Not everyone has the space or patience for a dishwasher sized subwoofer dominating the room, and that reality is exactly where SVS is aiming with its latest release. Making its debut at AXPONA 2026, the new $999 3000 Micro R|Evolution takes the core technology from the recently launched 3000 R|Evolution series and shrinks it down into something that actually fits into real world living spaces.
That context matters. Earlier in 2026, SVS rolled out the 3000 R|Evolution lineup with redesigned 13-inch drivers, more powerful amplification, and upgraded DSP trickled down from its flagship models, pushing performance deeper into the infrasonic range with far more control . Now they’ve taken that same platform and applied it to the smallest box in the lineup.
The 3000 Micro R|Evolution replaces the original 3000 Micro; one of the brand’s most successful compact subs, and upgrades it with larger drivers, new amplification, and more advanced DSP, while keeping the footprint intact .
This isn’t about chasing the biggest numbers on a spec sheet. Large subs still have their place in dedicated home theater rooms, but most people aren’t building those. The 3000 Micro R|Evolution is aimed squarely at everyone else; apartment dwellers, shared spaces, and systems where space is limited but the expectation for real bass hasn’t gone anywhere.
SVS 3000 Micro R|Evolution Core Features
Acoustically Optimized Sealed Cabinet Design: The 3000 Micro R|Evolution uses extra thick MDF side baffles and rigid internal bracing to support its dual driver assembly and maintain an acoustically inert enclosure. The reinforced design minimizes cabinet resonance and prevents unwanted coloration, even during deep bass playback at high output levels.
Force Balanced Drivers: The 3000 Micro R|Evolution employs dual opposing active 9-inch drivers that fire in opposite directions to cancel mechanical forces, reducing cabinet vibration and maintaining a sonically inert enclosure. Each high excursion driver uses a progressive inverted surround to maximize linear displacement, enabling greater air movement and delivering deep, tactile bass even from a compact cabinet.
Class D Amplification: Power is delivered by a Class D amplifier with a discrete MOSFET output stage rated at 1,200 watts continuous and over 4,000 watts peak when needed.
Advanced DSP: A 295 MHz Analog Devices DSP manages power delivery, thermal performance, and driver behavior in real time, optimizing output while protecting the system under demanding conditions.
Balanced XLR Inputs: Alongside unbalanced RCA connections, balanced XLR inputs provide flexible integration with higher-end systems. The 3000 Micro R|Evolution is designed to work equally well in stereo setups, home theater systems, and even studio environments for mixing and mastering.
Switch Mode Power Supply: The switch mode power supply ensures stable, consistent output even when AC line conditions fluctuate, maintaining performance under varying power conditions.
SVS Subwoofer Control App: Installed on a smartphone (iOS, Android), this app provides for easy setup, tuning, and system integration, including volume, low-pass filter, phase, polarity, room gain compensation, and up to six parametric EQ bands, with three onboard memory presets for fast system adjustments.
Comparison
| SVS Model | 3000 Micro R|Evolution (2026) | 3000 Micro (2021) |
| Product Type | Powered Subwoofer | Powered Subwoofer |
| Price | $999.99 | $899.99 |
| Subwoofer Type | Sealed | Sealed |
| Driver Size | Dual 9-inch Opposing Drivers | Dual 8-inch Opposing Drivers |
| Amplifier Type | Class D | Class D |
| Amplifier Power Output | 1200 watts continuous 4000+ Watts Peak | 800 watts continuous 2500+ watts peak |
| Frequency Response (+/-3dB) | 20Hz – 230Hz | 23Hz – 240Hz |
| Signal-to-Noise Ratio (SNR) | Not Indicated | Not Indicated |
| Inputs | 1 x Stereo RCA Unbalanced or LFE 1 x XLR Balanced | 1 x Stereo RCA Unbalanced or LFE |
| Outputs | 1 x Stereo RCA Unbalanced | 1 x Stereo RCA Unbalanced |
| Dimensions (HWD w/ grille) | 10.9” × 11.8” × 10.8” 276.9 x 299.7 x 274.3 mm | 10.9” x 11.7 “ x 12.2” 278 x 297 x 309.9 mm |
| Weight | 22.5 lbs. (10.2kg) | 22.5 lbs (10.2kg) |
“When the original SVS 3000 Micro subwoofer launched, we said it was like a magic trick for doing what no compact subwoofer had ever done before,” said Gary Yacoubian, President of SVS. “Our design team completely reimagined the original concept with larger drivers, double the amplifier output, lower distortion, the most powerful DSP ever deployed in a home subwoofer, and more tuning features and connectivity options, all from a cabinet that’s roughly the same size. The result is not just a vast improvement over the previous design, but a new reference standard for all micro subwoofers.”
The Bottom Line
SVS isn’t chasing novelty here. The 3000 Micro R|Evolution is a calculated move that takes the company’s latest amplifier and DSP platform and pushes it into a form factor that actually works in real homes. Dual opposing drivers, serious power, and advanced control in an 11 inch cabinet is the hook, and it directly addresses the biggest compromise with compact subs which has always been output and control.
What makes it stand out is how much of the larger 3000 R|Evolution DNA made the cut. This isn’t a watered down version for small rooms. It’s a deliberate attempt to deliver legitimate low frequency extension and tactile impact without forcing people to redesign their living space around a subwoofer.
What’s missing is the effortless headroom and room pressurization of larger ported designs. Physics still wins. If you have a dedicated theater and want to feel explosions in your chest from across the room, SVS already sells you that solution. This isn’t it.
But for everyone else and that’s most people the 3000 Micro R|Evolution makes a lot more sense. It’s built for apartments, shared living spaces, and systems where space and aesthetics matter just as much as performance. It also hits a sweet spot for two channel listeners who want real bass integration without turning their setup into a science project.
Price & Availability
The SVS 3000 Micro R|Evolution subwoofer is debuting at AXPONA 2026, and will be available April 30, 2026 for $999.99 at svsound.com in piano gloss black or white finish. Pre-orders start now.
Related Reading:
- SVS Unleashes R|Evolution: New 3000 Series Subwoofers and Dolby Atmos Soundbar Debut at CES 2026
- SVS 5000 R|Evolution Subwoofers Let You Feel Movie Night in the Next Zip Code
- New SVS 17-inch Subwoofer Will Rock Your World:
- SVS’s Ultra Evolution Flagship Speakers
- More AXPONA 2026 Coverage
