Samsung is expanding its already crowded TV lineup for 2026 with a new range of Mini LED 4K UHD models, alongside an updated Neo QLED series that pushes further into premium territory. The strategy is familiar but effective: take the core advantages of Mini LED backlighting; better contrast control, higher brightness, and more precise local dimming, and pair them with a deeper layer of AI-driven processing and smart platform refinements.
There’s a lot to unpack across both categories, so we’re keeping this focused. This article breaks down Samsung’s 2026 Mini LED 4K lineup; where the company is clearly trying to hit the sweet spot between performance and price, while the Neo QLED models, which lean more heavily into flagship features and higher-end positioning, are covered separately.
What Are Samsung Mini LED TVs?
Samsung’s Mini LED TVs are still LCD-based displays, but they use a more advanced form of full-array LED backlighting. The difference comes down to scale: the LEDs are significantly smaller, which allows for far more precise local dimming and better control of light across the screen—especially when rendering bright objects against darker backgrounds.
When paired with HDR formats like HDR10+, this improved backlight control translates into higher peak brightness, better contrast, and expanded color volume. In practical terms, that means a more dynamic and accurate picture without abandoning the proven strengths of LCD technology.
Samsung 2026 Mini LED TV Lineup
For 2026, Samsung is introducing two Mini LED TV series so far: the M80H and M70H. Both models feature 4K UHD resolution, the Tizen smart TV platform, gaming-focused features, and Samsung’s Vision AI Companion for enhanced picture and usability.
The M80H series is available in screen sizes from 55 to 85 inches, while the M70H series spans a broader range from 43 to 85 inches. Between the two, there’s enough flexibility to match just about any viewing distance or room size without forcing a compromise on features.
Key Features
Both series are built to deliver a strong 4K UHD viewing experience, with AI-driven processing handling upscaling and scene optimization. The M80H uses Samsung’s NQ4 AI Gen2 Processor, while the M70H relies on the Mini LED Processor 4K, with both designed to enhance clarity and detail on a scene-by-scene basis.
Samsung’s Real Depth Enhancer is included on both models, improving foreground definition and helping key on-screen elements stand out more clearly. The M80H adds AI Customization Mode, which learns your preferred picture settings by genre during setup and then automatically adjusts image quality based on what you’re watching.
For audio, the M80H also includes Active Voice Amplifier, which boosts dialogue and important sound effects to improve clarity—especially useful when background noise tries to steal the scene.
Also, with Q Symphony, the M80H and M70H can be combined with compatible Samsung soundbars and Wi-Fi speakers to operate as a single, coordinated sound system rather than isolated components.
Gaming support for both models includes Samsung’s Gaming Hub, Cloud Gaming, and VRR (Variable Refresh Rate) in both series. However, the M80H also provides AI Auto Game Mode, Gaming Motion Plus, and AMD Freesync Premium Pro support
Samsung’s Vision AI experience is included in both Mini LED TV series. Anchored by the Perplexity TV App, Vision AI on TVs goes beyond simple voice commands or video enhancements by combining AI audio/video processing, Bixby voice control, Tizen Smart TV integration, and Knox Security into a single, seamless ecosystem.
Comparison
There’s a fair amount of feature overlap between the M80H and M70H models, but key differences remain. We’ve included a detailed comparison chart below to make it easier to see where they separate.
