KEF Unveils Coda W: Bluetooth Speakers with aptX Lossless, But No Wi-Fi?
At $999/pair KEF’s Coda W wireless speakers feature Uni-Q drivers, built-in amps, MM phono preamp, and aptX Lossless, but lack support for AirPlay 2 and Spotify Connect.
KEF Coda W Wireless Speakers Titanium Lifestyle
KEF isn’t exactly new to the wireless game — the British brand has spent the past decade reminding everyone that great sound doesn’t need a mess of cables or a rack full of gear. After the runaway success of the LS50 WirelessLS50 Wireless II, LSX, and LSX II, KEF is now turning its attention to something a little more compact (and possibly more attainable) with the Coda W.
Building on the legacy of its classic passive Coda models; like the Coda 7 and 9.2, the new Coda W is a refined all-in-one wireless speaker that blends KEF’s signature design, built-in amplification, and flexible wired and wireless connectivity. In typical KEF fashion, it looks sharp, promises precision, and aims to make you forget your amp ever existed.
Our goal has always been to deliver the most authentic sound possible – the kind that forges an emotional connection. We designed the Coda W for those of us who love the ritual of vinyl – the magic of dropping a needle on a record, that moment of anticipation. With Coda W, you can get completely immersed in the depth of your records, appreciating the richness and nuance in every note, then switch to streaming a new track seamlessly. It’s about rediscovering your favourite songs like never before,” explained Grace Lo, President and Head of Global Marketing, KEF
kef-coda-w-moss-green-front-back
KEF Coda W Overview
The KEF Coda W system includes two speakers, with the main unit acting as the powered hub — handling all connectivity, amplification, and signal distribution for both channels. There’s no need for an external amplifier, stereo, or home theater receiver; everything’s built in.
The secondary speaker connects to the main unit via a 3-meter interspeaker cable, and KEF smartly offers an optional 8-meter C-Link cable for those whose rooms don’t follow the “perfect setup” blueprint.
Even better, the wired connection between the two speakers supports up to 24-bit/96kHz PCM audio, which is more than enough resolution for 99% of what’s available from today’s major streaming services. It’s a thoughtful balance of audiophile performance and real-world practicality.
kef-coda-w-vintage-burgundy-rear
Uni-Q: To optimize the listening experience, each speaker includes KEF’s 12th Generation Uni-Q driver array, which combines a 25mm (1-inch) aluminum dome tweeter with a 130mm (5.25-inch) magnesium/aluminum alloy cone woofer. This setup delivers the focused imaging, clarity, and wide dispersion that have made Uni-Q a hallmark of KEF’s design philosophy.
Music Integrity Engine: This KEF feature uses advanced signal-processing algorithms to correct timing errors, ensuring the Uni-Q drivers in the Coda W deliver precise imaging and tighter sound without unwanted artifacts.
Amplification: The Coda W wireless system delivers a total power output of 200 watts, with separate amplifiers for the woofer and tweeter in each speaker, managed by precision crossovers. The system’s frequency response ranges from 41Hz to 47kHz, depending on EQ settings, ensuring balanced, full-range sound.
kef-coda-w-vintage-burgundy-rear-signature
Pro Tip: Each speaker features a rear-mounted port to enhance low-frequency extension, delivering deeper, more impactful bass. Be mindful of the distance between the wall and the back of the cabinet, as positioning too close can affect bass performance.
Subwoofer Output: The Coda W includes a subwoofer preamp output for those looking to extend low-frequency performance — particularly useful for movie watching. Any powered subwoofer can be used, with the KEF KC62 as a space-saving option. For even greater placement flexibility, the optional KW1 wireless subwoofer adapter kit provides a clean, wireless connection, eliminating cable clutter.
Bluetooth Support: The Coda W lets you stream music wirelessly from a phone, tablet, or laptop, providing a simple pairing process and the freedom to play audio instantly. It supports Bluetooth Version 5.4 with aptX and aptX LosslessaptX Adaptive ensures low-latency audio for seamless listening with excellent clarity and reliability, while aptX Lossless delivers CD-quality resolution up to 16-bit/44.1kHz.
Wi-Fi? Neither Wi-Fi or network (wired Ethernet) connectivity is included, which means no support for Google Cast, Apple AirPlay 2, Spotify Connect, TIDAL Connect, or Qobuz Connect. Also, since Apple devices are not compatible with aptX, they’ll be limited to the lowest bandwidth Bluetooth quality.
