ProAc’s Response DB1R Brings Ribbon Tweeter Performance to a Compact Standmount Loudspeaker
Can ProAc’s compact Response DB1R with ribbon tweeter deliver true high end performance in a standmount likely priced around $5,000 per pair?
ProAc Response DB1R Stand-mount Loudspeakers
ProAc has long been a name whispered with reverence among British and American audiophiles; a company that built its reputation on handcrafted, musically transparent loudspeakers rather than flash and hype. Founded by Stewart Tyler in 1979 (evolving from his earlier Celef Audio venture in the 1970s), ProAc quickly earned acclaim for compact but capable designs like the Response and Tablette ranges that belied their size with a very natural sounding midrange and lifelike staging.
Across more than four decades, ProAc remained a tightly run UK family business known for well engineered crossovers, beautifully finished cabinets, and an almost obsessive approach to driver selection. More than a few long time audiophiles will nod at the old “straws” reference when the conversation turns to how particular the company has been about its woofers.The brand’s presence, however, in the U.S. wavered at times due to distributor changes, and in 2021 enthusiasts mourned the passing of Tyler, a designer whose work helped define a generation of British loudspeaker craftsmanship.
Into that legacy enters the new ProAc Response DB1R: the smallest ProAc loudspeaker ever offered with a ribbon tweeter, bringing the brand’s signature Response-series refinement to an even more compact standmount format. It’s a clear signal that ProAc’s dedication to natural, unforced musical expression remains alive, even as the company evolves its technology into the next chapter.
DB1R Ribbon Tweeter: Small Speaker, Big High Frequency Ambition
proac-response-db1r-speaker-cherry
ProAc Response DB1R
Following the success of the Response D2R standmount introduced in 2019, ProAc has now applied that same ribbon tweeter technology to its more compact Response DB1 platform. The original DB1, launched in 2016 with a silk dome tweeter, remains in the range, but the new DB1R replaces the dome with the ribbon unit first seen in the D2R.
The goal is straightforward: retain the tonal balance and overall character of the DB1 while extending high frequency resolution and speed through the use of ProAc’s ribbon design. According to ProAc, the ribbon diaphragm is lighter than a human hair and incorporates rear chamber damping along with an alnico magnet system to improve control and reduce distortion.
ProAc’s ribbon tweeter has already been implemented across several models in the Response series. With the DB1R, it now appears in the smallest loudspeaker in the company’s lineup to feature a ribbon, bringing that technology into a more compact standmount format.
Response DB1R Bass Driver: Small Cabinet, Serious Intent
proac-response-db1r-rear-cherry
Compact stand-mount speakers remain popular for listeners who want serious sound without large floorstanders dominating the room. Bigger cabinets typically offer deeper bass and a broader sense of scale, but they also take up visual and physical space. The Response DB1R is designed to balance those tradeoffs.
The cabinet uses varying thickness HDF panels combined with bituminous damping to help control resonance and reduce unwanted coloration. The 5 inch bass driver features a long throw design, raised spider, and linear motor system to maintain control at higher excursion levels. A rear port provides additional low frequency support.
The cone is formed from Pagina Mica, elastically coated, and fitted with ProAc’s acrylic pole damping phase plug. The crossover has been tuned to maintain a flatter response at higher listening levels, helping the speaker remain composed when pushed.
In practice, the DB1R aims to deliver low coloration through the midrange and treble, along with bass that is punchy and reasonably extended for its size. The overall goal is to create the scale and balance of a larger loudspeaker within a compact enclosure.
Zoe Tyler Mardle commented on the launch, stating: “The launch of the Response DB1R is the first step in developing our long term plans while continuing to honour Stewart Tyler’s designs and the legacy he left behind. As a team, we want to take everything he taught us over the last 30 years and build upon it. Music is at the heart of our family and central to ProAc’s ‘perfectly natural’ sound, something we are fully committed to preserving.”
