Dongle DACs
FiiO Launches Two TINY Dongle DACs For Only $21.99 Each
FiiO Snowsky TINY Dongle DACs arrive in two variations to unlock big sound from lossless and hi-res audio on your smartphone.
FiiO Tiny Dongle DACs
Oy, that’s one TINY dongle DAC. FiiO just dropped the SNOWSKY “TINY,” a $21.99 USB-C DAC and headphone amp that might be the most affordable way to unlock real hi-res audio in 2025. Don’t let the size fool you — this pocket-sized metal brick packs a DSP engine, 10-band parametric EQ via the FiiO Control app, and support for Spotify Lossless, Qobuz, Apple Music, TIDAL, and Amazon Music. Audiophiles, gamers, and anyone still clinging to wired headphones finally get a proper hi-res upgrade without shelling out a month’s rent.
FiiO TINY DAC Launches in Two Editions
FiiO wasn’t kidding when they called this thing “TINY,” but don’t let the size fool you — it’s got more brains than half the overpriced dongles cluttering up the market. At its core is an audiophile-grade DSP chip that unlocks a full 10-band parametric EQ, all adjustable through the FiiO Control app or even a web interface if you’re tethered to a laptop. You can fine-tune frequency and gain, save custom profiles to the cloud, and even share them with fellow EQ obsessives who think they’ve cracked the code to perfect sound.
fiio-tiny-dac-usb-c
There are actually two flavors of TINY, because why stop at one? TINY A comes with a 3.5 mm jack and USB-C passthrough that supports up to 2A/20V fast charging — meaning you can juice your phone while still blasting music. TINY B, on the other hand, ditches charging in favor of dual headphone outputs: 3.5 mm and 4.4 mm, both single-ended, both able to run simultaneously. Translation: you can actually share your music with a friend — assuming you have one who still uses wired cans.
On the spec sheet, TINY keeps up with the big boys: PCM up to 384 kHz/32-bit and DSD256 decoding, so whether you’re streaming Spotify Lossless, flipping through Apple Music or TIDAL, or diving into that dusty NAS, you’re covered. It also plays nice with your headphones’ inline remote and mic, which makes it just as handy for calls and game chat as it is for Mahler or Metallica.
Build quality is typical FiiO — a CNC-milled, all-metal chassis with a T-shaped side output that keeps cable stress to a minimum. It’s plug-and-play, pocketable, and doesn’t look like a cheap plastic keychain. Add in wide platform support (Android, iOS, Windows, macOS, Linux, plus UAC 1.0 mode for the Switch and PS5), a flashy little RGB sampling rate indicator, and Hi-Res Audio certification, and you’ve got a dongle DAC that actually earns its badge. For only $21.99 USD.
fiio-tiny-a-vs-b-specs
fiio-tiny-a-vs-b-dongle-dac
The Bottom Line
FiiO’s TINY DAC punches way above its pocket-sized weight. With full 10-band parametric EQ, DSP control, Hi-Res PCM and DSD support, and compatibility across smartphones, laptops, and even consoles, it delivers serious audiophile-grade sound for just $21.99. The two editions — TINY A for charging while listening, TINY B for dual headphone output — add a surprising amount of versatility.
Inline controls, mic support, and a rugged metal body only sweeten the deal. That said, it’s USB-C only, so older iPhone users will need a separate adapter, and there’s no Lightning or standard USB option. Still, for wired headphone fans looking for an affordable, high-res upgrade, TINY is a tiny marvel that proves you don’t need a $1,000 dongle to hear the difference.
Where to buy: $21.99 at Amazon
3 Comments
3 Comments
  1. Asa
    September 30, 2025 at 10:57 pm
    Vive le Fil !
    Next up, Quark-sized DAC. Lol.
    • Ian White
      September 30, 2025 at 11:36 pm
      Asa,
      Wait till you see all of the Bluetooth adapters Will is currently reviewing. Tiny.
      IW
      • Asa
        October 1, 2025 at 5:02 pm
        Can’t wait…have one that I use for a device where the adapter connection is larger than the BT electronics attached to it.
        If you want to see tiny, but still robust, look up JerryRigEverything on Yt where he disects the latest iPhone air. Amazing what can be produced at small sizes and still be robust.
JLab Blue XL Wireless Headphones and Speakers
Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
2026 ARCAM Radia AVA 2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026 Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
JBL Synthesis SCL In-room Loudspeakers 2026 JBL Synthesis SCL In-room Loudspeakers 2026
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Dongle DACs
Fosi Audio debuts the MD3 Magnetic and DS3 portable DAC/headphone amplifiers at CanJam Dubai 2026, focusing on compact design, XMOS processing, and IEM-friendly performance—not...
Dongle DACs
Can a $349 dongle DAC really deliver true tube sound and serious power? The ONIX Beta Xi2 aims to prove portable tubes aren’t a...
FiiO’s EH11 headphones and updated JM21 music player target commuters and travelers with retro design, hi-res Bluetooth, solid performance, and an affordable $240 combo.
Over-Ear Headphones
Can FiiO’s $699 FT7 open-back planar headphones deliver true high-end sound, or do build issues hold them back?
Is the FiiO K11 R2R the most musically engaging DAC/headphone amp under $200, blending R2R texture with real-world balance at $175?
Spotify is raising prices across Premium plans, now ranging from $6.99 to $21.99. Is the added cost justified, and who really benefits?
DAPs
FiiO’s M33 R2R enters the ~$600 DAP segment with a discrete ladder DAC and high expectations—but key specs and Bluetooth support remain unanswered.
Written from my hospital bed, our final 2025 Editor’s Round-Up covers hi-res Bluetooth, loss, and why performance and value still define great hi-fi.
