BenQ Debuts TK705 Series 4K Lifestyle Projectors for Big-Screen Streaming and Gaming
For under $2,000 BenQ’s TK705i and TK705STi 4K projectors deliver up to 150-inches of bright, low-lag home entertainment. But what’s different?
BenQ TK705i and TK705sti 4K UHD Entertainment Projectors
Following the launch of its premium W4100i home theater projector, BenQ is doubling down on the booming lifestyle projector market with the new TK705i and TK705STi. Designed for real-world living rooms rather than light-controlled theaters, these 4K models bring high brightness, accurate color, and smarter setup to the growing number of consumers who want big-screen entertainment without the hassle.
As demand for flexible, high-performance projectors continues to rise, BenQ’s TK705 Series aims to hit the sweet spot between performance, convenience, and affordability. Building on the success of the TK710 series, BenQ’s new TK705i and TK705STi projectors are built for everything from movie nights and sports watch parties to casual multiplayer gaming with family and friends.
Setting up the TK705i and TK705STi for tabletop viewing is straightforward with BenQ’s optional ST30 projector stand ($99), which features a durable 5mm curved metal arm, a solid metal base, and anti-slip silicone pads for added stability. For smaller rooms or tighter setups, the TK705STi offers a short-throw configuration capable of projecting sharp, cinema-quality images from 100 to 150 inches at a distance of just 5.8 to 8.7 feet from the wall.
benq-tk705i-distance
Key Features & Specifications
4K UHD Resolution: The TK705i and TK705STi utilize a 0.47-inch 1080p DLP imaging chip (DMD – Digital Micromirror Device) from Texas Instruments with 2.1 million mirrors. Through advanced pixel-shifting technology, the projectors display the full 8.3 million pixels required for true 4K UHD resolution, delivering sharp, detailed images well beyond standard HD.
DLP 4K Pixel Shifting
4K Pixel-Shifting Technology: To achieve full 4K UHD resolution, the 1080p DLP chip shifts its pixels both vertically and horizontally at 240Hz—240 times per second. This rapid movement creates the perception of 8.3 million distinct pixels, producing an image that meets the visual standard of true 4K on-screen.
LED Light Source: While many premium projectors have transitioned to laser illumination, BenQ equips the TK705 Series with a high-performance LED light engine. Like laser systems, the LED design delivers vibrant color reproduction, long operational life, and excellent energy efficiency, making it an ideal solution for everyday home entertainment.
BenQ TK705sti 4K Projector
The BenQ TK705i and TK705STi projectors look the same.
High Brightness: The TK705 Series delivers up to 3,000 ANSI lumens of white light output, ensuring bright, vivid images even in rooms with moderate ambient lighting. While the projectors can produce images up to 300 inches, BenQ recommends a maximum optimized screen size of 150 inches for the best balance of brightness, color accuracy, and clarity.
BenQ CinematicColor and HDR-PRO: The TK705 Series delivers 98% Rec. 709 color accuracy, ensuring faithful, lifelike colors. HDR-PRO technology enhances this further by providing greater depth, sharper detail, and optimized brightness for both HDR content and varying room lighting conditions.
Plug-and-Play Setup: With 8-way Smart Image Adaptation, the TK705 Series makes big-screen setup quick and effortless. Features include Optical Motorized/Digital Zoom, Auto 2D Keystone, Auto Focus, Auto Cinema Mode, and more, allowing users to achieve perfectly aligned images in seconds.
benq-tk705i-connect
Flexible Connectivity: The TK705 Series offers both wired and wireless options, including USB-C with 30W power delivery and Bluetooth 5.2. This makes it easy to connect soundbars, smartphones, laptops, and gaming consoles without the need for extra dongles or adapters, streamlining setup for any home entertainment environment.
Low-Lag Gaming: While not targeted at hardcore gamers, the TK705 Series still delivers responsive gameplay on consoles like the PS5, Xbox, or Nintendo Switch. With HDMI 2.1, ALLM support, and ultra-low input lag of just 5 ms at 4K/60Hz, it ensures fast, fluid action for casual and family gaming sessions.
benq-tk705i-game
Control Options: The TK705 Series projectors come with a “standard” wireless remote control, but BenQ also provides access to a free control app that you can download to your smartphone. The app is available for both iOS and Android.
