Focal’s $69K Diva Mezza Utopia Ditches Cables and Dares Audiophiles to Let Go of Their Separates
Focal’s Diva Mezza Utopia is a $69,000 high-end wireless speaker system with Naim Class A/B amps, UWB streaming, and app control. No separates required, no cables necessary.
Focal Diva Mezza Utopia Loudspeakers
Imagine stepping off a 10-hour flight from Hell—from Europe back to New Jersey—legs numb, ears assaulted by cabin pressure and crying toddlers, still fuming about €9 croissants and the state of airport coffee, only to open your inbox and find this. Focal, clearly unfazed by tariffs or the global surge in excellent affordable hi-fi, just dropped a $69,000 wireless loudspeaker system—the Diva Mezza Utopia.
That’s right. After two weeks abroad grumbling about the need for real-world audio gear and some industry-wide austerity, I’m greeted by a press release that reads like it was ghostwritten by a caviar sommelier. Because apparently, separates are optional now… if you’ve got seventy grand and strong Wi-Fi.
The worst part? Knowing these things are probably going to be really good. Sure, I can’t yet say if they’re worth every one of those $69,000 dollars, but after spending time with the original Focal Diva Utopia, disappointment isn’t exactly on the menu. These wireless beasts won’t just play music—they’ll serve it with that signature Focal polish that makes you question every dollar you’ve spent on your “affordable” setup.
So buckle up, because the Diva Mezza Utopia isn’t just a statement piece—it’s a reminder that in this game, sometimes you pay for the name, the engineering, and the sheer audacity to say, “We don’t need separates anymore.”
Focal Diva Mezza Utopia Loudspeakers Pair
Focal Diva Mezza Utopia: High-End Wireless Speakers Redefined at $69,000
Stepping into the ultra-luxury wireless arena, the Focal Diva Mezza Utopia delivers a no-compromise listening experience built for serious audiophiles ready to ditch their racks of separates. Featuring a sophisticated 3-way acoustic design with a beryllium M-profile tweeter, ‘W’ cone mid-bass driver, and four 8” push-push woofers per speaker, this active floorstander doesn’t just play music—it unleashes it.
With 500 watts of Class A/B amplification per speakercutting-edge UWB wireless transmission, and seamless streaming via the Naim Pulse platform, the Diva Mezza Utopia blends brute power, finesse, and connectivity into a design that screams modern luxury. Whether you’re streaming over AirPlay 2, Google Cast, HDMI eARC, or optical, this is next-gen hi-fi for those ready to abandon complexity—not quality.
focal-diva-mezza-utopia-rear-angle
High-Resolution Audio & Personalized Listening
Focal isn’t the first to aim wireless products at audiophiles, but with the Diva Mezza Utopia, they’ve gone further than most. These loudspeakers use Ultra Wideband (UWB) to transmit audio between the two enclosures at 96kHz/24-bit with no compression. That means no cables between speakers, and more importantly, no drop in resolution compared to a wired setup. For those who want absolute fidelity or simply don’t trust wireless, there’s also a wired Hi-Res Link option, which pushes the internal resolution up to 192kHz/24-bit.
Focal has also introduced something called Intelligent Dynamics Clocking (IDC)—essentially a precision timing system designed to maintain tight synchronization between left and right channels. The goal is straightforward: reduce jitter, lock in imaging, and keep the soundstage stable even during dynamic swings.
Another feature worth noting is ADAPT (Adaptive Acoustic Personal Tuning). This is Focal’s room and user calibration tech, accessed through the Focal & Naim app. It’s designed to fine-tune the speakers based on your listening space and personal preferences. It’s not magic, but it’s a smart, user-friendly way to optimize playback without reaching for bass traps or manually adjusting EQ settings by ear.
focal-diva-mezza-utopia-back-angle-zoom
Stream What You Want, How You Want
Like the larger Diva Utopia, the Mezza Utopia runs on the Naim Pulse Platform, giving it access to a wide range of wireless streaming options. You’ve got Bluetooth, AirPlay 2Google Cast, and UPnP—all built-in. Streaming support covers the usual suspects: Spotify ConnectTIDAL ConnectQobuz Connect, and QQ Music for users in China.
The system can also operate as part of a multi-room setup, syncing with up to 32 Focal & Naim streaming devices. It’s compatible with smart home systems like Control4CrestronSavant, and RTI, which means integration into a high-end home system isn’t an afterthought—it’s built in. Control is simple: use the app, the included remote, or voice assistants like Google Assistant and Siri.
Whether you’re spinning vinyl, watching a film, or streaming lossless files from a server, the interface doesn’t get in the way—and that’s exactly how it should be.
