Optoma GT4000UHD Ultra Short Throw Projector Delivers Big-Screen 4K for Home Theater and Gaming
Optoma GT4000UHD delivers 4K UHD, 4,000 lumens, ultra-low input lag, and UST convenience for an immersive gaming and movie experience in any room.
Optoma GT4000UHD UST Projector with 100-inch screen
The Optoma GT4000UHD is the latest addition to the brand’s UST lineup, following the compact PhotonGo from earlier in 2025, the GT3500HDR from 2024, and the CinemaX D2 Smart from 2022. It builds directly on the GT3500HDR, upgrading from 1080p to true 4K UHD resolution, boosting brightness to 4,000 lumens, and refining performance for home theater and gaming enthusiasts.
gt4000uhd-angle
Optoma GT4000UHD
Lasers & HDR
The GT4000UHD uses Optoma’s DuraCore laser light source, delivering up to 4,000 lumens of brightness and up to 30,000 hours of life in Eco mode. It offers a native contrast ratio of 500,000:1, supports both HDR10 and HLG, and can project a 100-inch image from just under 12 inches away (up to 120 inches max), making it ideal for big-screen viewing and gaming in tight spaces.
duracore-laser
4K UHD via Pixel Shifting
Similar to other 4K UHD DLP projectors, the GT4000UHD incorporates a 0.47-inch-sized 1080p DLP imaging chip—also known as a Digital Micromirror Device (DMD)—from Texas Instruments. This chip contains 2.1 million tiny mirrors (pixels), which is far fewer than the 8.3 million pixels required for true 4K resolution.
In order to make up the pixel number difference needed for 4K UHD Resolution display, the GT4000UHD rapidly shifts the pixels both vertically and horizontally at a rate of 240 times per second (240Hz). This pixel-shifting technique happens so quickly and precisely that the final result is classified as a 4K image when projected on a screen or wall.
DLP 4K Pixel Shifting
Gaming
For PC gamers, the GT4000UHD keeps input lag to a minimum: just 8ms at 120Hz and 4.3ms at 240Hz in 1080p mode, and 16.9ms at 60Hz in 4K. That means fast, responsive gameplay whether you’re chasing high frame rates or higher resolution.
gt4000uhd-gaming
Setup Tools
For easy installation, the GT4000UHD is equipped with four-corner keystone correction and 360-degree and portrait modes. Physical connections include three HDMI 2.0 inputs (one is eARC compatible). The GT4000UHD includes a single built-in speaker powered by a modest 115-watt amp—which is fine if you’re watching the news at grandma’s. But if you actually care about sound, use the HDMI-eARC port and connect it to a real audio system, soundbar, or AV receiver. It’s there for a reason—don’t let good picture quality suffer with weak audio.
From Billy Harrison, Product Manager at Optoma: “With consumers seeking flexible projection solutions for a variety of home usage scenarios, we’ve introduced our latest ultra short throw alternative with the GT4000UHD, delivering incredible brightness and true-to-life color in a new compact design….A suite of convenient installation features makes the GT4000UHD an ideal projector for any space and takes the big screen experience to new levels for competitive gaming, home entertainment, or home offices.”
