iFi GO Pod Air: Lighter, Smarter, and Ready for Wireless Hi-Res Audio With Your IEMs
At $249, the iFi GO Pod Air brings wireless hi-res audio to your IEMs without the weight of its predecessor. Same hi-res magic, now pocket-friendly—because not everyone wants to stream FLAC with a brick strapped to their ears.
iFi Go Pod Air Wireless IEM Adapter Collage
If Blackadder ever ditched his codpiece for a pair of IEMs, the iFi GO Pod Air would be his weapon of choice—lighter than a Tudor tax bill and infinitely more refined. Debuting at High End Munich 2025, iFi Audio’s latest gadget is here to rescue your beloved wired IEMs from Bluetooth mediocrity. While the masses are content streaming compressed noise through plastic earbuds that sound like a kazoo in a tin can, the iFi GO Pod Air brings hi-res wireless streaming, proper amplification, and British-engineered snark to your portable rig.
No more overpaying for “true wireless” fashion accessories with the audio fidelity of a plague cart. The iFi GO Pod Air shrinks the original GO Pod’s tech into a leaner, more affordable package—because good sound shouldn’t weigh more than a roast boar at a Tudor banquet.
Same Magic. Now Lighter.
ifi-go-pod-air-case-in-hand
Bluetooth audio has long meant trading sound quality for convenience. The iFi GO Pod Air changes that, delivering the same high-performance wireless architecture as the original GO Pod in a more compact, travel-friendly form.
Unlike typical true wireless earphones that rely on a single chip for everything, the GO Pod Air uses a more advanced design. A Qualcomm QCC514x handles Bluetooth reception, passing the signal to a dedicated Cirrus Logic MasterHIFI DAC for efficient conversion. From there, a balanced amplifier stage—complete with a dedicated clock—drives your IEMs with precision and clarity.
Weighing just 10 grams per pod, and with a case that’s over 40% lighter and 20% smaller than the original, the GO Pod Air keeps all the performance—and leaves the bulk behind — making it less attractive to thieves at the airport or in the break room at work — we’ve all been there.
How does the iFi GO Pod Air work?
Using a pair of iFi GO Pod Air is straightforward—no need for boring YouTube videos to figure all of this out. Start by detaching the cable from your favorite IEMs and connecting the left and right earpieces to their respective pods. Pair them with your source device—your phone’s probably the easiest—and then slip the ergonomically designed ear loops behind your ears for a secure fit. What you get is a true wireless stereo experience that’ll leave most standard earbuds in the dust–or in your sock drawer where they belong.
Switch, Sync, and Stop Suffering
ifi-connectors
Matching wireless gear with your favorite IEMs shouldn’t feel like assembling medieval siege equipment. The iFi GO Pod Air makes it easy, with thoughtful features designed for flexibility and sanity.
Right out of the box, it supports 2-pin and MMCX IEMs—because those cover most of the audiophile universe. But iFi doesn’t stop there. Optional T2A2DC, and Pentaconn ear loops are also available, so even your most obscure boutique IEMs don’t get left behind.
Swap. Sync. Listen. No adapters, no soldering, no angry posts or kvetching on Head-Fi about how these f@#*^#$ things don’t work — unless they don’t and you have our permission to unleash some wildfire.
Smart Match, No Guesswork
low-high-impedance
Getting the best sound shouldn’t involve spreadsheets and soldering irons. The GO Pod Air takes the guesswork out of pairing with your IEMs thanks to intelligent impedance matching—because yes, impedance still matters, even in 2025.
It automatically adjusts to 16, 32, or 64 ohms, ensuring your IEMs get the power they need without you lifting a finger. Just connect your IEMs, pop the pods into the case for a second, and let the system handle the rest. No menus, no switches, and no spec sheet hieroglyphics requiring the Hubble just to read.
