AZLA Expands 2025 Lineup With TRINITY Earphones and Ear Tips for Galaxy Buds 3 FE and AirPods Pro
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds 3 FE and AirPods Pro.
AZLA TRINITY Earphones USB-C Version
Korean audio specialist AZLA isn’t slowing down in 2025. The company behind some of the most obsessively engineered ear tips on the planet is rolling out three new additions: TRINITY, a compact wired earphone series in both USB-C and 3.5mm flavors; new MAX ear tips tailored specifically for Samsung’s Galaxy Buds 3 FE; and the second-generation XELASTEC 2 tips designed to give Apple’s AirPods Pro a more secure, better-sealing fit.
It’s a small lineup update, but a meaningful one for listeners who know comfort and fit can make or break the entire experience.
AZLA TRINITY Wired Earphones: USB-C and 3.5mm Options for 2025
AZLA’s new TRINITY are budget-friendly wired earphones that punch into mid-tier territory with tuning you’d normally expect to cost a lot more. Featuring an 8mm dynamic driver voiced for a neutral-bright balance, they deliver quick transients and a surprising level of clarity for the asking price.
azla-trinity-earphone-parts
The TRINITY arrives in two flavors: a standard 3.5mm analog version and a USB-C model with a built-in DAC, giving you consistent sound quality across phones, tablets, and laptops—no dongle roulette required in an era when most devices have ditched headphone jacks entirely.
It’s already making noise overseas: TRINITY sits at No. 1 in Japan’s wired earphone rankings and carries an endorsement from DK, one of South Korea’s most trusted audio reviewers. The pitch is simple—deliver a legitimately good listening experience at a price low enough to feel slightly illegal.
AZLA Trinity Earphones Specifications
azla-trinity-earphones
AZLA ModelTrinity 3.5mmTrinity USB-C
Product TypeWired EarphonesWired Earphones
Price$19.90$19.90
Driver8mm Dynamic Driver with Advanced ARD (PU+PEEK composite diaphragm)8mm Dynamic Driver with Advanced ARD (PU+PEEK composite diaphragm)
Frequency Response10 Hz – 40,000 Hz (Hi-Res Certified)10 Hz – 40,000 Hz (Hi-Res Certified)
Sensitivity (@1KHz)104 dB SPL/mW 104 dB SPL/mW
Impedance (@1KHz)16 ohm16 ohm
DesignSealed, 105° angled housing for comfortSealed, 105° angled housing for comfort
Cable4-conductor OFC (Oxygen-Free Copper)4-conductor OFC (Oxygen-Free Copper)
Plug3.5mm 3-pole L-shapedUSB Type-C
Cable LengthApprox. 120cm150cm
MicHigh-sensitivity in-line remote mic
Digital AudioUAC 1.0 spec supports up to 96kHz/24bit
DAC Built-inYes
CompatibilityWorks with smartphones, Switch, PS5Works with smartphones, Switch, PS5
Portable Pouch YesYes
AZLA premium ear tips (4 size options) –  M-size Pre-installedYes Yes
ColorsBlack, Blue, Champagne GoldBlack, Blue, Champagne Gold
Where to buy:
TRINITY is available now on Amazon.com for $19.90, offered in two versions: 3.5mm analog and USB-C with a built-in DAC.
MAX for Galaxy Buds 3 FE
max-galaxy-buds-3-fe-tips
AZLA’s MAX series ear tips have earned a strong following for their comfort and stability with TWS earbuds, and the newest entry—MAX for Galaxy Buds 3 FE—comes with Samsung’s SMAPP certification, a stamp of approval rarely given to performance-focused aftermarket tips.
Instead of the glued-on adapters used by many TWS-compatible designs, MAX uses a single-mold, medical-grade hypoallergenic silicone structure that removes weak points and keeps the acoustic path consistent.
Key Features
  • SMAPP-certified — officially approved by Samsung
  • Single-piece mold for better durability, hygiene, and seal consistency
  • Medical-grade silicone that minimizes irritation and supports long listening sessions
  • Engineered specifically for the Galaxy Buds 3 FE nozzle design
MAX for Galaxy Buds 3 FE delivers official compatibility with an enthusiast-grade fit that can tighten bass response and improve overall tonality.
Where to buy
XELASTEC 2
xelastec-ii-airpods-tips
When AZLA dropped the original XELASTEC, it instantly became a cult favorite—especially among AirPods Pro owners—thanks to its heat-reactive TPE material that softens with body temperature and molds itself to your ear canal.
XELASTEC 2 keeps that same “warms up, locks in” behavior but pushes the engineering further: the tip and adapter are now a single-mold piece instead of a glued two-part design, eliminating the occasional separation issues some users saw with the original. The result is a tougher, lower-pressure, more stable evolution of XELASTEC that aims to improve both comfort and longevity.
Key Features
  • Thermoplastic elastomer (TPE) softens with body heat to create a custom-style seal
  • Single-mold construction eliminates glued adapters and boosts long-term durability
  • Lower ear pressure with a more natural, less fatiguing fit
  • Improved stability for workouts, commuting, and extended listening
  • Tailored for AirPods Pro users who want a firmer seal than Apple’s stock silicone tips
Where to buy:
The Bottom Line
AZLA’s latest lineup isn’t trying to reinvent the wheel—it’s trying to make everyday listening a little easier, cheaper, and more comfortable. TRINITY sits squarely in that lane: two wired versions, both under twenty bucks, both delivering far better tuning than the price suggests. If you lose earphones like it’s a part-time job, these are exactly the kind of replacements that won’t make you wince.
And for Galaxy Buds 3 FE or AirPods Pro owners, AZLA’s MAX and XELASTEC 2 tips aren’t just swap-ins; they’re meaningful upgrades. Better seal, better comfort, better stability—the stuff that actually changes how your earbuds sound and feel. Anyone chasing a more secure fit, improved bass, or longer listening comfort should have these on the shortlist.
Sony True RGB TV compared to BRAVIA 9 Mini LED TV.
2026 Samsung Music Studio 7 Wireless Speakers Lifestyle 2026 Samsung Music Studio 7 Wireless Speakers Lifestyle
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
2026 Samsung HW-S990H Soundbar Lifestyle 2026 Samsung HW-S990H Soundbar Lifestyle
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Does the Meze Astru’s titanium driver tuning, sub bass extension, and controlled treble justify $899 against top IEM rivals?
ACTIVO Scoop feature a single 8mm dynamic driver, dual 6mm dynamic drivers, and dual balanced armatures, bringing Astell&Kern tech to an accessible price.
Can one driver beat complex hybrids? Meze Audio unveils the $899 ASTRU flagship IEM at CanJam NYC 2026 with a single dynamic driver design.
Are wired IEMs making a comeback? CanJam NYC 2026 suggests growing demand as audiophiles chase better sound beyond wireless earbuds.
Can the Campfire Audio Andromeda 10 justify its $1,799 price in today’s crowded flagship IEM market, and does it truly improve on the legendary...
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Is the DUNU DN142 the smartest buy under $300? This tribrid IEM delivers lively treble, controlled sub bass, strong build quality, and one of...
