Marantz Unveils AV 30 and AMP 30 Home Theater Separates With IMAX Enhanced and HEOS
Marantz brings the cost of A/V separates down to a more affordable price point with the AV 30 preamp/processor and AMP 30 multi-channel power amp.
Marantz AV 30 and AMP 30 Promo Shot
AVRs make sense for a lot of people—they’re convenient, compact, and handle everything in one box. But convenience isn’t the goal for serious home theater enthusiasts. For 2026, Marantz reinforces that distinction with the new AV 30 11-channel AV preamp/processor ($4,000) and AMP 30 6-Channel power amplifier ($4,000), two new separates aimed squarely at listeners who want maximum control, system flexibility, and the highest possible surround sound performance, but at a more affordable price point.
Building on the AV 20 and AMP 20 from 2025, and the AV 10 and AMP 10 before them, Marantz is making a clear statement: when ultimate immersion and long-term scalability matter, separating processing from amplification still delivers results that all-in-one receivers can’t reliably match. And you don’t need to mortgage your home for a high performance home theater.
The AV30 pre/pro features 11 channels of audio processing with decoding for Dolby Atmos, DTS-X, MPEG-H, Auro-3D and 360 Reality Audio codecs. It includes four independent subwoofer outputs for full compatibility with DIRAC ART (Active Room Treatment) for optimized in-room speaker performance at all frequencies. We should note that DIRAC room correction requires an additional license purchase.
The AMP 30 features six channels of amplification rated at 200 Watts/Channel (2 channels driven). The Class D amplifiers feature the latest version of Marantz HDAM-SA2 (Hyper Dynamic Amplifier Module) technology. If you need more than six channels, you can stack two of the AMP 30s, or use an AMP 20 (12 channels) instead.
The new AV 30 and AMP 30 perfectly represent Marantz’s unwavering commitment to excellence,” said Lyle Smith, President of Sound United at HARMAN. “With their outstanding performance, elegant design, and supreme versatility, the two models are exceptional additions to Marantz’s world class home theater portfolio.”
How Home Theater Separates Work — And Why Enthusiasts Still Use Them
In a preamp and power amp setup, also known as home theater separates, the AV preamp or preamp processor handles input switching, surround decoding, bass management, room EQ or room correction when included, and overall system control. It is the brain of the theater. The power amplifier is the muscle, taking the processed line level signal from the preamp processor and delivering the current and wattage required to drive passive speakers at realistic listening levels.
The key distinction is simple. An AV preamp processor like the Marantz AV 30 does not drive speakers directly because it does not include speaker level amplification. The only exception is when active or self powered speakers are used with analog inputs, which is not how most traditional multichannel home theater systems are designed.
AV preamp processors such as the AV 30 also include dedicated outputs for powered subwoofers, allowing full control over low frequency integration including level, crossover, and timing.
With that foundation established, we can now take a closer look at the features and specifications of the Marantz AV 30 and AMP 30.
Marantz AV 30 Preamp and Processor Overview
Marantz AV 30 AV Preamp Processor Front View Door Closed
With Marantz signature industrial design that is elegant, restrained, and clearly positioned at the premium end of the market, the AV 30 is built as a comprehensive control center for high end home theater systems. It delivers 11.4 channels of audio decoding and processing, supporting 11 assignable channels along with output for up to four powered subwoofers, allowing for advanced bass management and system tuning.
Before diving into the full specifications, here are the key features worth highlighting.
HDAM: The AV 30 uses Marantz HDAM SA2 preamplifier modules to feed up to 11.4 channels through both RCA and XLR outputs, giving installers and enthusiasts flexibility when pairing the processor with a wide range of multichannel power amplifiers and speaker layouts.
DSP: Processing duties are handled by a dual core SHARC DSP platform working with 32 bit DACs, ensuring precise decoding and consistent audio quality across all supported digital sources and surround formats.
Surround Sound Support: The AV 30 supports a full slate of modern immersive audio formats, including Dolby AtmosDTS: XAuro 3D, and IMAX Enhanced, making it suitable for complex multichannel and height based speaker configurations.
