • IP Control
    • CEC (HDMI)
    • 1 x Trigger Input
    • 1 x Trigger Output
    • 1 x RJ45 Ethernet LAN
  • Remote Control: Infrared or Bluetooth
  • Included Accessories:
    • RoomPerfect™ Microphone with Stand and Cable
    • Remote Control
  • Dimensions (W x H x D): 325 x 102 x 300 mm (12.8 x 4 x 11.8 inches)
  • Weight: 4.8 kg / 10.6 lbs
  • Finish: Matte Black
  • Available Versions:
    • TDAI-2210 + High-End Analog Module
    • TDAI-2210 + HDMI 2.1 Module
The TDAI-2210 is designed and assembled in Denmark, with each unit undergoing a 24-hour testing process to ensure performance and reliability.
lyngdorf-tdai-2210-top-angle
The Bottom Line
The Lyngdorf TDAI-2210 stands out with its all-digital amplification, extensive connectivity—including USB-C, HDMI 2.1, and analog inputs—and flexible upgrade modules that make it equally at home in a high-end stereo or home theater setup. Plus, it covers all the major streaming platforms, so whether you’re spinning vinyl or streaming Qobuz, this amp handles it with precision and plenty of power.
MSRP: $4,499 (or $5,049 with Analog module, or $5,149 with HDMI module)
For more information: lyngdorf.steinwaylyngdorf.com
1 Comment
1 Comment
  1. Anton
    May 16, 2025 at 9:39 pm
    Hmmm…has almost every feature and format one could want.
    But have any of these brands heard of this crazy thing called color?
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Børresen BM2 Bass Module Front Børresen BM2 Bass Module Front
2026 Borresen A-Series Loudspeakers 2026 Borresen A-Series Loudspeakers
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
JBL's Summit Series audiophile loudspeakers, the Makalu, Pumori, and Ama, honor 80 years of acoustic precision and emotional power.
Cambridge Audio Evo 300 delivers 300Wpc, Hypex NCOREx power, StreamMagic Gen 4, HDMI eARC, MM phono, and big Evo ambition.
Marantz's Model M1 packs 100W, HEOS, HDMI eARC, and Dirac Live into a compact streaming amp for only $1,000.
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
Ruark’s R610 compact music console delivers punch and clarity, though speaker matching is crucial to unlock its full potential.
Priced at $6,500, the MOON 371 Network Player/Amplifier includes a phono stage and trickle-down technology from the North Collection.