Codecs Without Compromise (or Call Treachery)
In the chaotic battlefield of Bluetooth audio, most earbuds are forced to pick a side—usually whichever codec their marketing team thinks sounds the fanciest. The result? You’re stuck with half-baked compatibility and streaming quality that would make even Blackadder’s minstrel weep.
Not so with the iFi GO Pod Air. True to form, iFi refuses to play favorites. Instead, it loads the deck with a full arsenal of codecsSBC, AAC, aptX (Classic, HD, Adaptive), LDAC, and LHDC/HWA. Whether you’re rocking an iPhone, Android, DAP, or something cooked up in a basement lab, the GO Pod Air is ready to talk your codec’s language. And so is the FBI if the later is your way of communicating.
ldac-sbc-aac
Whether you’re dodging deadlines or stuck in back-to-back video calls, the iFi GO Pod Air steps up as your all-day audio sidekick. It’s built for more than just audiophile indulgence—this one earns its keep.
Each pod features responsive touch controls that let you manage calls, music, volume, and summon voice assistants like Siri or Google Assistant—no need to fumble for your phone mid-meeting.
Calls stay clear thanks to dual mics and Qualcomm’s cVc noise suppression, so even if you’re wedged into a subway car dodging fare jumpers and getting sermonized by someone waving a “Free Gaza/Free Grindr” sign, folks on the other end will still hear you like you’re calling from a corner office.
ifi-go-pod-air-case-closed
Go Adventuring (Without Waiting for Air Traffic Control at Newark Airport)
The iFi GO Pod Air isn’t just your desk companion—it’s built to go wherever life takes you, from your morning commute to enduring the kind of air traffic delays only Newark Airport can provide.
With an IPX5 rating, the GO Pod Air is ready for anything—rain, sweat, or that jog you’ll definitely start during a downpour. Whether you’re powering through a workout or simply dodging puddles, these pods won’t let you down.
And because iFi knows you don’t need extra frustration while running, they’ve added the ability to disable touch controls—so no more accidental track skips while you’re trying to figure out how you’ve been stuck on the tarmac for 45 minutes.
With 7 hours of playback on a single charge, and a travel case giving you 15 hours, the GO Pod Air has you covered for everything—from your daily grind to an inevitable delay at Newark. Just grab the case and get going—no chargers, no drama, just music (and maybe some patience for that flight).
ifi-go-pod-air-front
The Bottom Line
The iFi GO Pod Air is a game-changer for audiophiles—transforming your IEMs into a high-res Bluetooth system that sounds better than any typical wireless earbuds. With 24/96kHz audio, balanced amplification, and automatic impedance matching, you’ll get premium sound without the usual compromises. Say goodbye to the need for multiple wireless earbuds; with this, you could build an entire stable of IEMs for every occasion—without sacrificing audio quality or dealing with the plastic nonsense. It’s like having your own personal audio harem… but, you know, with a lot less drama and far better sound.
Where to buy: $249 (coming soon)
2026 Samsung The Frame Pro vs. The Frame 4K Art TVs
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Does the Meze Astru’s titanium driver tuning, sub bass extension, and controlled treble justify $899 against top IEM rivals?
ACTIVO Scoop feature a single 8mm dynamic driver, dual 6mm dynamic drivers, and dual balanced armatures, bringing Astell&Kern tech to an accessible price.
Can one driver beat complex hybrids? Meze Audio unveils the $899 ASTRU flagship IEM at CanJam NYC 2026 with a single dynamic driver design.
Are wired IEMs making a comeback? CanJam NYC 2026 suggests growing demand as audiophiles chase better sound beyond wireless earbuds.
Can the Campfire Audio Andromeda 10 justify its $1,799 price in today’s crowded flagship IEM market, and does it truly improve on the legendary...
Dongle DACs
Power, neutrality, and a very affordable price. The iFi Audio GO Link gets a second listen and we think it's even better than we...
Dongle DACs
iFi Audio's latest budget dongle DAC boasts impressive specs and looks the part, but how does it sound?
