Audio-Technica Unveils ATH-ADX7000: Japan-Built Flagship Open-Back Headphones with HXDT Drivers: Paris Audio Visual Show 2025
Audio-Technica ATH-ADX7000 handcrafted Japanese open-back headphones with HXDT drivers, 275g lightweight design, and flagship sound. Sennheiser who?
Audio-Technica ATH-ADX7000 Headphones
Audio-Technica has raised the bar for open-back headphones with the introduction of the ATH-ADX7000 True Open-Air model, the new flagship of its acclaimed ADX line. Designed and handcrafted in Japan, the ATH-ADX7000 leverages over 60 years of transducer expertise and features Audio-Technica’s proprietary High-Concentricity X (Transfer) Dynamic Transducer (HXDT) technology, delivering precise, natural sound reproduction from design to final integration.
Following in the footsteps of the ATH-ADX5000 ($2,199) and ATH-ADX3000 ($1,099), which our UK Headphone Columnist James Fiorucci tested at CanJam London 2025, the ADX7000 takes open-back performance further. Its True Open-Air Audio design precisely controls airflow and relies solely on diaphragm movement, allowing unrestricted air movement through the housing. This reduces internal pressure and resonance, producing a clear, natural, and fatigue-free listening experience — even during extended sessions.
Audio-Technica has long earned praise for its extensive range of phono cartridges and affordable turntables, but in 2025 and beyond, the spotlight is shifting to its expanding lineup of high-end headphones. The Japanese manufacturer has already shown it can produce one of the most expensive headphone amplifiers ever offered, signaling a serious push into the premium headphone market.
ath-adx7000-front
adx7000-earpads
ATH-ADX7000 Open-Air Headphones: HXDT Drivers and Precision Engineering
At the core of the ATH-ADX7000 is Audio-Technica’s High-Concentricity X (Transfer) Dynamic Transducer (HXDT) technology. This process uses a controlled molding and alignment method to ensure that each diaphragm, baffle plate, magnet, and voice coil is perfectly concentric, with tolerances tightened to ±0.02 mm — nearly ten times more precise than conventional designs. The result is a diaphragm that moves consistently and freely, producing accurate transients, improved microdetail, and a cleaner, more natural sound.
The driver also features an updated voice coil with a 490-ohm impedance, which increases mechanical force without adding weight. This allows for more defined low frequencies, a wider dynamic range, and consistent clarity across the spectrum. The precise alignment of all components is central to the ADX7000’s performance, supporting the True Open-Air design to achieve balanced and open sound reproduction.
Key Features:
  • High-Concentricity X (Transfer) Dynamic Transducer (HXDT): Manufacturing process for precise, consistent diaphragm movement.
  • True Open-Air Audio: Controls airflow and relies solely on diaphragm movement for sound reproduction.
  • Core Mount Technology: Balances acoustic impedance of front and back cavities for symmetrical diaphragm motion at all frequencies.
  • Featherlight Design: Honeycomb aluminium housings reduce weight to 275g.
  • Magnesium Die-Cast Frame: Provides structural strength and absorbs vibration to limit coloration.
  • Two Earpad Options: High-density velvet pads for acoustic filtering or Alcantara pads for durability and comfort.
  • Made in Japan: Every component is designed and assembled in Japan for consistent build quality.
  • Accessories: Includes balanced XLR and unbalanced 6.3 mm cables with Neutrik connectors, gold-tipped A2DC connectors, and a compact carrying case.
adx5000-adx7000-adx3000
This combination of HXDT technology, open-air design, and precise engineering positions the ATH-ADX7000 as a carefully considered high-end headphone for detailed, natural listening.
While Audio-Technica has not released full specifications for the ATH-ADX7000, we can draw some reasonable expectations based on the previous ATH-ADX5000. The ADX5000 features a relatively high impedance of 420 ohms, a sensitivity rating of 100 dB/mW, and a frequency response spanning 5 to 50,000 Hz. It’s likely the ADX7000 will sit in a similar range, potentially requiring 700 to 1,000 mW to be driven to its full potential.
Despite these higher power requirements, the ADX7000 remains remarkably lightweight at 275 grams, only 5 grams heavier than the ADX5000, which is notable given the premium materials and construction. This balance of manageable weight and high-end engineering helps ensure extended listening sessions remain comfortable while maintaining the performance expected from a flagship open-air design.
ath-adx7000-case-open
The Bottom Line
The Audio-Technica ATH-ADX7000 will be available worldwide starting October 23, 2025, with a retail price of $4,000. The optional AT-HPC3 storage case, compatible with other high-end headphones, is priced at $100. This positions the ADX7000 above the Sennheiser HD800s in price, below the Meze Audio Empyrean II, and in the same range as premium planar magnetic models from Audeze and HiFiMAN. With its lightweight 275g build, open-air design, and HXDT drivers, the ATH-ADX7000 combines precise Japanese engineering with competitive flagship performance.
Grell OAE2 Open-Back Headphones Flat
Axel Grell’s OAE2 open-back headphones debut at CanJam NYC 2026 with a speaker-like soundstage concept. Can the $599 design change how we listen to...
Grado Labs Signature S550 Open-back Headphones Lifestyle Woman Grado Labs Signature S550 Open-back Headphones Lifestyle Woman
At $995, Grado's most affordable Signature Series open-back headphones feature new S2 drivers and cushion design with a Brazilian Walnut housing. Is this the...
Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black Samsung Galaxy Buds4 Pro wireless earbuds in pink, white and black
Samsung Galaxy Buds4 Pro at $249.99 and Buds4 at $179.99 add AI live translation, enhanced ANC, and Galaxy optimized tech but are they worth...
iFi GO Link 2 Dongle DAC connected to laptops iFi GO Link 2 Dongle DAC connected to laptops
Dongle DACs
The $59 iFi GO link 2 USB-C Dongle DAC makes the case that smaller is better for hi-res audio listening, but what do you...
Q Acoustics Easyfit In-ceiling Speakers Lifestyle Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Grado Labs expands its Signature Line with the new S750 headphones, featuring a redesigned S2 driver, improved comfort, and premium build quality aimed at...
Over-Ear Headphones
Can FiiO’s $699 FT7 open-back planar headphones deliver true high-end sound, or do build issues hold them back?
Austrian Audio’s Arranger open-back headphones combine a new 44mm DLC driver, low 25Ω impedance, and foldable metal design. A serious mid-tier reference option?
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Check out our favorite wired over-ear open-back and closed-back headphones for audiophiles and studio professionals at various price points.
Over-Ear Headphones
Audio-Technica's ATH-ADX7000 deliver stunning dynamics, vast staging and refined tuning at $3,499 with some drawbacks.
