ELAC Drops the Bass (and the Budget): 3 New Debut 3.0 Series Subwoofers That Won’t Wreck Your Wallet
ELAC’s entry-level 10″, 12″, and 15″ sealed subwoofers are priced from $479 to $949 to complement Debut 3.0 series loudspeakers.
Debut 3.0 10-inch DS103-BK, 12-inch DS123-BK, 15-inch DS153-BK Subwoofers
ELAC has landed at High End Munich 2025 with a suitcase full of new gear (see our companion articles if you’re into spoilers), including the new Debut 3.0 Series Subwoofers. Available in 10”, 12”, and 15” flavors, these subs are built with custom drivers, efficient amps, and cabinets that actually look like someone cared about your living room. It’s bass without the bulk—or the visual regret.
With the launch of the budget-priced ELAC Debut 3.0 series loudspeakers ($400-$1,300) last year, consumers can now add matching subwoofers to complete an all-ELAC home theater speaker system for much less than one might expect.
Features
Sealed Cabinet Design: The sealed enclosure design of the Debut 3.0 subwoofers keeps distortion in check and delivers quick, clean bass. The result? Tight, articulate low-end that plays nice with the rest of your system instead of stomping all over it.
Custom Drivers: The Debut 3.0 Subwoofers use custom drivers built for deep, dynamic bass without the mud. Designed for high excursion, these drivers stay composed even when pushed hard. The rigid, lightweight polypropylene cones feature a textured surface for extra stiffness, keeping things tight and clear when the volume knob climbs north.
Class D Amplification: The Debut 3.0 Subwoofers use Class D amps that dish out plenty of clean power without breaking a sweat. They run cool, stay efficient, and don’t flinch when you crank the volume—just the way a good sub amp should.
elac-ds123-rear
High Level In/Out: The Debut 3.0 subs are built to play nice with just about anything. With high-level inputs and outputs, they slot into AV receivers, stereo amps, or whatever else you’ve got without a fuss—making setup easy and performance rock solid no matter the system.
Auto On/Off:  The auto signal detection feature powers the subwoofer on when it detects an audio signal and switches it off when idle for a period of time. The is a great energy-saving tool that does not need manual intervention unless you want to turn this feature off.
Easy Speaker System Integration: The Debut 3.0 subs will get along with any speaker setup, but they’re built to lock in perfectly with ELAC’s own Debut 3.0 Series. With 10″, 12″, and 15″ options, there’s a size that’ll fit your room—and your bass cravings—just right.
Debut 3.0 Subwoofer Example Exploded
Specifications
DS103-BKDS123-BKDS153-BK
Product TypePowered SubwooferPowered SubwooferPowered Subwoofer
Price$479$599$949
Cabinet DesignSealedSealedSealed
Woofer Driver10“ Polypropylene cone with textured surface 12“ Polypropylene cone with textured surface15“ Polypropylene cone with textured surface
Low Frequency Extension31 Hz @ 3dB
29 Hz @ 6dB
28 Hz @ 3dB
26 Hz @ 6dB
31 Hz @ 3dB
29 Hz @ 6dB
Crossover Frequency (Variable)50 to 150 Hz50 to 150 Hz50 to 150 Hz
Amplifier TypeClass DClass DClass D
Maximum amplifier power (RMS/Peak)100 / 200 W200 / 400 W300 / 600 W
Standby Power Consumption< 0.5 W< 0.5 W< 0.5 W
InputsLFE, Line-in Stereo, High LevelLFE, Line-in Stereo, High LevelLFE, Line-in Stereo, High Level
OutputsHigh LevelHigh LevelHigh Level
ControlsVolume
Crossover Frequency
Phase
Auto on/off
Volume
Crossover Frequency
Phase
Auto on/off
Volume
Crossover Frequency
Phase
Auto on/off
Cabinet Finish OptionsBlack Ash Vinyl
Satin Black Vinyl
Black Ash Vinyl
Satin Black Vinyl
Black Ash Vinyl
Satin Black Vinyl
Dimensions
(WxDxH)
12.2  x 12.9 x 12.2 in
310 x 328 x 310 mm
14.17 x 14.8 x 14.17 in
360 x  378 x  360 mm
18.4 x  19.1 x 18.4 in
468 x 486 x 468 mm
Net Weight22.7 lbs
10.3 kg
30.20 lbs
13.7 kg
55.34 lbs
25.1 kg
The Bottom Line
ELAC’s Debut 3.0 Subwoofers check all the right boxes—sealed enclosures for tight, musical bass, efficient Class D amps, and high-excursion drivers that don’t flinch under pressure. Available in 10″, 12″, and 15″ sizes, there’s a model to fit your room and your system. Whether you’re building around the Debut 3.0 Series or mixing brands, these subs bring serious low-end without wrecking your budget.
elac-ds153
ELAC Debut 3.0 DS153-BK 15-inch Subwoofer
Price & Availability
All ELAC Debut 3.0 subwoofers are expected to be available at Crutchfield and authorized dealers by June 2025.
  • ELAC 10-inch DS103-BK is priced at $479
  • ELAC 12-inch DS123-BK is priced at $599
  • ELAC 15-inch DS153-BK is priced at $949
For more information: elac.com
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
WiiM Amp Ultra merges the brains of the Ultra and the brawn of the Amp Pro—now with a touchscreen and HDMI ARC for your...
Estelon unveils the AURELLE stand-mount and Centre speaker, and AURUS subwoofer at High End Munich 2025, celebrating its 15th anniversary. Prices start at €7,500...
Qobuz Connect launches this week, bringing seamless high-res audio streaming to HEOS and a wide range of devices, outshining TIDAL with smoother integration.
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Cyrus ditches half-width tradition with the bold new 80 Series, teased at High End Munich 2025—just don’t expect specs. In true industry fashion, it’s...
Raidho's TD-8 and TD-10 subwoofers deliver cutting-edge bass tech and luxury craftsmanship for those that don't want big black boxes.
Raidho TD3.10: Danish engineering at its most audacious, packing industry-leading 10" diamond-coated woofers and featherweight planar ribbon tweeters into a €120K+ package. For those...
