Klipsch isn’t slowing down. After rolling out the Red Oak finishes for the Forte IV and Heresy IV, plus fresh updates to the Klipschorn AK7 and La Scala AL6, the company has rolled into CEDIA 2025 with something new for the outdoors—the Courtyard Landscape Speaker System. This isn’t just another box on a patio; it’s a full system built to take the legendary Klipsch sound outside, giving CI integrators another weapon in the arsenal for clients who want their backyard to hit as hard as their living room.
What the Klipsch Courtyard Landscape Speaker System Brings to Outdoor Audio
The Courtyard is a complete 4.1 channel speaker system designed to drop straight into the backyard—whether it’s for movie nights, BBQs, family chaos, or poolside bragging rights. It’s an easy sell for integrators in a CI market that’s only getting bigger, and Klipsch knows exactly how to arm them with gear that keeps both clients and neighbors talking.
The system ships with four satellite speakers using Klipsch’s trademark horn-loaded tech and a low-profile subwoofer you can literally sink into the ground. Style points aren’t lost either—the Courtyard is built to disappear into just about any backyard setup. All the mounting hardware is in the box, and if 4.1 channels somehow feel tame, you can bump it up to 6.1 with an expansion pack. For those who want to go full “outdoor arena,” two Courtyard kits linked together give you an 8.2 channel system—perfect for blanketing larger spaces with music, movie soundtracks, or just a little friendly neighborhood domination
Klipsch Courtyard Satellite Speakers: Horn-Loaded Outdoor Performance
Each Courtyard satellite speaker packs the same Tractrix horn design found in Klipsch’s premium lines, paired with a 4″ woofer and 1″ tweeter inside a tilting head assembly that locks into place. Round, detachable stakes make it easy to plant and reposition for the best ground-level coverage. Getting sound up and running is straightforward—just connect through zone 2 of an AVR, a streaming amplifier, or a pre-amp/network player of your choice.
Klipsch points to Integra’s latest amps as an ideal partner for maximum dynamics and detail, but let’s be clear—you’re not locked in. Any capable AVR or multi-channel amp will get the Courtyard singing in your outdoor space.
Courtyard Subwoofer: The Bass You Can Bury in Your Backyard
The Klipsch Courtyard’s low-profile 10″ subwoofer can disappear into the landscaping—partially buried in the ground—or sit above it if that’s more your speed. Either way, it’s built to deliver the low-end punch outdoor systems need to feel like the real deal.
Stake mounts and rotatable anchors make placement flexible, while a built-in cable-management alcove on the bottom panel keeps wires hidden. The result is a clean install that doesn’t wreck the look of a backyard but still brings the kind of bass you expect from Klipsch.
Finish and Environmental Protection: How the Klipsch Courtyard Handles the Outdoors
The Klipsch Courtyard system is built to take whatever the outdoors throws at it. Rated IXP7, it laughs in the face of rain, snow, high-pressure water jets, and relentless sunlight. Out of the box, it’s ready to go with all the accessories you need—hammer-friendly caps, silicone wire nuts, and an Allen wrench—making setup straightforward.
The satellite speakers and subwoofer sport a colorfast brown matte finish, blending into the yard while standing up to the elements season after season. This isn’t just outdoor sound; it’s a system engineered to survive and perform no matter where it lives.
Klipsch Courtyard Landscape Speaker System Specifications
| Klipsch Model | Courtyard 4.1 Channel Speaker System |
| Product Type | Outdoor Speaker System |
| Price | 4.1 Channel System (4 Sats with Subwoofer) – $1,799.99 2 Channel Expansion Pack (2 extra Sats) – $599.99 |
| Frequency Response (+/- 3dB) | 5 – 20kHz |
| Power Handling (Continuous) | 120 Watts |
| Power Handling (Peak) | 40 Watts |
| Max Sound Pressure Level (SPL) | 107 dB |
| Sensitivity (@ 2.83V / 1m) | 86 dB |
| Area Coverage | V120 / H60 ° (Sat, Aimable) Omni-Directional (Sub) |
| Impedance (Nominal) | 8 Ω Compatible (6.0 Ω Min) |
| Crossover Frequencies | 120Hz (Sub-Sat) 3.0kHz (Sat Wfr/Twtr) |
| Tweeter (High-Frequency Driver) | Tractrix horn-loaded Aluminum |
| Woofer | 4” Polypropylene (Sats) |
| Subwoofer | 10” Polypropylene (Sub) |
| Enclosure Material | UV Treated All Weather ABS Rotomolded Linear Low-Density Polyethylene (LLDP |
| Enclosure Type | Sealed Hardscape/Partial Burial (Sub) |
| IP Rating | IPX7 |
| Inputs | 65cm Pigtail (30”) Bare Wire with Silicon Filled Wire Nuts |
| Dimensions (HWD) | Satellite: 5.75” (no stake) x 7.38” x 7” Subwoofer: 12” x 15” x 15” Stake: 12.5” length x 1.55” diameter, stake fits 1.5” schedule 40 PVC |
| Weight | Satellite: 3.5 lbs (1.6 kg) Subwoofer: 24 lbs (10.9 kg) Stake: 0.37 lbs (0.17 kg) |
| Finish | Brown Matte |
The Bottom Line
The Klipsch Courtyard Landscape Speaker System extends the brand’s signature horn-loaded clarity and dynamic punch to outdoor spaces, offering a fully integrated 4.1 (expandable to 8.2) setup that’s flexible for backyards of all sizes. Pricing positions it above entry-level outdoor speakers but well below full high-end custom install systems, making it a compelling option for integrators and homeowners who want premium sound without breaking the bank.
Between its durable IXP7-rated construction, versatile installation options, and compatibility with any AVR or multi-channel amplifier, the Courtyard is ideal for movies, music, and large outdoor gatherings—essentially a turnkey solution for delivering Klipsch-level performance outside.
Price & Availability
The Klipsch Courtyard Landscape speakers are expected to be available beginning in September 2025 from authorized Klipsch retailers and www.klipsch.com.
- Klipsch 4.1 Courtyard Landscape Speaker System: $1,799.99
- Klipsch Courtyard Expansion Pack (Two Additional Satellite Speakers): $599.99
Related Reading
- Polk Audio Atrium Series: Innovation and Performance Redefining Outdoor Speakers
- Projector Nights & Mosquito Fights: The 2025 Guide To Backyard Movie Theater Magic
- ELAC Muro Pro Outdoor Speakers Are Designed for Your Poolside or Castle in the Alps
- Preview: Monitor Audio’s Climate Series 3G Outdoor Speakers Can Be Used Anywhere
- Focal’s Littora 200 OD Series Loudspeakers Will Survive Your Outdoor Listening Experience
