It’s Here! Check Out the Hisense 116UX RGB Backlit 116-inch LED/LCD TV
Unveiled at CES, the groundbreaking Hisense 116UX is the first production TV to feature RGB MiniLED backlighting. Here’s how it looks.
Hisense 116UX 116-inch RGB MiniLED 4K TV at Press Event in New York City
Update: August, 2025 – Hisense announced a 100-inch size RGB-lit TV in the UX series, the 100UX. Stay tuned for details in an upcoming article.
In the past few months, we’ve seen three different TV manufacturers show off prototypes of a new kind of LCD TV. Sony, Samsung and Hisense have all revealed their plans for LCD TVs that use RGB LED backlights, instead of the the white or blue LED backlights used by traditional LED/LCD TVs.
RGB MiniLED backlighting has several advantages over standard monochromatic LED backlights including higher peak brightness, more extended color gamut and higher efficiency. Sony showed us their RGB-lit TV in prototype form at their headquarters in Tokyo earlier this year. Samsung and Hisense both showed their RGB-lit TVs at this year’s CES in Las Vegas. And while Sony said their version was still at least a year from production, Hisense promised theirs much sooner.
Hisense 116UX RGB-MiniLED TV up to 8,000 nits brightness
The Hisense 116UX features an all-new RGB MiniLED backlighting system.
Last week Hisense made good on that promise by unveiling the final production version of their 116UX TV at a press event in New York City. The 116-inch RGB-backlit behemoth is available to order on Amazon for $29,999. It is expected to begin shipping in the U.S. in late July or early August.
Check out our video of the Hisense 116UX RGB MiniLED/LCD TV.
Viewing Impressions
We got to spend a few hours with the 116UX at the event and brought our Kaleidescape Strato V loaded with some of our favorite films as well as Spears and Munsil’s UHD Benchmark disc on 4K Blu-ray with its vast array of test patterns and content. The set was quite impressive, offering peak brightness up to 8,000 nits (2% window), solid HDR tone-mapping, rich vibrant colors and much better off-axis viewing than most of the LED/LCD TVs we’ve seen.
The 116UX’ Anti-Reflection Pro coating on the panel minimized room reflections, allowing the set to produce solid black levels even in a bright room. With the lights turned off, the set looked even better with excellent contrast and bright accurate colors. Skin tones were particularly well represented. The 116UX is actually both Pantone validated as well as Pantone SkinTone validated. Hisense says the 116UX is capable of reproducing around 95% of the BT.2020 color space, which is impressive for any display device, but particularly impressive for a transmissive display.
Hisense 116UX 116-inch TV show Eye scene from Blade Runner
The eyes have it. “Blade Runner: The Final Cut” (Kaleidescape 4K) looks impressive on the Hisense 116UX.
But no TV is perfect. On challenging content like the “Blade Runner” intro with white and red text scrolling up a black screen, the 116UX did have some signs of haloing or bleed around the white edges. Also, the black background here was noticeably brighter than the black letterbox bars above and below the active 2.4:1 image area of this widescreen film.
Hisense 116UX 4K TV showing credits from Blade Runner
There was some minor haloing visible with white text on a black background on the 116UX.
Hisense 116UX 4K TV show Alpha scene 4,000 nits brightness
The film “Alpha” was mastered in HDR for 4000 nits peak brightness. With a peak luminance of 8,000 nits, the 116UX had no trouble reproducing this film in all its detail.
Transmissive displays like this which require a backlight will never quite match the lighting precision of an emissive display like an OLED or MicroLED TV where every individual pixel can be turned on, off or anywhere in between. But OLED TVs currently max out at 98 inches and can’t even come close to the brightness peaks of this TV, making them less well suited for bright room viewing. And MicroLED TVs are still prohibitively expensive for most buyers and panel size limits currently require multiple screen modules be connected together in order to create a large screen image (which can lead to visible seams at the edge of each component panel). Meanwhile, RGB backlit LCD TVs can use traditional LCD panel fabrication plants to keep costs relatively low and still reach these ultra large panel sizes.
That French Sound?
