In-Wall Speakers
KEF Introduces New THX-Certified In-Wall Speakers: Ci3120QLM-THX and Ci5120QLM-THX Deliver Reference-Grade Home Theater Sound
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
KEF Ci3120QLM-THX and Ci5120QLM-THX In-Wall Architectural Speakers Grille Half
The high-end in-wall speaker market has quietly exploded since the pandemic, as more people turned their living spaces into permanent home theaters and listening rooms. KEF, never one to miss a shift in how we listen, has expanded its Extreme Home Theater lineup with two new models — the Ci5120QLM-THX and Ci3120QLM-THX.
At the core of both models is KEF’s 12th-generation Uni-Q driver array, a hallmark of the brand’s engineering that disperses sound evenly across the room so every listener hears precise imaging and balanced tonality. This latest generation incorporates Metamaterial Absorption Technology (MAT) — a labyrinthine structure that absorbs 99% of unwanted sound from the rear of the tweeter. The result is clearer, more natural treble response and an impressively detailed soundstage that maintains fidelity whether you’re watching films, gaming, or listening to music.
The Ci5120QLM-THX carries THX Ultra certification for large rooms, while the Ci3120QLM-THX is THX Select certified for medium-sized environments — proving that “hidden audio” doesn’t have to mean “hidden performance.”
Each model employs custom-engineered 120mm (4.75-inch) bass drivers with long-throw cones and exceptionally low distortion for deep, controlled bass from compact enclosures.
The Ci5120QLM-THX houses four bass drivers for maximum output, while the Ci3120QLM-THX uses two, optimized for smaller environments. KEF’s Flexible Decoupling Chassis further enhances clarity by reducing unwanted vibration and interaction between the midrange and high-frequency units, while a refined tweeter gap damper improves resonance control.
Both systems are true 3-way designs with fully optimized crossovers, ensuring each driver operates within its ideal frequency range for seamless, full-range sound.
KEF Ci3120QLM-THX: THX Certified Select In-Wall Speaker for High-Performance Home Theater
Since 1961, KEF has been dedicated to reproducing sound exactly as the artist intended — accurate, natural, and immersive. The new Ci3120QLM-THX continues that legacy, combining acoustic innovation from KEF’s premium ranges with the discreet design flexibility that today’s multipurpose living spaces demand.
Part of the brand’s Q Series architectural lineup, the Ci3120QLM-THX is engineered for those who want high-fidelity, room-filling sound without compromising aesthetics. Compact yet powerful, it’s ideal for medium-sized home theaters, living rooms, or hybrid entertainment spaces, offering THX Certified Select performance — a benchmark that ensures the speaker meets strict standards for output levels, frequency response, and distortion.
kef-ci3120qlm-thx-in-wall-speaker
Two 120mm (4.75-inch) long-throw bass drivers deliver deep, clean low-end response from a compact form factor, while KEF’s Flexible Decoupling Chassis minimizes unwanted vibration for precise midrange and treble performance. A re-engineered tweeter gap damper further reduces resonance, enhancing clarity and detail across all frequencies. With a 3-way system design and fully optimized crossovers, each driver performs at peak efficiency, resulting in an effortlessly cohesive and dynamic presentation.
True to KEF’s “Hide your speakers, not your sound” philosophy, the Ci3120QLM-THX features an Ultra-Thin Bezel (UTB) and a paintable magnetic metal grille for a clean, modern look that integrates seamlessly into any wall. Rated IP64 for dust and splash resistance, it’s equally at home in a wide range of environments — from media rooms to open-plan living spaces.
KEF Ci3120QLM-THX Specifications
FeatureDetails
ModelCi3120QLM-THX
SeriesQ Series
Design Type3-Way In-Wall Architectural Speaker
THX CertificationTHX Certified Select (Medium Rooms)
Nominal Impedance
Sensitivity (2.83V/1m)89dB
Frequency Response (±6dB)50Hz – 20kHz (open-backed)
Frequency Range (-10dB)42Hz – 20kHz
Max SPL105dB
Crossover Frequencies440Hz, 2.75kHz
Drive UnitsLF: 2 × 120mm (4.75″) long-throw bass
MF: 100mm (4″) Uni-Q
HF: 19mm (0.75″) vented aluminum dome with MAT™
Recommended Amp Power25 – 250W
Recommended High-Pass Filter35Hz – 100Hz
Nominal Coverage150°
Mounting Depth90mm (3.6″)
Cut-Out Dimensions (H × W)513 × 163mm (20.2″ × 6.4″)
External Dimensions (H × W × D)536 × 186 × 96mm (21.1″ × 7.3″ × 3.8″)
Ideal Rear Volume40L (minimum 20L)
Net Weight6.2 kg (13.7 lbs)
Safety / ComplianceIP64 (splash and dust proof)
Ceiling Thickness Range6mm – 36mm (0.24″ – 1.42″)
KEF Ci5120QLM-THX: THX Certified Ultra In-Wall Speaker for Large Home Theater Spaces
The KEF Ci5120QLM-THX represents the next evolution in high-end architectural audio — a solution designed for modern multipurpose rooms where performance and discretion must coexist. Built to KEF’s uncompromising standards, this model delivers cinema-grade sound in a sleek, install-friendly design that disappears into the wall yet fills the room with dynamic, lifelike detail.
