Paradigm Premier Series v2 Debuts at AXPONA 2026: Affordable High-End Speakers Get a Major Upgrade
Paradigm Premier Series v2 arrives at AXPONA 2026 with six new models, upgraded driver technology, and pricing aimed at affordable high performance.
2026 Paradigm Premier v2 Loudspeakers
Toronto-based Paradigm is debuting its Premier Series v2 loudspeaker series at AXPONA 2026 which is priced from $800 to $2,300 per pair. Although the company is leaning hard into its usual talk of trickle-down tech and refined engineering, the real story is far simpler: they’ve managed to keep this line genuinely affordable in a market that’s been sprinting in the opposite direction.
The new lineup is a full-system play, covering the 820F and 720F floorstanding speakers, 220B and 120B bookshelf models, the 620C center channel, and the 520LCR for flexible front-stage or custom-install use. Built as a ground-up redesign of the original 2018 Premier Series, the v2 range pulls design cues and driver technology from Paradigm’s higher-end offerings without dragging pricing into five-figure territory.
Like DALI, Paradigm remains one of the few speaker manufacturers still doing everything in-house; from driver design to cabinet construction, backed by extensive testing and measurements in its own anechoic chamber. That level of control tends to show up where it counts: tighter tolerances, more consistent performance, and fewer surprises once the speakers hit real rooms.
The Premier v2 Series is clearly designed as a complete, accessible ecosystem, but the headline isn’t just the redesign or the model count. It’s that Paradigm didn’t lose its grip on reality with the pricing. In 2026, that alone makes this launch worth paying attention to.
With the Premier v2, we wanted to make a reference-grade acoustics platform available at a more attainable price point,” says John Bagby, Managing Director at PML Sound International. “By using some of the technologies and materials developed for our award-winning Founder Series and tuning them for this new line, we’ve delivered a strong level of value—and an experience that we are incredibly excited to share with our dealers and fans.”
Advanced Driver and Enclosure Technologies
paradigm-premier-v2-drivers
The v2 series integrates a range of driver and enclosure technologies designed to deliver balanced, accurate sound across the full frequency range:
  • AL-MAC High-Frequency Drivers: A blend of aluminum, magnesium, and ceramic designed to reduce resonances and deliver a clean, controlled treble response without added harshness.
  • AL-MAG Midrange Drivers: Engineered for high sensitivity and responsiveness, these drivers keep vocals and instruments clear, focused, and tonally accurate.
  • Carbon-X Unibody Bass Drivers: One-piece cone construction designed to maintain rigidity under load, delivering deeper bass with better control and less distortion at higher output levels.
paradigm-premier-v2-sound-guides
Patented Sound Guides: The PPA (Perforated Phase-Aligning) Lens and OSW (Oblate Spheroidal Waveguide) work together to focus sound toward the listener, ensuring a wide “sweet spot” regardless of the room’s layout. Paradigm’s Oblate Spheroidal Waveguide (OSW) is a proprietary tweeter waveguide designed to improve sound dispersion. It focuses the tweeter output on the listening area, reducing off-axis reflections and enhancing clarity
paradigm-premier-v2-feet
Outrigger Shock-Mount Isolation Feet: An adjustable system that decouples the speaker from the floor to reduce vibration, helping deliver tighter, more controlled bass on any surface using the included spikes or rubber feet.
From Affordable Entry Point to Serious High Performance
The Premier v2 is positioned as a clear step up for listeners ready to move beyond entry-level gear and into a more refined, higher-performance home audio system.
We designed the Premier v2 for the enthusiast who is ready to move into a higher tier of performance without the typical high-end cost,” says Badar Qureshi, CEO of PML Sound International. “This series represents the future of our brand by proving that truly exceptional audio can be both approachable and attainable. We are committed to ensuring that Paradigm remains the standard for performance in its class, giving our customers a clear path to owning a world-class listening experience.”
Premier v2 820F
paradigm-premier-v2-820f
The 820F v2 sits at the top of the Premier v2 lineup, built to anchor a serious two-channel or home theater system. With multiple 7-inch Carbon-X bass drivers and a high-volume enclosure, it’s designed to move a lot of air; delivering deep, controlled bass and a wide, room-filling soundstage without losing composure as volume climbs.
