Andover Audio Unveils SpinPlay: A Modern All-in-One Hi-Fi Record Player That Redefines Value and Simplicity
Andover Audio’s new $729 SpinPlay all-in-one record player combines true hi-fi sound, IsoGroove tech, and Bluetooth connectivity—outclassing Crosley-style decks.
Andover Audio SpinPlay Suitcase Turntable Audio System in White Lifestyle
Andover Audio, the Boston-based crew that’s been quietly outclassing half the “lifestyle audio” market, just dropped the SpinPlay, a new all-in-one record player that might be the easiest way yet to get proper hi-fi sound without a single headache. Known for smartly engineered gear like the SpinStage phono preamp and the SpinBase MAX turntable speaker system—both absolute killers for the money—Andover’s latest creation takes the plug-and-play concept to its logical extreme.
The SpinPlay is built around the company’s patented IsoGroove technology—borrowed from their flagship Andover-One ($2,499)—to keep vibrations from wrecking your sound, even when you crank it. Pull it from the box, plug it in, drop a record, and you’re spinning. No tonearm balancing. No cable jungle. Just vinyl, simplified. And because Andover knows real life doesn’t always happen in one place, the SpinPlay’s sturdy construction, hardtop cover, and fabric-clad retro styling make it easy to move, display, or show off—without looking like you borrowed it from your college dorm.
andover-spinplay-black-angle
The SpinPlay is for vinyl fans who want the simplicity of an all-in-one system with true out-of-the-box hi-fi sound quality,” said Bob Hazelwood, Director of Engineering and Product Development at Andover Audio. “We have a well-established history of delivering reliable, award-winning sound from compact vinyl playback systems that are built to perform and built to last—satisfying both discerning music enthusiasts and newcomers to the format alike.”
IsoGroove Tech and Real Hi-Fi Sound—No Fuss, No Audiophile Ego Required
The Andover Audio SpinPlay takes a straightforward approach to real hi-fi sound in an all-in-one record player. It uses Dual Direct Drive amplification, giving each woofer and tweeter its own amplifier for clean, balanced playback. With a 270° driver array that combines two 1.75″ × 4″ oval woofers and 0.75″ silk-dome tweeters, it delivers 20 watts to the lows and 15 watts to the highs across a 60Hz–20kHz range. The result is an open, detailed presentation that feels far larger than the small enclosure suggests.
andover-spinplay-black-corner-closeup
The belt-drive turntable features an electronically regulated motor for steady speed and low noise. A 12-inch aluminum platter provides weight and stability, while the 9-inch balanced aluminum tonearm includes an Audio-Technica magnetic cartridge for accurate tracking. The tonearm’s adjustable anti-skate keeps things in check. It’s ready to play out of the box—the platter and belt are already installed, and the tonearm comes pre-balanced.
The SpinPlay offers Line, Optical Digital, and USB flash-drive inputs, along with Bluetooth transmit and receive support, so it works easily with both wired and wireless setups. It also pairs with Andover’s SpinSub subwoofer ($379) and SpinStand ($269), which can hold up to 150 records.
For travel, the upcoming SpinPlay Go-Bag (available Q1 2026) is designed to fit under a commercial airline seat or in an overhead compartment. The system’s sturdy construction and protective cover make it easy to move from one space to another without fuss. It’s built for people who want solid sound without the usual setup drama.