Samsung Model M80H M70H Product Type Mini-LED TV Mini-LED TV Screen Size (diagonal inches) 55, 65, 75, 85 43, 50, 55, 65, 75, 85 Price
(55″) $699.99
(65″) $799.99
(75″) $1,199.99
(85″) $1,799.99(43″) $349.99
(50″) $399.99
(55″) $449.99
(65″) $529.99
(75″) $729.99
(85″) $1,199.99Refresh Rate: 144Hz (VRR Support) 60Hz Lighting Technology Mini LED Mini LED Display Resolution 4K (3840 x 2160) 4K (3840 x 2160) Anti Reflection – – Dimming Technology Supreme Mini LED Dimming Supreme Mini LED Dimming Processor NQ4 AI Gen2 Processor Mini LED Processor 4K Upscaling 4K AI Upscaling 4K Upscaling Variable Refresh Rate (VRR) Yes Yes Motion Handling Motion Xcelerator 144Hz Motion Xcelerator DLG (Dual Line Gate) 240Hz 85″ – 55″: 120Hz
50″ – 43″”: N/AContrast Enhancer Real Depth Enhancer Yes Color Pure Spectrum Color Pure Spectrum Color Color Booster Pro Yes HDR (High Dynamic Range) Mini LED HDR Mini LED HDR HDR10+ Yes Yes Auto HDR Remastering Yes – Adaptive Picture AI Customization – Supersize Picture Enhancer – – TV Depth 3″ 3″ Front Color Black Titan Black Stand Type Basic Feet Basic Feet Stand Color Titan Gray Black Adjustable Stand: 75-inch only – Wi-Fi Yes (Wi-Fi 6E) Yes (Wi-Fi 6E) Bluetooth Version 5.3 5.3 HDMI Inputs 3 3 HDMI Maximum Input Rate 4K 144Hz (for HDMI 1/2/3) 4K 60Hz (for HDMI 1/2/3) HDMI Audio Return Channel eARC eARC HDMI-CEC Yes Yes USB Ports 1 x USB-A 1 x USB-A Ethernet (LAN) Yes Yes Digital Audio Out (Optical): – – RF Connection: Yes Yes RS-232C Input – – Samsung Vision AI Yes Yes Gaming Support Gaming Hub
Cloud Gaming- Xbox, NVIDIA GeForce Now, Luna, Blacknut, Antstream, Boosteroid
ALLM (Auto Low Latency Mode)
HGIG
AI Auto Game Mode
Gaming Motion Plus
Super Ultra Wide Game View
Game Bar
Mini Map Zoom
AMD FreeSync: Freesync Premium™ Pro
Hue SyncGaming Hub
Cloud Gaming: – Xbox, NVIDIA GeForce Now, Luna, Blacknut, Antstream, Boosteroid
HGIGTV Art Features Art Mode: NA
Art Store: YesArt Mode: NA
Art Store: YesOperating System One UI Tizen One UI Tizen Free Ad Supported TV Samsung TV Plus Samsung TV Plus Smart Home Connectivity: SmartThings, Matter, IoT-Sensor Functionality Quick Remote Only Smart Assistants (Built-In) Bixby, Alexa Bixby, Alexa Smart Assistants (Works with) Google Assistant Google Assistant Far-Field Voice Interactions Yes – Web Browser: Yes Yes Samsung Health Yes Yes Multi-Device Experience Mobile to TV
Sound Mirroring
Wireless TV On
TV initiates mirroringMobile to TV
Sound Mirroring
Wireless TV OnMulti-View Up to 2 videos – Buds Auto Switch Yes – Works with Apple AirPlay Yes Yes Works with Google Cast Yes Yes Daily+ Yes – Now Brief Yes Voice/User Detection – Workout Tracker Yes – Audio 2 Channel speaker system
20 Watts Output Power
Object Tracking Sound
(OTS) Lite\Q-Symphony
Active Voice Amplifier (AVA) Pro
Adaptive Sound Plus2 Channel speaker system
Object Tracking Sound (OTS) Lite\Q-SymphonyKaraoke Mic: Yes Yes Multi-Control Yes – Storage Share: Yes – Security Knox Vault: N/A
Knox Security: YesKnox Vault: N/A
Knox Security: YesRemote Control Bluetooth Simple Remote TM2280A with batteries IR Simple Remote TM2240A with batteries
The Bottom Line
Samsung’s 2026 Mini LED lineup sits in a very calculated middle ground. You’re getting the core benefit that actually matters; Mini LED backlighting for better contrast, brightness control, and more consistent HDR performance without paying Neo QLED prices. Add in Tizen, Vision AI, and solid gaming support, and these don’t feel stripped down in daily use. For a lot of buyers, this is where the real value is.
What’s missing is just as important. No Quantum Dot layer means color accuracy and color volume won’t match Samsung’s Neo QLED models, and you’re not getting the full processing and refinement stack reserved for the higher tier. These are for buyers who want a meaningful step up from basic LED TVs without drifting into premium pricing. If you’re chasing reference-level performance, keep walking. If you want a well-equipped 4K Mini LED TV that covers the essentials and then some, this is the safer—and smarter—place to land.
Availability & Pricing
Samsung’s 2026 Mini LED 4K TVs are available now:
M80H Series
- 85” Class M80H: $1,799.99 at Amazon
- 75” Class M80H: $1,199.99 at Amazon
- 65” Class M80H: $799.99 at Amazon
- 55” Class M80H: $699.99 at Amazon
M70H Series
- 85” Class M70H: $1,19.99 at Amazon
- 75” Class M70H: $729.99 at Amazon
- 65” Class M70H: $529.99 at Amazon
- 55” Class M70H: $449.99 at Amazon
- 50” Class M70H: $399.99 at Amazon
- 43” Class M70H: $349.99 at Amazon
For more information: Samsung Product Page
Related Reading:
