Sony Launches INZONE H9 II Wireless Gaming Headset and E9 In-Ear Monitors for Gamers
Sony expands its INZONE lineup with the H9 II Wireless Gaming Headset and E9 IEMs, featuring FNATIC tuning, 360 Spatial Sound, and pro-level gaming audio.
Sony INZONE H9 II Wireless Gaming Headset and E9 Wired IEM
Sony has been busy flooding the market with new cans—LinkBuds Open and Fit, the WH-1000XM6, and even the Pulse Elite—and now they’ve decided gamers need some fresh toys too. Enter the INZONE H9 II Wireless Gaming Headset and the E9 IEMs, because apparently immersive sound and low latency weren’t already keeping you glued to your chair for 12 straight hours.
Sony INZONE H9 II Wireless Gaming Headset: Features, Specs, and Performance
sony-inzone-h9-ii-black
Sony INZONE H9 II Wireless Gaming Headset (black)
Successor to the original H9, the Sony H9 II doesn’t just slap on a new badge—it actually brings some meaningful upgrades, thanks in part to Sony’s team-up with FNATIC. Translation: these cans aren’t just for casual Call of Duty nights, they’re tuned for the people who actually think spawn timing is a lifestyle choice.
The headline change is the new 30mm dynamic driver, borrowed straight from Sony’s WH-1000XM6 wireless headphones. That means better performance across the frequency range and bass that hits harder than your average energy drink.
Gamers also get a new FPS (First Person Shooter) Mode, plus support for both the INZONE Hub and Sony Sound Connect, because apparently default settings are for quitters.
Battery life anxiety? Forget it. The H9 II gives you up to a full hour of use on just a 5-minute charge—perfect for when you’re already late for your squad and “sleep” is just a rumor.
And since lugging around a headset shouldn’t feel like carrying a brick, the H9 II trims down to 260 grams without the detachable mic, or 273 grams with it. That mic isn’t just there for show either—it delivers 50dB of gain and a 14,000 Hz frequency range, which is literally double what the original H9 offered. Trash talk never sounded so crisp.
Sony INZONE H9 II vs. H9 Comparison
sony-inzone-h9-ii-vs-h9
H9 II (2025)H9 (2022)
Product Type Wireless Gaming Headset Wireless Gaming Headset
MSRP$349.99$329.99
Noise Cancelling  Yes (AI-Based)Yes
Driver30mm (same as Sony WH-1000M6)40mm
360 Spatial Sound Gaming and PersonalizerYesYes
FPS Mode with FnaticYes
INZONE Hub (PC)Yes
Sony Sound Connect (Mobile) Yes
Detachable MicYes
Mic DirectivityUniterctionalBi-Directional
Bluetooth Classic
LE Audio
Classic
Audio Cable Included Yes
Battery Life 30 Hours32 Hours
Quick Charge 5 min = Up to 1 Hour Play10 min = 1 Hour Play
Weight273 grams330 grams
Colors Black/WhiteBlack/White
Included AccessoriesHeadphone Cable
USB-C cable (USB-A to USB-C)
USB-C transceiver
Soft pouch
 Warranty card
 Reference guide
USB Cable
USB transceiver
Warranty card
Reference Guide
Sony INZONE E9 In-Ear Monitors for Gaming: Specs, Features, and Performance
sony-inzone-e9-white
Alongside the full-size H9 II headset, Sony is also rolling out something new for gamers who prefer to keep things light: the INZONE E9 In-Ear Monitors. Unlike the headset, the E9 doesn’t have a direct predecessor, but like the H9 II it’s been tuned in collaboration with FNATIC—so yes, these little guys are built with competitive play in mind, not just casual background Spotify.
The E9 features a high-stability ear hook design to keep them locked in place during long sessions, plus a sealed structure for passive noise isolation—because your teammates are loud enough without hearing the rest of your house. Sony also bakes in 360 Spatial Sound and EQ adjustments specifically tailored to highlight footsteps and gunshots in FPS titles. If someone’s sneaking up on you, it won’t be the earbuds’ fault.
Connectivity is flexible with both USB-C and 3.5mm options, and the included 1.8-meter cable means you won’t be tethered like a dog on a short leash. PC gamers get additional tuning control via the INZONE Hub, thanks to an included USB audio box.
