At MWC 2026 this week, TCL expanded its personal audio lineup with the new CrystalClip open-ear wireless earbuds, including a premium CrystalClip with Crystals by Swarovski edition. While TCL is best known globally for its televisions, the company has steadily built a presence in the true wireless category with models such as the MOVEAUDIO S600, Neo, and S180.
The new CrystalClip series signals a deeper push into the fast-growing open-ear clip-on earbud segment, combining air conduction audio technology, AI-driven features, and extended battery life with a design focused on all-day comfort.
Tip: Watch our TCL CrystalClip news brief on YouTube
Air Conduction vs. Bone Conduction: What’s the Difference?
Open-ear clip-on earbuds rely on air conduction to deliver sound into your ears, directing audio toward the ear canal without sealing it off. This approach has gained traction because it tends to provide a more natural fit, greater long-term comfort, and fuller sound layering with more balanced bass, mids, and treble compared with most bone-conduction designs. At the same time, the open design keeps your ears unobstructed, allowing you to remain aware of your surroundings—an important advantage for commuting, exercising outdoors, or everyday listening where safety and environmental awareness still matter.
Clip-on Design Prioritizes Awareness and All Day Comfort
The clip-on form factor of the TCL CrystalClip is designed to keep listeners aware of their surroundings while enjoying music, podcasts, or calls. Because the earbuds rest outside the ear canal, users can still hear approaching traffic, public announcements, or nearby conversations without removing the earbuds. This open design supports everyday situational awareness while maintaining continuous playback.
To balance comfort with stability, TCL integrates an ergonomic clip structure engineered for consistent contact without excessive pressure. The CrystalClip applies approximately 43 grams of clamping force to help maintain a secure fit across different ear shapes. A titanium arch bridge reinforces the clip mechanism, contributing to durability and shape retention over extended use.
Each earbud weighs just 5.5 grams, minimizing fatigue during long listening sessions. With an IPX4 water resistance rating, the CrystalClip is built to withstand sweat and light splashes, making it suitable for office use, workouts, commuting, and daily mobility.
Blending Technology & Style
Beyond comfort and stability, the TCL CrystalClip combines practical audio engineering with a design intended to complement everyday style. The earbuds feature a streamlined clip-on silhouette that sits close to the ear, allowing them to function not only as a listening device but also as a subtle accessory. The compact shape and balanced proportions help maintain a clean, understated appearance suitable for commuting, office environments, or casual use.
For users who prefer a more fashion-forward option, TCL also offers a CrystalClip with Crystals by Swarovski edition. This version incorporates decorative crystal elements that add a subtle visual accent while maintaining full functionality, including charging and wireless connectivity. The result is a design that blends personal audio technology with a touch of jewelry-inspired styling.
Immersive Audio Experience
Inside the TCL CrystalClip, a 10.8 mm dual-magnetic dynamic driver forms the foundation of its audio performance. The driver is paired with 3D spatial audio processing, designed to create a wider and more layered listening presentation for music, podcasts, and video content while maintaining clarity across highs, mids, and bass.
TCL also incorporates enhanced bass tuning to add greater depth and presence to everyday listening. While the open-ear design prioritizes comfort and environmental awareness, the tuning aims to maintain a balanced and engaging sound profile suitable for a wide range of content.
For connectivity, Bluetooth enables wireless playback from smartphones, tablets, and other compatible devices. During calls, dual microphones with ENC (Environmental Noise Cancellation) help reduce background noise so voices remain clearer in busy environments such as cafés, public transit, or crowded streets.
Smart Interaction Powered by AI
Beyond audio playback, the TCL CrystalClip is designed to support communication and everyday productivity through a range of smart features. Touch controls on the earbuds allow users to manage playback, answer calls, and activate additional functions directly from the earbud surface. When paired with compatible TCL smartphones and supported apps, users can also access simultaneous interpretation features, enabling real-time multilingual communication for travel, meetings, or everyday interactions.
CrystalClip also provides quick access to popular voice assistants, including Siri, Google Assistant, and Google Gemini. This allows users to check information, manage schedules, control smart devices, or send messages using voice commands, keeping interactions hands-free while on the move.
All-Day Listening
TCL’s CrystalClip provides up to 36 hours of total battery life and fast charging that delivers hours of playback in just minutes. Bluetooth 5.4 connectivity and dual-device seamless switching further enhance convenience, enabling seamless transitions between smartphones, tablets, and other connected devices.
