WiiM Introduces Sound Lite Smart Speaker With Streamlined, Screenless Design
WiiM’s original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice remote.
WiiM Sound Lite Smart Speaker in white
WiiM isn’t wasting any time expanding its footprint in the smart-speaker arena. Hot on the heels of the original WiiM Sound, the new WiiM Sound Lite arrives as a stripped-down sibling aimed squarely at price-sensitive buyers who don’t need a touchscreen staring back at them. The pitch is simple: same size, same acoustic performance, same feature set — just without the 1.8-inch round display and without the bundled WiiM Voice Remote 2 Lite.
Everything else runs through the WiiM Home app, onboard controls, or your voice via Alexa or Google Assistant. It’s a cleaner, cheaper way to get into the WiiM ecosystem, and WiiM knows that’s exactly what a lot of consumers want.
wiim-sound-lite-black
Features
As a summary, here are the core features of the WiiM Sound Lite that it shares with the previously released WiiM Sound:
High-Resolution Wireless Streaming: Stream music, podcasts, Smart Presets, and radio in full 24-bit/192 kHz quality without keeping your phone locked to the speaker.
Connectivity: Built-in Wi-Fi 6E, Ethernet, and Bluetooth give you every modern wireless option, and there’s also a 3.5mm analog input for legacy sources.
Room Correction (AIRoomFit): WiiM’s room-tuning system measures your space and applies tailored corrections so the Sound Lite performs at its best in any environment.
Sound Customization: In addition to room correction, listeners can dial in the sound with 24 EQ presets, a 10-band graphic EQ, and a parametric EQ for deeper fine-tuning.
WiiM Home App
Stereo Pairing: Link two WiiM Sound speakers for true left/right stereo playback and a wider, more convincing soundstage.
Subwoofer Pairing: Add low-end authority by connecting the WiiM Sound to the upcoming WiiM Sub Pro for deeper, more controlled bass.
Home Theater Integration: Deploy the WiiM Sound as a surround or center channel in a Dolby 5.1 configuration to build a more immersive home cinema setup.
Universal Casting Support: Cast from virtually any major app using Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast for a frictionless streaming experience.
WiiM Ecosystem: The WiiM Home app ties it all together—streaming control, voice commands, EQ adjustments, stereo or surround configuration, and whole-home audio live in one place.
Comparison
wiim-sound-lite-vs- sound
WiiM Model WiiM Sound LiteWiiM Sound
Product TypeSmart SpeakerSmart Speaker
Price (each)$229$299
Frequency Response50 Hz – 20K Hz50 Hz – 20K Hz
Peak Power100 W total100 W total
Speaker Drivers1 x 4” long-throw woofer, 50W
2 x full-range tweeters, 2x25W
1 x 4”long-throw woofer, 50W
Crossover Frequency2.4 kHz. 2.4 kHz
Hi-Res AudioUp to 24-bit/192 kHz, gapless playbackUp to 24-bit/192 kHz, gapless playback
Room CorrectionAI RoomFit™ automatic/assisted tuning. AI RoomFit™ automatic/assisted tuning
EQAdvanced EQ in app (presets + custom); separate EQ settings for Wi Fi/Ethernet, Bluetooth, and Aux. On-device Quick EQ; advanced EQ in app (presets + custom); separate EQ settings for Wi-Fi/Ethernet, Bluetooth, and Aux.
Wireless InputWi-Fi 6E (802.11 b/g/n/ax, tri-band: 2.4/5/6 GHz)
Bluetooth 5.3 (Receiver & Transmitter, supports SBC, AAC, LC3)
Wired Input100 Mbps Ethernet
3.5mm Aux input
100 Mbps Ethernet
3.5mm Aux input
Control OptionsTouchButtons: Play/Pause, Volume Up/Down, Next/Previous Track
Voice: Works with Alexa or Google Assistant via compatible devices
App: WiiM Home App for iOS/Android/Windows/MAC/Apple TV/Google TV
1.8″ Round Touch Display (Hi‑Res)
WiiM Voice Remote 2 Lite (included) — one‑tap playback/volume/skip, push‑to‑talk voice, preset buttons
Supported PlatformsWiiMHome App, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Certification pending)WiiMHome App, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Certification pending)
Multi-Room AudioWiiM, Google Cast, and Alexa multi-room systemsWiiM, Google Cast, and Alexa multi-room systems
Stereo PairingEnables left/right speaker setup for expanded soundstageEnables left/right speaker setup for expanded soundstage
Home Theater IntegrationFunctions as the surround or center channel speaker in a Dolby 5.1 setupFunctions as the surround or center channel speaker in a Dolby 5.1 setup
Smart PresetStreamlines the listening experience by offering quick access to frequently used content and settingsStreamlines the listening experience by offering quick access to frequently used content and settings
Alarm ClockSet the alarm time, occurrence, and choose from various music sources.Set the alarm time, occurrence, and choose from various music sources.