HDR Support: The AV 30 supports HDR10HDR10+Dolby VisionHLG, and Dynamic HDR pass through, ensuring compatibility with current HDR video formats and modern displays.
HDMI 2.1: HDMI 2.1 connectivity includes eARC along with full support for advanced gaming features such as 4K at 120Hz, 8K at 60Hz, Variable Refresh Rate, Auto Low Latency Mode, and Quick Frame Transport, allowing the AV 30 to integrate cleanly into high performance gaming and home theater systems.
Hi Resolution Audio: The AV 30 supports high resolution audio playback up to 24 bit 192kHz. Compatible digital formats include MP3, WMA, WAV, MPEG 4 AAC, FLAC, ALAC, and DSD at 2.8 MHz and 5.6 MHz.
HEOS: The AV 30 supports the HEOS multi room wireless streaming platform, enabling audio playback throughout a compatible HEOS ecosystem. Support for Qobuz Connect is expected via a future update.
Wireless Music Streaming: The AV 30 supports a broad range of music streaming services, including Amazon Music, TIDAL, Deezer, Napster, and SoundCloud, with Qobuz Connect planned. It is also Roon Ready, allowing seamless integration into Roon based music systems for high quality network playback.
M-DAX 2 Compressed Audio Enhancer: This feature enhances compressed audio formats like MP3, Windows Media Audio, and AAC by recalculating the frequency range to deliver clearer, more detailed sound through M-DAX2 processing.
Wireless Connectivity: Bluetooth, Apple AirPlay 2, Wi-Fi (Wired Ethernet is also included if needed).
Marantz AV 30 Preamp/Processor Rear View
Wired Connectivity Inputs: The AV 30 provides a flexible selection of wired inputs, including six analog inputs with one balanced XLR, two optical digital inputs, two coaxial digital audio inputs, and a dedicated moving magnet phono input for turntable use.
Wired Connectivity Outputs: The AV 30 includes three HDMI outputs for connection to televisions, monitors, or projectors. It also offers RCA and XLR audio outputs for all channels, allowing straightforward integration with multichannel power amplifiers and powered subwoofers.
Room Correction: The AV 30 includes built in Audyssey room correction with MultiEQ XT32, Dynamic EQ, Dynamic Volume, and Low Frequency Containment. A connected power amplifier is required to run the calibration measurements since the AV 30 does not include onboard amplification.
The AV 30 is also upgradable to Dirac Live and Dirac Bass Control with the purchase of the appropriate license. Support for Dirac Live Active Room Treatment is planned for a future update, further expanding system tuning options for advanced home theater installations.
Marantz AV 30, 20 and 10 Comparison
Marantz AV 30, AV 20, and AV  10 Comparison
Marantz Model Number AV 30 (2026)AV 20 (2025)AV 10 (2022)
Product TypeMulti-Channel AV Preamp/ProcessorMulti-Channel AV Preamp/ProcessorMulti-Channel AV Preamp/Processor
Price $4,000.00$6,000.00$8,000.00
Number of Preamp Output Channels 11.413.415.4
Dolby SupportDolby TrueHD
Dolby Atmos
Dolby Height Virtualization
Dolby Surround
Dolby TrueHD
Dolby Atmos
Dolby Atmos Height Virtualization
Dolby Atmos Music
Dolby Surround