Smart TV Integration: Unlike the earlier TK710 Series, the TK705 projectors feature built-in Wi-Fi and Google TV OS. This enables immediate access to popular streaming services like Netflix, Prime Video, and YouTube right out of the box. Users can also connect additional sources, including Blu-ray players or gaming consoles, for a complete home entertainment experience.
Comparison
benq-tk705i-tk710
Projector ModelTK705iTK705STiTK710TK710STi
Price$1,799$1,999$1,799$1,999
Projection SystemDLPDLPDLPDLP
Imaging Chip.47″ DMD.47″ DMD.47″ DMD.47″ DMD
Light SourceLEDLEDLaserLaser
Light Source Hours20,00020,00020,00020,000
Resolution (via Pixel Shift)4K UHD (3840 x 2160)4K UHD (3840 x 2160)4K UHD (3840 x 2160)4K UHD (3840 x 2160)
Screen Size Range30″ – 300″30″ – 300″30″ – 300″30″ – 300″
Optimal Screen Size Range60″ – 150″60″ – 150″60″ – 150″60″ – 150″
Light Output (ANSI Lumens)3000300032003200
Native Aspect Ratio16:916:916:916:9
Contrast Ratio (Full On/Full Off)600,000:1 600,000:1 600,000:1 with Light Source Dimming600,000:1 with Light Source Dimming
Color Display30-bit (1.07 billion colors)30-bit (1.07 billion colors)30-bit (1.07 billion colors)30-bit (1.07 billion colors)
Throw Ratio1.0 – 1.30.81.15~1.50.69~0.83
Zoom RatioFixedFixed1.3x1.2x
Lens SpecsF/# = 1.8-1.85, f = 10.55-13.68 mmF/# = 1.8, f = 8.498 mmF / # = 2.48 ~ 2.78 , f = 16.88~21.88 mmF / # = 2.53~2.73 , f = 10.2~12.24 mm
Projection Offset (Full Height)105%102.5%105%102.5%
Keystone Correction(Auto) Vertical: ± 30 degrees (single axis)
(Auto) Horizontal: ± 20 degrees (single axis)
Vertical ± 30 degrees
Horizontal ± 30 degrees
Rotation ± 30 degrees
Horizontal ± 30 degrees;
Lens Shift+10%
Rec 709 Coverage98%98%95%95%
Picture Modes3D, Bright, Cinema, HDR10, HDR10+, HLG, Living Room, RPG, User3D, Bright, Cinema, HDR10, HDR10+, HLG, Living Room, RPG, User3D, Bright, Cinema, HDR10, HLG, Living Room, RPG, User3D, Bright, Cinema, HDR10, HLG, Living Room, RPG, User
HDR Game ModesFPS, HDR FPS, HDR RPGFPS, HDR FPS, HDR RPGFPS, HDR FPS, HDR RPGFPS, HDR FPS, HDR RPG
Input Lag5 ms: 4K/60Hz
Additional information not provided:
5 ms: 4K/60Hz
16.7 ms (1080P 60Hz)
16.7ms (2K 60Hz)*downscaling to 1080p 60Hz
16.7 ms (4K 60Hz)
4.2 ms (1080P 240Hz)
8.3 ms (1080P 120Hz)
8.3ms (2K 120Hz) *downscaling to 1080p 120Hz
16.7 ms (4K 60Hz)
HDMI Input 2 x  HDMI-1 (CEC)- HDMI-2 (CEC / Audio Return+ with multichannel audio output)2 x  HDMI-1 (CEC)- HDMI-2 (CEC / Audio Return+ with multichannel audio output)2 x Ver 2.0b/HDCP 2.22 x Ver 2.0b/HDCP 2.2
USB Type A1 x USB 2.0 (5V 1.5A): For service and power supply (up to 5V/1.5A) / USB reader / Firmware upgrade 1 x USB 2.0 (5V 1.5A): For service and power supply (up to 5V/1.5A) / USB reader / Firmware upgrade USB Type A-1 (2.0/Power Supply1.5A/Service)USB Type A-1 (2.0/Power Supply1.5A/Service)
RS232DB-9pin x1DB-9pin x1
Speaker2 x 8W2 x 8W1 x 5W1 x 5W
Android TV StreamingAndroid 11/Google TV Android 11/Google TVYes – Via Included QS02 Plug-in Dongle
Licensed NetflixYesYesYes
HDMI ARC/eARCYesYesYes, eARC, Dolby AtmosYes, eARC, Dolby Atmos
Digital Optical (S/PDIF)
Audio Out (Analog)3.5mm Mini Jack x13.5mm Mini Jack x13.5mm Mini Jack x13.5mm Mini Jack x1
Built-in Wi-FiYesYes–
Operating Temperature0~40℃0~40℃0~40℃0~40℃
Power SupplyAC 100 to 240 V, 50/60 HzAC 100 to 240 V, 50/60 HzAC 100 to 240 V, 50/60 HzAC 100 to 240 V, 50/60 Hz
Typical Power Consumption (110V)250 W (Max)250 W (Max)275 W (Max)275 W (Max)
Standby Power Consumption<0.5W<0.5W<0.5W<0.5W
Acoustic Noise Typical  28dB, ECO 24 dB Typical  28dB, ECO 24 dB Typical 31dB, ECO 28 dB Typical 31dB, ECO 28 dB