Premier v2 720F
paradigm-premier-series-v2-720f-lifestyle
The 720F v2 delivers floorstanding scale without dominating the room. Its 3-way design uses dual Carbon-X unibody bass drivers for low-frequency control and rigidity, paired with a dedicated AL-MAG midrange and AL-MAC tweeter for a more cohesive, full-range presentation. Adjustable Outrigger Shock-Mount feet help keep things stable and isolated, so the speaker maintains composure and clarity even when pushed harder.
Premier v2 220B
paradigm-premier-v2-220b
The 220B v2 is a larger bookshelf or standmount design built around a 1-inch AL-MAC tweeter and a 6-inch AL-MAG driver, paired with a cabinet that offers more internal volume than you’d expect at this size. The result is deeper bass extension and greater dynamic range, making it viable in both smaller rooms and more open spaces. It’s a strong option for listeners who want something close to floorstander performance without committing to full-size towers.
Premier v2 120B
paradigm-premier-series-v2-120b-lifestyle
The Premier 120B v2 is positioned as the entry point into the lineup, built for smaller spaces without giving up on sound quality. This compact 2-way bookshelf pairs a 1-inch AL-MAC tweeter with a 5.5-inch AL-MAG mid-bass driver to deliver a detailed, surprisingly expansive soundstage for its size. It works equally well as a dedicated stereo pair or as part of a larger home theater system.
Premier v2 620C Center Channel
paradigm-premier-v2-620c
The 620C v2 is a substantial center channel built for larger home theater systems. It uses a 4-driver array paired with dual passive radiators to deliver deeper, more impactful low-end while retaining the placement flexibility of a sealed cabinet design. The goal here is straightforward: clear, intelligible dialogue with enough weight and presence to anchor even bigger, more demanding setups.
Premier v2 520LCR
paradigm-premier-v2-520c
The 520LCR v2 is a dedicated left, center, right solution built for high-performance home theater systems. Its sealed acoustic suspension design allows for flexible placement—inside cabinetry or out in the open—without sacrificing clarity or control. A coaxial AL-MAG midrange helps lock in dialogue and imaging, creating a more cohesive and seamless front soundstage. It can be positioned horizontally as a center channel or vertically for left, right, or even surround duties, making it one of the more versatile options in the lineup.
Paradigm Premier Series V2 Speakers Comparison
paradigm-820f-720f-220b-120b
Paradigm Premier Series V2 Model820F720F220B120B
Product TypeFloorstanding Speaker Floorstanding Speaker Bookshelf/Standmount SpeakerBookshelf/Standmount Speaker
Price (each)$1,299.99$999.99$549.99$399.99
Design4-driver, 3-way ported floor standing speaker with AL-MAC, AL-MAG, Carbon-X, OSW™, and PPA™4-driver, 3-way ported floor standing speaker with AL-MAC, AL-MAG, Carbon-X, OSW™, and PPA™2-driver, 2-way ported bookshelf with AL-MAC, AL-MAG, OSW™, and PPA™2-driver, 2-way ported bookshelf with AL-MAC, AL-MAG, OSW™, and PPA™
Crossover2nd Order Electro-acoustic at 1.8kHz
(tweeter/midrange)
2nd Order Electro-acoustic at 450Hz (midrange/woofer)
2nd Order Electro-acoustic at 1.3kHz (tweeter/midrange)
2nd Order Electro-acoustic at 500Hz (midrange/woofer)
2nd Order Electro-acoustic at 1.1kHz (tweeter/midwoofer)2nd Order Electro-acoustic at 1.2kHz (tweeter/mid woofer))
High-Frequency Driver1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Per forated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Per forated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Perforated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Perforated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled
Mid-Frequency Driver6” (152mm) AL-MAG™ Cone with Perforated Phase-Aligning (PPA™) Lens, and a 2” high-temp multi-layered voice coil with ventilated Apical™ former6” (152mm) AL-MAG™ Cone with Perforated Phase-Aligning (PPA™) Lens, and a 2” high-temp multi-layered voice coil with ventilated Apical™ formerN/AN/A
Mid/Bass Frequency DriverN/A N/A6” (152mm) Ultra-High-Excursion AL-MAG™ Cone with Perforated Phase-Aligning (PPA™) Lens, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high-temp multi-layered voice coil with ventilated Apical™ former5.5” (140mm) Ultra-High-Ex cursion AL-MAG™ Cone with Perforated Phase-Aligning (PPA™) Lens, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high temp multi-layered voice coil with ventilated Apical™ former
