Loudspeakers
Fyne Audio’s Full-Bleed Bristol Takeover: Colorful F500SP Speakers Steal the 2026 Hi-Fi Show
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Fyne Audio Speakers Any Color You Like Available in the UK only
Scotland’s own Fyne Audio did not just show up at the Bristol Hi-Fi Show in 2026; it took over, trading polite reserve for a dose of bold Highland swagger. Claiming Bristol Suite 1, the event’s largest demonstration space, the Ayrshire-based loudspeaker specialist marked its biggest presence ever at the annual show while unveiling expanded color options and custom finishes across select models. The company also confirmed full UK availability of its S-Trax super tweeter, broadening access to its high-frequency enhancement platform.
Systems on demonstration ranged from the award-winning F500E series to the flagship F704SP floorstanders paired with the S-Trax, powered by reference electronics from Accuphase and spinning vinyl on a Linn LP12 — because if you’re going to bring Scottish loudspeakers to Bristol, you might as well show up properly dressed and louder than the bagpipes at Hogmanay.
Any Color You Like If You Happen to Live in the UK
Fyne Audio F500SP Bookshelf Speaker in custom green lifestyle
Fyne Audio F500SP Bookshelf Speaker in Custom Green (UK only)
Fyne Audio has expanded its color and customization program for the F500SP Series under the Any Color You Like banner, giving UK buyers far more than the usual black, white, or walnut routine.
At the show, attendees and press previewed an expanded range of standard finishes across the F500SP models, along with a fully bespoke option. Customers can now order any F500SP loudspeaker in any RAL Classic color, matt or gloss, for a 30 percent SRP premium over standard finishes. The program is available exclusively through authorized Fyne Audio dealers in the UK.
Once a color is selected and a deposit placed, customers receive a painted swatch for final approval before production begins. Each pair is then painted to order, with delivery typically taking six to eight weeks from confirmation.
Pro tip: The F500S builds on the F500SP platform, incorporating the latest evolution of Fyne’s IsoFlare point source driver technology for improved clarity and dispersion.
S-Trax Super Tweeter
fyne-audio-s-trax-super-tweeter
In addition to the Any Color You Like debut, Fyne Audio confirmed full UK dealer availability of its previously introduced S Trax omnidirectional super tweeter system. First unveiled in late 2025, S Trax is now shipping through Fyne’s premium retail network and was demonstrated at the Bristol Hi Fi Show paired with the F502S, giving listeners a clear sense of the added spatial scale and high frequency air it brings to performance systems.
S Trax sits below the flagship SuperTrax super tweeter launched in 2024 and is designed as a more accessible option, while the SuperTrax remains the more natural partner for Fyne’s F700 and F700SP loudspeaker models.
Fyne Audio S-Trax Specifications
Fyne Audio ModelS-Trax
Product Type Super Tweeter
Price (each)$1,299.99 / £999.99
Drive Unit25mm (1”) Magnesium dome with neodymium magnet system
Recommended Amplifier Power400 Watts RMS (Max)
Sensitivity (2.83 Volt @ 1m)Suitable for loudspeakers up to 98dB
Nominal impedance8 Ohm
Frequency response (-6dB typical in room)16kHz – 50kHz
Crossover Type and Frequency3rd order high pass 16kHz, CryoLite treated
System adjustments+/- 4.5dB from nominal setting
Dimensions – (HWD)79 x 82 x 149mm (3.1 x 3.2 x 5.6″)
Net Weight – Each1kg (2.2lbs)
FinishesBlack
Fyne Audio Speaker Technology
fyne-audio-speaker-technology
Across three active demonstration systems, visitors and press experienced the full scope of Fyne Audio engineering, from accessible, high value pairings of F55E loudspeakers with WiiM streaming electronics to reference level IsoFlare point source designs driven by Accuphase amplification and a dedicated vinyl front end.
Fyne Audio’s presence at the Bristol Hi Fi Show focused on demonstrating the complete philosophy behind its point source loudspeaker technology. Through IsoFlare drivers, FyneFlute surrounds, and BassTrax porting, the systems highlighted the brand’s central objective: coherent, room filling musical realism achieved through engineering precision and purposeful design.
Comparison
F500S
(2025)
F500SP
(2021)
F704SP
(2025)
F502S
(2025)
F55E
(2025)
Product Type Bookshelf SpeakerBookshelf SpeakerFloorstanding SpeakerFloorstanding SpeakerFloorstanding Speaker
Price (pair)$1,299 $1,999
$2,299
$25,999$3,499$1,235
Speaker Type2-way, downwards firing port, with BassTraxTM Tractrix diffuser2-way, downwards firing port, with BassTraxTM Tractrix diffuser*2 ½ way, downwards firing port, with BassTrax™ Tractrix diffuser, twin cavity loading system2 ½ way, downwards firing port, with BassTraxTMTractrix diffuser.2 ½ way, downwards firing port, with BassTraxTMTractrix diffuser.
Recommended amplifier power (Watt RMS)30 – 10030 – 12030 – 30030- 18030 – 120
Continuous power handling (Watt RMS)50601509060
Sensitivity (2.83 Volt @ 1m)89 dB90 dB96 dB91dB88 dB
Nominal impedance8 Ohm8 Ohm8 Ohm8 Ohm8 Ohm
Frequency response (-6dB typical in room)45Hz – 34kHz42Hz – 34kHz22Hz – 26kHz30Hz – 34kHz42Hz – 38kHz
Drive unit complement1 x 150mm IsoFlare™, bass / mid
1 x  25mm magnesium dome compression tweeter
1 x 150mm IsoFlare™ point source driver Multi-fibre bass/midrange cone, FyneFlute™ surround
1 x 25mm magnesium dome compression tweeter, neodymium magnet system
1 x 300mm IsoFlare, point source driver, multi-fibre bass/midrange cone, FyneFlute surround
1 x 75mm titanium dome compression tweeter, neodymium magnet system.
