Coastal Source 1000 Series Bollards Bring Ribbon Tweeters Outdoors, Because Why Not
Coastal Source 1000 Series Bollards bring ribbon tweeters, modular configurations, and serious all-weather sound to luxury outdoor installations.
2026 Coast Source 1000 Series Bollard Outdoor Speaker
The custom-installation category has grown far beyond hidden televisions, rack-mounted amplification, and living rooms that cost more than a decent first home. As more affluent buyers relocate to warmer Southern markets where patios, pools, covered kitchens, and outdoor entertaining spaces are usable for most of the year, high-end outdoor audio has become a meaningful part of the residential installation conversation.
Coastal Source is clearly betting on that opportunity with its new 1000 Series Bollard speakers. Building on the company’s established 10.0 Bollard platform, the new modular range promises higher output, deeper bass, improved fidelity, and the kind of environmental durability required when Mother Nature, landscapers, and the occasional poorly aimed golf ball all have a vote.
The 1000 Series represents a major milestone for Coastal Source and for outdoor audio as a category,” said Franco D’Ascanio, CEO of Coastal Source. “We challenged ourselves to create a system that delivers the emotional impact, clarity, and dynamic range people expect from premium indoor listening environments while maintaining the durability required for the outdoors. The result is a platform that elevates every outdoor entertainment experience.”
coastal-source-eb1150-ellipse
EB1150 Ellipse
Borrowing technology from Coastal Source’s flagship 12.0 Line Source Bollard, the 1000 Series uses weatherized ribbon tweeters engineered for the realities of outdoor listening. Their wide horizontal dispersion should help cover larger seating and entertaining areas more evenly, while the design aims to preserve the detail and dynamic range that conventional landscape speakers often trade away in the name of durability.
Those tweeters are paired with an acoustic-suspension enclosure and force-canceling bass technology intended to deliver more controlled low-frequency output, clearer vocals, and greater overall musical coherence. In other words, this is not another pair of speakers meant to disappear behind the hydrangeas and politely mumble during a barbecue.
coastal-source-b1100
B1100
The 1000 Series is built around sealed elliptical enclosures made from Coastal Source’s color-through rotomolded composite material. Beyond avoiding the usual painted-metal aging process, the construction is designed to withstand moisture, UV exposure, heat, cold, and corrosion; important considerations in coastal markets where salt air has a rather efficient way of ruining expensive things.
Flexibility is another major part of the platform. Coastal Source offers six optional modules and multiple installation approaches, including landscape, hardscape, and partially buried applications, allowing installers to shape both the coverage and visual impact of a system around the property rather than forcing every project into the same planter-bed formula.
The speakers also integrate with Coastal Source’s Plug+Play ecosystem and Uni-Connect cabling, which should simplify installation, future expansion, and serviceability. For integrators building larger outdoor systems, that modular approach matters almost as much as the speaker itself, because the last thing anyone wants is to excavate half a patio just to add another zone.
Every aspect of the 1000 Series was engineered to push the boundaries of what’s possible outdoors,” added D’Ascanio. “From its acoustic performance and modular architecture to its environmental resilience, this platform reflects fifteen years of innovation and real-world experience designing products that truly Defy the Elements.”
Coastal Source Series 1000 Comparison
Coastal Source 1000 Series Bollard Speakers - EB2650 - B2600 - EB1250 - B1100 - EB1150 - B1500 Sub
Coastal Source ModelEB2650 EllipseB2600EB1250 EllipseB1100EB1150 EllipseB1500
Product Type 3-Way Bollard Speaker3-Way Bollard Speaker2-Way Bollard Speaker2-Way Directional Bollard Speaker2-Way Bollard Satellite SpeakerPassive Bollard Subwoofer
Construction Rotomolded color through polymer composite Rotomolded color through polymer compositeRotomolded color through polymer compositeRotomolded color through polymer compositeRotomolded color through polymer compositeRotomolded color through polymer composite
Outdoor RatingMeets or exceeds NEMA 6 / IP67 testing standards Meets or exceeds NEMA 6 / IP67 testing standardsMeets or exceeds NEMA 6 / IP67 testing standardsMeets or exceeds NEMA 6 / IP67 testing standardsMeets or exceeds NEMA 6 / IP67 testing standardsMeets or exceeds NEMA 6 / IP67 testing standards
Tweeter 3” Planar Ribbon 2.5” Planar Ribbon3” Planar Ribbon3” Planar Ribbon3” Planar RibbonNot Applicable
Mid-Bass Woofer 7” x 10” Carbon Fiber Cone 6.5” Carbon Fiber Cone, 7″ x 10” Carbon Fiber Cone7″ x 10” Carbon Fiber Cone7″ x 10” Carbon Fiber ConeNot Applicable
Passive RadiatorsNot Applicable 3x 6.5” Passive RadiatorsNot Applicable Not Applicable Not Applicable Not Applicable
Subwoofer 4x 6.5” Laminate Cones 4x 6.5” Laminate ConesNot Applicable Not Applicable Not Applicable 4x 6.5” Laminate Cones
Power Handling Sub – 500W, Sat – 200W Sub – 500W, Sat – 125W200W125W200W500W