At under 20 grams, the E9 is featherlight, but Sony still throws in extras: hybrid earpieces (two types), noise-isolation tips, a carrying case, and the usual paperwork. Available in black or white, the INZONE E9 is essentially Sony’s way of saying: “You wanted gaming IEMs? Fine, here’s a set—now stop borrowing your AirPods for Valorant.”
sony-inzone-e9-in-case
Sony E9 IEM Features
Sony Model E9 (2025)
Product TypeIn-Ear Monitor
Price$149.99
High Stability Ear HookYes
Sound Tuned by FNATICYes
Drivers (each ear)1 x 5mm MDD (Micro Dynamic Driver)
Passive Noise Isolation Yes (sealed structure)
360 Spatial Sound Yes
EQ Yes – Adjusted to emphasize footsteps and gunshots in FPS gameplay
INZONE Hub (PC)Yes
Wired Connectivity 3.5mm and USB-C
Cable Length1.8 meters
Hybrid Earpieces2 Types included
Included Accessories Noise isolation earbuds tips
Hybrid earbuds tips
Carrying Case
Reference guide,
Warranty card
USB Audio Box (for INZONE Hub)
Colors Black, White
Weight < 20 grams
sony-inzone-h9-ii-front-white
Sony INZONE H9 II (front)
The Bottom Line
Sony’s latest gaming audio drop shows they’re serious about competing beyond casual plug-and-play gear. The INZONE H9 II Wireless Gaming Headset builds on the original H9 with a lighter frame, detachable mic, faster charging, and the same 30mm dynamic driver found in the WH-1000XM6. Add in FNATIC’s tuning, FPS Mode, and access to Sony’s INZONE Hub, and you’re looking at a headset designed to give competitive gamers both immersion and a tactical edge. Downsides? It’s not exactly cheap, and even with the weight savings, some players still prefer the less bulky in-ear route.
That’s where the INZONE E9 IEMs come in. Sony’s first stab at gaming-focused IEMs offers passive noise isolation, 360 Spatial Sound, and an EQ tuned for FPS awareness. At under 20 grams with both USB-C and 3.5mm connectivity, they’re lightweight and versatile, though without a predecessor in Sony’s lineup, performance is still an open question. Priced in line with competitors like the Campfire Audio Axion 1 ($249) and Meze Audio Alba ($159), the E9 will need to prove it can hang with established audiophile brands while delivering the latency and positional accuracy gamers demand.
In short: the H9 II looks like a safe upgrade for Sony loyalists, while the E9 is more of a wild card—one that could pay off if Sony nailed the tuning. Either way, the competition just got interesting.
Price & Availability
Note: The previously released INZONE H9 is $329.99 $198.95 at Amazon
Pro-Ject Debut Reference 10 Turntable Lid Open
Pro-Ject unveils the Debut Reference 10 and names a new U.S. distributor. With pricing updates and tariff shifts looming, what changes for buyers?
Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow Audioengine A2+ Desktop Speakers with S6 Subwoofer and Crosley C6 Turntable in Limoncello Yellow
Audioengine’s A2+ system in Limoncello Yellow mixes analog and digital playback and makes it easier to believe spring will eventually show up.
Sennheiser CX 80U Wired Earbuds and HD 400U Headphones Sennheiser CX 80U Wired Earbuds and HD 400U Headphones
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Creek Audio Cymatics 6 Stand-mount Speaker Front Creek Audio Cymatics 6 Stand-mount Speaker Front
Can Creek Audio stand out in 2026 as it enters the crowded speaker market and rethinks its amplifier strategy?
ProAc Response DB1R Stand-mount Loudspeakers ProAc Response DB1R Stand-mount Loudspeakers
Can ProAc’s compact Response DB1R with ribbon tweeter deliver true high end performance in a standmount likely priced around $5,000 per pair?
ATC EL50 Active Floorstanding Loudspeaker ATC EL50 Active Floorstanding Loudspeaker
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Is the DUNU DN142 the smartest buy under $300? This tribrid IEM delivers lively treble, controlled sub bass, strong build quality, and one of...
Our hands-on review of Sony’s new top-of-the-line WF-1000XM6 wireless earbuds reveals they've been improved in a few key areas.
Is the SIVGA Nightingale Pro the planar IEM that finally gets linear tuning right, or is its warm, reference sound too niche to break...
The Case for Audio/Video Receivers (AVRs) While soundbars have evolved over the years and can provide a convenient solution to better TV sound, nothing beats a...
Can Sony gain ground in a crowded entry-level vinyl market with the new PS-LX3BT and PS-LX5BT Bluetooth turntables, or will strong competition from established...
At $229 do Sony LinkBuds Clip justify their price with comfort, smart features and open-ear convenience or do the sound tradeoffs matter more?
Premium audio sounds better than ever but warranties are stuck in the past. Why are $400 to $2000 headphones and speakers still treated as...
Sony and TCL are forming a global TV joint venture with TCL holding majority control. It’s a seismic power shift that rewrites the future...