Touch DisplayNoneScreen: 1.8” glass-covered, high-resolution touch display
Functions:  Playback control, album art, EQ adjustments, audio input selection, device settings
Display queue, presets, VU meters, time/date in standby mode
Supports customizable wallpapers
Guides setup (OOBE) and OTA firmware updates
PowerAC-powered, 100-240V AC universal power supply; energy-efficient standby; firmware over-the-air (OTA) updates.AC-powered, 100-240V AC universal power supply; energy-efficient standby; firmware over-the-air (OTA) updates.
FinishesMinimalist modern, Black/White, Fabric/Glass/PC.Minimalist modern, Black/White, Fabric/Glass/PC.
Dimensions146 x 146 x 193 mm
5.7” x 5.7” x 7.5”
146 x 146 x 193 mm
5.7” x 5.7” x 7.5”
Weight5.5 lbs (2.5 kg)5.5 lbs (2.5 kg)
In the BoxWiiM Sound Lite Smart Speaker
Power Cable
RCA/Aux Cable
Quick Start Guide
WiiMSound Smart Speaker
PowerCable
WiiMVoice Remote 2 Lite (with batteries)
USB-C Charge Cable for Remote
RCA to 3.5mm cable
QuickStart Guide
Setting up WiiM SoundPlug in and connect to Wi-Fi with the WiiM Home App.
RunAIRoomFit™totailor the sound to your room.
Add services and create Smart Presets or Music Alarms.
Personalize the display (clock/wallpaper/art) and create your first Smart Preset
wiim-sound-lite-lifestyle-white
The Bottom Line
WiiM knows exactly what it’s doing here. By shaving off the touchscreen and remote, the WiiM Sound Lite drops to a far more appealing $229, while keeping every core performance feature that actually matters: high-resolution streaming, room correction, analog input support, Wi-Fi 6E/Ethernet, full EQ control, and WiiM’s rapidly expanding ecosystem. Yes, it still skips AirPlay, HDMI-ARC, and any hope of a phono stage, but at this price—and with this feature density—it’s hard to argue with the value proposition.
The competitive landscape only sharpens the point. The KEF Coda W costs more and still can’t match the connectivity suite. The Denon Home 150 sits just above it at $249 with AirPlay and HEOS support, but doesn’t bring the same customization or next-gen wireless stack. For WiiM loyalists—and for anyone who wants serious capability without serious sticker shock—the Sound Lite hits the sweet spot where price, performance, and practicality finally meet.
Price & Availability
The WiiM Sound Lite Smart Speaker will be available for  $229 at Amazon beginning on December 25, 2025.
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Amp Multi is Sonos’ first new product in over a year, built for complex home audio systems. Is this where the platform goes next?
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Our favorite integrated amplifiers for audiophiles in 2025 includes models from WiiM, Advance Paris, Moon by Simaudio, Quad and Marantz.
Our favorite streaming amplifiers of 2025 for audiophiles include models from WiiM, Marantz, Ruark, Naim and Aavik.
In 2025, the best-in-class streamers from Cambridge, Bluesound and WiiM set the pace as new challengers from FiiO, Topping, and Eversolo loom for 2026.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
At $329, WiiM Ultra is the company's top-of-the-line digital music streamer which adds a touchscreen, HDMI ARC and a subwoofer out.
Discover the FiiO K15 DAC Headphone Amp: A powerful, affordable desktop solution offering balanced audio, Wi-Fi, and Bluetooth, all for $549. Compare with top...
