Fosi Audio S3 Launches Balanced Music Streamer Without Qobuz Connect or LDAC Support
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
Fosi Audio S3 Music Streamer Front Angle Silver with Orange Knob
Fosi Audio has built its reputation the hard way by delivering affordable gear that actually works as promised, earning a loyal following in the entry-level category where expectations are low and competition is relentless. Now it is stepping into a far more crowded and scrutinized arena with the S3, a $259 balanced HiFi music streamer, DAC, and preamp designed to anchor a modern two channel system.
That puts it directly in the crosshairs of established players like WiiM and Bluesound, both of which have already set a high bar for usability, ecosystem integration, and streaming performance at relatively accessible price points.
The S3’s pitch is straightforward. Combine network streaming, high resolution DAC capability, and preamp functionality into one compact and affordable component. Execution is where this category gets brutal. Fosi Audio has proven it can win on value. The question now is whether it can compete on polish, software, and long term usability where the real battles are fought.
fosi-audio-s3-front-angle
Fosi Audio S3 balanced HiFi streamer under ZA3 balanced stereo amplifier with SP601 speaker.
Streaming Platform, Architecture, and Real World System Flexibility
The Fosi Audio S3 Balanced HiFi Music Streamer is built around the Amlogic A113X streaming platform, paired with an AKM 4493SEQ DAC and OPA1612 op amps in a fully balanced circuit design. That combination forms the foundation of its digital and analog performance, aiming for a low noise signal path and consistent channel separation at a price point where that is not always guaranteed. It is a familiar architecture on paper, but one that has proven effective when properly implemented.
On the streaming side, the S3 supports dual band Wi-Fi across 2.4 GHz and 5 GHz, along with a 10/100 Ethernet port for more stable wired operation. Bluetooth 5.3 is included with SBC and AAC codec support, which covers basic wireless playback but does not target higher quality Bluetooth use cases. Streaming protocol support is broad and practical, including Spotify Connect, TIDAL Connect, AirPlay 2, Google Cast, DLNA, and Roon Ready (still awaiting certification), allowing the S3 to integrate into multiple ecosystems without forcing users into a single platform or app.
Playback capability varies depending on the input path. HDMI and optical inputs support up to 24-bit/192kHz PCM, while Wi-Fi streaming is also capped at 24-bit 192kHz. Google Cast reaches 24-bit/96kHz, AirPlay 2 is limited to 16-bit/48kHz, and Bluetooth tops out at 24-bit/48kHz. For users within the Roon ecosystem, the S3 supports up to 32-bit384kHz PCM, which represents its highest resolution playback scenario.
fosi-audio-s3-front-back-labeled
As a component, the S3 is designed to function as more than just a streamer. It can operate as a digital transport, standalone DAC, or preamp, making it suitable as the central source in a compact two channel or 2.1 system. Connectivity reflects that goal, with HDMI eARC, RCA and XLR outputs, optical input, and a dedicated subwoofer output, allowing it to integrate into both traditional HiFi systems and TV based setups without additional hardware.
Control and system management are handled through the Fosi Audio app, which manages setup, input selection, and playback, along with a built in 5-band EQ for basic tuning. A Bluetooth remote with a range of over 15 meters is also included for direct control.
Power is supplied via a 12V 1.5A external adapter, and the compact chassis measures 17.3 by 17.3 by 4.7 cm, or 6.81 by 6.81 by 1.85 inches, making it easy to integrate into space conscious desktop or rack based systems.
fosi-audio-s3-rear-angle
Fosi Audio S3 rear angle with remote control
The Bottom Line
The S3 is Fosi Audio taking a serious swing at becoming the center of an affordable modern system. At $259, what makes it stand out is the combination of balanced XLR output, HDMI eARC, subwoofer integration, and broad streaming protocol support in a single compact box. That is not common at this price, and it positions the S3 as more than just a basic streamer. It is a true digital front end for someone building a clean, minimal two channel or 2.1 setup without stacking multiple components.
What it does not offer is just as important. There is no room correction, no advanced DSP beyond a basic 5-band EQ, and Bluetooth is limited to SBC and AAC with no LDAC, aptX HD, or aptX Lossless support. Qobuz Connect is also not supported at launch. Roon Ready certification is also not available yet, which matters in this category, even if AirPlay 2 and Google Cast provide a workaround. Long term usability will also depend heavily on the stability and refinement of the Fosi control app, where competitors already have a clear edge.
This is aimed squarely at users who want a simple, affordable, and flexible streaming hub with modern connectivity, especially those building their first real Hi-Fi system or upgrading from a basic Bluetooth or single box solution. It is less compelling for experienced users who prioritize mature software ecosystems, advanced room correction, or higher end wireless codec support.
The competition is not forgiving. The S3 goes directly up against WiiM with the Pro and Pro Plus, and Bluesound with the NODE, both of which offer more established software platforms and, in some cases, features like room correction or broader ecosystem support. Fosi is betting that its hardware value and connectivity will be enough to pull buyers in. Whether that is enough will come down to execution, because in this category, good hardware is only half the story.
Where to buy: $259.99 at Fosi Audio or Amazon
LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs LAiV Crescendo Verse DAC headphone amplifier lifestyle with headphones and IEMs
2026 Samsung QN70H and QN80H Neo QLED 4K TVs 2026 Samsung QN70H and QN80H Neo QLED 4K TVs
Samsung M80H and M70H Mini-LED 4K TVs Angle Samsung M80H and M70H Mini-LED 4K TVs Angle
Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s. Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s.
Sony just launched two new soundbars, new rear speakers and three new subwoofers plus the ability to add a second powered sub to their...
Sony BRAVIA 3, Mark II Sony BRAVIA 3, Mark II
Sony is bringing its renowned XR video processor for TVs to a much more affordable price point.
Hi-Fi Components
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
Dongle DACs
Can a $149 MagSafe compatible DAC/amp deliver clean, neutral sound and fix the cable chaos of dongle DACs for iPhone users? The Fosi MD3...
Fosi Audio debuts the C3 AI Gaming Sound Card and MD3 Magnetic DAC/Amp at CanJam NYC 2026, expanding into gaming audio and portable hi-fi.
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
Can the iFi NEO Stream 3 and ZEN Stream 3 stand out in the crowded sub-$1,000 streamer market where WiiM, Bluesound, Eversolo, and Cambridge...
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