KEF Coda W Physical Source Connectivity: Wired Inputs, MM Phono Preamp, and HDMI ARC
Beyond wireless streaming, the Coda W offers a wide array of wired connections for maximum flexibility. This includes HDMI ARCDigital Optical, and USB-C inputs, allowing direct connection to TVs, CD/DVD/Blu-ray players, game consoles, and more.
  • Digital Optical Audio: Supports PCM up to 24-bit/96kHz
  • USB-C: Supports PCM up to 24-bit/192kHz for high-resolution computer audio
  • HDMI ARC: Supports PCM up to 1.411 Mbps, making TV and home theater integration seamless
For vinyl enthusiasts, the Coda W features a dedicated MM-compatible phono input with an integrated phono preamp, allowing almost any turntable to connect directly without extra equipment. Turntables with built-in preamps can use the RCA (LINE) input, providing flexibility for all types of analog sources.
With this mix of HDMI ARC, USB-C, optical, and RCA inputs, the Coda W functions as a versatile audio hub, easily accommodating modern and legacy devices while delivering high-resolution audio across every connection.
kef-coda-w-moss-green-desktop
Control Options
The Coda W features intuitive top-panel buttons for quick access to essential functions and source switching. KEF’s Connect app (iOS, Android) provides more control, including EQ settings, and access to select streaming services.
KEF Coda W Cabinet Design: Minimalist Aesthetic, Timeless Silhouette, and Five Elegant Finishes
The Coda W speakers feature a minimalist design reminiscent of KEF’s Q-Series Meta speakers, with clean, rectilinear lines and subtle detailing that create a timeless silhouette. This refined aesthetic blends vintage charm with modern sophistication, making the speakers at home in a living room, home studio, study, or reading nook.
The Coda W is available in Dark Titanium, Nickel Grey, Vintage Burgundy, Moss Green, and Midnight Blue, giving you options to match a variety of interiors while maintaining that understated elegance KEF is known for.
KEF Wireless Bookshelf Speakers Comparison
kef-wireless-speakers-2025
KEF ModelCoda WLSX II LTLSX IILS50 Wireless II
Product TypeWireless Speaker SystemWireless Speaker SystemWireless Speaker SystemWireless Speaker System
Price$999$999$1,499$2,999
Drive unitsUni-Q Driver Array:
HF: 25 mm (1 in.) aluminium dome
LF/MF: 130 mm (5.25 in.) magnesium/aluminium alloy cone
Uni-Q driver array:
HF: 19mm (0.75in.) aluminium dome
LF/MF: 115mm (4.5in.) magnesium/aluminium alloy cone
Uni-Q driver array:
Uni-Q Driver Array:
HF: 25 mm (1 in.) vented aluminium dome with Metamaterial Absorption Technology
LF: 130 mm (5.25 in.) aluminium cone
Frequency range (-6dB) measured at 85dB/1m38 Hz- 20 kHz49 Hz – 47 kHz49 Hz – 47 kHz40 Hz – 47 kHz
Frequency response (±3dB) measured at 85dB/1m41 Hz – 20 kHz54 Hz – 28 kHz54 Hz – 28 kHz45 Hz – 28 kHz
Amplifier output power (per speaker)LF: 70W
HF: 30W
LF: 70W
HF: 30W
LF: 70W
HF: 30W
LF: 280W
HF: 100W
Amplifier class (per speaker)LF: Class D
HF: Class D
LF: Class D
HF: Class D
LF: Class D
HF: Class D
LF: Class D
HF: Class AB
Max SPL measured at 1m102 dB102 dB 102 dB 108 dB
Built-in WiFiYesYesYes
EthernetYesYesYes
AirPlay 2YesYesYes
Wireless Streaming FeaturesBluetooth 5.4
aptX Adaptive™
aptX Lossless™
Bluetooth 5.0
Google Chromecast
UPnP
Compatible
Plays with Audirvāna
Bluetooth 5.0
Google Chromecast
UPnP Compatible
Roon Ready
Bluetooth 5.0
Google Cast
UPnP Compatible
Roon Ready
Source resolutionOptical up to 96kHz/24-bit
USB Type-C up to 192kHz/24-bit
HDMI up to 1.411 Mbps PCM
Network up to 384kHz/24-bit
USB Type C up to 192kHz/24-bit
PCM
HDMI up to 1.411Mbps PCM
Coaxial up to 192kHz/24-bit
HDMI up to 192kHz/24-bit
Interspeaker ConnectionWired: all sources resampled to 96kHz/24-bit PCMWired: all sources resampled to 96kHz/24-bit PCMWireless:  all sources resampled to 48kHz/24-bit PCM
Wireless: all sources resampled to 96kHz/24-bit PCM
Wired: all sources resampled to 192kHz/24-bit PCM
Dimensions (HWD per speaker)285 x 168 x 268  mm
11.2 x 6.6 x 10.55 in.
