Edifier Expands Wireless Speaker Lineup with M90 at CES 2026, Featuring Bluetooth 6.0, LDAC and HDMI eARC
Edifier’s M90 is a “cross-scenario, multi-purpose” active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and Bluetooth listening environments.
Edifier M90 Wireless Speakers Lifestyle Gaming in White
This story was sponsored by Edifier.
Edifier came to CES with a message that’s refreshingly practical and very on-brand: “Cross-Scenario Audio Solutions for Modern Home Entertainment.” Translation—stop thinking in silos. Desktops, living rooms, hybrid workspaces, secondary systems, and everything in between are no longer separate audio problems. Edifier’s latest lineup is built to move fluidly across all of them, with products designed to connect, adapt, and scale without forcing users to rethink their entire setup every time they change rooms—or screens.
That positioning matters in a brutally crowded wireless speaker market where dozens of companies are battling for the same shelf space and streaming subscriptions. Louder specs and trendy finishes aren’t enough anymore. What Edifier is showing at CES leans hard into real-world use: flexible connectivity, modern streaming support, compact form factors that don’t scream “tech appliance,” and systems that make sense whether they’re parked next to a monitor, under a TV, or pulling double duty in a shared space.
edifier-booth-ces-2026
Edifier booth at CES 2026
Edifier didn’t get here by accident. Over the past few years, the brand has quietly—and sometimes very loudly—built momentum by pairing solid industrial design with features people actually use, and sound quality that usually costs more than the asking price. While plenty of competitors chase lifestyle cred or audiophile buzzwords, Edifier’s CES lineup sticks to a clearer idea: audio that works everywhere you live, work, and listen.
edifier-logo
With that broader strategy in place, Edifier has been methodically expanding its wireless speaker lineup without asking buyers to take out a second mortgage on their listening rooms. Sensible pricing, features that translate to real use cases, and performance that actually holds up have given the brand legitimate traction in a market that punishes half-baked ideas. In 2025, that approach showed up clearly in coverage of the MR5 and S880DB MKII—both sub-$400 designs aimed at listeners who want flexibility without cutting corners. The newly introduced M90 doesn’t replace either model; it widens the net, giving buyers another option that fits neatly into Edifier’s growing ecosystem rather than forcing a reset.
edifier-m90-desktop-lifestyle-white
Edifier M90 active desktop speakers in white
Building on the momentum of the M60 ($199 at Amazon) released in 2024, Edifier’s new M90 active speaker is designed to feel equally comfortable on a desk or in a home entertainment setup. The goal with the M90 is straightforward: bridge the gap between desktop audio, TVs, streaming platforms, and gaming consoles without forcing users to juggle multiple systems or compromises.
Ease of use is clearly part of the brief. The M90 offers onboard controls for quick adjustments, an omnidirectional remote for couch-friendly operation, and support for the Edifier ConneX mobile app on iOS and Android—covering everything from basic control to setup without turning the experience into a troubleshooting exercise.
edifier-m90-pair-white
Edifier M90
The Edifier M90 uses a two-way driver configuration built around a 4-inch long-throw mid-bass driver paired with a 1-inch silk-dome tweeter. Power is rated at 100 watts RMS, with maximum output reaching up to 100 dB SPL, putting it comfortably into small-room and near-field territory without pretending to be something it isn’t.
The system is bi-amped, allowing each driver to be controlled independently, and supports 24-bit/96kHz audio resolution depending on the source. In practical terms, that means cleaner signal handling and better control over dynamics—assuming you feed it something better than a heavily compressed stream.
edifier-m90-pair-white-rear
Edifier M90 (rear)
DSP plays a central role in shaping the M90’s sound, optimizing performance across different types of content from music and video to gaming. On the rear, connectivity is refreshingly broad, with Line-in, Optical, USB-C, and HDMI eARC on tap, covering most modern use cases.
Wireless duties are handled by Bluetooth 6.0, with support for LDAC and multipoint, allowing higher-quality wireless playback and seamless switching between devices. In a market where wireless convenience often comes at the expense of fidelity, Edifier is clearly trying to keep both camps reasonably happy.
The M90 may be the headline act, but it isn’t a one-off. At CES 2026, Edifier is showing how the rest of its lineup supports the same “cross-scenario” idea from different angles: the MR3 and MR5 focus on compact, DSP-managed monitoring for desktop and home-studio setups, while the QR65 targets modern gaming and creator desks with a hi-fi-forward design and a more restrained approach to ambient lighting.
Near-Field Monitor Series: Built for Modern Workflows
Edifier MR5 Studio Monitors White Desktop Front
Edifier’s MR Series remains the backbone of its desktop and home-studio strategy. Designed for compact spaces and hybrid workflows, these near-field monitors prioritize accuracy and consistency over flash. The MR3 ($149.99 at Amazon) targets space-constrained desktop setups, while the three-way MR5 adds a built-in woofer and side-mounted acoustic lens to deliver deeper bass from a relatively small enclosure. Across the series, Edifier relies on end-to-end DSP, bi-amp or tri-amp amplification, tonal tuning, and room/placement compensation, paired with wide off-axis response for usable listening beyond the traditional sweet spot. Both the MR3 and MR5 earned Japan’s VGP 2025 Design Award—a nod to execution, not marketing noise.