Bass Frequency DriverTwo 7” (177mm) Ultra-HighExcur sion CARBON-X™ Unibody Cone, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high-temp multi-layered voice coil with ventilated Apical™ formerTwo 6″ (152mm) Ultra-HighExcur sion CARBON-X™ Unibody Cone, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high-temp multi-layered voice coil with ventilated Apical™ formerN/AN/A
Passive RadiatorN/AN/AN/AN/A
Frequency Response (On Axis)±3dB from 52Hz – 23kHz±3dB from 55Hz – 23kHz±3dB from 58Hz – 23kHz±3dB from 62Hz – 23kHz
Frequency Response (Off Axis)±3dB from 52Hz – 20kHz±3dB from 55Hz – 20kHz±3dB from 58Hz – 20kHz±3dB from 62Hz – 20kHz
Low Frequency Extension21Hz (DIN)27Hz (DIN)36Hz (DIN)39 Hz (DIN)
Sensitivity Room/Anechonic93dB / 90dB92dB / 89dB91dB / 88dB90dB / 87dB
Amplifier Power Range15 – 250 Watts15 – 220 Watts15 – 130 Watts15 – 130 Watts
Max Input Power180 Watts180 Watts80 Watts70 Watts
Impedance Compatible with 8 ohmsCompatible with 8 ohmsCompatible with 8 ohmsCompatible with 8 ohms
Weight (each)65 lbs (29.5 kg) 57.3 lbs (26 kg) 20.1 lbs (9.1 kg) 16.3 lbs (7.4 kg)
Dimensions (HWD)43.4” x 13.1” x 18.6”
110.2 cm x 33.3 cm x 47.2 cm
39.6” x 12.5” x 17”
100.6 cm x 31.8 cm x 43.2 cm
14.6” x 8.3” x 12.9”
37.1 cm x 21.1 cm x 32.8 cm
12” x 7” x 12.1”
30.5 cm x 17.8 cm x 30.7 cm
FinishesPiano Black, Black Walnut, WalnutPiano Black, Black Walnut, WalnutPiano Black, Black Walnut, WalnutPiano Black, Black Walnut, Walnut, Satin White
paradigm-620c-520lcr
Paradigm Premier Series V2 Model620C520LCR
Product TypeCenter Channel SpeakerLeft, Center, Right Channel Speaker
Price (each)$1,299.99$899.99
Design4-driver, 2-passive radiator, 3-way sealed center channel speaker with AL-MAC, AL-MAG, Carbon-X, OSW™, and PPA™4-driver, 3-way sealed LCR speaker with AL-MAC, AL-MAG, Carbon-X, OSW™, and PPA™
Crossover2nd Order Electro-acoustic at 1.7kHz (tweeter/midrange)
2nd Order Electro-acoustic at 750Hz (midrange/woofer)
2nd Order Electro-acoustic at 1.5kHz (tweeter/midrange) 2nd Order Electro-acoustic at 650Hz (midrange/woofer)
High-Frequency Driver1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Per forated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled1” (25mm) AL-MAC™ Ceramic Dome with Oblate Spheroid Waveguide (OSW™) and Perforated Phase-Aligning (PPA™) Tweeter Lens, ferro-fluid damped / cooled
Mid-Frequency DriverCoaxial 6” (152mm) AL-MAG™ Cone, a 2” high-temp multi-layered voice coil with Apical™ former, Patented Dual-Sync™ Continuous Flux MotorCoaxial 6” (152mm) AL-MAG™ Cone, a 2” high-temp multi-layered voice coil with Apical™ former, Patented Dual-Sync™ Continuous Flux Motor
Mid/Bass Frequency DriverN/AN/A
Bass Frequency DriverTwo 7” (177mm) Ultra-High Excursion CARBON-X™ Unibody Cone, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high-temp multi-layered voice coil with ventilated Apical™ formerTwo 6” (152mm) Ultra-High Excursion CARBON-X™ Unibody Cone, Gen3 Active Ridge Technology (ART™) with Vertical Mounting System, and a 1” high-temp multi-layered voice coil with ventilated Apical™ former
Passive RadiatorTwo 7” (177mm) Ultra-High Excursion CARBON-X™ Unibody Passive Raditators with Gen3 Active Ridge Technology (ART™) and Vertical Mounting SystemN/A
Frequency Response (On Axis)±3dB from 49Hz – 23kHz±3dB from 75Hz – 23kHz
Frequency Response (Off Axis)±3dB from 49Hz – 20kHz±3dB from 75Hz – 20kHz
Low Frequency Extension33Hz (DIN)50Hz (DIN)
Sensitivity Room/Anechonic93dB / 90dB93dB / 90dB
Amplifier Power Range15 – 180 Watts15-120 Watts
Max Input Power120 Watts80 Watts
Weight (each)48.1 lbs (21.8 kg) 31.1 lbs (14.1 kg)
Dimensions (HWD)8.9” x 41” x 13.7”
22.6 cm x 104.1 cm x 34.8 cm
8.3” x 23.4” x 12”
21.1 cm x 59.4 cm x 30.5 cm
FinishesPiano Black, Black Walnut, WalnutPiano Black, Black Walnut, Walnut, Satin White
paradogm-premier-series-v2-720f-lifestyle-woman
Paradigm Premier v2 720F
The Bottom Line
Chasing better sound usually ends the same way: higher prices, diminishing returns, and a lot of second-guessing. The Premier Series v2 doesn’t pretend to rewrite that reality, but it does offer a more grounded path through it.