240 × 155 × 180 mm
9.5 × 6.1 × 7.1 in.
240 × 155 × 180 mm
9.5 × 6.1 × 7.1 in
305 x 200 x 311 mm
12 x 7.9 x 12.2 in.
Weight (per set)11.3 kg (24.9 lbs)6.8kg (15.0lbs)7.2kg (15.6lbs)20.1kg (44.3lbs)
Power input100 – 240VAC 50/60Hz100 – 240VAC 50/60Hz100 – 240VAC 50/60Hz100 – 240VAC 50/60Hz
Power consumption200W (operating power)
 <0.5W (standby power)
<2.0W (standby power)
Primary speakerPrimary speakerPrimary speakerPrimary speakerPrimary speaker
InputsHDMI ARC
Optical
USB Type-C (audio)
RCA (LINE)
RCA (PHONO)
HDMI ARC
Optical
USB Type C (audio)
RJ45 Ethernet (network)
HDMI ARC
TOSLINK
Optical
USB Type-C
Analog 3.5mm
Auxiliary
HDMI eARC
Optical
Digital Coaxial
Analog 3.5mm
Auxiliary
USB Type-A (service)
OutputRCA Subwoofer output
USB Type-C (interspeaker)
USB Type-C (5V DC)
RJ45 Ethernet (interspeaker)
Secondary SpeakerSecondary SpeakerSecondary SpeakerSecondary SpeakerSecondary Speaker
InputUSB Type-C (interspeaker)USB Type-C (interspeaker)RJ45 Ethernet (interspeaker)USB Type-A (service)
FinishesDark Titanium. Nickel Grey, Vintage Burgundy, Moss Green, Midnight Blue, Sage Green, Stone White, and Graphite GreyCarbon Black, Mineral White, Cobalt Blue, Lava Red, and SoundwaveCarbon Black, Titanium Grey, Mineral White, Sand Shell, and Moss Green
What’s In The BoxA set of Coda W
Power cord
Interspeaker cable (3m)
Remote control
Quick Start Guide
Warranty and safety information
A set of LSX II LT
Power cord
Remote control
Quick Start Guide
A set of LSX II
Power cords
Interspeaker cable
Remote control
Quick Start Guide
warranty and safety information
A set of LS50 Wireless II
Remote control
Interspeaker Cable
Power cord
Quick Start Guide, Warranty
kef-coda-w-colors
The Bottom Line
The KEF Coda W is a thoughtful addition to KEF’s wireless speaker lineup, blending high-end compact audio technology with a minimalist, Q-META-inspired aesthetic. At $999, it matches the LSX II LT in price but opts for straight edges and a more traditional look rather than the curved, modern styling of KEF’s other compact wireless models. Technically, it packs the essentials: 12th Generation Uni-Q drivers, built-in amplification, MM phono preamp, subwoofer output, and aptX/aptX Lossless Bluetooth streaming.
Where the Coda W stands apart — and raises questions — is its lack of Wi-Fi or Ethernet connectivity. Unlike the LS50 Wireless II or LSX II, this system relies solely on Bluetooth for streaming, and while you can control the speakers through the KEF Connect App, the absence of a network connection and WiFi support means Spotify Connect, AirPlay 2 or Google Cast support is off the table. For vinyl lovers and those who prioritize clean, wired or Bluetooth setups, the Coda W delivers on performance and flexibility. For those who lean on networked streaming or smart-home integration, the missing Wi-Fi is a notable limitation.
Price & Availability
KEF Coda W is available for $999/pair at Crutchfield.