Design That Serves the Performance
Focal clearly didn’t treat the Diva Mezza Utopia’s design as an afterthought. The enclosure is made from a high-density polymer, formed using a low-pressure molding process that keeps the build solid while minimizing unwanted resonance. It sits on a two-level beveled base, giving it the physical stability this kind of speaker demands.
The most noticeable visual feature is the floating side panels, a detail lifted from the full-size Diva Utopia. They’re finished in felt—a material choice that’s both functional (it helps with acoustic dampening) and more refined than it sounds. Focal has introduced a new ivory colorway, which adds contrast and gives the cabinet a cleaner profile in modern spaces.
Small design cues push this into the Utopia family: the dual red and black tweeter grille, the brushed aluminum band circling the tweeter faceplate, and what Focal refers to as the “signature watch detail.” It’s branding, sure, but it’s tasteful and well-executed.
focal-diva-mezza-utopia-angle-top-crop
DIVA Comparison
DIVA UTOPIADIVA MEZZA UTOPIA
MSRP$39,999/pair$69,000/pair
Type3-way bass-reflex active3-way bass-reflex active
Bass4 x ‘W’ 6-1/2″ (16.5cm) push-push configuration4 x ‘W’ 8” (20.5cm) push-push configuration
Midbass‘W’ 6-1/2″ (16.5cm) with TMD surround and NIC motor‘W’ 6-1/2” (16.5cm) with TMD surround and NIC motor
TweeterIAL2 15/8″ (27mm) pure beryllium ‘M’-shaped inverted domeIAL2 11/16” (27mm) pure beryllium ‘M’-shaped inverted dome
Bandwidth(+/-3dB) 27Hz-40kHz(±3dB) 27Hz-40kHz
Low-frequency cut-off (-6dB) 24Hz(-6dB) 22Hz
Maximum volume (per pair) 116dB SPL (@ 1m)120dB SPL (@ 1m)
LF Amp250W Class AB280W Class AB
MF Amp75W Class AB130W Class AB
HF Amp75W Class AB90W Class AB
Power supply 110-120V/220-240V ~50/60Hz110-120V/220-240V ~50/60Hz
Power consumption280W320W
Network standby mode<2W<2W
No-network standby mode: <0.5W<0.5W
Primary loudspeaker Inputs– HDMI eARC, CEC– HDMI eARC, CEC
– TOSLINK Optical– TOSLINK Optical
– RCA analogue– RCA analogue
– Type A USB 2.0– Type A USB 2.0
– RJ45 Ethernet– RJ45 Ethernet
– RJ45 Speaker Link
Secondary loudspeaker Input:– RJ45 Speaker Link– RJ45 Speaker Link
Internet radio formatWindows Media-formatted content, MP3, ACC, Ogg Vorbis streams and MMSStreaming containers: HLS, DASH, OGG. Codecs: MP3, AAC, Vorbis, FLAC, Icecast, Shoutcast, XPeri Extended Metadata support
Internet Radio YesYes
Audio format– WAV, FLAC and AIFF – up to 24bits/384kHz– WAV, FLAC and AIFF – up to 24bits/384kHz
– ALAC (Apple Lossless Audio Codec) – up to 24bits/384kHz– ALAC (Apple Lossless Audio Codec) – up to 24bits/384kHz
– MP3 – up to 48kHz/ 320kbits (16bits)– MP3 – up to 48kHz/ 320kbits (16bits)
– AAC – up to 48kHz/320kbits (16bits)– AAC – up to 48kHz/ 320kbits (16bits)
– OGG and AAC – up to 48kHz (16bits)– OGG and AAC – up to 48kHz (16bits)
– DSD64 and DSD128– DSD64 and DSD128
– Bluetooth® – aptX™ Adaptive, SBC, AAC– Bluetooth® – aptX™ Adaptive, SBC, AAC
– Note: handles smooth, gapless playback on all formats– Note: handles smooth, gapless playback on all formats
MultiroomSync up to 32 Focal & Naim streaming devices and control them from the Focal & Naim appSync up to 32 Focal & Naim streaming devices and control them from the Focal & Naim app
Wireless streaming feature– AirPlay 2– AirPlay
– Google Cast– Google Cast
– UPnP™– UPnP™
– Bluetooth® 5.3– Bluetooth® 5.3
– Spotify via Spotify Connect– Spotify via Spotify Connect
– TIDAL via TIDAL Connect– TIDAL via TIDAL Connect
– QQ Music via QPlay– QQ Music via QPlay
– Qobuz via Qobuz Connect
Music streaming services via the Focal & Naim app– TIDAL– TIDAL
– Qobuz– Qobuz
– QPlay
– Internet radio– Internet radio
– Podcasts depend on services available in each country– Podcasts depend on services available in each country
NetworkEthernet (1000/100/10Mbps), Wi-Fi (Wi-Fi 6)Ethernet (1000/100/10Mbps), Wi-Fi (Wi-Fi 6)
Wireless connection UWB 96kHz/24bitsUWB 96kHz/24bits
Connection with Hi-Res Link 192kHz/24bitsConnection using Hi-Res Link 192kHz/24bits
Handheld Integrated remote controlHandheld Integrated remote control
Focal & Naim control app for iOS and AndroidFocal & Naim control app for iOS and Android