1 x 300mm multi-fibre bass FyneFlute surround.
1 x 200mm IsoFlare™, bass / mid
1 x 25mm magnesium dome compression tweeter.
1 x 200mm bass.
1 x 125mm IsoFlare™ multi-fibre bass / mid
1 x 19mm titanium dome compression tweeter.
1 x 125mm multi-fibre bass
Crossover frequency1.7kHz1.7kHz250Hz & 850Hz250Hz & 1.7kHz350Hz & 1.8kHz
Crossover Type2nd order low pass, 1st order high passBi-wired passive low loss, 2nd order low pass, 1st order high pass. Cryo-Lite treated.Bi-wired passive low loss, 2nd order low pass, 1st order high pass. Cryogenically treated2nd order low pass, 1st order high pass2nd order low pass, 1st order high pass
System AdjustmentsPresence control +/- 3dB (2.5 – 5.0kHz)Not IndicatedNot IndicatedPresence control +/- 3dB (2.5 – 5.0kHz)Not Indicated
Dimensions – (HWD)325 x 204 x 317mm (12.8 x 8.0 x 12.5″)323 x 200 x 320mm (12.7 x 7.9 x 12.6”)1353 x 579 x 568mm (53.3 x 22.8 x 22.4″)1112 x 300 x 382mm (43.8 x 11.8 x 15.0″)925 x 210 x 236mm (36.4 x 8.3 x 9.3″)
Net Weight – Each8.3kg (18.3lbs)8.1kg (17.6lbs)71.5kg (157.6lbs)28.5kg (62.8lbs)11.9kg (26.2lbs)
FinishesNatural Walnut
Black Oak
Piano Gloss Black
Natural Walnut
Piano Gloss Walnut
Piano Gloss Black
Piano Gloss White
Also – Any Color You Like options (only available in the UK)
Natural Walnut
Piano Gloss Walnut
Piano Gloss Black
 Piano Gloss White
Natural Walnut
Black Oak
Piano Gloss Black
Black Ash
Cabinet ConstructionNot IndicatedNot IndicatedPressed High-Density Birch Ply with extensive internal bracing.High-rigidity MDF with extensive internal bracingNot Indicated
S-Trax Position (from cabinet front edge)44mm (1.7″)44mm (1.7″)119mm61mm (2.4″)32mm (0.08″)
SuperTrax Position (from cabinet front edge)20mm (0.8″)20mm (0.8″)95mm (3.7″)37mm (1.5″)N/A
Fyne Audio F501SP Loudspeaker in Custom Pink Lifestyle
The Bottom Line
With its largest ever presence at the Bristol Hi Fi Show, Fyne Audio made it clear that engineering alone is no longer the whole story. The Any Color You Like program opens the door for UK customers to step outside the traditional safe finishes that have long defined British loudspeakers. For once, it is not just about walnut, black, or polite understatement. It is about matching serious acoustic performance with a cabinet that does not look like it was designed to apologize for itself.
Right now, that freedom belongs to UK buyers willing to pay the premium and wait for a made to order finish. If the response is strong, it would not be surprising to see the initiative expand. But as it stands, Fyne has handed its home market something rare in British hi fi: the chance to keep the stiff upper lip in the listening chair while letting the loudspeakers show a bit of personality.
fyne-audio-f500sp-ral-2017
Fyn Audio F500SP
Price & Availability
NOTE: Fyne Audio’s Any Color You Like option is only available in the UK. The regular color models are available at Upscale Audio in the U.S.
Andrew Jones Introduces New Speaker and Company Jones and Cerreta
Andrew Jones to debut Jones and Cerreta at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how much...
Børresen Center3 Front Angle Lifestyle Børresen Center3 Front Angle Lifestyle
Center Speakers
Børresen’s $7,000 Center3 brings flagship tech to home theater but is it the missing piece for X Series owners or still overkill?
FiiO Darkside Pro Linear Power Supply FiiO Darkside Pro Linear Power Supply
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
Netflix Stranger Things Complete Series July 2026 Netflix Stranger Things Complete Series July 2026
Movies
Stranger Things Complete Series on Blu-ray and 4K UHD arrives this July in four collector box sets, but which edition should you buy?
Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle Schiit Lyr 5 Forkbeard Headphone Amplifier and Preamp Silver Angle
Schiit's Lyr 5 Headphone Amplifier at $799 combines tube and MOSFET gain with up to 6W output and Forkbeard control but skips balanced inputs...
Technics x Aimé Leon Dore SL-1200M7ALD Turntable Technics x Aimé Leon Dore SL-1200M7ALD Turntable
Technics x Aimé Leon Dore SL-1200M7ALD lands at $2100. Just hype or a smart play on vinyl’s billion dollar comeback?
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Can Creek Audio stand out in 2026 as it enters the crowded speaker market and rethinks its amplifier strategy?
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Can ProAc’s compact Response DB1R with ribbon tweeter deliver true high end performance in a standmount likely priced around $5,000 per pair?
Børresen M8 Gold Signature is a $1,150,000 loudspeaker built in Denmark. Engineering breakthrough or high-end excess for the ultra wealthy?
Kii Audio SEVEN wireless speakers add a third color, Qobuz Connect, Spotify Lossless support, and more with free software update.
Ultrafide Audio will unveil the ENSO INT-125 integrated amplifier at Bristol Hi-Fi Show 2026, a UK-built 125W design with DAC.
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