For bass duties, the Ci5120QLM-THX features four custom-engineered 120mm (4.75-inch) long-throw drivers with ultra-low distortion, producing deep, articulate low frequencies from a compact footprint. This design, combined with KEF’s Flexible Decoupling Chassis, isolates driver motion to prevent vibration from coloring the sound, while the re-engineered tweeter gap damper enhances overall precision and clarity.
kef-ci5120qlm-thx-in-wall-speaker
The 3-way system architecture and fully optimized crossovers allow each driver to perform its dedicated role with surgical accuracy. The result is a wide, immersive soundstage that maintains fidelity and dynamics even at high volume levels. Certified as THX Certified Ultra, the Ci5120QLM-THX meets the strictest standards for frequency response, output, and distortion, making it ideal for large home theaters or open-plan entertainment areas where power and accuracy are equally critical.
True to KEF’s design ethos — “Hide your speakers, not your sound” — the Ci5120QLM-THX incorporates an Ultra-Thin Bezel (UTB) and a paintable magnetic metal grille, ensuring a near-invisible finish that blends seamlessly with any interior. Its IP64 rating means it’s protected against dust and splashes, allowing flexible installation across different environments without compromising reliability or performance.
KEF Ci5120QLM-THX Specifications
FeatureDetails
ModelCi5120QLM-THX
SeriesQ Series
THX CertificationTHX Certified Ultra (Large Rooms)
Nominal Impedance
Frequency Response (±6dB)45Hz – 20kHz (open-backed)
Frequency Range (-10dB)38Hz – 20kHz
Max SPL105dB
Drive UnitsLF: 4 × 120mm (4.75″) long-throw bass
Cut-Out Dimensions (H × W)795 × 163mm (31.3″ × 6.4″)
External Dimensions (H × W × D)818 × 186 × 96mm (32.2″ × 7.3″ × 3.8″)
Ideal Rear Volume70L (minimum 35L)
Net Weight9.7 kg (21.4 lbs)
kef-ci5120qlm-thx-ci3120qlm-thx-lifestyle-tv
The Bottom Line
KEF’s new Ci5120QLM-THX ($1,699.99 each) and Ci3120QLM-THX ($1,299.99 each) bring true high-fidelity performance to the in-wall speaker category, combining the company’s 12th-generation Uni-Q driver array, Metamaterial Absorption Technology (MAT), and THX certification for uncompromising accuracy and dynamics. Designed for listeners who want cinema-grade sound without visible hardware, these models are ideal for architectural home theaters, luxury media rooms, and multipurpose living spaces where aesthetics and acoustic precision both matter.
While DALIMonitor Audio, and Theory Audio Design all make compelling in-wall options in the premium range, KEF’s new offerings stand out for their balanced mix of engineering sophistication, installation versatility, and THX-backed performance. The Ci5120QLM-THX suits larger rooms needing commanding output and low distortion, while the Ci3120QLM-THX fits perfectly into medium spaces where clean detail and immersive sound are the goal.
In short: if you want reference-level sound hidden behind the drywall—and the reassurance that it’s built to exacting standards—KEF’s latest Extreme Home Theater models are among the most complete, future-ready choices in the category.
For more information: us.kef.com/collections/architectural-speakers
Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Victrola and Third Man Records Limited Edition Turntable and Speakers Victrola and Third Man Records Limited Edition Turntable and Speakers
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
2026 TCL QM8L 4K TV Lifestyle 2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
ZMF Tessidera Planar Magnetic Audiophile Headphones ZMF Tessidera Planar Magnetic Audiophile Headphones
ZMF Tessidera planar magnetic headphones debut at AXPONA 2026 with Canarywood tuning, new chassis options, and a $2199 launch price.
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Editors’ Choice 2025: The best in-wall and in-ceiling speakers for home theater and whole-home audio—reference-level performance, properly installed.
KEF adds two new colors to its LSX II wireless speakers, refreshing the compact hi-fi lineup — but in a price-sensitive market, is a...
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
KEF refreshes its flagship Blade Meta speakers for 2025 with three new color options—Grigio, Garnet, and Sapphire—while retiring older finishes. Same legendary sound, bold...
