DSLR Cameras
Nikon D5200 Digital SLR Camera
Nikon D5200
Nikon just announced the D5200 D-SLR camera, equipped with a new Nikon DX-format CMOS sensor with an effective pixel count of 24.1-million pixels and an image-processing engine equivalent to EXPEED 3 built into the D4 flagship camera. It offers the superior basic performance needed for full-scale photography in a compact and lightweight body.
The D5200 offers the same side-hinged vari-angle monitor as the D5100 that enables flexible shooting from any angle, high or low, making even self portraits possible. It is an entry-level model that meets photo enthusiasts’ demands for full-scale photography capabilities with its new Nikon DX-format CMOS sensor with an effective pixel count of approximately 24-million pixels as well as an image-processing engine equivalent to EXPEED 3 built into high-end Nikon D4, D800, D800E, and D600 digital SLR cameras for superior resolution, and image quality with very little noise at high sensitivities.
Nikon D5200 - back
The standard range of sensitivities covers a broad range of ISO 100 to ISO 6400, with support for additional expansion to equivalents up to ISO 25600 (Hi 2). It also offers the most focus points available in its class-39 — for fast and reliable focus acquisition and tracking. The Scene Recognition System, made possible with the same 2,016-pixel RGB sensor found in high-end Nikon cameras, more accurately analyzes scene brightness and color information, which is then reflected in autofocus, automatic-exposure, i-TTL balanced fill-flash, and auto white-balance control.
The D-Movie function supports recording of full-HD 1920 x 1080 60i/50i movies for sharp HD movies exhibiting excellent detail. The D5200 is also equipped with Special Effects mode that enables the application and adjustment of special effects with shooting. Combining a variety of effects with a vari-angle LCD monitor that enables shooting from a wide range of angles significantly broadens imaging expression possibilities with both still image and movie recording.
Nikon D5200 - left
Nikon D5200 - right
The D5200 is compatible with the Wireless Mobile Adapter WU-1a and the new Wireless Remote Controller WR-R10/WR-T10 (both available separately) for collaboration with smart devices and more possibilities for remote control over the camera, making the D5200 more convenient than its predecessor. When the WU-1a is connected to the camera, images can be transferred to a smart device, such as a smart phone or tablet, and the smart device can also be used to control camera shooting remotely. In addition, the new WR-R10 (transceiver) and WR-T10 (transmitter) enable remote control over the camera from greater distances and broader angles than are possible with infrared remote controls for simple and convenient remote control even through obstacles. The WR-T10 can be used to control the camera to which the WR-R10 is connected. However, it can also control multiple cameras to which WR-R10s have been connected, enabling smooth remote control over a number of cameras.
Nikon D5200 - LCD
Features
  • Vari-Angle LCD – The high-resolution, 921,000-dot 3-inch LCD screen swivels and rotates at a variety of angles, and is viewable at 170 degrees. This makes it easy to capture images and HD video from creative angles such as above the crowd or down low from a toddler’s perspective. Users can even swivel the LCD screen for creative and fun self-portraits.
  • In-Camera Special Effects for video and still images – By selecting the Effects option on the Mode Dial, users can apply a wide range of creative filters and effects for both photos and HD video. Modes include Selective Color to visually highlight up to three selected colors within a monochrome scene; Color Sketch to create a vivid drawing from a scene; Miniature effect to make a scene appear as a miniature model and Night Vision to enable images and video in very low-light by increasing the camera’s sensitivity. Users can also enable modes to emphasize silhouettes or create color effects with high-key and low-key images and video. These effects can be applied prior to shooting the photo or video, or can be applied post-capture for photos through the retouch menu.
  • Creativity has never been easier – The D5200 features an enhanced graphical user interface (GUI) that makes it easy to visualize camera settings for optimal results. Additionally, users can enable other visual effects including High Dynamic Range (HDR) and six settings of Nikon’s Picture Controls to creatively and automatically manipulate tone and color for striking images and HD video.
  • Wide ISO range (from 100-6400) – For shooting in even the most challenging lighting conditions, the D5200 covers a wide ISO range and is expandable to as high as ISO 25,600. Shooting at high ISO sensitivity enables users to shoot at faster shutter speeds and reduce the effects of image blur caused by camera shake even in low-light situations or when shooting a moving subject, delivering clean and sharp images with minimal noise.
  • EXPEED 3 image processing – Nikon’s most recent image processing engine, dubbed EXPEED 3, drives the rapid response and swift performance of the camera, while maximizing energy efficiency, reducing image noise and delivering true-to-life colors.
  • Scene Recognition System – Information from the 2,016 pixel RGB sensor is used to instantly analyze and recognize the scene prior to capture, resulting in adjustments to exposure, AF and white balance for the best possible image quality. The result is brilliant landscapes, flattering portraits and fast-moving action captured with split-second precision.
  • 39-point AF system with wide area coverage – The D5200 features Nikon’s quick and accurate 39-point AF system to help users create tack-sharp images for a wide variety of subjects. The Multi-CAM 4800 DX AF sensor works in tandem with the Scene Recognition System to accurately acquire and track subjects throughout the frame. Users can lock-on to fast moving subjects throughout the frame using 3D tracking to create sharp images of fast action, or use one of the other modes including single point AF, Dynamic AF and Auto-Area AF. When in Live View or recording video, contrast detect AF quickly acquires, and can even track focus through the frame.
  • Speed and performance – Whether upgrading from a compact point-and-shoot or exploring the benefits of D-SLR photography, users will appreciate the speed to capture fast action and fleeting moments at the press of a button. The D5200 can shoot full-resolution images at up to five frames-per-second to help freeze fast moving subjects, and quickly acquires focus thanks to the intelligent AF system. The D5200 delivers amazing performance with lightning fast start-up time and nearly imperceptible shutter lag, the time when the shutter button is pressed to when the beautiful image is captured.
[youtube id=”4OnV9CQOmVY” width=”610″ height=”373″]
NIKKOR, Speedlight and System Compatibility
The creative potential for the D5200 is unlimited when combined with the versatility of Nikon’s legendary NIKKOR optics and powerful system accessories. Compatible with Nikon’s dedicated DX-format lenses and more than 50 FX-format lenses as well as Nikon’s Speedlight System, the Nikon D5200 puts the ability to create stunning images and HD video at the user’s fingertips.
Price and Availability
The Nikon D5200 will be available in three colors (Black, Red and Bronze), starting in late January 2013 for $899.95 with the AF-S DX NIKKOR 18-55mm f/3.5-5.6 VR lens.
Nikon D5200 - top
Edifier MR4.5 Desktop Studio Speakers Black Lifestyle
T+A HV Series high-end audio components T+A HV Series high-end audio components
The SDX 3100 HV handles native DSD1024, streaming, and analog preamplification, while the A 3100 HV delivers 500 watts per channel. Together, they cost...
SIVGA Lyrebird IEMs front and back SIVGA Lyrebird IEMs front and back
Marantz Model 70 Integrated Amplifier on the left and CD 70 on the right Marantz Model 70 Integrated Amplifier on the left and CD 70 on the right
CD Players
Entry-level Marantz MODEL 70 adds HDMI ARC, aptX Adaptive Bluetooth and 50 watts per channel, while the CD 70 substantially undercuts the existing CD...
2026 MSI Maestro 500 Wireless Gaming Headset in Blue and Black 2026 MSI Maestro 500 Wireless Gaming Headset in Blue and Black
HiFi Rose RW800 Rose Air Lite Streaming Expansion Module Lifestyle Closeup HiFi Rose RW800 Rose Air Lite Streaming Expansion Module Lifestyle Closeup
Daily Deals
