Estelon Expands A-Series Speakers for Home Theater: HIGH END Munich 2025
Estelon unveils the AURELLE stand-mount and Centre speaker, and AURUS subwoofer at High End Munich 2025, celebrating its 15th anniversary. Prices start at €7,500 each.
Estelon A-Series - AURELIA, AURELIA Centre, and AURUS Sub Lifestyle
Update: On July 23, 2025, Estelon announced a name change of its AURELIA loudspeakers to AURELLE, due to a naming similarity with another product in the audio industry. Our story has been updated to reflect the new name.
Based out of Estonia, Estelon is expanding their entry-level A-Series loudspeaker lineup with their smallest and least expensive models yet. They join the AURA floorstanding speakers (released in 2023 for €19,990), and include the AURELLE, AURELLE Centre, and AURUS Subwoofer, which can be used together in a high-end audio or home theater setup.
From Estelon: “The AURA is part of the A-Series. We launched this model a couple of years ago, and so due to its success, we expanded the line.”
The new A-Series speaker additions will be officially introduced at the High End Munich 2025, marking a significant moment for the brand. This event, which coincides with Estelon’s 15th anniversary, promises to be a landmark occasion, spotlighting these groundbreaking speakers to the global audio community.
AURELLE
estelon-aurelia
The AURELLE is a 2-way passive bookshelf/stand-mount speaker with a sealed box design, aimed at delivering controlled bass and a balanced soundstage. It uses two 132 mm (5”) Egyptian Papyrus fibre-filled paper cone mid-range drivers from SB Acoustics and a 25 mm (1”) textile dome tweeter from Scan-Speak. The combination is designed to offer clear, detailed sound suitable for a range of listening environments.
The AURELLE’s cabinet is made from a thermoformed mineral-filled composite, chosen to reduce resonance and standing waves. It’s intended for small to medium-sized rooms, home offices, and TV setups, with a form factor that fits into a variety of living spaces.
AURELLE Centre
estelon-aurelia
Built with the same design principles as the AURELLE, the AURELLE Centre is designed for home theatre use. It aims to deliver consistent tonal balance and clear imaging for center channel content, including dialogue and front-stage sound effects.
estelon-a-series
Comparison
AURELLE (2025)AURELLE Centre (2025)AURA (2023)
MSRP€14,900/pair€7,500/each€19,900/pair
Speaker Type2-way passive speaker, sealed box2-way passive speaker, sealed box3-way passive speaker, sealed box
SizeBookshelfBookshelfFloorstanding
Tweeter1 x 25 mm (1”) textile dome tweeter from Scan-Speak1 x 25 mm (1”) textile dome tweeter from Scan-Speak1 x 26mm (1-inch) Scan-Speak “Illuminator” Textile Dome tweeter
Midrange2 x 132 mm (5”) mid-range drivers from SB Acoustics2 x 132 mm (5”) mid-range drivers from SB Acoustics2 x 130mm (5-inch) mid-woofer made by Satori
Woofer1 x (250mm) 10-inch down-firing woofer
Frequency Response70 – 30,000 Hz70 – 30,000 Hz35 – 25,000 Hz
Power Rating80 Watts80 Watts200 Watts
Nominal Impedance4 Ω (min 3.7 Ω at 170 Hz)4 Ω (min 3.7 Ω at 170 Hz)4 Ω (min 2 Ω at 58 Hz)
Sensitivity87 dB/2.83 V87 dB/2.83 V90 dB/2.83 V
Min Amplifier Power30 Watts30 Watts30 Watts
Internal CablingKubala-SosnaKubala-SosnaKubala-Sosna
Cabinet MaterialThermoformed mineral-filled composite Thermoformed mineral-filled composite Marble-based composite
Finish OptionsWhite
Black Gloss
Horizon Blue
Starlight
Amber Elegance
Iron Grey
White
Black Gloss
Horizon Blue
Starlight
Amber Elegance
Iron Grey
White
Black Gloss
Horizon Blue
Starlight
Amber Elegance
Iron Grey
Dimensions (HWD) – Without Stand550 x 290 x 210 mm
21.6 x 11.4 x 8.3 inches
237 x 520 x 195 mm
9.3 x 20.4 x 7.6 inches
1366 x 384 x 367 mm
53.7 x 15.1 x 14.4 inches
Dimensions (HWD) – With Stand1155 x 305 x 295 mm
45.4 x 12 x 22.6 inches
Weight (per speaker)9.5 kg (20.9 lbs)10 kg (22 lbs)34 kg (75 lbs.)