Frequency Response 30Hz – 20kHz 30Hz – 20kHz50Hz – 20kHz60Hz – 20kHz110Hz – 20kHz30–120Hz
Sensitivity (1w @ 1m)Sat – 90db
Sub -88db
Sat – 88db
Sub – 88db
90db 88db 90db88db
Dispersion 120° 120°120°120°120°Omnidirectional
Impedance 16 ohms 16 ohms16 ohms16 ohms16 ohms16 ohms
Speaker Connectors8C16 Uni-Connect Input & Output Connectors 8C16 Uni-Connect Input & Output Connectors8C16 Uni-Connect Input & Output Connectors8C16 Uni-Connect Input & Output Connectors8C16 Uni-Connect Input & Output Connectors8C16 Uni-Connect Input & Output Connectors
Finish Brown (fine textured satin) Brown (fine textured satin)Brown (fine textured satin)Brown (fine textured satin)Brown (fine textured satin)Brown (fine textured satin)
Mounting Freestanding, Partial Burial, or Hardscape Mount (optional) Freestanding, Partial Burial, or Hardscape Mount (optional)Freestanding, Partial Burial, or Hardscape Mount (optional)Freestanding, Partial Burial, or Hardscape Mount (optional)Freestanding, Partial Burial, or Hardscape Mount (optional)Freestanding, Partial Burial, or Hardscape Mount (optional)
Dimensions (HWD) 45” x 11” x 12.25” 42.5” x 11” x 12.25”29” x 11” x 12.25”13” x 11” x 12.25”16” x 11” x 12.25”31.5” x 11” x 12.25”
Weight 49.5 lb 50.6 lb27.5 lb20.5 lb19.8 lb32.5 lb
The Bottom Line
Coastal Source remains one of the more serious names in high-performance outdoor audio, lighting, and power, and the 1000 Series Bollards expand on its established 10.0 platform with a more flexible, higher-performance approach to landscape sound. The real differentiator is not simply the addition of ribbon tweeters, although that is unusual outdoors. It is the combination of weatherized ribbons, modular 2-way and 3-way configurations, force-canceling bass technology, and a sealed, purpose-built bollard enclosure designed to integrate into larger Coastal Source systems.
This is not a DIY patio-speaker solution, nor is it intended for someone who wants a Bluetooth speaker beside the grill. The 1000 Series is aimed at luxury residential, hospitality, and large-scale commercial installations where the system needs to deliver serious output, broad coverage, and durable all-weather performance without turning the landscape into a field of black boxes. External amplification is required, including for the passive B1500 subwoofer, so dealer involvement is essential to determine placement, amplification, zoning, and the right combination of speaker modules.
Pricing has not been announced, but Coastal Source enters a competitive field that includes Theory Audio’s ic6 and iws12 Bollards, Origin Acoustics’ landscape and ribbon-based systems, and Definitive Technology’s Dymension Outdoor Bollards. Coastal Source’s advantage may be its more comprehensive ecosystem and the flexibility to create a more tailored, higher-end outdoor system. That will matter to buyers with the property, budget, and patience to do it properly.
Price & Availability
Coastal Source 1000 Series speakers are available through Coastal Source and Authorized Dealers. Refer to dealers for pricing and installation.
2026 Cayin HA-1A MK3 Tube Headphone Amplifier
Cayin's HA-1A MK3 features pure Class A tube amplification with 2.7W output, impedance matching and preamp functionality for $999.
2026 FiiO M25 Veritas and M25-R2R DAPs 2026 FiiO M25 Veritas and M25-R2R DAPs
DAPs
FiiO’s M25 VERITA and M25 R2R finally launch with AKM or resistor-ladder DACs, 1.7W per channel, 31-band PEQ and the same price.
Silent Angel H1 Silent Angel H1
Silent Angel’s $849 H1 combines dual ESS DACs, streaming, local storage, high-res playback, and VitOS in one compact digital hub.
2026 FiiO FT15 Headphones 2026 FiiO FT15 Headphones
FiiO’s $499 FT15 gets a bigger planar driver, thinner diaphragm and lighter chassis, and we already have first impressions from CanJam London.
2026 Bose Ultra Open 2nd Gen and Sport Open Earbuds in Black 2026 Bose Ultra Open 2nd Gen and Sport Open Earbuds in Black
Is Bose trying to make open ear audio mainstream? The $199 Sport Open Earbuds and $299 Ultra Open Earbuds 2nd Gen target fitness and...
2026 Hisense Boom Portable Bluetooth Speakers 2026 Hisense Boom Portable Bluetooth Speakers
Hisense takes on JBL, Sony, Marshall, LG and TCL with four new Bluetooth and party speakers led by the $399.99 Party Thunder Pro.
Can Coastal Source turn the backyard into a true high-end system? Its CEDIA 2026 lineup combines outdoor audio, lighting and simplified power.
KEF takes Uni-Q outdoors with new landscape speakers, bollards, subwoofers and GaN KASA amps. Can it challenge Theory Audio Design?
Andover Audio FreePlay vs KEF Muo: which portable Bluetooth speaker sounds better at home, outdoors, and on the road?
Can the Andover Audio FreePlay deliver true stereo sound, long battery life, and real durability in a portable Bluetooth speaker?
Bang & Olufsen teams with Antolini on Beosound Haven, a high end outdoor speaker concept that blends stone, design, and integrated audio.
Priced from $225, Polk Audio Atrium Series outdoor speakers bring high-quality sound to patios, pools, and outdoor entertainment spaces.
Tired of buffering, screaming kids, and neighbors mooching your Wi-Fi? Build a home network that actually streams—and survives South Florida’s weather and personalities.
ELAC Muro outdoor speakers are built for your chalet or beer garden because ugly rock speakers are so 2015. IP66-rated, port optional, and priced...