Comparison
gt4000uhd-gt3500hdr
Model GT4000UHD (2025)GT3500HDR (2024)
Price$4,499$1,499
Projector TypeUST (Ultra Short Throw)UST (Ultra Short Throw)
Display TechnologyDLPDLP
Light Source TypeDuraCore LaserDuraCore Laser
Light Source Life30,000 hours (Eco Mode)30,000 Hours (Eco Mode)
Resolution4K UHD (3840×2160) via Pixel Shifting1080p Full HD
Brightness (While Light Output)4,000 lumens3,800 Lumens
HDR SupportHDR10, HLGHDR10, HLG (via 4K UHD Input)
Contrast Ratio 500,000:(Native) 1,700,000:1 (Dynamic)500,000:1(Native)
Native Aspect Ratio16:916:9
Aspect Ratio Compatible4:3,16:94:3, 16:9
Keystone Correction5°+/- Four corner correctionHorizontal: +/- 5 degrees, Vertical +/- 5 degrees
Horizontal Scan Rate15KHz ~ 150KHz15 ~ 140KHz
Vertical Scan Rate24KHz ~ 240KHz24 ~ 120Hz
Screen Uniformity75%75%
Screen Size100″ ~ 150″ diagonal80″ ~ 130″ diagonal
Projection Distance 10.53″ – 21.43″ (<12 inches for 100-inch screen)7.95″ – 15.67″
Throw Ratio0.25:10.253:1
ZoomFixedFixed
Zoom TypeFixedFixed
Focal Length (mm)3.7 mm3.7 mm
Lens ShiftNoNo
Native Offset120% ( + or – 5%)Yes
Inputs1 x HDMI 2.0,
1 x HDMI 2.0 (eARC),
1 x USB service shared with USB-A power,
1 x DC
2 x HDMI 2.0
Outputs1 x Audio 3.5mm,
1 x 3D sync
1 x Audio 3.5mm,
1 x 3D sync,
1 x USB-A power 1.5A
Control1 x RS232,
1 x RJ45,
1 x HDBaseT 4K,
IR Remote
1 x RS232,
1 x RJ45,
Noise Level Min: 29dB
Max: 34dB
27dB Eco Mode
3DFull 3DFull 3D
SecuritySecurity bar, Kensington LockSecurity bar, Kensington Lock, Password-protected interface
OSD / Display Languages25 languages: Arabic, Czech, Danish, Dutch, English, Farsi, Finnish, French, German, Greek, Hungarian, Indonesian, Italian, Japanese, Norwegian, Polish, Portuguese, Romanian, Russian, Chinese (simplified), Spanish, Swedish, Chinese (traditional), Turkish, Vietnamese25 languages: Arabic, Czech, Danish, Dutch, English, Farsi, Finnish, French, German, Greek, Hungarian, Indonesian, Italian, Japanese, Norwegian, Polish, Portuguese, Romanian, Russian, Chinese (simplified), Spanish, Swedish, Chinese (traditional), Turkish, Vietnamese
24/7 OperationYesYes
360° OperationYesYes
Operating Conditions0°C~40°C/32°F~104°F, max. altitude 3,048m/10,000ft, max. humidity operating 80%, non-operating 90%0°C~40°C/32°F~104°F, max. altitude 3,048m/10,000ft
Speaker System1 Channel x 15 watts 1 Channel x 15 watts
Input lag16.9ms input lag at 8ms at 120Hz 1080p
4.3ms at 240Hz 1080p
16.9ms at 60Hz 4K
8.6ms (1080p 120Hz)
17ms (1080p 60Hz)
NetworkingWired LANWired LAN
IPX RatingIP6XIP6X
Power Supply250WExternal power supply, 180W DC 19.5V, 9.23A
Power Consumption (Standby)0.5WStandby: 0.5 watts –
Power Consumption (min)180 W +/- 15% (typical)@110VAC 178 W +/- 15% (typical)@220VAC119 watts
Power consumption (max)255 W +/- 15% (typical)@110VAC 250 W +/- 15% (typical)@220VAC 173 Watts
Dimensions (WDH)12.87 x 12.91 x 3.35 inches12.87 x 12.87  x 4.29 inches
Weight9.92 lbs8.6 lbs
In The BoxProjector
QSG (Quick Start Guide)
Power Adapter and Cable
Remote
Batteries (2xAAA)
AC power cord
Remote control
1x CR2025 Battery User Manual
gt4000uhd-rear
The Bottom Line
The Optoma GT4000UHD bumps up both the resolution and brightness over the earlier GT3500HDR, making it a strong contender for big-screen movie nights or immersive gaming. But let’s take a closer look.
