DALI V-16 F Subwoofer Debuts at High End Munich 2025: Danish Thunder That Doesn’t Ask for Permission
DALI’s flagship 16-inch subwoofer is a 1500-watt beast built to match its KORE and EPIKORE speakers, offering low distortion extension down to 18Hz.
Deep bass doesn’t just add weight to movies and music—it defines the space, pacing, and realism of what you hear. But clean, well-integrated low-end is hard to do right. That’s where the new DALI V-16 F steps in. Built to support the company’s flagship KORE and EPIKORE loudspeakers, this is DALI’s most advanced subwoofer to date—designed not just to go low, but to stay articulate and in control while doing it.
The uber high-end subwoofer market has seen significant growth, with manufacturers like McIntosh, SVS, and Grimani Systems pushing the boundaries of bass reproduction. The McIntosh PS1K, for instance, is a true powerhouse with 2000 watts of continuous power and an unmatched ability to deliver deep, controlled bass, appealing to audiophiles and home theater enthusiasts alike.
Similarly, SVS’s 5000 R|Evolution series has revolutionized performance with its advanced technology and fine-tuned engineering, bringing extreme low-frequency precision to large spaces. Not to be outdone, Grimani Systems’ IS-21 Infrasonic subwoofer offers an ultra-low-frequency response that’s designed to deliver immersive cinema-grade bass in even the most demanding environments.
DALI V-16 F Subwoofer Details
dali-v-16-f-subwoofer-parts-exploded
At its core is a 16-inch driver with a massive ±16 mm linear travel, housed in a 90-liter cabinet and backed by 1500 watts of Class D power (2500 W peak). DALI’s design focus was low distortion, low group delay, and bandwidth that extends cleanly down to 19 Hz in-room.
Four flare-tuned reflex ports and a broad suite of DSP tools (including Room Mode Attenuation and Constant Group Delay) make it adaptable to both large listening rooms and tighter home theater setups.
The V-16 F plays clean, fast, and deep without stepping on the midrange or losing pitch definition. Whether you’re matching it with a pair of EPIKORE 11s in a reference stereo system or dropping it into a multichannel setup with the full KORE treatment, the sub keeps up—without drawing attention to itself or bloating the presentation.
As DALI puts it, they built the V-16 F because serious low-end deserves the same engineering attention as the rest of the system. No gimmicks, no fluff—just the company’s best thinking on subwoofer design, delivered in one understated and brutally capable box.
dali-v-16-f-subwoofer-css-technology
Constant Surface Surround (CSS Technology) claims to be better at absorbing diaphragm resonances, resulting in less reflections and resonances on the driver
surface, and thereby lower distortion overall.
Specifications
  • Driver: 16″ (406mm) with Constant Surface Surround (±16mm linear, 70mm peak-to-peak excursion)
  • Amplifier: 1500W Class D (2500W peak)
  • Frequency Response: In-room down to -3dB @ 19Hz
  • Ports: 4x flare-tuned reflex ports (tuned to 18Hz)
  • Design Focus: Wideband, low-loss, low distortion, non-resonant roll-off
  • Latency: Ultra-low signal latency
  • DSP Modes:
    • Room Mode Attenuation
    • Leader/Follower
    • Constant Group Delay
  • Cabinet Volume: 90 liters
  • Weight: 53.15 kg / 117.18 lbs
DALI Adds New High-Gloss Finishes to KORE and EPIKORE Loudspeakers
Alongside the debut of the V-16 F flagship subwoofer at High End Munich 2025, DALI is expanding the aesthetic appeal of its top-tier loudspeakers. The KORE now comes in a range of seven new high-gloss finishes—Velvet Red, Navy Blue, Steel Grey, Racing Green, White, Black, and a second edition of Amara Ebony.
These are available to order starting May 15th. Meanwhile, the EPIKORE range gets a crisp new look with an all-white edition across the lineup, arriving in November. Danish performance, now dressed to impress.
dali-v-16-f-subwoofer-angle
The Bottom Line
High End Munich 2025 might go down as the “Pantone Edition” of audio shows, with brands like DALI and Focal treating loudspeakers like luxury handbags—new finishes, same sonic muscle. But amidst the color parade, DALI’s V-16 F subwoofer is the real heavyweight. With 1500 watts of Class-D power and a 16-inch driver built for controlled fury, it’s designed to anchor flagship systems like KORE and EPIKORE with precision and authority. While everyone else is chasing paint samples, DALI quietly dropped a bass cannon.
For more information: dali-speakers.com
MSRP: £4499 / €4999 (U.S. price forthcoming) with availability expected July 2025.
HiBy W4 Portable HiFi Bluetooth Headphone Amplifier
HiBy W4 packs aptX Lossless, LDAC, 475mW balanced output, and a touchscreen into a $99 portable Bluetooth DAC Amplifier.
Pro-Ject Debut Reference 10 Turntable Lid Open Pro-Ject Debut Reference 10 Turntable Lid Open
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Sennheiser CX 80U Wired Earbuds and HD 400U Headphones Sennheiser CX 80U Wired Earbuds and HD 400U Headphones
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Creek Audio Cymatics 6 Stand-mount Speaker Front Creek Audio Cymatics 6 Stand-mount Speaker Front
Can Creek Audio stand out in 2026 as it enters the crowded speaker market and rethinks its amplifier strategy?
ProAc Response DB1R Stand-mount Loudspeakers ProAc Response DB1R Stand-mount Loudspeakers
Can ProAc’s compact Response DB1R with ribbon tweeter deliver true high end performance in a standmount likely priced around $5,000 per pair?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Which compact speaker sounds best on a desk? DALI, Q Acoustics, and Acoustic Energy go head-to-head.
At $2,749, can PS Audio’s Foundry F12 justify its price against SVS, REL, and MartinLogan by delivering cleaner, more controlled bass where it actually...
Just days after CES 2026, SVS’s 3000 R|Evolution subwoofers are now available—but do they raise the bar for output and control?
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Are the DALI KUPID just flash and color for $600—or something more?
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
From budget-friendly upgrades to room-shaking reference bass, these subwoofer picks deliver accurate low-end performance, smart features, and real value at every price tier.