Dolby TrueHD
Dolby Atmos
Dolby Atmos Music
Dolby Surround
DTS SupportDTS-HD Master Audio
DTS:X
DTS Virtual:X
DTS Neural:X (11ch)
DTS-HD
DTS:X
DTS:X Pro
DTS Virtual:X
DTS Neural:X (13ch)
DTS HD Master Audio
DTS:X
DTS:X Pro
DTS Neural:X (15 ch)
DTS Virtual:X
Audyssey Room CorrectionMultEQ XT32 MultEQ XT32 MultEQ XT32
IMAX EnhancedYesYesYes
Multichannel StereoYesYesYes
Clock Jitter ReducerYesYesYes
Compressed Audio Enhancer: MDAX2YesYesYes
Dirac Upgradability YesYesYes
Copper-Plated Chassis / Toroidal Power TransformerYes / YesYes/YesYes / Yes
Pure Direct / Gold-Plated RCA TerminalsYes / YesYes / YesYes / Yes
Current Feedback Topology / Hyper Dynamic Amplifier Modules (HDAM)Yes / Yes (HDAM-SA2)Yes / Yes (SA3, monolithic)Yes / Yes
Audyssey Dynamic EQ / Dynamic Volume / Audyssey LFC (Low Frequency Containment)Yes / Yes / Yes Yes / Yes / Yes Yes / Yes / Yes
Wi-Fi / Bluetooth / EthernetYes / Yes / Yes Yes / Yes / Yes Yes / Yes / Yes
Auro 3D / 360 Reality Audio / MPEG HYes/Yes/YesYes/Yes/YesYes / Yes / Yes
Bluetooth Retransmit for Bluetooth HeadphonesYesYesYes
Lossy FormatsMP3, WMA, AACMP3, WMA, AACMP3, WMA, AAC
Lossless FormatsFLAC, FLAC HD 192/24, ALAC, ALAC 192/24, WAV, WAV 192/24FLAC, FLAC HD 192/24, ALAC, ALAC 192/24, WAV, WAV 192/24FLAC, FLAC HD 192/24, ALAC, ALAC 192/24, WAV, WAV 192/24
DSD Audio StreamingYes (up to DSD5.6)Yes (2.8/5.6 MHz)Yes (2.8/5.6 MHz)
Gapless PlaybackFLAC, ALAC, WAV, DSDFLAC, ALAC, WAV, DSDFLAC, ALAC, WAV, DSD
TuneIn / AirPlay 2 / Spotify Yes / Yes / Yes Yes / Yes / YesNot Indicated/Yes/Yes
Internet Radio / Pandora / SiriusXMNot IndicatedYes/Not Indicated/Not IndicatedYes / Yes / Yes
Roon-ReadyYesYesYes
Other Streaming ServicesAmazon Music / TIDAL / Deezer / Napster / SoundCloudAmazon Music / TIDAL / Deezer / Napster / SoundcloudAmazon Music / Amazon Music HD / TIDAL / Deezer / iHeart Radio / Napster / Soundcloud / Mood Mix
Compatible with Remote App for SmartphonesMarantz AVR RemoteMarantz AVR RemoteMarantz 2016 AVR Remote
Compatible with Remote App for TabletsAndroid / iOS / Amazon KindleAndroid / iOS / Amazon KindleAndroid / iOS / Amazon Kindle
HDMI Inputs7 (rear)7 (rear)7 (rear)
HDCP 2.3 SupportYesYesYes
HDMI Outputs: Main / Zone 2 / 12 / 12 / 1
HDMI Upscaling1080p/4K to 8K1080p/4K to 8K1080p/4K to 8K
GUI Overlay on HDMIYesYesYes
HDMI 2.1: 8K/60Hz/ 4K/120HzYes / YesYes / YesYes / Yes
8K/60Hz, 4K/120Hz Pass-Through In/Out7 / 2 (up to 40 Gbps7 / 2 (up to 40 Gbps)7 / 2 (up to 40 Gbps)
HDR / HLG / Dolby Vision / HDR10+ / Dynamic HDRYes / Yes / Yes / Yes / YesYes / Yes / Yes / Yes / YesYes / Yes / Yes / Yes / Yes
Enhanced ARC (eARC)YesYesYes
ALLM (Auto Low Latency Mode) Pass-Through for GamingYesYesYes
Variable Refresh Rate / Quick Frame TransportYes / YesYes / YesYes / Yes
3D Signal Pass-ThroughNot IndicatedNot IndicatedYes
HDMI Pass-Through in Standby ModeYesYesYes
DSD Audio CapabilityYesYesYes
Auto LipSyncYesYesYes
Video ConnectionsComposite In / Out 2 / 0
Component In / Out 1 / 0
HDMI In / Out 7 / 3
Multi-Room Video Out: HDMI
HDMI In / Out 7 / 3
Multi-Room Video Out via HDMI
HDMI In / Out 7 / 3
Audio ConnectionsAnalogue In 6 (1× XLR)
Phono (MM) In