Weight (per speaker with stand)14 kg (30.8 lbs)
AURUS
estelon-aurus-subwoofer
The AURUS subwoofer is designed to integrate with the AURA and AURELLE speakers. It features a 12-inch long-excursion driver with a 3-inch voice coil and is rated for 300W of continuous power. A custom passive radiator is included to support low-frequency extension.
The 12-inch driver is supported by a 1200W bridged Class-D amplifier and dual input filter systems. This configuration is designed to support precise integration and phase coherence, making the AURUS a natural extension of the main speakers.
The AURUS subwoofer includes line-level (XLR) and high-level (banana plug) input options. It features an active analog line-level filter and a passive high-level filter, with preset profiles matched to the AURA and AURELLE speakers. A level control allows adjustment of output to align with the main speaker system. The compact enclosure supports a range of placement options in different room setups.
Specifications
AURUS Subwoofer
Speaker TypePowered Subwoofer – Sealed
Price€13,500 Each
Driver12-inch driver with a 3-inch voice coil
Passive RadiatorYes
Frequency Response18 – 45 Hz for AURA
18 – 75 Hz for AURELLE
Inputs1 set Line-level (XLR)
1 set High-level (Banana Plugs)
Input impedance for active filter connection10k Ω
Input impedance for passive high-level filter connection> 470 Ω
Output Level Adjustment+/- 6 dB active input (0 or +3 dB passive input)
Amplifier TypeClass D
Internal Amplifier Power1200 Watts short-term RMS
Finish OptionsWhiteBlack, GlossHorizon, BlueStarlight, Amber Elegance, Iron Grey
Dimensions (HWD)490 x 330 x 450 mm
(9.2 x 12.9 x 17.7 inches)
Weight45 kg (99 lbs)
estelon-logo
The Bottom Line
Estelon, with 15 years of experience, has established itself as one of the leading luxury loudspeaker manufacturers in Europe. While still a relatively young company, it has steadily gained recognition among audiophiles for its distinctive design approach and engineering.
Building on the reception of the AURA loudspeaker, Estelon is expanding its offerings through the new “A Series,” designed for both music listening and home theater use.
For attendees of High-End Munich 2025 (May 15–18), Estelon’s exhibit will offer a look at the latest developments in its product lineup.
Pricing & Availability
Check the availability of the full A-Series product range – AURELLE, AURELLE Centre, AURUS, and AURA – with authorized dealers, including US and Canadian dealers. Prices listed below are MSRP. Canadian and US prices forthcoming.
  • AURELLE Bookshelf/Standmount Speakers: €14,900 (Pair)
  • AURELLE with stand: €17,900 (Pair)
  • AURELLE Centre Speaker: €7,500 (Each)
  • AURUS Subwoofer: €13,500 (Each)
  • AURA Floorstanding Speakers: €19,900 (Pair)
Lexus RZ Ad featuring VPI Titan Direct turntable
Lexus is pushing its first full-electric SUV with Miles Davis on classic vinyl and a gorgeous turntable from VPI, and we're fully on board.
ecoute TH2 Wireless Headphones ecoute TH2 Wireless Headphones
Second generation écoute vacuum tube wireless noise cancelling headphones improve comfort and sound in a slightly modified design.
JLab Blue XL Wireless Headphones and Speakers JLab Blue XL Wireless Headphones and Speakers
Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
2026 ARCAM Radia AVA 2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
ARCAM debuts the Radia Series loudspeakers at ISE 2026, returning to speakers with a premium-priced lineup for music and home cinema.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
KLH Audio President David Kelley joins the podcast to discuss the company's history, loudspeaker design, today's product line and more.
LG came on strong at CES 2026 with a new suite of OLED TVs featuring stunning design and impressive video performance.
Daily Deals
Didn't get that A/V receiver you wanted for Christmas? No worries. Onkyo's 9.2-channel TX-RZ30 just dropped to the lowest price we've seen.
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
