Devialet Tunes Hisense HT SATURN: Say Au Revoir to Crappy TV Sound
Hisense gets serious about spatial audio with HT SATURN home theater speaker system tuned by Devialet for only $1,299.
Hisense HT SATURN Promo Image
Hisense has been climbing the ladder fast when it comes to TVs and Laser TVs (UST projectors), carving out a serious piece of the market with aggressive pricing and surprisingly solid performance. But when it comes to soundbars? Let’s just say the audio side of the house hasn’t exactly kept pace—more filler than thriller, and definitely nothing to rattle the cages of Sonos, Samsung, or the audiophile crowd.
Enter the HT SATURN. This time, Hisense decided to take a different route—by calling in the French. Devialet, to be precise. Now, Devialet isn’t a name your average Costco shopper will recognize, but anyone who’s ever dropped $3K on a wireless speaker or had their ribcage rearranged by a Phantom knows the brand. Hisense teaming up with Devialet is like inviting a Michelin chef to work the deep fryer: it raises eyebrows, and maybe—just maybe—the game.
HT SATURN: A Wireless Audio Ecosystem, Not Just Another Soundbar
The HT SATURN, Tuned by Devialet, breaks away from the usual “long black bar under your TV” mold. Instead, Hisense has gone modular—this is a full 4.1.2-channel wireless system built around a compact central hub. That hub acts as the command center: handling HDMI and digital inputs, decoding audio formats, managing source switching, and wirelessly distributing signal to the four satellite speakers and subwoofer.
hisense-ht-saturn-system-front
It’s not just about ditching cables. The system architecture gives each speaker more room to breathe—literally and acoustically—allowing for better placement, separation, and room-filling immersion. The wireless protocol is low-latency and high-bandwidth, so you get synchronized, high-fidelity audio without the spaghetti mess of wires or the latency problems that plague most “wireless” setups.
Tuned by Devialet: Oui, It’s Actually Fancy
Hisense didn’t just slap a logo on this thing—they brought in the sonic surgeons from Paris. Devialet, the French high-end audio brand known for their obsessive R&D into exotic drivers and ultra-low distortion amplification, tuned the HT SATURN to do more than just sound loud. Their fingerprints are all over the system’s digital signal processing, driver voicing, and wireless playback performance.
This is not some watered-down “tuned by” sticker. Devialet’s expertise in hi-res wireless transmission and proprietary audio tech—usually reserved for speakers that cost more than your TV—helps the HT SATURN achieve clarity, scale, and finesse that would surprise anyone expecting typical soundbar-in-a-box fare.
hi-concerto
Hi-Concerto
In addition to Devialet’s tuning, the HT SATURN system includes Hisense’s Hi-Concerto technology. This allows it to work in tandem with the built-in speakers on select Hisense TVs, enabling all the speakers to operate together for a more cohesive and immersive sound experience. It’s a concept similar to Samsung’s Q-Symphony, offering users a more integrated audio setup without needing to disable their TV’s own speakers.
Room Fit
For installation and setup, the HT SATURN includes Hisense Room Fit, a basic room correction feature. It analyzes the room’s size and acoustics, then applies adjustments to reduce common issues like echoes and reflections. While not as advanced as some premium systems, it helps deliver cleaner and more balanced sound in most environments.
ht-saturn-surround-sound
Advanced 3-Way Speaker Array for Dolby Atmos and DTS:X Immersion
The HT SATURN features a 13-speaker setup arranged in a 4.1.2 channel layout to support Dolby Atmos and DTS:X formats. Each satellite speaker uses a 3-way design with a front-firing woofer, a midrange driver angled slightly upward, and a tweeter angled even more upward. This arrangement helps direct sound both forward and upward, enabling more precise spatial effects and a more immersive audio environment.
Wireless Audio Transmission with Multi-Band Wi-Fi Stability
The HT SATURN transmits audio wirelessly from the central unit to the satellite speakers and subwoofer using Wi-Fi. To maintain a stable connection, it operates across three frequency bands: 2.4, 5.2, and 5.8 GHz.
ht-saturn-wireless
Tip: While the audio signal is wireless, each speaker and subwoofer still requires connection to an AC power outlet to run their built-in amplifiers.