Comparison
| Crystal Clip / Swarovski Edition | Sony LinkBuds Clip | Bose Ultra Open | |
| Product Type | Wireless Earbuds | Wireless Earbuds | Wireless Earbuds |
| Wearing Style | Clip-On | Clip-On | Clip-On |
| Price | $100 / $200 (unconfirmed) | $228 | $299 |
| Noise Cancelling | Yes | Yes | – |
| Driver | 10.8 mm | 11mm | 12mm |
| MIC | 2 mic per earbud | 2 mic per earbud | 2 mic per earbud |
| MIC Type | MEMS | MEMS | MEMS |
| Voice Assistant | Yes – Native VA | Google Assistant, Siri, and Gemini Live | Siri, Google Assistant |
| EQ | 3 modes – Bass, Balanced, Podcast | Yes | 3-band (Bass, Mid, Treble) via app |
| Lag-free Mode | 127ms | – | – |
| OS | Android, iOS, Windows | Android, iOS | Android, iOS |
| Bluetooth Version | 5.4 | 5.3 | 5.3 |
| Bluetooth Codec Support | SBC, AAC | SBC, AAC, LC3 | SBC, AAC |
| Google Fast Pair* | Yes | Yes | Yes |
| App | TCL HOME App | Sound Connect App | Bose Music App |
| IP rating | IPX4 | IPX4 | IPX4 |
| Charging Port | USB-C | USB-C | USB-C |
| Playback Time – Earbuds | 8 hours | 8 hours | 7 hours |
| Playback Time – With Case | 36 hours | 14 hours | 19.5 hours |
| Charging Time – Earbuds | 1.5 hours | 1.5 hours | 1 hour |
| Charging Time – Case | 2 hours | 3 hours | 3 hours |
| Fast Charging | 15-minutes = 3 hours of playback | 3-minutes = 1 hour of playback | 10 min = 2 hours of playback |
| LED lights on the Charging Case | Yes | Yes | Yes |
| Earbud Weight | 5.5 g | 6.4 g | 6.35 g |
| Case dimension (HxWxD) | 65 x 52 x 29.2 mm | 50.4 x 50.4 x 32.6 mm | 41.9 x 65 x 26.4 mm |
| Case Weight | 38 g | 42 g | 44 g |
| Colors | Lunar White | Black Lavender Green Greige | Black White Smoke Sunset Iridescent Carbon Blue Chilled Lilac Sandstone Lunar Blue Midnight Violet Driftwood Sand Moonlight Grey Diamond 60th Edition |
The Bottom Line
TCL has made significant progress in the television market over the past year, highlighted by flagship displays such as the TCL X11L SQD Mini LED TV and expanded manufacturing partnerships that have strengthened its global presence. With the introduction of the CrystalClip line at Mobile World Congress 2026, the company is clearly looking to extend that momentum into the highly competitive wireless earbud category. Although TCL has previously released models such as the MOVEAUDIO S600, Neo, and S180, its presence in personal audio has remained relatively low profile until now.
The CrystalClip series stands out by combining open ear clip-on design, air conduction audio, spatial sound processing, and AI-driven features at a price that undercuts many established competitors. In addition with CrystalClip with Crystals by Swarovski edition, TCL is leaning into the growing overlap between personal audio and wearable style. On the feature side, the earbuds compete with products such as the Sony LinkBuds Clip and Bose Ultra Open Earbuds, both of which offer similar open-ear concepts but at significantly higher prices.
What ultimately makes the CrystalClip unique is the combination of affordable pricing, fashion-forward styling, spatial audio support, and open-ear situational awareness in a lightweight clip-on design. The addition of a low-latency gaming mode broadens the appeal even further for mobile gamers who want wireless convenience without added delay.
For listeners curious about open-ear earbuds but unwilling to spend premium prices, the CrystalClip may offer an accessible entry point. Commuters, casual listeners, and style-conscious buyers looking for something different from traditional in-ear buds will likely find the concept appealing. Whether TCL can carve out meaningful market share in an already crowded wireless earbud space remains to be seen, but the CrystalClip lineup suggests the company intends to compete on features, design, and aggressive pricing rather than brand legacy alone.
Price & Availability
Availability is expected across Asia-Pacific, Europe, and North America beginning March 2026.
- CrystalClip: €79 (about $90 US) available March 2026
- CrystalClip Swarovski Crystal Version €149 (about $175 US) available April-June 2026
Note: U.S. pricing is unconfirmed.
Related Reading:
