SOUNDPEATS H3 Wireless ANC Earbuds Support LDAC and aptX Lossless for $129, No Champagne Budget Required
The SOUNDPEATS H3 true wireless earbuds launch at $129 with Snapdragon Sound, LDAC, aptX Lossless, 55dB hybrid ANC, and app-based EQ in a crowded earbud market.
SoundPeats H3 with Hear the Difference on Charging Case
The SOUNDPEATS H3 Wireless ANC Earbuds ($129) drop into the overcrowded pool of true wireless earbuds, where meaningful differentiation is often drowned out by hype. But with support for Lossless hi-res streaming, SOUNDPEATS is betting that a full-feature set at a budget-friendly price will help the H3 stand out in a market that rarely makes sense.
SOUNDPEATS H3 Wireless ANC Earbuds with Snapdragon Sound, LDAC, and aptX Lossless
The SOUNDPEATS H3 is the newest addition to the brand’s wireless earbud lineup. Following in the footsteps of the H1 and Opera series—and coming after the Air5 Pro earlier in 2025—the H3 now takes the flagship spot in SOUNDPEATS’ portfolio.
Designed to compete with wired Hi-Fi options, the H3 delivers premium sound through two balanced armature drivers and a 12mm composite dynamic driver. It pairs this hardware with Snapdragon Sound, LDAC, aptX Lossless, and SOUNDPEATS’ most advanced hybrid ANC, offering up to 55dB of noise reduction for audiophile-grade performance in a daily-use wireless earbud.
soundpeats-h3-wireless-earbuds-woman
Key SOUNDPEATS H3 Features:
  • Flagship Sound Architecture: The SOUNDPEATS H3 combines two balanced armature drivers with a 12mm dynamic driver to deliver a full-range, detailed audio response.
  • High-Resolution Wireless Audio: Powered by the Qualcomm QCC3091 with Snapdragon Sound, the H3 supports LDAC and aptX Lossless streaming to maximize driver performance and ensure hi-res playback.
  • Long Battery Life & Fast Charging: Up to 7 hours of playback on a single charge, 37 hours total with the case, plus 2 extra hours from just a 10-minute fast charge.
  • Adaptive Noise Control: AI-powered hybrid ANC with six microphones delivers up to 55dB of noise reduction across four modes—Adaptive, Indoor, Outdoor, and Traffic.
  • Clear Calls: Six built-in microphones with AI noise reduction and cVc 8.0 ensure stable, clear voice quality for hands-free calls.
  • Distinctive Design: Semi-transparent housings paired with precision aluminum details give the H3 a premium look to match its sound.
  • App-Driven Audio Tuning: The Peats Audio app offers real-time sound customization with a 9-band EQ and multiple sound profiles.
  • Dual-Device Connectivity: Bluetooth Multipoint allows seamless switching between two devices, such as a smartphone and a laptop.
  • Gaming Support: A 60ms low-latency Game Mode ensures smooth, synchronized audio for gaming and streaming.
SOUNDPEATS H3, H1, and Air5 Pro Comparison
SOUNDPEATS ModelH3 (2025)H1 (2021)Air5 Pro (2025)
Product TypeWireless EarbudsWireless EarbudsWireless Earbuds
Price$129.99$79.99$79.99
Drivers (each ear)2  Balanced armature drivers
12mm dynamic driver
Knowles balanced armature driver
Customized dynamic driver
10mm Composite Bio-Diaphragm Driver (PU + PEEK)
ChipQCC3091QCC 3040QCC3091
Bluetooth VersionV5.4V5.2V5.4
Supported Bluetooth ProfilesHSP/ HFP / A2DP / AVRCPHSP / HFP / A2DP / AVRCPHSP / HFP / A2DP / AVRCP
Noise CancellationAI-powered ANC with 6-mic delivers up to 55dB noise reduction across 4 modes (Adaptive, Indoor, Outdoor, Traffic)cVc 8.0 Noise Cancellation & 4 MicsAI Adaptive ANC (-55dB) 6-MIC
AI Call Noise Cancellation
 cVc 8.0 Wind Noise Reduction
Supported Bluetooth CodecSBC/AAC/LDAC/aptX/aptX Adaptive/aptX
Note: LDAC is disabled by default. Enable via the PeatsAudio app
SBC, AAC, APTX, APTX-adaptiveSBC/AAC/LC3/LDAC/aptX/aptX Adaptive/aptX Lossless
Note: LC3 and LDAC are disabled by default. Enable via the PeatsAudio app
Frequency Response20Hz-40KHz20-20KHz20Hz-40KHz
Control MethodTouchTouchTouch
Water Resistance (IPX Rating)IPX5IPX5IPX5
Total Music Play Time at 60% Volume (AAC codec, standard mode)37 hours with chasing Case40 hours (10 hours/charge, case holds 3 charges)7.5Hrs Playtime + 37Hrs with Charging Case
Total Standby TimeNot Indicated55H35H
Auto-turn off if DisconnectedNot IndicatedNot IndicatedPowers off after 10 minutes if no device has ever been paired. Enters low-power mode after 10 minutes of disconnection if previously paired.