Specifications
HT SATURN
Product TypeHome Theater Sound System
Price:$1,299.99
Number of Channels4.1.2
Speakers8 x Full Range,
4 x Tweeter,
1 x 6.5-inch Subwoofer
Max Output Power (System Total)500W
Frequency Response40Hz – 20KHz
Surround Sound Format SupportDolby Atmos, Dolby TrueHD, Dolby Digital, Dolby Digital Plus
DTS:X, DTS-HD Master Audio, DTS Digital Surround
Sound ModeStandard/Movie/Music/Sport/Game
Sound EffectNight/Surround/Voice/AI/DTS Virtual:X
Virtual SurroundYes
Devialet TunedYes
Hi-ConcertoYes
EzPlayYes
Room Fitting Tuning (via Select Hisense TVs)Yes
Digital Audio Format SupportWAV, WMA, MP3
PCMPCM, Multi ch PCM
Wi-FiNo
BluetoothVer 5.3
Physical Connections1 x HDMI in
1 x HDMI (eARC/ARC, CEC)
1 x Digital Optical Audio Input:
1 x USB (Service support/update only, NO music playback)
HDMI Pass-ThroughUp to 4k 60Hz
Auto Power On with Signal DetectedAUX, eARC, HDMI, Optical
Auto Power Off without SignalAll sources
Power Consumption120W (including Satellite Speaker: 20W*4, Subwoofer: 40W)
Standby Consumption<0.5W
Power SupplyAC 100~240V, 50/60Hz
DimensionsControl Box: 4.6″ x 1.1″ x 4.6″
Subwoofer: 9.5″ x 15.4″ x 9.5″
Satellite Speaker: 4.8″ x 7.8″ x 4.8″
Weight Control Box: 0.8 lbs
Subwoofer: 11.2 lbs
Satellite Speaker: 3.4 lbs
Included AccessoriesRemote with 2 AAA Batteries
Quick Start Guide and/or User Manual
5 x Power Cable including 1 adapter)
1 x HDMI CableWall Mount Kit and Guide
ht-saturn-speakers
The Bottom Line
Hisense’s collaboration with Devialet signals a clear ambition to raise their audio profile and compete seriously in the higher-end sound system arena. While Hisense’s previous soundbar efforts mostly flew under the radar, the HT SATURN is a different animal—eschewing the traditional soundbar design for a more versatile setup with four wireless speakers and a central control unit. This approach clearly takes a page from Sony’s Bravia Theater QUAD system, but at nearly half the price. Although not as elegant as Sony, the price gap alone makes Hisense’s new offering impossible to ignore. If you’re in the market for better TV sound and a wireless multi-speaker setup, auditioning the HT SATURN would seem a smart move. Thanks to Devialet’s tuning and cutting-edge tech, Hisense might just carve out a spot on your shortlist.
Availability and Pricing
The Hisense HT SATURN 4.1.2-channel Home Theatre Sound System is available now for $1,299.99 or less from Hisense, Amazon, or Best Buy.
2026 LG W6 Wallpaper TV Lifestyle Angle
LG’s 2026 OLED evo W6 Wallpaper TVs bring ultra thin design, Zero Connect, and 165Hz support in either 77-inch or 83-inch screen sizes.
Sennheiser HD 480 Pro Headphones in the Studio Sennheiser HD 480 Pro Headphones in the Studio
Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle Klipsch OJAS kO-R2 Limited Edition 2-Way Speaker Silver Lifestyle
Klipsch and OJAS debut the kO-R2 at Milan Design Week 2026. Limited to 600 pairs total, with global availability expected in June.
Head(amame) Pro Headphones Head(amame) Pro Headphones
Head(amame) Pro debuts at AXPONA 2026 with 40mm glass diaphragm drivers, 3D printed modular design, 280g weight, and user-tunable acoustics.
Victrola and Third Man Records Limited Edition Turntable and Speakers Victrola and Third Man Records Limited Edition Turntable and Speakers
Victrola and Third Man Records debut a limited edition turntable and speaker system for Record Store Day 2026, combining vinyl playback with Bluetooth and...
2026 TCL QM8L 4K TV Lifestyle 2026 TCL QM8L 4K TV Lifestyle
TCL QM8L and QM7L TVs bring SQD Mini-LED tech from the X11L to lower prices, alongside the new RM9L RGB Mini-LED and an expanded...
Focal Mu-so Hekla at AXPONA 2026 delivers real Dolby Atmos from one box. Not a soundbar. Not cheap either. But it works.
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Sony just launched two new soundbars, new rear speakers and three new subwoofers plus the ability to add a second powered sub to their...
What makes Lyngdorf's $5000 SB-75 different? A passive soundbar with six drivers designed for external amplification and serious home theater systems.
Klipsch’s mid-range Dolby Atmos soundbar system delivers impressive performance at an affordable price
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
Head Units
Pioneer brings Dolby Atmos to Apple CarPlay with its SPHERA in-dash receiver, opening immersive in-car audio to existing vehicles without factory systems.
TCL’s A65K Design Series soundbar features 3.1.2 channels, 460-watts of power and Bang & Olufsen tuning, but pricing and final specs won’t arrive until...