Dimension (WDH – mm)229.2 x 249.7 x 168.2 229.2 x 249.7 x 168.2304.2 x 232.5 x 112.4304.2 x 232.5 x 112.4
Dimension (WDH – inches)9.02 x 9.83 x 6.629.02 x 9.83 x 6.6212 x 9.2 x  4.412 x 9.2 x  4.4
Net Weight (kg)3.8 kg3.8 kg3.0 kg3.0 kg
Net Weight (lbs)8.4 lbs8.4 lbs6 lbs 10 oz6 lbs 10 oz
Included AccessoriesRemote Control w/ Battery
Power Cord (by region)
Power Adapter
Quick Start Guide
Warranty Card
Power Adapter
Quick Start Guide
Warranty Card
Remote Control w/ Battery(RCV013)
Power Cord (by region)x1 (1.8M)
Quick Start Guide
Warranty Card (by region)
Android TV dongle (QS02)
Remote Control w/ Battery(RCI074)
Quick Start Guide
From Jeffrey Hsieh, Director and Head of Consumer Business Line at BenQ:Consumers value brightness, picture quality, and easy installation features when it comes to their home entertainment, and we continue to deliver leading solutions that meet these needs…From streaming movies to casual gameplay, the TK705i and TK705STi are the latest in our lineup of popular projectors designed to add even more versatility for home living spaces by adapting instantly to any setup while still delivering impeccable 4K image quality at any time of day.”
benq-tk705i-projector
The Bottom Line
The BenQ TK705i and TK705STi deliver versatile, high-quality 4K home entertainment for movies, shows, and casual gaming. Their high brightness allows for use in both dark and moderately lit rooms—even outdoors—while HDMI 2.1 and low input lag support smooth console gaming. The TK705STi adds short-throw capability for tighter spaces, making it more flexible than the standard TK705i.
On the downside, these projectors are not aimed at hardcore gamers or dedicated home theater enthusiasts, and while bright, they may not match the absolute color depth or contrast of higher-end laser models. For anyone seeking a convenient, all-around lifestyle projector with solid performance and smart features, the TK705 Series is a strong, practical choice.
Price & Availability
Bonus Offer: Through October 31, consumers can complete a “Find Your Watch Party Style” quiz on BenQ.com to receive a 10% off code for the TK705i and TK705STi.
2026 Samsung The Frame Pro vs. The Frame 4K Art TVs
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle Soundboks Mix Portable Wireless Bluetooth Party Speaker Lifestyle
Soundboks Mix delivers 72-watts Class D amplification, Bluetooth, and pro-level SKAA wireless with volume that goes to 11. Is it the right party speaker...
Can the $299 ViewSonic LX60HD deliver 630 ANSI lumens, 140-inch projection, Google TV, and easy setup without compromise?
XGIMI’s TITAN Noir Max aims to bridge lifestyle design and premium projection, but pricing, final specs, and Q1 2026 availability will determine where it...
Epson brings Google Gemini AI to its Lifestudio projectors, adding smarter content discovery, voice control, and smart home features ahead of CES 2026.
Samsung unveils the Freestyle+ ahead of CES 2026, adding AI features and higher brightness to its lifestyle projector—still best suited for dark rooms.
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
At $269, XGIMI’s Vibe One makes projectors fun and portable for convenient big screen entertainment just about anywhere.
LG CineBeam S is a compact 4K ultra short throw projector with RGB laser, smart streaming and Dolby Atmos for tight spaces.
The $200 Aurzen D1R Cube brings Roku OS to a 1080p lifestyle projector, but its limited light output holds it back.