What makes this lineup stand out isn’t some radical new concept. It’s execution. Paradigm is leveraging its in-house design, driver development, and anechoic testing to deliver a complete, coherent speaker family that pulls meaningful technology down from its higher-end lines without dragging the price into absurd territory. That balance, real engineering, full system flexibility, and pricing that still feels tethered to reality is the hook.
What’s missing? No dedicated subwoofer in the Premier v2 lineup. You’ll need to look at Paradigm’s Defiance or Essentials series, or elsewhere if you want to round out a full-range system. Not a dealbreaker, but it’s part of the equation.
Who should be looking at these? Anyone ready to move beyond entry-level speakers but not interested in playing the five-figure game. The Premier v2 series makes the most sense for listeners building a serious two-channel or home theater system who want consistency across channels, solid engineering, and performance that doesn’t collapse when pushed.
In a crowded sub-$10,000 category, that’s not a small thing. Paradigm isn’t chasing hype here. They’re offering a system you can actually live with and afford.
Price & Availability
The Paradigm Premier Series v2 Loudspeakers are priced individually (not in pairs) and the stands for smaller bookshelf models are not included. Look for them in June 2026 from Authorized Paradigm Dealers at the following prices:
  • Premier 820F v2 (Floorstanding) — $1,299.99 /each
  • Premier 720F v2 (Floorstanding) — $999.99 /each
  • Premier 220B v2 (Bookshelf) — $549.99 /each
  • Premier 120B v2 (Bookshelf) — $399.99 /each
  • Premier 620C v2 (Center Channel) — $1,299.99 /each
  • Premier 520LCR v2 (LCR Channel) — $899.99 /each
The Premier v2 series will make its public debut at AXPONA 2026 (April 10-12) at the Renaissance Schaumburg Hotel & Convention Center, where attendees will be the first to experience the new lineup through live demonstrations.
Advance Paris A-i190 Integrated Amplifier Black Advance Paris A-i190 Integrated Amplifier Black
Advance Paris debuts NOVA at AXPONA 2026 with modular integrated amplifiers, streaming and Bluetooth add-ons, but should streaming be optional at this price?
2026 Cambridge Audio MSX Speakers Lifestyle 2026 Cambridge Audio MSX Speakers Lifestyle
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
Sony True RGB TV compared to BRAVIA 9 Mini LED TV. Sony True RGB TV compared to BRAVIA 9 Mini LED TV.
2026 Samsung Music Studio 7 Wireless Speakers Lifestyle 2026 Samsung Music Studio 7 Wireless Speakers Lifestyle
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
2026 Samsung HW-S990H Soundbar Lifestyle 2026 Samsung HW-S990H Soundbar Lifestyle
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Andrew Jones to debut Jones and Cerreta Troubadour at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how...
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Magico previews the S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Buchardt Audio unveils the S400 MK3 bookshelf speaker with a larger cabinet, new drivers, and refined crossover. Can it dominate the $2,400 standmount class?
Audio Note ignores trends again. The Oto SE 35 brings new transformers and PSU to the cult EL84 amp. Low power, big attitude. Hear...
Hi-Fi Components
AXPONA 2026 returns April 10 to 12 in Schaumburg, Illinois. We have early details on new hi-fi products set to debut at North America’s...
