Bang & Olufsen Expands 100th Anniversary Lineup With New Beolab 90 Phantom and Mirage Editions
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero concern for checking their credit limit.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is rolling into its 100th anniversary with the kind of confidence only a century of Danish industrial design can buy. Founded in 1925 by Peter Bang and Svend Olufsen, the company didn’t just help define the look of modern audio gear — it built a reputation for turning high-end engineering into functional art. As 2025 unfolds, B&O is marking the milestone the only way it knows how: by doubling down on statement products that remind everyone why the brand is still part of the conversation a hundred years later.
Peter Bang and Svend Olufsen Founders
Peter Bang and Svend Olufsen, B&O Founders
As part of its 100-year celebration, B&O has already rolled out its Centennial Collection and the Beolab 90 TITAN Edition — a reminder that “anniversary” in Struer apparently translates to “go big or go back to the drawing board.” But Bang & Olufsen isn’t easing off the gas. As a follow-up to the TITAN, the company has introduced two new statement pieces: the Beolab 90 Phantom and Mirage Editions, each designed to push the brand’s flagship even further into art-object territory.
The Beolab 90 Story: From Anniversary Statement to Modern Icon
The original Beolab 90 landed in 2015 to mark Bang & Olufsen’s 90th anniversary, and it wasn’t just a birthday card — it was a shockwave. I was there for its debut, and every time I’ve heard it since, the reaction has been the same: this thing is a brute in the best possible way. Between the engineering, the power, and the sheer audacity of the design, the Beolab 90 has never been a speaker you forget after hearing.
Bang & Olufsen Beolab 90 (original version)
The Beolab 90 isn’t just powered — it’s practically a small electrical substation disguised as a loudspeaker. Each unit packs 8,200 watts of built-in amplification driving 18 Scan-Speak drivers, split across 14 ICEpower amps and four additional Class D units. All of that firepower is wrapped in an angular, multi-faceted enclosure perched on a curved wooden base, giving the Beolab 90 a silhouette that looks more like modern architecture than home audio. Unique doesn’t even begin to cover it.
Beyond its absurd power output and unmistakable architecture, the Beolab 90 is loaded with both wired and wireless connectivity — WiSA included — along with a suite of technologies designed to fine-tune setup and performance. It’s the rare flagship that doesn’t just look futuristic; it behaves like it too.
Active Room Compensation: This technology compensates for room acoustics, furniture, speaker placement, and listening position. It produces a more accurate soundstage, making it easier to identify where instruments or voices are positioned.
Beam Width Control: This feature lets listeners adjust how narrow or wide the sound beam is. You can move from a focused sweet spot to broader coverage that supports casual, around-the-room listening.
Beam Direction Control: This allows users to choose one of five directions as the acoustic front, effectively shifting the primary listening position. It’s useful when seating or room layout isn’t centered.
Active Bass Linearization (ABL): This system adjusts bass output based on available power and listening volume, adding low-end weight at lower levels while incorporating protection to prevent overload or driver damage.
Now that the fundamentals of the Beolab 90 are clear, Bang & Olufsen is marking both its 100th anniversary and the speaker’s 10-year milestone with a trio of limited releases: the Beolab 90 Titan Edition and the newly added Phantom and Mirage editions, all developed through B&O’s Atelier program.
 The Phantom Edition
bang-olufsen-beolab-90-phantom
The Beolab 90 Phantom Edition takes a monochromatic approach, finished entirely in deep black tones that give it a more understated, technical look. Its design draws on motorsport-inspired elements, resulting in a sculptural form that feels precise and purpose-driven rather than decorative.
Material Mastery: A semi-transparent black PVD metal mesh exposes portions of the speaker’s internal structure, creating a shifting visual effect that changes depending on viewing angle.
Carbon Fiber Accents: The face mask, base panels, and shoulder plates are crafted from carbon fiber, emphasizing lightweight rigidity and the motorsport design cues that inform the Phantom Edition.
Architectural Details: A pearl-blasted aluminum skeleton supports the acoustic mesh panels, with the framework integrating beams and joints into a single continuous structure. Precision trim rings add a final layer of clean, mechanical detailing.
Every element of the Phantom Edition is engineered and hand-finished, with carbon fiber panels applied in layered construction. The result is a loudspeaker with a focused, technical aesthetic aimed at listeners who value material craftsmanship and disciplined design.
The Mirage Edition: For a “Mirage,” It’s Not Exactly Trying to Hide
bang-olufsen-beolab-90-mirage
In contrast to the Phantom Edition, the Beolab 90 Mirage Edition leans heavily into color.
Electrifying Palette: An iridescent fabric shifts between sapphire and magenta tones, creating a surface that changes with lighting and movement, much like the variability of sound waves.
Gradient Aluminium: Each speaker includes five precision-milled aluminum components finished with custom gradient anodization. The wave-textured surfaces reinforce the visual connection to acoustic energy.
Artisan Techniques: The Mirage Edition incorporates manual polishing and controlled gradient anodization performed in Bang & Olufsen’s dedicated lab, highlighting the brand’s emphasis on material craft.
The Beolab 90 Mirage Edition is built as a visually expressive counterpart to the Phantom, intended to stand out in a room and underscore the blend of design and engineering that defines B&O’s limited Atelier releases.
Specifications
As far as we know, the internals and specifications of Beolab 90 and Beolab 90 Titan, Phantom, and Mirage Editions are identical. If we receive information to the contrary, the following chart will be updated.