Digital In: Optical / Coaxial 2 / 2
Multi-Room Out: Analog / Digital 2 / 0
Multichannel Pre-Amp Out Yes (11.4 RCA, 11.4 XLR)
 Subwoofer Out 4 (independent)
Phono (MM) In
Multichannel Pre-Amp Out Yes (15.4 RCA, 15.4 XLR)
Subwoofer Out 4 (independent) RCA, XLR
Analog In 5 (1, XLR)
Phono (MM) In
Multi-Room Out: Analog / Digital 1 / 0
Multichannel Pre-Amp Out Yes (17.4 RCA, 17.4 XLR)
Subwoofer Out 4 (Independent)
Speaker A / BAssignable Pre-OutAssignable Pre-OutAssignable Pre-Out
Bi-Amp DriveAssignable Pre-OutAssignable Pre-OutAssignable Pre-Out
Front USB Input / USB AudioYes / YesYes / YesYes / Yes
Front Inputs (other than USB)Not IndicatedNot IndicatedAudio / Composite / Digital (Opt) / HDMI
USB Power Supply (Rear)YesYesNot Indicated
AM/FM TunerYesYesYes
HEOS Multi-Room AudioYesYesYes
Multi-Room Zones333
Zone Audio Source: HDMI / Opt, Coax / Network, USB / AnalogueYes (2 ch) / Yes (2 ch) / Yes / YesYes (2 ch) / Yes (2 ch) / Yes / YesYes (2 ch) / Yes (2 ch) / Yes / Yes
Zone Audio OutputNoYesYes
Zone HDMI Output from HDMI SourceYesYesYes
IP Control / RS232 Control / Web Control / App ControlYes / Yes / Yes / YesYes / Yes / Yes / YesYes / Yes / Yes / Yes
IR Flasher In / Marantz Remote BusYes / YesYes / YesYes / Yes
DC Trigger Output333
HDMI DiagnosticsYesYesYes
Front Display2-Line FLD, Port Hole OLED2-Line FLD, Port Hole OLED2-Line FLD, Port Hole OLED
Graphic User InterfaceModern HD GUIModern HD GUIModern HD GUI
Setup Assistant Yes Yes Yes
Firmware Update by Network / USBYes / YesYes / YesYes / Yes
Variable Cross Over / Optimized Bass Redirection / Bass SyncYes / Yes / YesYes / Yes / YesYes / Yes / Yes
Auto Power Off / Sleep TimerYes / YesYes / YesYes / Yes
Metal Front PanelYesYesYes
System Remote ControlRC053SRRC051SRRC047SR
Power Consumption80 W90 W90 W
Standby Consumption0.2 W0.2 W0.2 W
Network Standby Consumption2.0 W<2.0 W<2.0 W
Maximum Dimensions (WDH) Antenna, Horizontal:17.4 × 16.3 × 7.5 in.
Antenna, Vertical:17.4 × 16.3 × 10.0 in.
w/o Antenna: 17.4 × 15.6 × 7.5 in.
Antenna, Horizontal: 17.4 × 18.0 × 7.5 in.
Antenna, Vertical:  17.4 × 18.0 × 10.0 in.
w/o Antenna: 17.4 × 17.2 × 7.5 in.
Antenna, Horizontal: 17.4 × 19.8 × 7.4 in.
Antenna, Vertical: 17.4 × 19.8 × 9.9 in.
w/o Antenna:17.4 × 19.0 × 7.4 in.
Weight 24.5 lbs33.1 lbs37 lbs.
What’s in the BoxMain unit
Remote control
Batteries
AM/FM antennas
Wire labels
Quick Start Guide
Audyssey microphone
Cardboard microphone stand
2 External Detachable Antenna
AC cord
Main unit
Remote control
Batteries
AM/FM antennas
Wire labels
Quick Start Guide
Audyssey microphone
Main unit
Remote control
Batteries
AM/FM antennas
Wire labels
Quick Start Guide
Audyssey microphone
Marantz AMP 30 Power Amplifier Overview
Serving as the natural partner to the AV 30 preamp and processor, Marantz new AMP 30 is a slimline, cool running six channel power amplifier designed to deliver clean, stable output of up to 200 watts per channel. It supports bi amp and BTL bridge tied load modes, offering flexible configuration options for a wide range of speaker layouts. Both XLR and RCA inputs are provided for straightforward system matching.