The Coda W can be paired with the optional SQ1 floor stands (offered in Grey or White), The stands provide a stable platform for elevated positioning and optimal listening height ($399 pair through KEF)
For more information: us.kef.com/products/coda-w
7 Comments
7 Comments
  1. Larry
    October 21, 2025 at 9:26 am
    Hi Robert,
    Nice review. I think it’s important that you highlighted the lack of network connectivity, as it didn’t jump out at me in other announcements I read.
    I have a couple of thoughts on that topic, as I own numerous different KEF speakers (MUO gen-1, KEF EGG, KEF EGG Duo, and a passive set of LS50 Meta). When paired with a Samsung Galaxy series phone, the powered KEF models sound fantastic using apt-X and KEF’s BT implementation. On small speakers, Hi-Res streaming isn’t all that important. (I have run the EGGs via BT and an external DAC to compare and found minimal difference.)
    If someone wants to use a streaming service, then buy a WiiM Mini or WiiM Pro and connect via the optical port. The Pro will use Qobuz Connect and YT Music, where the Mini can’t. (The Mini will use Qobuz via its app and YT via BT.)
    My hunch is that KEF figures that eliminating Wi-Fi will likely cut down the number of support calls substantially.
    I think KEF will sell a bazillion of these new speakers. BTW, Costco has the LSX LT ii for $600 if anyone would like a set of those instead. I ordered mine in white. 🙂
    Larry
    • Ian White
      October 21, 2025 at 1:45 pm
      Larry,
      It jumped out to Robert and I when we were working on the article. It does seem like a strange omission considering the price. I agree that one could use a WiiM Pro (I use one with my Triangle Borea BR03 BT in my bedroom system) in this scenario for a small expenditure.
      We hope to review a pair soon. KEF’s been slow of late getting out products.
      IW
  2. Larry
    October 21, 2025 at 2:46 pm
    Hi Ian,
    I forgot to mention that with a USB-C port, the easiest and cheapest streaming front end is your phone, or better yet, the old phone you no longer use that was worth $5 as a trade-in.
    I’ll bet they dropped Wi-Fi/Ethernet due to cost, space, or RF considerations. In a tight space, my hunch is it was for RF.
    For $999, this is comparable to a pair of on-sale Q1 Meta and one of the WiiM Amps.
    I look forward to reading your review. I’m certain it will be a good read.
    Larry
  3. David
    October 21, 2025 at 2:55 pm
    Robert or Ian,
    Regarding the promotional photo showing a desktop setup. Is anyone actually using speakers this large on such a small desk top? It seems ridiculous from a practicality and aesthetic perspective and the audio performance must surely be hampered by the speaker placement. I once had to temporarily place my 6.5 inch stand mount speakers atop my a/v stand. This placed the speakers about 30 inches apart. What emanated my beloved Energy c-3 monitors could only be described as a hot mess.
    David
    • Ian White
      October 21, 2025 at 3:49 pm
      David,
      Expecting PR people or the marketing department to figure that out as we all know that might be a rather big ask — not very likely.
      That being said — some of us have rather large desktops where larger monitors can work.
      IW
  4. David
    October 21, 2025 at 4:04 pm
    I will add these are quite aesthetically appealing and seem a decent value for a KEF powered speaker set.
  5. Robert Silva
    October 22, 2025 at 1:45 am
    Thanks for all the great comments – and yes – At first I thought the lack of Wi-Fi was just press release oversight – but it wasn’t.
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
KEF adds two new colors to its LSX II wireless speakers, refreshing the compact hi-fi lineup — but in a price-sensitive market, is a...
At $399, Arylic’s LP100 digital music streamer targets the WiiM Ultra with extra features including AirPlay 2, a built-in MC/MM phono stage, and extensive...
Bowers & Wilkins brings its McLaren partnership back for 2025 with the Px8 S2 McLaren Edition, pairing the updated S2 acoustic platform with clean...
At $699, Noble Audio’s FoKus Prestige Encore elevates luxury wireless listening with a four-driver hybrid design, Audiodo sound calibration, Bluetooth 5.4 with aptX Lossless...
The Triangle CAPELLA 2 delivers flexible home audio with WiSA wireless, Bluetooth, and multiple wired inputs, including a new subwoofer output, combining French design...
Bang & Olufsen marks 100 years with The Centennial Collection, reimagining the Beoplay H100, Beosound A5 and A9--stylish, nostalgic, and light on innovation.