The GT4000UHD is missing something that an increasing number of USTs are providing: a built-in Smart OS. For example, the Hisense PL2 ($2,499) and Formovie Cinema Edge ($2,199) both incorporate the Google TV OS, providing access to an abundance of streaming apps (including gaming apps). Of course, you can connect an external streamer (Roku, Fire TV, Apple TV) to the Optoma, but the convenience of having a system built-in is attractive for many.
Sure, Optoma wins the lumen war on paper, but both projectors are still bright enough to handle a semi-darkened room without breaking a sweat. Just don’t forget—like with most projectors—dropping $5K on the unit itself is only part of the story. You’ll want to factor in the cost of a proper screen if you actually want to see what you paid for.
Here’s the reality check: TVs are starting to squeeze projectors hard—on both size and price. For $3,999 or less, you can grab a 98-inch TCL QM7K or QM6K that doesn’t just give you a giant screen, but also tosses in built-in Google TV, Dolby Vision HDR, and brightness levels that the GT4000UHD (or almost any projector) simply can’t touch.
Sure, a projector like the GT4000UHD still delivers a more cinematic vibe for movie nights—but with streaming and gaming taking over, projectors are definitely starting to lose some ground.
Price & Availability
The Optoma GT4000UHD is available for an estimated street price of $4,499 (actual prices will vary) and can be purchased at Amazon USA ($5,299) and B&H Photo Video ($4,499).
2026 Focal Diva Alta Utopia Loudspeakers in Grey Felt
Weighing 236 pounds per speaker, Focal Diva Alta Utopia combines PRISM tweeter tech, M-profile W midrange, UWB wireless, and 600 watts of Naim amplification...
Monitor Audio Radius 3 4G Speakers in Black on Console Monitor Audio Radius 3 4G Speakers in Black on Console
Monitor Audio Radius Series 4G brings compact hi-fi speakers, on-wall models, and flexible mounting to modern homes and commercial spaces starting at $525 per...
2026 beyerdynamic DT 30 IE in-ear monitors for musicians 2026 beyerdynamic DT 30 IE in-ear monitors for musicians
beyerdynamic DT 30 IE targets musicians who need stage clarity, secure fit, and isolation, not bloated bass for the train.
clearaudio N2 MM Phono Cartridge Connected to Black Tonearm clearaudio N2 MM Phono Cartridge Connected to Black Tonearm
Clearaudio N2 MM cartridge uses a carbon fibre PETG body, 8.5g weight and $290 price to challenge Audio-Technica, Grado, Ortofon and Sumiko.
JBL PartyBox 330 and 130 Party Speakers Lifestyle JBL PartyBox 330 and 130 Party Speakers Lifestyle
JBL PartyBox 330 and 130 add upgraded drivers, Auracast, mic and guitar inputs, fast charging, and party-ready power from $449.95.
2026 Fluance RT87 Dual Plinth Turntable in Walnut 2026 Fluance RT87 Dual Plinth Turntable in Walnut
Fluance RT87 flagship turntable adds dual-plinth isolation, a 22mm acrylic platter, and AT-VM95ML or 2M Blue cartridge options.
Father's Day 2026 4K UHD Blu-ray Disc Movies
AWOL debuts its Aetherion Pro and Max UST projectors at CES 2026, taking aim at Hisense’s L9Q with big-screen scale, PixelLock tech, and gaming-focused...
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Priced from $1,699 to $2,999, XGIMI’s HORIZON 20 Series projectors offer high brightness, HDR and Harman/Kardon audio with Google TV.
3D never died, it evolved. Today’s high output home theater projectors bring Blu-ray 3D films to life with sharper detail, deeper immersion, and a...
The new Epson Lifestudio Grand Plus LS970 UST Projector is bright enough to light up a huge screen just inches from the wall and...
Does Optoma's $1,299 UHZ36 deliver the right balance of brightness, gaming performance, and Filmmaker Mode upgrades or are key features missing for serious installs?
Skyworth debuts 100-inch Canvas Elite Art TV at CEDIA 2025, featuring 4K QD-MiniLED, matte screen, Google TV, and premium display tech.