Like most dedicated power amplifiers, the AMP 30 has a focused role. It takes the line level signal from the preamp and processor and provides the current and power required to drive passive speakers. Volume and gain are controlled entirely by the connected preamp and processor, allowing for tight system integration and simple, predictable operation without redundant controls.
Marantz AMP 30 Power Amplifier Rear View
The AMP 30 carries the same clean, restrained exterior design language seen on the AV 20 and Marantz CINEMA Series AVRs, though in a slimmer chassis. Its signature front panel porthole display is more than cosmetic, doubling as a level meter that provides real time visual feedback on output levels during operation.
Marantz AMP 30, 20, and 10 Comparison Chart
Marantz AMP 30, AMP 30, and AMP 10 comparison
Marantz ModelAMP 30 (2026)AMP 20 (2025) AMP 10 (2022)
Product TypeMulti-channel Power AmplifierMulti-channel Power AmplifierMulti-channel Power Amplifier
Price$4,000.00$6,000.00$8,000.00
Amplifier TypeClass D with Marantz HDAM-SA2 (Hyper Dynamic Amplifier Module) TechnologyClass D with Marantz HDAM-SA2 (Hyper Dynamic Amplifier Module) TechnologyClass D with Marantz HDAM-SA2 (Hyper Dynamic Amplifier Module) Technology
Number of Channels61216
Power Output (8 ohm, 1 kHz, 0.05% 2ch Drive) Normal / BTL200W / 400W200W / 400W200W / 400W
Power Output (4 ohm, 1 kHz, 0.7% 2ch Drive) Normal400W400W400W
Power Output (8 ohm, 1 kHz, 0.7% 5ch Drive) Normal200W200W200W
Main Amplifier InputsBalanced & Unbalanced: 6ch (Exclusive use by a selector switch.)Balanced & Unbalanced: 12ch (Exclusive use by a selector switch.)Balanced & Unbalanced: 16ch (Exclusive use by a selector switch.)
Speaker Terminal TypeSPKT-1+SPKT-1+Brass type (same as MODEL 40n)
Number of Speaker Terminals61216
Bi-Amp Drive / BTL DriveYes / YesYes / YesYes / Yes
Porthole Level MeterYesYesYes
ChassisCopper PlatedCopper PlatedCopper-Plated
RS232 ControlYesYesYes
IR Flasher InYesYesYes
DC Trigger Input / Output1 / 11 / 11 / 1
Front DisplayLevel MeterLevel MeterLevel Meter
Auto Power OffYesYesYes
Power Consumption300W400W500W
Power Consumption, No-Sound70W110W140W
Standby Consumption0.2W0.2W0.2W
Maximum Dimensions (WDH)17.4 × 17.4 × 4.4 in.17.4 × 17.4 × 7.5 in.17.4 × 19.2 × 7.4 in.
Weight22.0 lbs39.7 lbs43.7 lbs
Quick start guide
AC cord
Amp control cable
Remote control cable
Main unit
Quick start guide
AC cord
Amp control cable
SP terminal wrench
Main unit
Quick start guide
AC cord
Amp control cable
SP terminal wrench
Marantz AV 30 and AMP 30 System Compatibility Explained
The AV 30 preamp and processor is compatible with virtually any standalone power amplifier, and the AMP 30 will operate with other AV preamp and processor models, giving system builders a high degree of flexibility when upgrading or expanding an existing home theater. You can also mix and match components across Marantz current and previous generations, including the 30, 20, and 10 Series. For example, pairing the AV 30 with an AMP 20 or AMP 10 is fully supported.
One practical consideration is channel count. The AMP 30 provides six channels of amplification, which means that when it is used with processors such as the AV 30, AV 20, or AV 10, multiple amplifiers may be required depending on how many speaker channels are being powered in the system.
Regardless of configuration, speaker selection remains critical to overall performance. With this level of cross compatibility, users can build a system incrementally or commit to a full separates setup from the start, tailoring amplification and processing to match their room, speaker layout, and performance goals.