While TCL is partnering with Danish company Bang and Olufsen for their TV sound systems, Hisense has partnered with French high-end speaker maker Devialet for the 116UX speaker system. They’re calling it a “6.2.2-channel” system with up-firing, side-firing and bottom-firing speakers and two integrated subwoofers. The system supports Dolby Atmos and DTS Virtual:X surround. I put on a few Dolby Atmos clips from “Dune” and “Blade Runner” and found that the sound was actually quite good for an integrated speaker system. I’d still recommend adding a component surround system (or at least a high quality soundbar system with discrete rear speakers) but the built-in sound will definitely get you by if you want to keep things simple and clean.
Features Up the Wazoo
The Hisense 116UX supports virtually all flavors of HDR (high dynamic range): Dolby Vision, Dolby Vision IQ, Dolby Vision Gaming, HDR10, HDR10+, HDR10+ Adaptive and HLG (Hybrid Log Gamma) so it’s likely any content you feed it, from physical media to streaming, to Kaleidescape downloads, will be fully supported. It’s even IMAX Enhanced certified. There are 3 HDMI 2.1 ports on board (one with eARC support) as well as a USB Type C Display Port. The RF antenna input will accept a local antenna input and the on-board tuner supports both ATSC 3.0 (“NextGen TV”) as well as ATSC 1.0 local digital broadcasts.
Hisense UX TV Features
The set’s integrated far-field microphone supports Google Assistant directly, and the set also works with Amazon Alexa, Google Cast and Apple Home Kit for smart home integration. The set is built on Google TV so you’ll get access to all the popular streaming services.
Gamers will appreciate the Hisense Game Bar, with instant access to picture and sound settings to optimize the gaming experience, VRR (Variable Refresh Rate), a native 165 Hz panel for smooth motion reproduction as well as AMD FreeSync Premium Pro support. At 116 inches, The “infected” in “Last of Us” will probably actually be larger than you are in real life, but if you’re up for the challenge, the 116UX should provide a pretty killer immersive gaming experience.
The Bottom Line
At $30,000, the Hisense 116UX is outside the realm of affordability for most TV buyers, but it does have the distinction of being the biggest and brightest consumer TV currently on the market. It also offers excellent color reproduction and contrast, thanks to its novel RGB MiniLED backlighting system. Will that be enough to convince buyers to bring one home? We shall see.
Where to Buy:
3 Comments
3 Comments
  1. ORT
    July 20, 2025 at 7:39 pm
    Hail and well met, Chris!
    Hisense is my favorite brand of TV having bought 5 so far in the last 1.5 years. Today I am giving a friend a TCL 4K set. That is what they want so…BINGO!
    At a not exactly local Best Buy I have seen some very large TVs costing well over $100,000. Those are for folks that are very serious about what the watch and what they view it on! Good for them. This Hisenese would likely be my choice if I had my druthers and the ability to buy one!
    I am a value minded individual. I am also quite the NITSwit, LOL!
    ORTucles of Thebes
    • Chris Boylan
      July 20, 2025 at 11:37 pm
      Hey, ORT,
      Great to hear from you as always. It is amazing what Hisense and TCL are doing these days, particularly in the bang-for-buck department. I wouldn’t be surprised if this one drops below $25K, perhaps even lower. Personally, I still prefer OLED for my viewing (mostly movies and episodic series). In my living room, something this size would dominate the room. 65-inch is still the sweet spot for me for the living room.
      And in the basement/home theater, I have a projection set-up with a 117-inch CinemaScope screen, so that’s about as cinematic as it gets. But for those who want the brightness, responsiveness and ease of use of a TV, but in a giant screen size, something like this or the 115-inch TCL make sense (if you’ve got the budget for it).
    • Ian White
      July 21, 2025 at 12:33 pm
      ORT,
      Ditto that sentiment. Hisense definitely offers tremendous value for the money.
      LG and Hisense are what I recommend to friends and family.
      IW
TVs
Hisense unveils 2026 U7 and U6 MiniLED TVs from 55 to 116 inches and $1,299 to $19,999, targeting Samsung and TCL in the TV...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
Panasonic has aligned with Skyworth for US TV production starting in 2026. Will this strengthen the brand or change what buyers expect from its...
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
LG came on strong at CES 2026 with a new suite of OLED TVs featuring stunning design and impressive video performance.