Remote control ZigbeeRemote control Zigbee
Dimensions (HxLxD) 47 5/8 x 161/2×22″
(121 x 42 x 56 cm)
50 x 181/8 x 247/16”
(127 x 46 x 62cm)
Net Weight 141 lbs (64kg)192 lbs (90kg)
Weight (with packaging) 174 lbs (79kg)238 lbs (108kg)
The Bottom Line
The Focal Diva Mezza Utopia isn’t just a statement product—it’s a fully integrated, high-performance system that blends cutting-edge wireless tech with serious Class A/B amplification courtesy of Naim. The control app is well-designed, responsive, and actually useful—a rarity in high-end audio. And the physical design? Refined, architectural, and unmistakably Focal. This is not just about eliminating boxes—it’s about rethinking the entire experience of listening to high-resolution audio without compromising on performance.
Can you build a more “complete” traditional system for $69,000—one that includes a high-end CD player, a reference turntable, and top-tier electronics and speakers? Absolutely. And it would probably offer more flexibility and source variety. But the person considering the Diva Mezza Utopia isn’t looking to fill a rack or rotate cartridges. They want a two-box, plug-and-play solution that just works—without giving up audiophile performance or aesthetic gravitas.
Focal isn’t the only brand chasing this hybrid space either. DynaudioSonus faber, DALICabasse, and others have launched high-end wireless speaker systems that combine amplification, streaming, and connectivity into elegant enclosures—often at lower price points, and often with similar features. But not always with the same driver pedigree or the Class A/B power that Naim brings to the table here.
The Diva Mezza Utopia isn’t for the average audiophile. It’s for the enthusiast who values effortless performancearchitectural simplicity, and a rack-free lifestyle—all without surrendering the core values of serious hi-fi.
For more information: focal.com
1 Comment
1 Comment
  1. FunnyChap
    August 26, 2025 at 5:15 pm
    Very nice speakers….they would be my dream speakers.
    I currently have a $20k stereo system using an R2R DAC and DDC.
    When my $300 Denon HEOS powered speakers needed repair, it costs more to fix and ship back and forth, so I tossed it in the trash.
    So now I come close to active speaker by buying a PS AUDIO FR5 speaker that can be bi-amped so I power it with NAD C298 (for tweeters) and PS AUDIO S300 dual mono amp (for mids).
    My Parasound 2100 preamp takes care of active crossover highpass and lowpass (to the 2 powered sealed subwoofers).
    source=Apple Music lossless
    My video:
    https://youtu.be/IwdzDbRUs_0
ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path finally a DAC...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Clarus Concerto MKII Power Conditioner Angle Clarus Concerto MKII Power Conditioner Angle
Clarus Concerto MKII targets noise and power stability for high-end systems, but at $12,000 it raises the question: who really needs it?
SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle
Can the SVS 3000 Micro R|Evolution deliver deep bass from dual 9-inch drivers, 1,200 watts power, and advanced DSP without taking over your room?
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
Capital Audiofest 2025 wrapped the hi-fi show season with standout systems, strong crowds, and big sound. Here's what impressed us!
Exclusive Videos
In this episode of eCoustically Speaking, find out the differences between passive, powered, and active loudspeakers.
At Audio Advice Live 2025, hear Focal's $150K+ home theater, $69K wireless speakers and its full line of headphones. Prepare to drool.
2025 “innovation”? Forget tech — it’s pastel colors and retro vibes. Why? Because Hi-Fi might finally be getting smart about style, and appealing to...
This convergence of Danish Hi-Fi and some of the finest Italian stone or petrified wood will not be cheap. And that was before the...
An immersive and dynamic listening experience, with a bold omni-directional design that creates a spacious, all-encompassing soundstage.
McIntosh is offering limited edition versions of its RS150 and RS250 Wireless Speakers with Grateful Dead branding for a premium price.