The Bottom Line
The AV 30 and AMP 30 are purpose built separates aimed at home theater systems where control, flexibility, and predictable performance matter more than all in one convenience. The AV 30 covers the full spread of modern surround formats, including Dolby Atmos, DTS X, Auro 3D, and IMAX Enhanced, ensuring compatibility with today’s immersive mixes and complex speaker layouts.
There are clear tradeoffs. Channel counts are more limited than some buyers may expect at this level, and the financial math is not trivial. A single Marantz AMP 20 delivers twelve channels of amplification at a similar power level for $6,000, while achieving the same channel count with the AMP 30 requires two units at a combined cost of $8,000. For larger systems, that difference matters.
Taken together, the AV 30 and AMP 30 are best suited for home theater enthusiasts who want modern surround format support and a true separates architecture, but who do not need maximum channel density. They are not value driven components, but they offer a controlled, scalable approach to building a high performance surround system without unnecessary excess.
Price & Availability
The Marantz AV 30 and AMP 30 are coming soon to Authorized Marantz Dealers near you.
AV 30: $4,000
AMP 30: $4,000
If you are interested in getting the previously released AV 20,  AV 10 and AMP 20, and AMP 10.
AV 20: $6,000 at Crutchfield
AMP 20: $6,000 at Crutchfield
AV 10: $8,000 at Crutchfield
AMP 10: $8,000 at Crutchfield
2 Comments
2 Comments
  1. Alain T.
    January 14, 2026 at 3:27 pm
    (Very) strange choice of channels number for the power amp…
    6 ???
    It’s more logic to have 3, 5, or 7
    • Ian White
      January 14, 2026 at 6:19 pm
      Alain,
      I totally agree. Which is why I added that comment at the end about having to buy two versus the cheaper AMP 20.
      IW
Epson Lifestudio Grand Plus UST Projector
The new Epson Lifestudio Grand Plus LS970 UST Projector is bright enough to light up a huge screen just inches from the wall and...
Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle Denon Home 200, 400 and 600 Wireless Speakers White Lifestyle
Denon brings Dolby Atmos music support to its HEOS whole home music platform with this trio of wireless speakers.
Andrew Jones Introduces New Speaker and Company Jones and Cerreta Andrew Jones Introduces New Speaker and Company Jones and Cerreta
Andrew Jones to debut Jones and Cerreta at AXPONA 2026 with MoFi Distribution but what is this field coil concentric floorstander and how much...
Børresen Center3 Front Angle Lifestyle Børresen Center3 Front Angle Lifestyle
Center Speakers
Børresen’s $7,000 Center3 brings flagship tech to home theater but is it the missing piece for X Series owners or still overkill?
FiiO Darkside Pro Linear Power Supply FiiO Darkside Pro Linear Power Supply
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
Netflix Stranger Things Complete Series July 2026 Netflix Stranger Things Complete Series July 2026
Movies
Stranger Things Complete Series on Blu-ray and 4K UHD arrives this July in four collector box sets, but which edition should you buy?
Onkyo wowed crowds at CES 2026 with an entirely refreshed line of A/V receivers, as well as a return to the A/V separates market.
At $12,000 for the combo, the new Marantz home theater separates include a 13.4-channel AV preamp and 12-channel amplifier.
Compare Denon and Marantz AVRs for 2025—explore features, performance, and prices to find the best home theater receiver for your setup, from budget to...
Dirac Live Active Room Correction for select Denon and Marantz A/V Receivers and Preamp/Processors is now available for $299 extra.
The Marantz AV 10 Preamp/Processor and AMP 10 Power Amplifier are capable of delivering 15.4 channels of surround sound.
Marantz offers six home theater A/V Receivers from $599 to $4,500. What’s the difference, and which one might be right for you?
NextLevel Acoustics Audio Art turns the frame around your TV into a high-performance integrated surround sound system, with speakers built directly inside the frame.
Qobuz Connect launches this week, bringing seamless high-res audio streaming to HEOS and a wide range of devices, outshining TIDAL with smoother integration.