Comparison
proac-response-db1r-db1-d2r
Response DB1R (2026)Response DB1 (2016)Response D2R (2019)
Product TypeStandmount SpeakerStandmount SpeakerStandmount Speaker
Price (Pair)£2,945 to £3,465
US Price TBD
£2,495 to £3,225
$4,750 to $5,300
£3,665 to £4,295
$4,500 to $5,500
Speaker TypePorted – Bass ReflexPorted – Bass ReflexPorted – Bass Reflex
Nominal Impedance8 ohms8 ohms8 ohms
Recommended Amplifiers20 to 100 watts20 to 100 watts20 to 150 watts
Frequency Response35Hz-30kHz35Hz-30kHz30Hz-30kHz
Sensitivity87.5 dB linear for 1 watt at 1 metre87.5 dB linear for 1 watt at 1 metre88.5 dB linear for 1 watt at 1 metre
Bass /midrange DriverProAc 127mm (5”) long throw unit with Pagina Mica cone and acrylic phase plug.ProAc 127mm (5”) long throw unit with Pagina Mica cone and acrylic phase plug.165mm (6.5”) ProAc unit with Excel Magnet system, glass fibre weave cone and copper phase plug
TweeterProAC Ribbon Tweeter with a rear chamber damping and ainico magnetProAc 25mm (1”) silk dome with special coolantProAC Ribbon Tweeter with a rear chamber damping and ainico magnet
CrossoverFinest components on a dedicated circuit board. Multistrand oxygen-free copper cable throughout. Split for optional Bi wiring or Bi amplificationFinest components on a dedicated circuit board. Multistrand oxygen-free copper cable throughout. Split for optional Bi wiring or Bi amplificationFinest components on a dedicated circuit board. Multistrand oxygen-free copper cable throughout. Split for optional Bi wiring or Bi amplification
Dimensions (HWD)12.5” (320mm) x 7.28” (182mm) x 10.4” (280mm)12.5”(320mm) x 7.28” (182mm) x 10.4” (280mm)17” (430mm) x 8” 203mm) x 10.25” (260mm)
Weight (each)8.8kg (19.6 lbs)8.8kg (19.6 lbs)11kg (24 lbs)
ModeStand mountStand mountStand mount on a rigid high mass
GrilleAcoustically transparent crimplene. Magnetic grilles are available with certain finishes.Acoustically transparent crimplene. Magnetic grilles are available with certain finishes.Acoustically transparent crimplene
Standard FinishesBlack Ash, Mahogany, Cherry, Walnut, Natural Oak, Silk White.Black Ash, Mahogany, Cherry, Walnut, Natural Oak, Silk White.Black Ash, Mahogany, Cherry, Walnut, Natural Oak, and Silk White.
Premium Finishes (extra cost)Liquidambar, Rosewood, EbonyLiquidambar, Rosewood, EbonyLiquidambar, Rosewood, Ebony
proac-response-db1r-speaker-cherry-on-stand
The Bottom Line
ProAc has never chased mainstream visibility, and the Response DB1R is unlikely to change that. What it does reinforce is the company’s long standing focus on compact loudspeakers that prioritize tonal balance, midrange clarity, and refined high frequency detail over brute force output.
The DB1R is for listeners who value scale and precision in smaller rooms, who want the speed and openness of a ribbon tweeter without committing to a large floorstander. It is also for those who appreciate careful crossover design and cabinet craftsmanship rather than feature lists and lifestyle packaging.
If pricing lands north of $5,000 per pair as expected, the ProAc Response DB1R will not be entry level. But in a world where statement loudspeakers like the new ATC EL50 now command $99,999 per pair, it occupies a very different tier of ambition. This is not about maximum output or seismic bass. It is about delivering a balanced, articulate presentation in a manageable enclosure for serious two channel systems where space and aesthetics still matter.
Price & Availability
The ProAc Response DB1R is priced at £2,945 with Standard Finishes and £3,465 with Premium Finish, and is available through Authorized Dealers. Availability is expected to start in May, 2026. The Response DB1 and D2R are currently available through Authorized Dealers.
Tip: The ProAc Response DB1R is being shown at the 2026 Bristol Hi-Fi Show from February 20 – 22.
For more information: proac-loudspeakers.com
2026 Paradigm Premier v2 Loudspeakers
Paradigm Premier Series v2 arrives at AXPONA 2026 with six new models, upgraded driver technology, and pricing aimed at affordable high performance.
Advance Paris A-i190 Integrated Amplifier Black Advance Paris A-i190 Integrated Amplifier Black
Advance Paris debuts NOVA at AXPONA 2026 with modular integrated amplifiers, streaming and Bluetooth add-ons, but should streaming be optional at this price?
2026 Cambridge Audio MSX Speakers Lifestyle 2026 Cambridge Audio MSX Speakers Lifestyle
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
Sony True RGB TV compared to BRAVIA 9 Mini LED TV. Sony True RGB TV compared to BRAVIA 9 Mini LED TV.
2026 Samsung Music Studio 7 Wireless Speakers Lifestyle 2026 Samsung Music Studio 7 Wireless Speakers Lifestyle
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
2026 Samsung HW-S990H Soundbar Lifestyle 2026 Samsung HW-S990H Soundbar Lifestyle
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Loudspeakers
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Can Creek Audio stand out in 2026 as it enters the crowded speaker market and rethinks its amplifier strategy?
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Kii Audio SEVEN wireless speakers add a third color, Qobuz Connect, Spotify Lossless support, and more with free software update.
Ultrafide Audio will unveil the ENSO INT-125 integrated amplifier at Bristol Hi-Fi Show 2026, a UK-built 125W design with DAC.
Arendal Sound unveils the 1610 loudspeaker series bringing flagship inspired design and three way performance to a more accessible price point without cutting corners.
