Cambridge Audio MSX Series Reborn: The Modular Naughty Minx Speaker System Returns with a Modern Edge
Cambridge Audio’s MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
2026 Cambridge Audio MSX Speakers Lifestyle
Cambridge Audio isn’t reinventing the wheel here. It’s doing something far more sensible, which already puts it ahead of half the industry. The new MSX Series is a clean reboot of the long running Minx lineup, keeping the formula intact while dragging the naming and design into the present day without unnecessary theatrics. Same idea: ultra compact satellites, wide dispersion, and sound that refuses to behave like it lives in a tiny little box.
What’s changed is mostly what needed changing. The branding now aligns with Cambridge’s current range, the finishes are properly modern in matte black or white, and the lineup has been streamlined into MSX10 and MSX20 satellites with Sub 200 and Sub 300 handling low end duties. It’s modular, flexible, and designed for people who want real stereo or surround sound without turning their living room into a shrine to oversized cabinets.
cambridge-audio-msx-10-black
MSX10
Cambridge Audio has kept the MSX Series firmly in the affordable lane, with pricing that makes a full system far more attainable than most compact hi-fi or home theater setups. The MSX10 starts at $99 each, the MSX20 at $129 each, while the Sub 200 and Sub 300 come in at $399 and $499 respectively.
That puts a flexible stereo or surround system within reach without immediately crossing into four figure territory. It also undercuts most of Cambridge’s newer L/R wireless range, which leans more premium overall, with the exception of the L/R S at $549 per pair.
The trade off is clear: the L/R Series offers a simpler, all in one path with amplification and streaming built in, fewer boxes, and arguably better out of the box performance. The MSX system takes the more traditional route, requiring an external amp or receiver, but gives users more control over how the system is built and expanded over time.
cambridge-audio-msx-20-white-lifestyle
MSX20 with MSX Sub 200
Compact Cabinets, Engineered for Wide Dispersion and Real World Placement
At the core of the MSX Series is Cambridge Audio’s Balanced Mode Radiator (BMR) driver. It combines conventional driver movement with bending wave dispersion, allowing a single driver to cover a wider range while maintaining consistent output across the room. The goal is straightforward: more even sound distribution without relying on a narrow listening position.
The MSX10 uses a fourth generation BMR driver, with refinements aimed at improving efficiency, extending treble response, and smoothing overall integration. At 8cm, it remains very compact and easy to place in smaller spaces.
The MSX20 builds on that platform by adding a dedicated woofer alongside the same BMR driver. This provides additional low frequency support and improved dynamic range, making it better suited for larger rooms or listeners who want a fuller presentation.
cambridge-audio-msx-sub-200
MSX SUB 200 Subwoofer
Compact Subwoofers with DSP Control
Low frequencies are handled by the MSX Sub 200 and MSX Sub 300, two compact subwoofers designed to add depth without taking over the room. Both use forward firing drivers, auxiliary bass radiators, and DSP to keep output controlled and consistent, even as volume increases.
The MSX Sub 200 pairs a 200 watt amplifier with a 6.5 inch active woofer and dual ABRs. It is the smaller option, aimed at tighter spaces where placement and restraint matter as much as output.
The MSX Sub 300 increases power to 300 watts and moves to an 8 inch active woofer in a larger cabinet. It delivers more low end extension and headroom, making it a better fit for bigger rooms or systems where a bit more impact is required.
cambridge-audio-msx-sub-300
MSX SUB 300
Clean Design. Flexible Placement. Passive by Design.
Not every room is built around speakers, and Cambridge Audio has designed the MSX Series to integrate easily into shared living spaces.
Finish options are limited to matt black or matt white, keeping the look simple and consistent whether the speakers are placed on a shelf or mounted on a wall. These are passive speakers, so they require an external amplifier or AV receiver. There is no built in amplification or streaming.
Connections are standard. The terminals support 4mm banana plugs, with no proprietary cabling required. Each satellite can be wall mounted or placed on furniture as standard, with optional pivoting mounts and table stands available for more flexible positioning.
cambridge-audio-msx-20-front-black-lifestyle
The Bottom Line
The MSX Series keeps things simple on the surface, but system matching still matters. These are passive speakers paired with active subwoofers, so your amplifier or receiver needs to support proper sub integration. That means a dedicated subwoofer output or usable pre-outs. Without one of those, you’re not getting the system to behave as intended.
Within Cambridge Audio’s own lineup, models like the CXA61, CXA81, and EXA100 make the most sense, offering proper subwoofer outputs and system flexibility. The AXR100 can also work, but its fixed crossover limits how precisely you can integrate the subwoofers.
You are not locked into Cambridge, however. Amplifiers and streaming amps from NAD, Arcam, Rotel, and Audiolab all offer compatible options with subwoofer outputs or pre-outs. Even newer entries like WiiM’s streaming amplifiers can work in a compact system like this, provided they include proper bass management or sub connectivity.
The takeaway is straightforward: the MSX system is flexible, but only if the electronics are chosen with the same level of care.
cambridge-audio-msx-sub-200-rear
cambridge-audio-msx-sub-300-rear
Price & Availability
Cambridge Audio MSX will be available from April 2026 at Cambridge Audio’s website and approved retailers at the following prices:
Victrola and Third Man Records Limited Edition Turntable and Speakers
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
2026 TCL QM8L 4K TV Lifestyle 2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
Dan D'Agostino Momentum C2Z Preamplifier with Power Supply Dan D'Agostino Momentum C2Z Preamplifier with Power Supply
Dan D’Agostino Momentum C2Z preamplifier refines the C2 with Z circuitry and FET output stage. If you have to ask the price this is...
Musical Fidelity M6xi Integrated Amplifier Silver Musical Fidelity M6xi Integrated Amplifier Silver
At $3,799, Musical Fidelity’s M6xi delivers 230 WPC with an onboard DAC, HDMI ARC, and MM/MC phono stage, offering a powerful and flexible solution...
Denon AVR-S980H Home Theater A/V Receiver Lifestyle Denon AVR-S980H Home Theater A/V Receiver Lifestyle
Denon AVR-S980H adds wireless surround support, 1440p pass-through, and channel level monitoriing offering a flexible step-up from soundbars under $1,000.
Hi-Fi Components
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
Qobuz Connect arrives on Cambridge Audio StreamMagic Gen 2 and 3 via firmware update, extending new streaming features to legacy models.
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Podcasts
On this live stream podcast, the eCoustics team discusses the very best of what we saw and heard at CES 2026 in Las Vegas.
Cambridge Audio unveils its L/R Active Speaker Series at CES 2026—bold design, serious power, StreamMagic streaming, and a clear shot at KEF’s LS dominance.
Hi-Fi Components
Cambridge Audio names Fidelity Imports as its exclusive U.S. distributor, promising better service, wider retail access, and overdue visibility at hi-fi shows. About time.
In 2025, the best-in-class streamers from Cambridge, Bluesound and WiiM set the pace as new challengers from FiiO, Topping, and Eversolo loom for 2026.