Beolab 90
Product TypeWirelss Powered Speaker
MSRPFrom $211,800 (base model)
DesignerNoto GmbH
Construction MaterialsAluminium, Fabric, Wood
Recommended Room Size30-200 m²
300-2000 ft²
Driver Configuration (per speaker)7 x 1″ Scan-Speak Illuminator tweeter
7 x 4 ½” Scan-Speak Illuminator mid-range
3 x 10″ Scan-Speak Discovery woofer
1 x 13″ Scan-Speak Revelator front woofer
Amplification (per speaker)7 x Bang & Olufsen ICEpower AM300-X for tweeter
7 x Bang & Olufsen ICEpower AM300-X for mid-range
3 x Heliox AM1000-1 for woofer
1 x Heliox AM1000-1 for front woofer
Frequency Range<12 – >43.000 Hz
Maximum Sound Pressure Level (SPL) @1m126 dB SPL
Bass Capability (per pair)118 dB SPL
Advanced Sound FeaturesAdaptive Bass Linearization
Advanced Active Room Compensation
Beam Direction Control (5 sides)
Beam Width Control
Thermal Protection
Wireless ConnectionsWireless Power Link (24bit/48kHz)
WiSA (24bit/96kHz)
Physical Connections (Primary Speaker)1 x RCA (L/R)
1 x MIC / IR
1 x Power Link (RJ45)
1 x S/P DIF (24 bit / 192 kHz)
1 x XLR (L/R) (fully balanced)
1 x Optical (24 bit / 96 kHz)
1 x USB-B (Audio) (24 bit / 192 kHz)
1 x USB-A
2 x Digital Power Link
1 x Digital Power Link / Ethernet
1 x Power
Physical Connections (Secondary Speaker)1 x USB-B (Audio)
1 x USB-A
3 x Digital Power Link
1 x Power
Dimensions (WHD) – (per speaker)73.5  x 125.3 x 74.7 cm
28.94 x 49.33 x 29.41
Weight (per speaker)137 kg / 302 lbs
Bang & Olufsen Beolab 90 Mirage and Phantom Loudspeakers with top covered
Bang & Olufsen Beolab 90 Mirage (left) and Phantom (right) Loudspeakers
The Bottom Line
Bang & Olufsen has spent a century balancing performance, industrial design, and a level of exclusivity that has never pretended to be for everyone. The Phantom and Mirage editions of the Beolab 90 stay firmly in that lane — ultra-limited, materially ambitious, and priced for a very particular customer. The strategy may raise eyebrows, but history shows that there’s always a market for statement pieces when the engineering backs it up, and the Beolab 90 remains one of the most respected high-end loudspeakers available.
At the same time, B&O isn’t blind to the broader market. Its partnership with TCL brings the brand into living rooms well outside the flagship price brackets, a practical move to stay visible to mainstream consumers who might eventually graduate to higher-end products. Yet the company is equally protective of its image, now navigating a legal dispute with fellow Danish firm Canvas HiFi and one of its U.S. dealers — a reminder that brand control matters just as much as product design.
In the end, exclusivity has its audience, and Bang & Olufsen knows exactly who it’s speaking to. The Phantom and Mirage editions won’t change the Beolab 90’s reputation — they simply reinforce it: a technically accomplished, visually distinctive loudspeaker that continues to command attention, admiration, and, for most of us, a safe distance from our bank accounts.
beolab-90-mirage-edition-top-speaker-drivers
Bang & Olufsen Beolab 90 Mirage Edition (top section)
Price & Availability
No word on pricing yet for either 100th Anniversary Edition model. However, we can expect it be over $212K. For context, the original Beolab 90 debuted in 2015 at roughly $78,000, increased to $135,000 in 2023, and now sits at $211,800 per pair in 2025. As with the TITAN Edition, the Phantom and Mirage versions are expected to carry a premium above the standard model — how much remains to be seen. Bang & Olufsen has confirmed that production will be limited to just 10 pairs of each edition.
The two speakers are being unveiled at Bang & Olufsen’s new San Francisco Culture Store — the largest Bang & Olufsen showroom in the world and one of three culture stores that Bang & Olufsen will open in California during the brand’s centenary year. Subsequently, the Beolab 90 Anniversary Editions will tour the world, offering discerning clients an intimate encounter with these unique, luxurious speakers.
Where to order: bang-olufsen.com
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers Bang & Olufsen Beolab 90 Zenith and Monarch Loudspeakers
Bang & Olufsen's Beolab 90 Zenith and Monarch Editions look like they escaped a Cylon basestar, with extreme design and six figure pricing to...
Magico previews the S7 flagship loudspeaker ahead of AXPONA 2026. Can its latest S-Series design compete with Wilson, Estelon, and Børresen?
Loudspeakers
Fyne Audio is now offering bold custom colors to UK buyers. Have Scottish speakers decided beige is no longer brave enough?
Is ATC’s EL50 Anniversary the most compelling fully active 3-way tower under £50K for serious listeners seeking studio grade precision at home?
Børresen M8 Gold Signature is a $1,150,000 loudspeaker built in Denmark. Engineering breakthrough or high-end excess for the ultra wealthy?
Is the Aavik M-880 pure excess, or a serious rethink of Class A amplification delivering 400 watts at $115,000 per channel?
Luxman's CENTENNIAL series D-100 SACD/CD player and L-100 Class A Integrated Amplifier aim to end your desire to upgrade.