Charging Input5V/1A5V/1A5V/1A
Battery Capacity35 x 2 mAH (Earbuds)
 400mAH (Case)
55mAh x 2 (Earbuds)
500mAh (Case)
35mAh x 2 (Earbuds)
520mAh (Case)
Charge TimeEarbuds: 1H
Charging Case: 2H
Earbud Charge Time: 1.5 hours
Charging Case Charge Time: 2 hours
Earbuds: 1H
Charging Case: 2H
Fast ChargingSupported (10 minutes = 2Hrs playback)Not IndicatedSupported (10 minutes = 2 hours playback)
Charging portType-CType CType-C
Length*Width*Height  (mm)Earbuds: 25.64 x 22.16 x 25.97 mm
Charging Case: 70.88 x 48.18 x 31 mm
Earbuds: 24.5 x 22.5 x 27 mm
Charging Cae: 71.9×41.9×32.8mm
Earbuds: 34.6 x 19.87 x 23.50mm
Charging Case: 66.88 x 48.33 x 26.92mm
Net WeightSingle Earbud: 6g
Earbuds+Charging Case: 53g
Single Earbud: 6.5g Single Earbud: 4.8g
Earbuds+Charging Case: 50.3g
ColorsSemi-transparent with Aluminum highlightsBlack, Transparent BlueBlack (White, Purple, and Beige will be available later)
APP Links Google Play – PeatsAudio APP
App Store – PeatsAudio APP
What’s included in the packageEarbuds
Charging Case
Type-C Charging Cable
Ear Tips (XS/S/M/L/XL) 5 Pairs
User Manual
SOUNDPEATS Stickers
Earbuds
Charging Case
Ear tips (S, M, L) 3 Pairs  & 1 pair of foam tips
User Manual
Earbuds
Charging Case
Charging Cable
Ear Tips (S/M/L) 3 pairs
User Manual
App Guide
SoundPEATS Stickers
soundpeats-h3-accessories
The Bottom Line
At $129.99, the SOUNDPEATS H3 stands out with Snapdragon Sound, aptX Lossless, LDAC, AI-powered ANC up to 55dB, and app-based 9-band EQ tuning—features rarely seen at this price. But competition is fierce: the Nothing CMF Buds 2 bring Dirac optimization for less, Skullcandy Method pushes “Bose-like” tuning, Final’s VR3000 targets gamers with spatial audio, and Samsung’s Galaxy Buds3 FE land just above at $150. Specs and features give the H3 an edge, but comfort and fit remain the dealbreaker—because no amount of hi-res streaming matters if you can’t stand wearing them.
Where to buy: $129.99 at Amazon | soundpeats.com
Emotiva BasX TA2+ Integrated Amplifier
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Lyngdorf SB-75 Passive Soundbar Lifestyle Angle Lyngdorf SB-75 Passive Soundbar Lifestyle Angle
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Sonos Era 100 SL and Sono Play Wireless Speakers 2026 Sonos Era 100 SL and Sono Play Wireless Speakers 2026
Sonos unveils the $299 Play and $189 Era 100 SL wireless speakers designed for flexible listening at home or on the go. Are these...
Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds Woman wearing ASUS ROG Cetra Open Gaming Wireless Earbuds
ASUS launches the ROG Cetra Open Wireless gaming earbuds with cross platform support for PC, Mac, PlayStation, Switch, iOS, and Android. Are open earbuds...
STAX SR-009S Headphones STAX SR-009S Headphones
STAX unveils the SR-009D, the latest evolution of its legendary SR-009 electrostatic headphone platform. Can the new flagship raise the bar again?
ABYSS Diana TC Signature Audiophile Headphones ABYSS Diana TC Signature Audiophile Headphones
Can the $4,995 ABYSS Diana TC Signature really compete with Audeze and Meze? We listened at CanJam NYC 2026 on a $30K Woo Audio...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
LG expands its xboom lineup with Buds Plus and Buds Lite, adding ANC, Auracast, UVnano+ tech, and up to 35 hours of battery life.
Our hands-on review of Sony’s new top-of-the-line WF-1000XM6 wireless earbuds reveals they've been improved in a few key areas.
Premium audio sounds better than ever but warranties are stuck in the past. Why are $400 to $2000 headphones and speakers still treated as...
26 Best in Show winners crowned at CES 2026 across multiple categories including TVs, projectors, loudspeakers, home theater, portable audio, headphones and more.
Sony’s LinkBuds Fit Hatsune Miku Edition blends ANC earbuds with a virtual idol—real human voice, not AI hype. Culture, color, and clarity collide.
EarFun unveils Air Pro 4+, Clip 2, and Wave Pro X at CES 2026 with hybrid ANC, Bluetooth 6.0, lossless audio, AI translation, and...
Find out if your Bluetooth earbuds or wireless headphones are vulnerable, and update your firmware just in case.