QR Series: Gaming Aesthetics, Hi-Fi Intent
edifier-qr65-desktop-speakers-ces-2026
Edifier QR65
The QR Series reflects how gaming desks have evolved into multi-purpose hubs for streaming, content creation, and remote work. Rather than leaning into aggressive RGB, the QR65 ($499 at Amazon) and QR30 ($169 at Amazon) take a restrained approach. Their Infinity Mirror design produces subtle ambient lighting that adds depth without overwhelming a clean setup. Under the hood, these are firmly hi-fi designs. The QR65 uses a two-way configuration with a long-throw mid-low driver and silk-dome tweeter, delivers 70W RMS via bi-amped DSP, and employs a precision maze-type bass-reflex port for controlled low-end response. A built-in GaN fast charger adds practical value, simplifying power delivery and cable management on crowded desks.
Edifier M90 vs. M60 Comparison
edifier-m90-m60-speakers
Edifier Model M90 (2026)M60 2.0 (2024)
Product TypeWireless Desktop SpeakerWireless Desktop Speaker
Price$369.99$199.99
Toal Output Power (RMS)100 watts66 watts
Biamplification (RMS)Tweeters: 15W x 2
Mid-low: 35W x 2
Tweeters: 15W x 2
Mid-low: 18W x 2
Tweeters1” Silk Dome1” Silk Dome
Woofers4” long-throw aluminum diaphragm3″ long-throw aluminum diaphragm
Frequency Response50 Hz – 40 kHz58 Hz – 40 kHz
Signal-to-Noise Ratio≥ 85dB(A)≥ 85dB(A)
Input SensitivityAUX: 450 ± 50mV
USB-C: 500 ± 50mFFS
Bluetooth: 500 ± 50mFFS
HDMI eARC: 500 ± 50mV (PCM Stereo)
Optical: 500 ± 50mFFS
AUX: 500 ± 50mV
USB-C: 450 ± 50mFFS
Bluetooth: 450 ± 50mFFS
Audio InputsBluetooth
AUX (3.5mm)
USB-C
HDMI eARC
Optical
Bluetooth
AUX (3.5mm)
USB-C
Bluetooth Version6.05.3
Bluetooth Codec SupportSBC, LDACSBC, LDAC
Mobile AppEdifier ConneX AppEdifier ConneX App
High Res Audio Certified Hi-Res Audio and Hi-Res Audio Wireless AudioHi-Res Audio and Hi-Res Audio Wireless Audio
Subwoofer OutputYes
Bluetooth Multi-Point ConnectionYes
ControlsPower Knob
Volume +/-
Source Switch
Remote Control
Touch panel
Volume +/-
Power / Source switch
Enclosure Construction Material MDFMDF
Dimension
(WxHxD)
Right Speaker
133 x 212 x 225 mm
(5.2 x 8.4 x 8.9 inches)
Left Speaker
133 x 212 x 210 mm
(5.2 x 8.4 x 8.3 inches)
Each Speaker
100 x 168 x 147 mm
(4 x 6.6 x 6.8 inches)
Weight 6.05 kg3.07 kg
edifier-m90-lifestyle-tv-black
Edifier M90 active speakers for use with a TV.
The Bottom Line
Edifier arrived in Las Vegas with a clear message: this is no longer a brand content to sit on the sidelines of the wireless speaker market. Alongside the debut of the M90 active speakers, Edifier is also showing established models from its MR and QR series, reinforcing just how deep—and deliberate—its current lineup has become across desktop, lifestyle, and home entertainment categories.
The M90 sits at the center of Edifier’s CES strategy, and the positioning is clear: one active speaker designed to work across multiple scenarios without forcing compromises. Described by Edifier as a “cross-scenario, multi-purpose” system, the M90 is intended to cover TV and home-entertainment duties just as comfortably as PC, desktop, and casual Bluetooth listening.
Built on the foundation of the M60, the M90 pushes further into gaming and living-room use. It delivers higher output from a slightly larger enclosure, adds Bluetooth 6.0 with LDAC and multipoint support, and expands physical connectivity with HDMI-eARC and a dedicated subwoofer output. The inclusion of a remote reinforces the shift away from strictly near-field use, signaling a system designed to operate just as easily from across the room as it does next to a keyboard.
In the context of Edifier’s broader CES showing, the M90 feels like a smart and calculated move. It strengthens the company’s push into living-room audio and gaming without abandoning its desktop roots.
edifier-m90-pair-black
Price & Availability
The Edifier M90 will be available for $369 at Amazon.com in early March, 2026.
For more information, visit edifier.com.
4 Comments
4 Comments
  1. Anton
    January 8, 2026 at 6:02 pm
    Is this the company that bought and saved STAX?
    These look like a great deal at the price.
    How do they include all of the connectivity options and support the hi-res Bluetooth codecs (licensing fees) at that price?
  2. Anthony Ferretto
    January 12, 2026 at 8:40 am
    None of the official product pages or CES 2026 announcements list a subwoofer output, and the published rear‑panel photos show no sub‑out jack. What makes you suggest they have sub out?
    • Brian Mitchell
      January 12, 2026 at 9:11 am
      The rear photo of the M90 above does show a “SUB OUT” port, and we heard them at CES last week connected to a subwoofer.
    • Ian White
      January 12, 2026 at 12:23 pm
      Anthony,
      Look above the “speaker out” on the primary speaker. There are the certification logos and above that is the “Sub Out.”
      IW
LG announces pricing and availability for its 2026 OLED evo G6 and C6 TVs, featuring brighter panels, new processing, and enhanced gaming performance.
Exclusive Videos
Spotify and Liquid Death launch the Eternal Playlist Urn and generator so your music lives on after you’re gone. Limited to...5 per customer.
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Kii Audio SEVEN wireless speakers add a third color, Qobuz Connect, Spotify Lossless support, and more with free software update.
Exclusive Videos
Find out what the Focal Mu-so Hekla all-in-one speaker can actually do, and why the company doesn't want to call it a soundbar.
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