andover-spinplay-black-back
Andover Audio SpinPlay — Technical Specifications
Audio System
  • Technology: IsoGroove feedback elimination
  • Amplification: Dual Direct Drive (DDD) amplification
  • Speakers: Four-driver system
    • Two 1.75″ × 4″ oval woofers (20W each, 40Hz–2.5kHz)
    • Two 0.75″ silk-dome tweeters (15W each, 2.5kHz–20kHz)
  • Frequency Response: 60Hz–20kHz
  • High-Pass Filter: Selectable 100Hz
  • Headphone Output: 120mW @ 16Ω
  • Line Output: 2V RMS
  • USB Power Output: 5V DC / 300mA
  • Power Supply: 100–250V AC, 50–60Hz, 1.5A
  • Remote Control: Full-function infrared
Inputs and Sources
  • Phono (internal)
  • Line (Aux) — 10kΩ input impedance
  • Optical Digital Input — up to 24-bit/96kHz
  • USB Flash Drive — supports MP3, WMA, WAV
  • Bluetooth 5.0 — transmit and receive modes
Turntable Section
  • Type: Custom Andover belt-drive with electronic speed control
  • Speeds: 33⅓ and 45 RPM
  • Auto Stop: End-of-record function
  • Motor: Electronically governed DC motor
  • Cartridge: Audio-Technica AT3600L (replaceable stylus options: ATN3600LC conical, ATN3600LE elliptical)
  • Tracking Force: Preset
  • Wow & Flutter: <0.15% (weighted)
  • Platter: 12″ cast aluminum with damped silicone mat
  • Tonearm: 8.9″ aluminum, precision ball bearings, semi-fixed counterweight
  • Cueing: Viscous-damped
  • Anti-Skate: Fully adjustable
Build and Dimensions
  • Cabinet: Braced MDF enclosure
  • Dimensions: 18″ (W) × 6.75″ (H) × 13.5″ (D)
  • Weight: 20.5 lbs (9.3 kg)
andover-spinplay-black-lifestyle
The Bottom Line
At $729 USD, the Andover Audio SpinPlay lands squarely between entry-level turntables and the bloated “lifestyle” record players flooding Amazon. It’s built like a real component, not a prop. With IsoGroove feedback controlDual Direct Drive amplificationBluetooth transmit/receive, and a fully equipped belt-drive turntable topped with an Audio-Technica cartridge, it’s clear Andover aimed to make something both serious and simple.
While the Crosley crowd might eye the SpinPlay as overkill, anyone who’s actually listened to one knows the difference. This isn’t a toy—it’s a real hi-fi system that happens to be plug-and-play.
The SpinPlay does include a 3.5mm line output, so it can be connected to an external amplifier or powered speakers if you really want to. Andover even includes a mini-to-RCA adapter cable in the box, which is a nice touch given the limited space on the rear panel.
That said, the company doesn’t expect most users to go that route—the SpinPlay is meant to stand on its own. Still, a pair of dedicated RCA outputs would have made system integration a bit cleaner for those building around separate amplification.
Price & Availability
Available now for pre-order in black or white for $729 at andoveraudio.com, the SpinPlay ships mid-November 2025 and will also roll out through authorized dealers and Amazon soon.
Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Technics SL-1500CS Turntable Silver Technics SL-1500CS Turntable Silver
Technics SL-1500CS upgrades the popular SL-1500C with Delta Sigma Drive motor control. Does this precision boost make it the new direct drive leader in...
Rega Aos MC Phono Preamplifier Angle Left Rega Aos MC Phono Preamplifier Angle Left
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
Nagra Compact Player Angle Nagra Compact Player Angle
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
LG xboom Plus and Lite wireless earbuds LG xboom Plus and Lite wireless earbuds
LG expands its xboom lineup with Buds Plus and Buds Lite, adding ANC, Auracast, UVnano+ tech, and up to 35 hours of battery life.
ViewSonic LX60HD smart LED 1080p projector angle ViewSonic LX60HD smart LED 1080p projector angle
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
Andover Audio’s SpinPlay is a brutally well-executed all-in-one record player that sounds far better than it should at its price—and may be the company’s...
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Editors’ Choice 2025 turntables show prices are up and cheap decks still disappoint. Choosing a long-term table now takes more thought—but pays off in...
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
Looking for a space saving all-in-one turntable system with Bluetooth connectivity? The Andover-One E might be worth checking out.
