Audio-Technica Fires Back at Ortofon with New AT33x Phono Cartridge Range — Handcrafted in Japan with Stereo and Mono Versions
Priced from $449 to $899, the Audio-Technica AT33x Series stereo and mono MC phono cartridges feature die-cast zinc, hybrid bodies and refined suspension for improved analog performance.
Audio-Technica AT33x Phono Cartridges
Audio-Technica has finally answered the call. After more than a decade since its last major cartridge update, the Japanese brand returns with the all-new AT33x Series, a handcrafted Moving Coil lineup that feels like a direct response to Ortofon’s recently launched MC X Series from late July. The range includes five precision-engineered models — AT33xMLB, AT33xMLD, and AT33xEN stereo cartridges, alongside the AT33xMONO/I and AT33xMONO/II monaural editions — marking Audio-Technica’s strongest statement yet in the modern analog revival.
While Audio-Technica hasn’t exactly been quiet in 2025, debuting the $2,000 AT-LPA2 and the $10,000 Hotrau turntables that looked straight out of a sci-fi concept lab — the new AT33x cartridges mark a more grounded return to form. This is the brand’s most extensive new lineup priced below $1,000 USD, aimed squarely at the real-world audiophile. Designed to pair effortlessly with a wide range of turntables, the AT33x Series blends precision engineering with accessibility; proof that Audio-Technica hasn’t forgotten the enthusiasts who built its legacy.
Audio-Technica Elevates Craftsmanship and Innovation with New AT33x Cartridge Design
at33xmld-phono-cartridge-tonearm
Underscoring its leadership in phono cartridge engineering, Audio-Technica takes a major step forward with the AT33x Series, introducing new materials and design refinements aimed squarely at performance and longevity. For the first time, the company is using die-cast zinc in its cartridge construction — a material chosen for its exceptional density and rigidity. This helps suppress unwanted resonance and delivers a fuller, more articulate sound, especially through the mid and low frequencies where analog playback lives and breathes.
The AT33x Series also debuts a new suspension mechanism with slightly lower dynamic compliance than conventional designs. The result is greater setup flexibility and improved compatibility across a wider range of tonearms — a welcome detail for analog enthusiasts who take their cartridge matching seriously.
Each cartridge in the series is handcrafted in Japan, precision-machined, and individually adjusted by skilled artisans. This level of craftsmanship isn’t about automation or mass production; it’s about preserving the meticulous, human touch that has defined Audio-Technica’s Japanese heritage for more than six decades.
Audio-Technica AT33x Series Stereo & Mono Cartridges
The new Audio-Technica AT33x Series introduces five cartridges — three stereo and two mono — designed to cover a wide range of listening preferences and system setups. Audio-Technica has not yet released the final specifications, but based on previous models, output levels for both stereo and mono versions are expected to fall between 0.3 and 0.35 mV.
at33xen
at33xmld
at33xmlb
Stereo Models
  • AT33xEN – Uses a nude elliptical stylus to deliver a controlled, balanced presentation with accurate tracking and a wide playback bandwidth.
  • AT33xMLD – Equipped with a microlinear stylus that combines clarity and dynamic strength, offering precise imaging and tonal accuracy.
  • AT33xMLB – The flagship stereo model, featuring a boron-tapered cantilever and a lightweight vibration system for improved response and bandwidth control.
Mono Models
  • AT33xMONO/I – A high-performance mono cartridge designed to capture the full tonal range of monaural records with clean, stable playback.
  • AT33xMONO/II – Employs a samarium cobalt magnet and pure iron yoke, providing a warm, detailed presentation with consistent output stability.
at33xmono-i
The AT33x Series incorporates several updates to Audio-Technica’s moving coil design. The dual moving coilstructure delivers strong channel separation and a broad frequency response, while the TRUE MONO generator in the mono models isolates horizontal groove movement for reduced surface noise and improved signal purity.
duralumin tapered cantilever enhances high-frequency control, and the new suspension system offers slightly lower dynamic compliance for broader tonearm compatibility. The die-cast zinc base improves rigidity and vibration control, while the hybrid body construction of zinc, aluminum, and polymer helps manage resonance evenly across the cartridge housing.
Other refinements include PCOCC pure copper coil wiringthick gold-plated terminal pins to minimize contact resistance, a neodymium magnet with a Permendur yoke for high magnetic efficiency, and threaded mounting holes for straightforward installation. Together, these updates position the AT33x Series as a thoughtful evolution of Audio-Technica’s moving coil design rather than a radical overhaul.
The Bottom Line
The Audio-Technica AT33x Series marks an important addition to the brand’s long-running cartridge lineup — one that sits comfortably between its entry-level workhorses and acclaimed high-end models. Handcrafted in Japan, the AT33x range combines new materials like die-cast zinc, a hybrid body structure, and a refined suspension design to deliver improved rigidity, lower resonance, and broader tonearm compatibility.
With pricing starting at $699 for the stereo versions and $449 for the mono models, this series brings serious moving coil engineering into reach for a wider audience. As with all MC designs, you’ll need a dedicated moving coil phono stage or a step-up transformer if you plan to use one with an MM phono input.
Price & Availability
The Audio-Technica AT33x Series will be available starting October 23, 2025 at the following prices:
1 Comment
1 Comment
  1. Dave Johnson
    October 26, 2025 at 6:59 pm
    These look great, and this is perfect timing (and price range) as I am planning on updating the cartridge on my AT-LP2022 turntable very soon…
2026 Samsung The Frame Pro vs. The Frame 4K Art TVs
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Can the $3,500 Audio-Technica ATH-ADX7000 deliver electrostatic-like speed and space without an energizer? We listened at CanJam NYC 2026.
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Over-Ear Headphones
Audio-Technica's ATH-ADX7000 deliver stunning dynamics, vast staging and refined tuning at $3,499 with some drawbacks.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Rega closes out 2025 with the Nd9, a £695 moving-magnet cartridge featuring a Boron cantilever, fine line diamond stylus, and N55 Neodymium magnet, set...
Limited to 5,000 units, the $199 Audio-Technica ATH-M50xENSO headphones feature custom engraving on the earcups and headband inspired by Japanese ink paintings of the...
