DAPs
FiiO M27 Flagship DAP: 5W Balanced Amp, aptX Lossless, and Dragonwing AI—Pocket Power That Could Actually Scare iBasso and Astell&Kern
FiiO M27 DAP combines flagship DACs, FPGA architecture, 5W balanced output, and hi-res audio. Full specs and pricing set for September.
FiiO M27 DAP
FiiO has launched the M27, a reference-class digital audio player stepping into the surprisingly competitive high-end DAP market. Building on the JM21, M21, and M23, it delivers precise engineering, hi-res streaming, and 5W balanced output. With no price announced yet, it could easily join the ranks of the priciest offerings from iBasso, Shanling, Cayin, and Astell&Kern—proof that serious audiophile credentials often come with a serious tag.
High-end DAPs are flirting with $4,000 territory now—good luck convincing anyone to drop that kind of cash while trade wars play pocket roulette—CanJam SoCal 2025 is just around the corner and it will be interesting to see how the Head-Fi community responds.
The M27 starts with a chassis built from titanium alloy—the first time FiiO has used the same material that shields flagship smartphones—paired with a glass fiber rear panel. Rugged, lightweight, and precise, it sets the tone for a player that’s as tough as it is refined.
FiiO’s Desktop Mode also manages power efficiently when docked, while the 9,200mAh battery provides extended playback for long listening sessions.
Cutting-Edge Tech: Qualcomm Dragonwing AI, Hi-Res Streaming & 5W Balanced Amp in the FiiO M27
fiio-m27-dap-front-back
FiiO M27 DAP
Elite Performance
At the core of the M27 sits Qualcomm’s QCS6490, built on Snapdragon 770G architecture. Eight Kryo 670 CPU cores, an Adreno 642L GPU, LPDDR5 RAM, and UFS 3.1 storage combine to keep this player running smooth and fast. Android 13 handles the interface with 8GB of RAM, putting it in line with the kind of responsiveness you’d expect from high-end smartphones—not bad for a pocketable DAP—that will likely cost more than a new iPhone 17 and MacBook Air combined.
Wireless Freedom
The M27 also packs the Qualcomm QCC5181, bringing aptX lossless support along with LE Audio and Auracast. Finally, Bluetooth playback can actually sound good. Audiophiles can now get reference-grade wireless audio that can be transmitted to headphones and wireless speakers that support hi-res formats—which makes the M27 a rather formidable network player for those who may want something that they can take with them on the road as well.
fiio-m27-dap-top-bottom
Flagship-Grade DACs
Dual ESS ES9039SPRO DACs handle the heavy lifting, giving wide dynamic range, low distortion, and precise detail. From a whispering jazz vocal to the full-on drama of classical crescendos, the M27 keeps it clean, detailed, and alive—exactly what you expect from a flagship DAC setup.
Monumental Power
With 5 watts per channel in Ultra gain mode, this little guy competes with some full-size desktop amps. Headphones that usually get an attitude problem at high volumes? The M27 tames them, delivering power without sacrificing balance, warmth, or clarity.
Versatile I/O
You get 3.5mm, 4.4mm, and 6.35mm headphone outputs, plus line-level and digital connections. Whether it’s a compact bedside rig or a full-blown multi-component setup, the M27 slots in without drama. FiiO also launched the closed-back FT13 headphones alongside the M27, rounding out their new portable ecosystem—the new headphones will make their debut at CanJam SoCal and be priced around $300 USD.
fiio-ft13-headphones
FiiO FT13 closed-back headphones
Huge Storage
For those lugging around massive libraries, the M27 handles it with dual microSD slots, each supporting up to 2TB. That’s enough for studio masters, DSD files, or every guilty-pleasure track you’ve hoarded. Add 256GB of onboard storage and you can leave the cloud behind.
Enhanced Audio Architecture
The M27’s architecture is engineered for uncompromising audio. At its core, a high-capacity FPGA drives fully balanced output stages, while dual RIVER femtosecond crystal oscillators and independent power supplies ensure jitter is minimized, timing is precise, and the signal path remains pure. The result is a “spacious, detailed soundstage” that rivals many dedicated desktop rigs. Add the FiiO Control app for PEQ adjustments, and the M27 becomes a studio-worthy reference player. Pair it with the SP5 studio speakers, and you have a full, high-fidelity system that’s as capable at home as it is in the control room.
fiio-sp5-speaker
FiiO SP5 Desktop Speakers
The Bottom Line
The FiiO M27 stands out with its combination of high-end DACs, advanced FPGA-based architecture, fully balanced output stages, and next-generation jitter reduction, making it one of the most technically ambitious portable players FiiO has produced.
That said, we’ll have to wait until September for pricing and key specs—size, weight, and single-ended output power at various impedances—before we can judge how it will handle demanding headphones (looking at you, Beyerdynamic, HiFiMAN, Audeze).
It’s also not built for electrostatic headphones, which still need their own energizer, though the M27 could serve as an excellent digital source in such a setup. Competition is stiff in this category, with the Shanling M3 Plus, iBasso DX340, and Astell&Kern A&Ultima SP4000 all vying for audiophile attention.
MSRP: TBD (availability expected Fall 2025)
Samsung M80H and M70H Mini-LED 4K TVs Angle
Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s. Bravia 3, II TV with BRAVIA Home Theater Bar 9 and 2 BRAVIA Theater Sub 9s.
Sony just launched two new soundbars, new rear speakers and three new subwoofers plus the ability to add a second powered sub to their...
Sony BRAVIA 3, Mark II Sony BRAVIA 3, Mark II
Sony is bringing its renowned XR video processor for TVs to a much more affordable price point.
2026 Grado Classic Headphones 2026 Grado Classic Headphones
Grado Classic Series launches with 7 updated headphones from $125. What’s new, what’s not, and who these are really for.
2026 Cambridge Audio CXN100 SE Music Streamer Black 2026 Cambridge Audio CXN100 SE Music Streamer Black
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
Cambridge Audio CX Series Hi-Fi Components in Black Stacked Cambridge Audio CX Series Hi-Fi Components in Black Stacked
Hi-Fi Components
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Can a $159 linear power supply fix weak wall adapters and unlock better sound from your DAC or amp? FiiO thinks the DARKSIDE PRO...
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Dongle DACs
Can the $199 FiiO BTR17 still compete in 2026? With dual ESS DACs, THX power, and LDAC support, this pocket DAC/amp aims close to...
DAPs
The FiiO JM21 portable DAP offers big power, Android 13, and wide flexibility, but does its neutral sound do enough to stand out?
DAPs
At $2,749, can the Astell&Kern PD10 actually replace your DAP and your streamer—or is it solving a problem you don’t have?
FiiO’s EH11 headphones and updated JM21 music player target commuters and travelers with retro design, hi-res Bluetooth, solid performance, and an affordable $240 combo.
Over-Ear Headphones
Can FiiO’s $699 FT7 open-back planar headphones deliver true high-end sound, or do build issues hold them back?
Is the FiiO K11 R2R the most musically engaging DAC/headphone amp under $200, blending R2R texture with real-world balance at $175?
