ELAC NAVA100 Marks Their First Portable Bluetooth Speaker: About Time They Joined the Party
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few missing features.
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC finally plugged the one glaring hole in its lineup: a true portable Bluetooth speaker. The new NAVA100 isn’t just a cash-grab to chase the beach-party crowd — it’s built on a century of ELAC engineering and tuned like a real loudspeaker, not a plastic noisemaker. Drawing on the brand’s maritime roots in Kiel, the “NAVA” name leans into motion and exploration, positioning the NAVA100 as a compact traveler that carries your music with the same confidence ELAC brings to its floorstanders and subwoofers.
From Joe Riggi, President of ELAC Americas Inc, “The NAVA100 embodies ELAC’s heritage while answering the way people listen today—portable, powerful, and beautifully designed… It’s more than just a speakerit’s Music in Motion.”
On the Outside: ELAC’s First Portable Bluetooth Speaker Gets the Premium Treatment
elac-nava100-black-white-outdoors
The NAVA100 doesn’t fake it — the exterior is pressed aluminum from the top and bottom plates to the grille, controls, and rear panel. It feels like real metal because it is real metal, and the whole thing has that “go ahead, toss me in a bag” solidity ELAC’s known for.
ELAC also tapped New York label Adsum for a limited Adsum × ELAC Cream Edition, wrapping the NAVA100 in a soft cream finish that looks more boutique than beach toy. If you prefer something classic, the standard Black version keeps it simple. Up top, the controls sit in a clean linear layout framed by gold trim on the Black model or black trim on the Cream edition — a small detail, but exactly the kind of design touch that separates this from the usual plastic Bluetooth suspects.
To keep things genuinely portable, the NAVA100 comes in at a compact 5.9 x 3.07 x 5.04 inches and weighs just 3 lbs 1 oz — small enough to toss in a backpack, heavy enough to feel like an actual piece of audio gear, not a disposable toy.
elac-nava100-white-adsum
What’s on the Inside: ELAC Packs Real Speaker Tech into a Portable Frame
Inside that metal shell, ELAC kept things practical and focused on delivering real sound, not gimmicks. A 3-inch full-range driver does the heavy lifting, backed by two passive radiators that give the NAVA100 far more bass presence than its size suggests — the kind of low-end you expect from a brand that actually knows how to design speakers.
The internal platform is equally serious: high-quality 24-bit DAC/ADC stages, ELAC’s own DSP tuning, and a dedicated amplifier stage to keep playback consistent no matter the source. It’s a mono speaker by design, but ELAC built in a Dual Play mode so you can pair two NAVA100 units for full stereo spread when you want something bigger.
Battery performance is solid for its class: up to 15 hours of playtime at 25% volume and around 6 hours when you’re pushing it at max. When it’s time to top up, USB-C Fast Charging gets you back to full in about two hours with a 1.5A charger.
elac-nava100-diagram-design-sketch
ELAC NAVA100 Specifications
ELAC Model NAVA100
Predict Type Portable Bluetooth Speaker
Price$229
Driver Setup 1 × 3” full-range driver + 2 × passive radiators
InputsBluetooth 5.3
USB-C charging
Bluetooth Codec SupportSBC
Bluetooth ProfilesA2DP (Stereo audio streaming)
AVRCP (Playback & volume control)
Dual PlayPair Two Nava 100 speakers for Stereo Playback
Battery7.4V, dual 18650 cells (5000 mAh total)
Battery Life 15 hrs (25% volume)
6 hrs (100% volume)
USB-C Charging TimeStandard Charging 4 to 5 Hours
Fast Charging 2 Hours @ 1.5A
Amplifier Power 10-watts RMS
Max SPL 95 dB @ 1m
Frequency Response 55 Hz – 19.6 kHz (-10 dB)
SNR (Signal To Noise Ratio)82dB
THD (Total Harmonic Distortion<1%
ControlsBT/Play/Vol-/Vol+/Power
IPX RatingIPX4
Dimensions (LWH) 150 × 78 × 128 mm
Weight 1.4 Kg / 3lbs 1oz
Colors Black, Adsum Cream (aka White)
Package ContentsELAC NAVA100
USB-C Charging Cable
Quick Install Guide
elac-nava100-white-rear-usbc
elac-nava100-white-black-top-buttons
The Bottom Line
The ELAC NAVA100 is a confident first step into the portable Bluetooth arena — a classy build, real speaker engineering inside, and tuning that clearly comes from a company with actual audio DNA. But it’s not flawless. The lack of AAC, aptX, LC3, or Auracast is a miss in 2025, and leaving out a 3.5mm input and any kind of carry handle feels like ELAC forgot a couple of the basics that matter on the go.
And make no mistake, this space is no gentle playground. ELAC is walking into a knife fight with brands already owning mindshare at multiple price points — DALI with its rugged KATCH lineage, Bang & Olufsen and KEF with their style-first high-design portables, Brane X rewriting what DSP and deep bass can do in a small box, and Devialet still flexing with its bass-grenade lifestyle offerings. The NAVA100 will need its build quality and sonic chops to make an impression, but it’s a promising start for a company finally deciding it wants to play outside.
elac-nava100-white-black-by-lake
Price & Availability
The ELAC NAVA100 is available with an MSRP of $229 at Crutchfield and other authorized ELAC dealers.
1 Comment
1 Comment
  1. Val
    December 12, 2025 at 3:33 pm
    Wow, great and informative article!
    Can’t wait to try this speaker out 🙂
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
KEF Muo ($249.99) arrives Sept 23 for myKEF, full launch Sept 30—Bluetooth 5.4, aptX Adaptive, IP67, 24hr battery, and P-Flex racetrack driver.
Ikarao's Shell S1, Break X1, and Break X2 combine wireless and wired music streaming with touchscreens, light effects, and karaoke features for the ultimate...
Rugged, floating Bluetooth speaker built to survive saltwater, drops, and your worst outdoor mishaps. Expect serious bass, 16-hour playtime, and an emergency alarm that...
ELAC Concentro M 807: Looks like a spaceship, sounds like a weapon. High-end tech and bold design collide at High End Munich 2025. Ready...
ELAC Muro outdoor speakers are built for your chalet or beer garden because ugly rock speakers are so 2015. IP66-rated, port optional, and priced...
The $349 Beosound A1 3rd Gen adds sound upgrades, fresh colors, and the same IP67 waterproof build—still one of the most stylish portable Bluetooth...
